LTL2R3KG
LTL2R3KG
    LITE-ON(光宝)
    插件,D=5mm
    发光二极管/LED 翠绿色 插件,D=5mm 572nm 180mcd
LTL2R3KG 数据手册
LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Features * High luminous intensity output. * Low power consumption. * High efficiency. * Versatile mounting on P.C. board or panel. * I.C. Compatible/low current requirements. * Popular T-13/4 diameter. Package Dimensions Part No. LTL2R3KG Green Lens Diffused Source Color AlInGaP Green Notes: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25mm(.010") unless otherwise noted. 3. Protruded resin under flange is 1.0mm(.04") max. 4. Lead spacing is measured where the leads emerge from the package. 5. Specifications are subject to change without notice. Part No. : LTL2R3KG Page : 1 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Absolute Maximum Ratings at TA=25℃ Parameter Power Dissipation Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) DC Forward Current Derating Linear From 50℃ Reverse Voltage Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm(.063") From Body] Maximum Rating 75 60 30 0.4 5 -40℃ to + 100℃ -55℃ to + 100℃ 260℃ for 5 Seconds Unit mW mA mA mA/℃ V Part No. : LTL2R3KG Page : 2 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Electrical / Optical Characteristics at TA=25℃ Parameter Luminous Intensity Viewing Angle Peak Emission Wavelength Dominant Wavelength Spectral Line Half-Width Forward Voltage Reverse Current Capacitance Symbol IV 2θ1/2 λP λd ∆λ VF IR C 40 Min. 85 Typ. 180 40 575 572 11 2.1 2.4 100 Max. Unit mcd deg nm nm nm V µA pF IF = 20mA VR = 5V VF = 0 , f = 1MHz Test Condition IF = 20mA Note 1 Note 2 (Fig.5) Measurement @Peak (Fig.1) Note 4 NOTE: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. θ1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 3. Iv classification code is marked on each packing bag. 4. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device. Part No. : LTL2R3KG Page : 3 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Typical (25℃ Electrical Ambient / Optical Characteristics Otherwise Curves Temperature Unless Noted) Part No. : LTL2R3KG Page : 4 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY Packing Spec CORPORATION Property of Lite-On Only 1000, 500 or 250 pcs per packing bag 8 packing bags per inner carton total 8000 pcs per inner carton 8 Inner cartons per outer carton total 64000 pcs per outer carton In every shipping lot, only the last pack will be non-full packing Part No. : LTL2R3KG Page : 5 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Bin Code List Bin Code EF GH JK For Reference Unit : mcd @20mA Min. 85 140 240 Max. 140 240 400 Luminous Intensity Note: Tolerance of each bin limit is ±15% Dominant Wavelength Bin Code H06 H07 H08 H09 H10 H11 Min. 566.0 568.0 570.0 572.0 574.0 576.0 Unit : nm @20mA Max. 568.0 570.0 572.0 574.0 576.0 578.0 Note: Tolerance of each bin limit is ±1nm Part No. : LTL2R3KG Page : 6 of 10 BNS-OD-C131/A4 LITE-ON TECHNOLOGY CAUTIONS CORPORATION Property of Lite-On Only 1. Application The LEDs described here are intended to be used for ordinary electronic equipment (such as office equipment, communication equipment and household applications).Consult Liteon’s Sales in advance for information on applications in which exceptional reliability is required, particularly when the failure or malfunction of the LEDs may directly jeopardize life or health (such as in aviation, transportation, traffic control equipment, medical and life support systems and safety devices). 2. Storage The storage ambient for the LEDs should not exceed 30°C temperature or 70% relative humidity. It is recommended that LEDs out of their original packaging are used within three months. For extended storage out of their original packaging, it is recommended that the LEDs be stored in a sealed container with appropriate desiccant or in desiccators with nitrogen ambient. 3. Cleaning Use alcohol-based cleaning solvents such as isopropyl alcohol to clean the LEDs if necessary. 4. Lead Forming & Assembly During lead forming, the leads should be bent at a point at least 3mm from the base of LED lens. Do not use the base of the lead frame as a fulcrum during forming. Lead forming must be done before soldering, at normal temperature. During assembly on PCB, use minimum clinch force possible to avoid excessive mechanical stress. 5. Soldering When soldering, leave a minimum of 2mm clearance from the base of the lens to the soldering point. Dipping the lens into the solder must be avoided. Do not apply any external stress to the lead frame during soldering while the LED is at high temperature. Recommended soldering conditions : Soldering iron Temperature Soldering time 300°C Max. 3 sec. Max. (one time only) Wave soldering Pre-heat Pre-heat time Solder wave Soldering time 100°C Max. 60 sec. Max. 260°C Max. 10 sec. Max. Note: Excessive soldering temperature and/or time might result in deformation of the LED lens or catastrophic failure of the LED Part No. : LTL2R3KG BNS-OD-C131/A4 Page : 7 of 10 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only 6. Drive Method An LED is a current-operated device. In order to ensure intensity uniformity on multiple LEDs connected in parallel in an application, it is recommended that a current limiting resistor be incorporated in the drive circuit, in series with each LED as shown in Circuit A below. Circuit model A LED Circuit model B LED (A) Recommended circuit (B) The brightness of each LED might appear different due to the differences in the I-V characteristics of those LEDs 7. ESD (Electrostatic Discharge) Static Electricity or power surge will damage the LED. Suggestions to prevent ESD damage: Use a conductive wrist band or anti- electrostatic glove when handling these LEDs All devices, equipment, and machinery must be properly grounded Work tables, storage racks, etc. should be properly grounded Use ion blower to neutralize the static charge which might have built up on surface of the LEDs plastic lens as a result of friction between LEDs during storage and handing Part No. : LTL2R3KG BNS-OD-C131/A4 Page : 8 of 10 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only Suggested checking list : Training and Certification 1. Everyone working in a static-safe area is ESD-certified? 2. Training records kept and re-certification dates monitored? Static-Safe Workstation & Work Areas 1. Static-safe workstation or work-areas have ESD signs? 2. All surfaces and objects at all static-safe workstation and within 1 ft measure less than 100V? 3. All ionizer activated, positioned towards the units? 4. Each work surface mats grounding is good? Personnel Grounding 1. Every person (including visitors) handling ESD sensitive (ESDS) items wear wrist strap, heel strap or conductive shoes with conductive flooring? 2. If conductive footwear used, conductive flooring also present where operator stand or walk? 3. Garments, hairs or anything closer than 1 ft to ESD items measure less than 100V*? 4. Every wrist strap or heel strap/conductive shoes checked daily and result recorded for all DSL? 5. All wrist strap or heel strap checkers calibration up to date? Note: *50V for Blue LED. Device Handling 1. Every ESDS items identified by EIA-471 labels on item or packaging? 2. All ESDS items completely inside properly closed static-shielding containers when not at static-safe workstation? 3. No static charge generators (e.g. plastics) inside shielding containers with ESDS items? 4. All flexible conductive and dissipative package materials inspected before reuse or recycle? Others 1. Audit result reported to entity ESD control coordinator? 2. Corrective action from previous audits completed? 3. Are audit records complete and on file? Part No. : LTL2R3KG BNS-OD-C131/A4 Page : 9 of 10 LITE-ON TECHNOLOGY CORPORATION Property of Lite-On Only 8. Reliability Test Classification Test Item Test Condition Reference Standard Operation Life Ta= Under Room Temperature As Per Data Sheet Maximum Rating *Test Time= 1000HRS (-24HRS,+72HRS) Ta= 65±5℃ RH= 90 〜 95% Test Time= 240HRS±2HRS Ta= 65±5℃ RH= 90 〜 95% VR=5V Test Time = 500HRS (-24HRS, +48HRS) Ta= 105±5℃ *Test Time= 1000HRS (-24HRS,+72HRS) MIL-STD-750D:1026 (1995) MIL-STD-883D:1005 (1991) JIS C 7021:B-1 (1982) MIL-STD-202F: 103B(1980) JIS C 7021 : B-11(1982) High Temperature High Humidity Storage Endurance Test High Temperature High Humidity Reverse BIAS JIS C 7021 : B-11(1982) High Temperature Storage MIL-STD-883D:1008 (1991) JIS C 7021:B-10 (1982) Low Temperature Storage Ta= -55±5℃ *Test Time=1000HRS (-24HRS,+72HRS) 105℃ 〜 25℃ 〜 -55℃ 〜 25℃ 30mins 5mins 30mins 5mins 10 Cycles 105 ± 5℃ 〜 -55℃ ± 5℃ 10mins 10mins 10 Cycles T.sol = 260 ± 5℃ Dwell Time= 10 ± 1secs JIS C 7021:B-12 (1982) MIL-STD-202F:107D (1980) MIL-STD-750D:1051(1995) MIL-STD-883D:1010 (1991) JIS C 7021: A-4(1982) MIL-STD-202F:107D(1980) MIL-STD-750D:1051(1995) MIL-STD-883D:1011 (1991) MIL-STD-202F:210A(1980) MIL-STD-750D:2031(1995) JIS C 7021: A-1(1982) MIL-STD-202F:208D(1980) MIL-STD-750D:2026(1995) MIL-STD-883D:2003(1991) JIS C 7021: A-2(1982) Temperature Cycling Environmental Test Thermal Shock Solder Resistance Solderability T. sol = 230 ± 5℃ Dwell Time= 5 ± 1secs 9. Others The appearance and specifications of the product may be modified for improvement, without prior notice. Part No. : LTL2R3KG BNS-OD-C131/A4 Page : 10 of 10
LTL2R3KG 价格&库存
很抱歉,暂时无法提供与“LTL2R3KG”相匹配的价格&库存,您可以联系我们找货
LTL2R3KG
    库存:7053
