VHF36-16IO5
VHF36-16IO5
    IXYSCORPORATION
    FO-F-A
    RECT BRIDGE 1PH 1600V FO-F-A
VHF36-16IO5 数据手册
VHF 36 Half Controlled Single Phase Rectifier Bridge with Freewheeling Diode IdAVM = 40 A VRRM = 800-1600 V VRSM VDSM V 900 1300 1500 1700 VRRM VDRM V 800 1200 1400 1600 Type 6 4 2 1 3 1 2 3 6 4 VHF 36-08io5 VHF 36-12io5 VHF 36-14io5 VHF 36-16io5 8 8 Symbol IdAV IdAVM x IFRMS, ITRMS IFSM, ITSM Test Conditions TK = 85°C, module module per leg TVJ = 45°C; VR = 0 V TVJ = TVJM VR = 0 V t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine repetitive, IT = 50 A Maximum Ratings 36 40 28 320 350 280 310 500 520 390 400 150 A A A A A A A A2s A2s A2s A2s A/ms A/ms V/ms Features Package with DCB ceramic base plate Isolation voltage 3600 V~ Planar passivated chips ¼" fast-on terminals UL registered E 72873 q q q q q I2t TVJ = 45°C VR = 0 V TVJ = TVJM VR = 0 V Applications Supply for DC power equipment DC motor control q q q q q (di/dt)cr TVJ = 125°C f =50 Hz, tP =200 ms VD = 2/3 VDRM IG = 0.3 A, diG/dt = 0.3 A/ms non repetitive, IT = 1/2 • IdAV 500 1000 10 Advantages Easy to mount with two screws Space and weight savings Improved temperature and power cycling (dv/dt)cr VRGM PGM PGAVM TVJ TVJM Tstg VISOL Md Weight TVJ = TVJM; VDR = 2/3 VDRM RGK = ¥; method 1 (linear voltage rise) TVJ = TVJM IT = ITAVM tp = 30 ms tp = 500 ms tp = 10 ms £ £ £ Dimensions in mm (1 mm = 0.0394") V W W W W °C °C °C V~ V~ Nm lb.in. g 10 5 1 0.5 -40...+125 125 -40...+125 50/60 Hz, RMS IISOL £ 1 mA Mounting torque t = 1 min t=1s (M5) (10-32 UNF) 3000 3600 2-2.5 18-22 50 Data according to IEC 60747 and refer to a single thyristor/diode unless otherwise stated. x for resistive load IXYS reserves the right to change limits, test conditions and dimensions. © 2000 IXYS All rights reserved 1-3 VHF 36 Symbol IR, ID VT, VF VT0 rT VGT IGT Test Conditions VR = VRRM; VD = VDRM IT, IF = 45 A; TVJ = 25°C For power-loss calculations only (TVJ = 125°C) VD = 6 V; VD = 6 V; TVJ = 25°C TVJ = -40°C TVJ = 25°C TVJ = -40°C TVJ = 125°C VD = 2/3 VDRM VD = 2/3 VDRM TVJ = 25°C TVJ = -40°C TVJ = 125°C £ £ £ £ £ £ £ £ £ £ £ £ typ. TVJ = TVJM TVJ = 25°C Characteristic Values £ £ £ 5 0.3 1.45 0.85 13 1.0 1.2 65 80 50 0.2 5 150 200 100 100 2 150 75 1.15 0.29 1.55 0.39 12.6 6.3 50 mA mA V V mW V V mA mA mA V mA mA mA mA mA ms ms mC K/W K/W K/W K/W mm mm m/s2 1000 µs tgd 100 typ. Limit TVJ = 25°C 0.1 1 1 10 1: IGT, TVJ = 125°C V VG 2: IGT, TVJ = 25°C 3: IGT, TVJ = -40°C 2 3 6 4 5 VGD IGD IL TVJ = TVJM; TVJ = TVJM; IG = 0.3 A; tG = 30 ms; diG/dt = 0.3 A/ms; IGD, TVJ = 125°C 4: PGAV = 0.5 W 5: PGM = 1 W 6: PGM = 10 W 1 10 100 1000 IG mA IH tgd tq Qr RthJC RthJK dS dA a TVJ = 25°C; VD = 6 V; RGK = ¥ TVJ = 25°C; VD = 1/2 VDRM IG = 0.3 A; diG/dt = 0.3 A/ms TVJ = 125°C, IT = 15 A, tP = 300 ms, VR = 100 V di/dt = -10 A/ms, dv/dt = 20 V/ms, VD = 2/3 VDRM per thyristor (diode); DC current per module per thyristor (diode); DC current per module Creeping distance on surface Creepage distance in air Max. allowable acceleration Fig. 1 Gate trigger range 10 1 10 100 IG mA 1000 Fig. 2 Gate controlled delay time tgd © 2000 IXYS All rights reserved 2-3 750 VHF 36 70 A 60 IF 50 40 30 100 20 300 A 103 As I2t 2 50Hz, 80% VRRM VR = 0 V typ. 250 IFSM 200 TVJ = 45°C TVJ = 45°C TVJ = 125°C TVJ = 125°C TVJ = 25°C max. 150 102 TVJ = 125°C 10 0 0.0 50 0.5 1.0 VF 1.5 V 2.0 0 0.001 101 0.01 0.1 t s 1 1 2 3 4 5 6 7 8 910 ms t Fig. 3 Forward current versus voltage drop per diode 120 W 100 Ptot 80 Fig. 4 Surge overload current Fig. 5 I2t versus time per diode 50 A RthHA : 0.5 1.0 1.5 2.0 3.0 4.0 6.0 K/W K/W K/W K/W K/W K/W K/W 40 Id(AV)M 30 60 20 40 10 20 0 0 10 20 30 40 IF(AV)M A 0 20 40 60 80 100 120 °140 C Tamb 0 0 20 40 60 80 100 120 °C TH Fig. 6 Power dissipation versus direct output current and ambient temperature 2.0 K/W 1.5 ZthJH Fig. 7 Max. forward current versus heatsink temperature 1.0 Constants for ZthJH calculation: i Rthi (K/W) 0.005 0.2 0.875 0.47 ti (s) 0.008 0.05 0.06 0.25 0.5 1 2 3 4 0.01 0.1 1 t s 10 0.0 0.001 Fig. 8 Transient thermal impedance junction to heatsink © 2000 IXYS All rights reserved 3-3
VHF36-16IO5 价格&库存
很抱歉,暂时无法提供与“VHF36-16IO5”相匹配的价格&库存,您可以联系我们找货
