GaAlAs T-1 3/ 4 S tandard 5 Infrared Emitting Diode
LTE-3271T/LTE-3371T/LTE-3271TL/LTE-3371TL
Features
Special for high current and low forward voltage. High power. Available for pulse operating. Wide viewing angle. LTE-3271TL/LTE-3371TL are blue transparent color package.
Package Dimensions
Description
The LTE-3271T/LTE-3371T/LTE-3217TL/LTE-3371TL are high intensity Gallium Aluminum Arsenide infrared emitting diodes mounted in plastic end looking packages. They provide a broad range of intensity selection and are specified under pulsed drive up to 2 Amps.
Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is 0.25mm (.010") unless otherwise noted. 3. Protruded resin under flange is 1.5mm (.059") max. 4. Lead spacing is measured where the leads emerge from the package. 5. Specifications are subject to change without notice.
Absolute Maximum Ratings at Ta=25
Parameter
Power Dissipation Peak Forward Current(300pps, 10 Continuous Forward Current Reverse Voltage Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm (.063 in.) from body] s pulse)
Maximum Rating
150 2 100 5 -40 -55 260 to +85 to +100 for 5 Seconds
Unit
mW A mA V
1 0-14
E3271t.p65
Page 14
2000/7/11, ¤W¤È 11:54 Adobe PageMaker 6.5C/Win
Electrical Optical Characteristics at Ta=25
Parameter Symbol Part No.
LTE-3271T *Aperture Radiant Incidence Ee LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Radiant Intensity Ie LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Peak Emission Wavelength Spectral Line Half-Width LTE-3271T Forward Voltage VF LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Forward Voltage VF LTE-3271TL LTE-3371T LTE-3371TL Reverse Current IR LTE-3271T View Angle (See Fig. 6) 2
1
Min.
0.80 0.90 6 6.77
Typ.
1.4
Max.
Unit
Test Condition
IF=20mA
mW/cm 2 1.6 10.5 mW/sr 12
IF=20mA
Peak
940
nm
IF=20mA
50
nm
IF=20mA
1.25
1.6
V
IF=50mA
INFRARED PRODUCTS
1.65
2.1
V
IF=250mA
100 50 LTE-3271TL LTE-3371T LTE-3371TL 40
A
VR=5V
/2
deg
Note: *Ee is a measurement of the average radiant incidence upon a sensing area 1cm 2 i n perpendicular to and centered on the mechanical axis of the lens and 26.8mm from lens.
1 0-15
E3271t.p65
Page 15
2000/7/11, ¤W¤È 11:55 Adobe PageMaker 6.5C/Win
Typical Electrical/Optical Characteristic Curves (25 Ambient Temperature Unless Otherwise Noted)
1 0-16
很抱歉,暂时无法提供与“LTE-3371T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.954371+0.51406
- 10+2.6894010+0.34962
- 100+1.91638100+0.24913
- 500+1.56859500+0.20392
- 1000+1.453971000+0.18901
- 2000+1.356392000+0.17633
- 5000+1.249505000+0.16243
- 10000+1.1827610000+0.15376
- 25000+1.1098925000+0.14429
- 国内价格
- 1+2.80285
- 10+1.94642
- 100+1.31638
- 500+1.11515
- 1000+1.05766
- 5000+0.97740
- 国内价格
- 1+0.59066
- 200+0.23577
- 500+0.22788
- 1000+0.22400
