LTL-307YLC
LTL-307YLC
    LITE-ON(光宝)
    插件,D=5mm
    发光二极管/LED 黄色 插件,D=5mm 588nm 3.7mcd
LTL-307YLC 数据手册
L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Features * High efficiency. * Low power consumption. * CMOS/MOS compatible. * TTL compatible. Package Dimensions Part No. LTL-307YLC Lens Yellow Diffused Source Color Yellow Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25mm(.010") unless otherwise noted. 3. Protruded resin under flange is 1.0mm(.04") max. 4. Lead spacing is measured where the leads emerge from the package. 5. Specifications are subject to change without notice. Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 1 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Absolute Maximum Ratings at TA=25℃ Parameter Power Dissipation Tamb ≦ 90℃ Forward Current Forward Surge Current ( 10μsec pulse) Reverse Voltage Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm(.063") From Body] Maximum Rating 20 7 500 5 -55℃ to + 100℃ -55℃ to + 100℃ 260℃ for 5 Seconds Unit mW mA mA V Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 2 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Electrical / Optical Characteristics at TA=25℃ Parameter Luminous Intensity Viewing Angle Peak Emission Wavelength Dominant Wavelength Spectral Line Half-Width Forward Voltage Reverse Current Symbol IV 2θ1/2 λP λd Δλ VF IR Min. 1.1 Typ. 3.7 50 585 588 35 1.8 2.2 10 Max. Unit mcd deg nm nm nm V μA IF = 2mA VR = 5V Test Condition IF = 2mA Note 1,4 Note 2 (Fig.6) Measurement @Peak (Fig.1) Note 3 Note: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE (Commission International De L'Eclairage) eye-response curve. 2. θ1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 3. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device. 4. The Iv guarantee should be added ±15% . Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 3 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Typical Electrical / Optical Characteristics Curves (25℃ Ambient Temperature Unless Otherwise Noted) Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 4 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only CAUTIONS 1. Application The LEDs described here are intended to be used for ordinary electronic equipment (such as office equipment, communication equipment and household applications).Consult Liteon’s Sales in advance for information on applications in which exceptional reliability is required, particularly when the failure or malfunction of the LEDs may directly jeopardize life or health (such as in aviation, transportation, traffic control equipment, medical and life support systems and safety devices). 2. Storage The storage ambient for the LEDs should not exceed 30°C temperature or 70% relative humidity. It is recommended that LEDs out of their original packaging are used within three months. For extended storage out of their original packaging, it is recommended that the LEDs be stored in a sealed container with appropriate desiccant or in desiccators with nitrogen ambient. 3. Cleaning Use alcohol-based cleaning solvents such as isopropyl alcohol to clean the LEDs if necessary. 4. Lead Forming & Assembly During lead forming, the leads should be bent at a point at least 3mm from the base of LED lens. Do not use the base of the lead frame as a fulcrum during forming. Lead forming must be done before soldering, at normal temperature. During assembly on PCB, use minimum clinch force possible to avoid excessive mechanical stress. 5. Soldering When soldering, leave a minimum of 2mm clearance from the base of the lens to the soldering point. Dipping the lens into the solder must be avoided. Do not apply any external stress to the lead frame during soldering while the LED is at high temperature. Recommended soldering conditions : Soldering iron Temperature Soldering time 300°C Max. 3 sec. Max. (one time only) Pre-heat Pre-heat time Solder wave Soldering time Wave soldering 100°C Max. 60 sec. Max. 260°C Max. 10 sec. Max. Note: Excessive soldering temperature and/or time might result in deformation of the LED lens or catastrophic failure of the LED Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 5 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only 6. Drive Method An LED is a current-operated device. In order to ensure intensity uniformity on multiple LEDs connected in parallel in an application, it is recommended that a current limiting resistor be incorporated in the drive circuit, in series with each LED as shown in Circuit A below. Circuit model A LED Circuit model B LED (A) Recommended circuit (B) The brightness of each LED might appear different due to the differences in the I-V characteristics of those LEDs 7. ESD (Electrostatic Discharge) Static Electricity or power surge will damage the LED. Suggestions to prevent ESD damage: Use a conductive wrist band or anti- electrostatic glove when handling these LEDs All devices, equipment, and machinery must be properly grounded Work tables, storage racks, etc. should be properly grounded Use ion blower to neutralize the static charge which might have built up on surface of the LEDs plastic lens as a result of friction between LEDs during storage and handing ESD-damaged Leeds will exhibit abnormal characteristics such as high reverse leakage current, low forward voltage, or “no light up” at low currents. To verify for ESD damage, check for “light up” and Vf of the suspect LEDs at low currents. The Vf of “good” LEDs should be >2.0V@0.1mA for InGaN product and >1.4V@0.1mA for AlInGaP product. Chip ESD level InGaN / Sapphire AlInGaP InGaN / SiC Machine Mode 100 V 200 V 600 V Human Body Model 300 V 500 V 1000 V Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 6 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Suggested checking list : Training and Certification 1. Everyone working in a static-safe area is ESD-certified? 2. Training records kept and re-certification dates monitored? Static-Safe Workstation & Work Areas 1. Static-safe workstation or work-areas have ESD signs? 2. All surfaces and objects at all static-safe workstation and within 1 ft measure less than 100V? 3. All ionizer activated, positioned towards the units? 4. Each work surface mats grounding is good? Personnel Grounding 1. Every person (including visitors) handling ESD sensitive (ESDS) items wear wrist strap, heel strap or conductive shoes with conductive flooring? 2. If conductive footwear used, conductive flooring also present where operator stand or walk? 3. Garments, hairs or anything closer than 1 ft to ESD items measure less than 100V*? 4. Every wrist strap or heel strap/conductive shoes checked daily and result recorded for all DSL? 5. All wrist strap or heel strap checkers calibration up to date? Note: *50V for Blue LED. Device Handling 1. Every ESDS items identified by EIA-471 labels on item or packaging? 2. All ESDS items completely inside properly closed static-shielding containers when not at static-safe workstation? 3. No static charge generators (e.g. plastics) inside shielding containers with ESDS items? 4. All flexible conductive and dissipative package materials inspected before reuse or recycle? Others 1. Audit result reported to entity ESD control coordinator? 2. Corrective action from previous audits completed? 3. Are audit records complete and on file? Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 7 of 8 L ITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only 8. Reliability Test Classification Test Item Test Condition Ta= Under Room Temperature As Per Data Sheet Maximum Rating *Test Time= 1000HRS (-24HRS,+72HRS) Ta= 65±5℃ RH= 90 〜 95% Test Time= 240HRS±2HRS Ta= 65±5℃ RH= 90 〜 95% VR=5V Test Time = 500HRS (-24HRS, +48HRS) Ta= 105±5℃ *Test Time= 1000HRS (-24HRS,+72HRS) Reference Standard MIL-STD-750D:1026 (1995) MIL-STD-883D:1005 (1991) JIS C 7021:B-1 (1982) MIL-STD-202F: 103B(1980) JIS C 7021 : B-11(1982) Operation Life High Temperature High Humidity Storage Endurance Test High Temperature High Humidity Reverse BIAS High Temperature Storage JIS C 7021 : B-11(1982) MIL-STD-883D:1008 (1991) JIS C 7021:B-10 (1982) Low Temperature Storage Ta= -55±5℃ *Test Time=1000HRS (-24HRS,+72HRS) 105℃ 〜 25℃ 〜 -55℃ 〜 25℃ 30mins 5mins 30mins 5mins 10 Cycles 105 ± 5℃ 〜 -55℃ ± 5℃ 10mins 10mins 10 Cycles T.sol = 260 ± 5℃ Dwell Time= 10 ± 1secs JIS C 7021:B-12 (1982) MIL-STD-202F:107D (1980) MIL-STD-750D:1051(1995) MIL-STD-883D:1010 (1991) JIS C 7021: A-4(1982) MIL-STD-202F:107D(1980) MIL-STD-750D:1051(1995) MIL-STD-883D:1011 (1991) MIL-STD-202F:210A(1980) MIL-STD-750D:2031(1995) JIS C 7021: A-1(1982) MIL-STD-202F:208D(1980) MIL-STD-750D:2026(1995) MIL-STD-883D:2003(1991) JIS C 7021: A-2(1982) Temperature Cycling Environmental Test Thermal Shock Solder Resistance Solderability T. sol = 230 ± 5℃ Dwell Time= 5 ± 1secs 9. Others The appearance and specifications of the product may be modified for improvement, without prior notice. Part No. : LTL-307YLC BNS-OD-C131/A4 Page : 8 of 8
LTL-307YLC 价格&库存
很抱歉,暂时无法提供与“LTL-307YLC”相匹配的价格&库存,您可以联系我们找货
LTL-307YLC
    库存:1789
    LTL-307YLC
      LTL-307YLC
