LTL1CHJETNN
LTL1CHJETNN
    LITE-ON(光宝)
    插件,D=3.1mm
    发光二极管/LED 插件,D=3.1mm
LTL1CHJETNN 数据手册
                        General Purpose LTL1CHJxTNN LTL2F7JxTNN 45 degree 45 degree Features ! ! ! ! ! ! T-1(3mm) and T-1 3/4(5mm) General Purpose LED Lamps. Low Power Consumption. High Luminous Intensity Output. Tinted Lens Options. Variety Of Colors. High Efficiency. Description This family 3mm and 5mm LED lamps are standard designed for applications requiring higher intensity level. The source color devices are made with Aluminum Indium Gallium Phosphide(AlInGaP) on Gallium Arsenide light emitting diode. Application ! General Purpose. ! Indicator Lights. Devices Part No. (LTL) 1CHJDTNN / 2F7JDTNN 1CHJRTNN / 2F7JRTNN 1CHJETNN / 2F7JETNN 1CHJFTNN / 2F7JFTNN 1CHJYTNN / 2F7JYTNN 1CHJSTNN / 2F7JSTNN 1CHJGTNN / 2F7JGTNN Lens Red Transparent Red Transparent Red Transparent Amber Transparent Yellow Transparent Yellow Transparent Green Transparent Source Color AlInGap Hyper Red AlInGap Super Red AlInGap Red AlInGap Yellow Orange AlInGap Amber Yellow AlInGap Yellow AlInGap Green        ! "#                                      $ "%%&'()$')$')('%%'($*')+,$-  %)+'$./((*. .0-1)%$$,2'$)& !1&&$')1)&%)'$ .((*.#0-( # &$3+')'$($1&2,,%&$((,3+4 /3+''+')$$156++,)2',1)'+        ! "#                           Absolute Maximum Ratings at TA=25°C Hyper Red Super Red Yellow Orange Amber Yellow Parameter Red Yellow Green Unit Power Dissipation Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) Continuous Forward Current Derating Linear From 70°C Reverse Voltage(IR =100 A) Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm(.063") From Body] 75 75 75 75 75 75 75 mW 90 90 90 60 60 60 60 mA 30 0.4 5 30 0.4 5 30 0.4 5 30 0.4 5 30 0.4 5 30 0.4 5 30 0.4 5 mA mA / °C V -40°C to + 100°C -55°C to + 100°C 260 for 5 Seconds          ! "#  !                         Electrical / Optical Characteristics at TA=25 (F Series) Parameter Symbol Part No. (LTL) 1CHJDTNN 1CHJRTNN 1CHJETNN 1CHJFTNN 1CHJYTNN 1CHJSTNN 1CHJGTNN 1CHJDTNN 1CHJRTNN 1CHJETNN 1CHJFTNN 1CHJYTNN 1CHJSTNN 1CHJGTNN 1CHJDTNN 1CHJRTNN 1CHJETNN 1CHJFTNN 1CHJYTNN 1CHJSTNN 1CHJGTNN 1CHJDTNN 1CHJRTNN 1CHJETNN 1CHJFTNN 1CHJYTNN 1CHJSTNN 1CHJGTNN 1CHJDTNN 1CHJRTNN 1CHJETNN 1CHJFTNN 1CHJYTNN 1CHJSTNN 1CHJGTNN Min. 65 65 65 65 65 65 65 Typ. 120 140 180 180 180 180 180 45 650 639 632 611 595 588 575 639 632 624 605 592 587 572 20 20 20 17 15 15 15 2.0 2.0 2.05 2.05 2.05 2.05 2.05 40 Max. Unit Test Condition Luminous Intensity Iv IF = 20mA mcd Note 1 Note 2 Viewing Angle 2 θ1/2 deg Note 3 (Fig.5) Peak Emission Wavelength λP nm Measurement @ peak (Fig.1) Dominant Wavelength λd Nm Note 5 Spectral Line Half-Width ∆λ Nm Forward Voltage VF 2.4 2.3 2.4 2.4 2.4 2.4 2.4 100 V IF = 20mA Reverse Current Capacitance IR C µA pF VR = 5V VF = 0, f = 1 MHz NOTES: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. Luminous intensity rank classified products support two ranks. 3. θ 1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 4. Iv classification code is marked on each packing bag. 5. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device.        #   ! "#                         Electrical / Optical Characteristics at TA=25 (H Series) Parameter Symbol Part No. (LTL) 2F7JDTNN 2F7JRTNN 2F7JETNN 2F7JFTNN 2F7JYTNN 2F7JSTNN 2F7JGTNN 2F7JDTNN 2F7JRTNN 2F7JETNN 2F7JFTNN 2F7JYTNN 2F7JSTNN 2F7JGTNN 2F7JDTNN 2F7JRTNN 2F7JETNN 2F7JFTNN 2F7JYTNN 2F7JSTNN 2F7JGTNN 2F7JDTNN 2F7JRTNN 2F7JETNN 2F7JFTNN 2F7JYTNN 2F7JSTNN 2F7JGTNN 2F7JDTNN 2F7JRTNN 2F7JETNN 2F7JFTNN 2F7JYTNN 2F7JSTNN 2F7JGTNN Min. 65 65 65 65 65 65 65 Typ. 120 140 180 180 180 180 180 45 650 639 632 611 595 588 575 639 632 624 605 592 587 572 20 20 20 17 15 15 15 2.0 2.0 2.05 2.05 2.05 2.05 2.05 40 Max. Unit Test Condition Luminous Intensity Iv IF = 20mA mcd Note 1 Note 2 Viewing Angle 2 θ1/2 deg Note 3 (Fig.5) Peak Emission Wavelength λP nm Measurement @ peak (Fig.1) Dominant Wavelength λd nm Note 5 Spectral Line Half-Width ∆λ nm Forward Voltage VF 2.4 2.3 2.4 2.4 2.4 2.4 2.4 100 V IF = 20mA Reverse Current Capacitance IR C µA pF VR = 5V VF = 0, f = 1 MHz NOTES: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. Luminous intensity rank classified products support two ranks. 3. θ 1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 4. Iv classification code is marked on each packing bag. 5. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device.        ! "#  /                         Typical Electrical / Optical Characteristics Curves (25 Ambient Temperature Unless Otherwise Noted)        ! "#
LTL1CHJETNN 价格&库存
很抱歉,暂时无法提供与“LTL1CHJETNN”相匹配的价格&库存,您可以联系我们找货
LTL1CHJETNN
    LTL1CHJETNN
      • 1+0.23598
      • 200+0.09418
      • 500+0.09105
      • 1000+0.08943
