LTL2R3KFK
LTL2R3KFK
    LITE-ON(光宝)
    插件,D=5mm
    LTL2R3KFK
LTL2R3KFK 数据手册
LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Features * High luminous intensity output. * Low power consumption. * High efficiency. * Versatile mounting on P.C. board or panel. * I.C. Compatible/low current requirements. * Popular T-13/4 diameter. Package Dimensions Part No. LTL2R3KFK Lens Water Clear Source Color AlInGaP Yellow Orange Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25mm(.010") unless otherwise noted. 3. Protruded resin under flange is 1.0mm(.04") max. 4. Lead spacing is measured where the leads emerge from the package. 5. Specifications are subject to change without notice. Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 1 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Absolute Maximum Ratings at TA=25℃ Parameter Power Dissipation Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) Continuous Forward Current Derating Linear From 50℃ Reverse Voltage Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm(.063") From Body] 60 30 0.4 5 -40℃ to + 100℃ -55℃ to + 100℃ 260℃ for 5 Seconds mA mA mA/℃ V Maximum Rating 75 Unit mW Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 2 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Electrical / Optical Characteristics at TA=25℃ Parameter Symbol Min. Typ. Max. Unit Test Condition IF = 20mA Note 1 ,5 Note 2 (Fig.5) Measurement @Peak (Fig.1) Note 4 Luminous Intensity IV 2θ1/2 λP λd Δλ 240 700 mcd Viewing Angle 30 deg Peak Emission Wavelength 611 nm Dominant Wavelength 605 nm Spectral Line Half-Width 17 nm Forward Voltage VF 2.05 2.4 V μA IF = 20mA Reverse Current IR 100 V R = 5V Capacitance C 40 pF VF = 0 , f = 1MHz NOTE: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. θ1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 3. Iv classification code is marked on each packing bag. 4. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device. 5. The Iv guarantee should be added ±15%. Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 3 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Typical Electrical / Optical Characteristics Curves (25℃ Ambient Temperature Unless Otherwise Noted) Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 4 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Packing Spec 1000, 500 or 250 pcs per packing bag 8 packing bags per inner carton total 8000pcs per inner carton 8 Inner cartons per outer carton total 64000pcs per outer carton Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 5 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Bin Code List For Reference Luminous Intensity Bin Code J K L M N P Min. 240 310 400 520 680 880 Unit : mcd @20mA Max. 310 400 520 680 880 1150 Note: Tolerance of each bin limit is ±15% Dominant Wavelength Bin Code H22 H23 H24 H25 H26 Min. 598.0 600.0 603.0 606.5 610.0 Unit : nm @20mA Max. 600.0 603.0 606.5 610.0 613.5 Note: Tolerance of each bin limit is ±1nm Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 6 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only CAUTIONS 1. Application limitation The LEDs described here are intended to be used for ordinary electronic equipment (such as office equipment, communication equipment and household application.) Consult Liteon’s sales in advance for information on application in which exceptional quality and reliability are required, particularly when the failure or malfunction of the LEDs may directly jeopardize life or health (such as airplanes, automobiles, traffic control equipment, life support system and safety devices). 2. Storage After being shipped from Liteon the LEDs should be kept at 30°C or less and 70%RH or less. The LEDs should be used within 3 months. They can be stored for a year in a sealed container with a nitrogen atmosphere and moisture absorbent material. Please avoid rapid transitions in ambient temperature in high humidity environments where condensation may occur. 3. Cleaning Use alcohol-based cleaning solvents such as isopropyl alcohol to clean the LED. 4. Forming & Mounting When forming a lead, the leads should be bent at a point at least 3mm from the base of epoxy bulb. Do not use the base of the leadframe as a fulcrum during forming. Lead forming must be done before soldering at normal temperature. When mounted through hole type LED lamp, avoid the occurrence of residual mechanical stress due to clinching as figure shown here. 5. Soldering When soldering, leave a minimum of 2mm clearance from the resin to the soldering point. Dipping the resin into the solder must be avoided. Do not apply any stress to the lead frame during soldering while the LED is at high temperature. Recommended soldering condition Soldering iron Temperature Soldering time 300°C Max. 3 sec. Max. (one time only) Wave soldering Pre-heat Pre-heat time Solder wave Soldering time 100°C Max. 60 sec. Max. 260°C Max. 10 sec. Max. 6. Drive Method LED is a current operated device, and therefore, requires some kind of current limiting incorporated into the drive circuit. This current limiting typically takes the form of a current limiter resistor placed in series with the LED. Consider worst case voltage variations that could occur across the current limiting resistor. The forward current should not be allowed to change by more than 40% of its desired value. Circuit model A LED Circuit model B LED (A) Recommended circuit. (B) The difference of brightness between LEDs could be found due to the Vf-If characteristics of LED Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 7 of 8 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only 7. ESD (Electrostatic Discharge) Static Electricity or power surge will damage the LED. Use of a conductive wrist band or anti- electrostatic glove is recommended when handling these LED. All devices, equipment and machinery must be properly grounded. 8. Reliability Test Classification Test Item Test Condition Duration / Cycle Referance Standard Endurance Test Room Temp. Operation Life Ta= Room Temp, IDC= 30 mA 1000 hrs MIL-STD-202F:107D (1980) Temperature Cycling 105℃ ~ 25℃ ~ -55℃ ~ 25℃ 30mins 5mins 30mins 5mins 10 cycles MIL-STD-750D:1051(1995) MIL-STD-883D:1010 (1991) JIS C 7021: A-4(1982) Environmental Solder Test Resistance MIL-STD-202F:210A(1980) Solder temperature is 260± 5 ℃ 10 sec MIL-STD-750D:2031(1995) JIS C 7021: A-1(1982) MIL-STD-202F:208D(1980) Solderability Solder temperature is 230± 5 ℃ 5 sec MIL-STD-750D:2026(1995) MIL-STD-883D:2003(1991) JIS C 7021: A-2(1982) 9. Others The appearance and specifications of the product may be modified for improvement without notice. Part No. : LTL2R3KFK BNS-OD-C131/A4 Page : 8 of 8
LTL2R3KFK 价格&库存
很抱歉,暂时无法提供与“LTL2R3KFK”相匹配的价格&库存,您可以联系我们找货
LTL2R3KFK
  • 1+2.385411+0.30884
