LTE-3371TL
LTE-3371TL
    LITE-ON(光宝)
    插件
    EMITTER IR 940NM 100MA RADIAL
LTE-3371TL 数据手册
GaAlAs T-1 3/ 4 S tandard 5 Infrared Emitting Diode LTE-3271T/LTE-3371T/LTE-3271TL/LTE-3371TL Features Special for high current and low forward voltage. High power. Available for pulse operating. Wide viewing angle. LTE-3271TL/LTE-3371TL are blue transparent color package. Package Dimensions Description The LTE-3271T/LTE-3371T/LTE-3217TL/LTE-3371TL are high intensity Gallium Aluminum Arsenide infrared emitting diodes mounted in plastic end looking packages. They provide a broad range of intensity selection and are specified under pulsed drive up to 2 Amps. Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is 0.25mm (.010") unless otherwise noted. 3. Protruded resin under flange is 1.5mm (.059") max. 4. Lead spacing is measured where the leads emerge from the package. 5. Specifications are subject to change without notice. Absolute Maximum Ratings at Ta=25 Parameter Power Dissipation Peak Forward Current(300pps, 10 Continuous Forward Current Reverse Voltage Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm (.063 in.) from body] s pulse) Maximum Rating 150 2 100 5 -40 -55 260 to +85 to +100 for 5 Seconds Unit mW A mA V 1 0-14 E3271t.p65 Page 14 2000/7/11, ¤W¤È 11:54 Adobe PageMaker 6.5C/Win Electrical Optical Characteristics at Ta=25 Parameter Symbol Part No. LTE-3271T *Aperture Radiant Incidence Ee LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Radiant Intensity Ie LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Peak Emission Wavelength Spectral Line Half-Width LTE-3271T Forward Voltage VF LTE-3271TL LTE-3371T LTE-3371TL LTE-3271T Forward Voltage VF LTE-3271TL LTE-3371T LTE-3371TL Reverse Current IR LTE-3271T View Angle (See Fig. 6) 2 1 Min. 0.80 0.90 6 6.77 Typ. 1.4 Max. Unit Test Condition IF=20mA mW/cm 2 1.6 10.5 mW/sr 12 IF=20mA Peak LTE-3271TL LTE-3371T LTE-3371TL 940 nm IF=20mA 50 nm IF=20mA 1.25 1.6 V IF=50mA INFRARED PRODUCTS 1.65 2.1 V IF=250mA 100 50 LTE-3271TL LTE-3371T LTE-3371TL 40 A VR=5V /2 deg Note: *Ee is a measurement of the average radiant incidence upon a sensing area 1cm 2 i n perpendicular to and centered on the mechanical axis of the lens and 26.8mm from lens. 1 0-15 E3271t.p65 Page 15 2000/7/11, ¤W¤È 11:55 Adobe PageMaker 6.5C/Win Typical Electrical/Optical Characteristic Curves (25 Ambient Temperature Unless Otherwise Noted) 1 0-16
LTE-3371TL 价格&库存
很抱歉,暂时无法提供与“LTE-3371TL”相匹配的价格&库存,您可以联系我们找货
