T-13/4 (5mm) Ultra Bright
8 degree 15 degree 22 degree 30 degree
LTL2F3VxKNT LTL2H3VxKNT LTL2P3VxKNT LTL2R3VxKNT Features ! ! ! ! ! !
High luminous intensity output. Low power consumption. High efficiency. Versatile mounting on P.C. board or panel. I.C. compatible / low current requirement. Popular T-13/4 diameter.
Description
The source color devices are made with Aluminum Indium Gallium Phosphide on Gallium Arsenide light emitting diode. The devices are made with water clear epoxy package, And with 8, 15, 22 and 30 degrees of viewing angle.
Application ! Message sign. ! Traffic sign Devices
Part No. (LTL) 2F3VRKNT / 2H3VRKNT 2P3VRKNT / 2R3VRKNT 2F3VEKNT / 2H3VEKNT 2P3VEKNT / 2R3VEKNT 2F3VHKNT / 2H3VHKNT 2P3VHKNT / 2R3VHKNT 2F3VAKNT / 2H3VAKNT 2P3VAKNT / 2R3VAKNT 2F3VFKNT / 2H3VFKNT 2P3VFKNT / 2R3VFKNT 2F3VYKNT / 2H3VYKNT 2P3VYKNT / 2R3VYKNT 2F3VSKNT / 2H3VSKNT 2P3VSKNT / 2R3VSKNT Lens Water Clear Water Clear Water Clear Water Clear Water Clear Water Clear Water Clear Source Color AlInGap Super Red AlInGap Red AlInGap Red Orange AlInGap Red Orange AlInGap Yellow Orange AlInGap Amber Yellow AlInGap Yellow
$ "%%&'()$')$')('%%'($*')+,$- %)+'$./((*..0-1)%$$,2'$)& 1&&$')1)&%)'$.((*.#0-( #
&$3+')'$($1&2,,%&$((,3+4 /3+''+')$$156++,)2',1)'+
Absolute Maximum Ratings at TA=25°C
Super Red Red Orange Red Orange Yellow Orange Amber Yellow
Parameter
Red
Yellow
Unit
Power Dissipation Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) Continuous Forward Current Derating Linear From 70°C Reverse Voltage(IR =100 A) Operating Temperature Range Storage Temperature Range Lead Soldering Temperature [1.6mm(.063") From Body]
120
120
120
120
120
120
120
mW
130
130
90
90
90
90
90
mA
50 0.6 5
50 0.6 5
50 0.6 5
50 0.6 5
50 0.6 5
50 0.6 5
50 0.6 5
mA mA / °C V
-40°C to + 100°C -55°C to + 100°C
260 for 5 Seconds
Electrical / Optical Characteristics at TA=25 (F Series)
Parameter Symbol Part No. (LTL) 2F3VRKNT 2F3VEKNT 2F3VHKNT 2F3VAKNT 2F3VFKNT 2F3VYKNT 2F3VSKNT 2F3VRKNT 2F3VEKNT 2F3VHKNT 2F3VAKNT 2F3VFKNT 2F3VYKNT 2F3VSKNT 2F3VRKNT 2F3VEKNT 2F3VHKNT 2F3VAKNT 2F3VFKNT 2F3VYKNT 2F3VSKNT 2F3VRKNT 2F3VEKNT 2F3VHKNT 2F3VAKNT 2F3VFKNT 2F3VYKNT 2F3VSKNT 2F3VRKNT 2F3VEKNT 2F3VHKNT 2F3VAKNT 2F3VFKNT 2F3VYKNT 2F3VSKNT Min. 3200 4200 4200 4200 4200 4200 4200 Typ. 5500 7200 7800 7800 7800 7800 7200 8 639 632 624 621 611 595 588 631 624 618 615 605 592 587 20 20 18 18 17 15 15 1.9 2.0 2.0 2.0 2.0 2.0 2.0 40 Max. Unit Test Condition
Luminous Intensity
Iv
IF = 20mA mcd Note 1 Note 2
Viewing Angle
2 θ1/2
deg
Note 3 (Fig.5)
Peak Emission Wavelength
λP
Measurement nm @ peak (Fig.1)
Dominant Wavelength
λd
nm
Note 5
Spectral Line Half-Width
∆λ
nm
Forward Voltage
VF
2.3 2.4 2.4 2.4 2.4 2.4 2.4 100
V
IF = 20mA
Reverse Current Capacitance
IR C
µA pF
VR = 5V VF = 0, f = 1 MHz
NOTES: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. Luminous intensity rank classified products support two ranks. 3. θ 1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 4. Iv classification code is marked on each packing bag. 5. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device.
Electrical / Optical Characteristics at TA=25 (H Series)
Parameter Symbol Part No. (LTL) 2H3VRKNT 2H3VEKNT 2H3VHKNT 2H3VAKNT 2H3VFKNT 2H3VYKNT 2H3VSKNT 2H3VRKNT 2H3VEKNT 2H3VHKNT 2H3VAKNT 2H3VFKNT 2H3VYKNT 2H3VSKNT 2H3VRKNT 2H3VEKNT 2H3VHKNT 2H3VAKNT 2H3VFKNT 2H3VYKNT 2H3VSKNT 2H3VRKNT 2H3VEKNT 2H3VHKNT 2H3VAKNT 2H3VFKNT 2H3VYKNT 2H3VSKNT 2H3VRKNT 2H3VEKNT 2H3VHKNT 2H3VAKNT 2H3VFKNT 2H3VYKNT 2H3VSKNT Min. 1500 1900 1900 1900 1900 1900 1900 Typ. 2400 3100 3400 3400 3400 3400 3100 15 639 632 624 621 611 595 588 631 624 618 615 605 592 587 20 20 18 18 17 15 15 1.9 2.0 2.0 2.0 2.0 2.0 2.0 40 Max. Unit Test Condition
Luminous Intensity
Iv
Viewing Angle
2 θ1/2
deg
Note 3 (Fig.5)
λP
nm
Measurement @ peak (Fig.1)
Dominant Wavelength
λd
nm
Note 5
∆λ
nm
Forward Voltage
VF
V
IF = 20mA
IR C
µA pF
NOTES: 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. Luminous intensity rank classified products support two ranks. 3. θ 1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 4. Iv classification code is marked on each packing bag. 5. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which Define the color of the device.
Electrical / Optical Characteristics at TA=25 (P Series)
Parameter Symbol Part No. (LTL) 2P3VRKNT 2P3VEKNT 2P3VHKNT 2P3VAKNT 2P3VFKNT 2P3VYKNT 2P3VSKNT 2P3VRKNT 2P3VEKNT 2P3VHKNT 2P3VAKNT 2P3VFKNT 2P3VYKNT 2P3VSKNT 2P3VRKNT 2P3VEKNT 2P3VHKNT 2P3VAKNT 2P3VFKNT 2P3VYKNT 2P3VSKNT 2P3VRKNT 2P3VEKNT 2P3VHKNT 2P3VFKNT 2P3VFKNT 2P3VYKNT 2P3VSKNT 2P3VRKNT 2P3VEKNT 2P3VHKNT 2P3VAKNT 2P3VFKNT 2P3VYKNT 2P3VSKNT Min. 880 1150 1150 1150 1150 1150 1150 Typ. 1400 1900 2000 2000 2000 2000 1900 22 639 632 624 621 611 595 588 631 624 618 615 605 592 587 20 20 18 18 17 16 15 1.9 2.0 2.0 2.0 2.0 2.0 2.0 40 Max. Unit Test Condition
Luminous Intensity
Iv
IF = 20mA mad Note 1 Note 2
Viewing Angle
2 θ1/2
deg
Note 3 (Fig.5)
λP
nm
Dominant Wavelength
λd
nm
Note 5
∆λ
nm
Forward Voltage
VF
V
IF = 20mA
IR C
µA pF
7
Electrical / Optical Characteristics at TA=25 (R Series)
Parameter Symbol Part No. (LTL) 2R3VRKNT 2R3VEKNT 2R3VHKNT 2R3VAKNT 2R3VFKNT 2R3VYKNT 2R3VSKNT 2R3VRKNT 2R3VEKNT 2R3VHKNT 2R3VAKNT 2R3VFKNT 2R3VYKNT 2R3VSKNT 2R3VRKNT 2R3VEKNT 2R3VHKNT 2R3VAKNT 2R3VFKNT 2R3VYKNT 2R3VSKNT 2R3VRKNT 2R3VEKNT 2R3VHKNT 2R3VAKNT 2R3VFKNT 2R3VYKNT 2R3VSKNT 2R3VRKNT 2R3VEKNT 2R3VHKNT 2R3VAKNT 2R3VFKNT 2R3VYKNT 2R3VSKNT Min. 520 680 680 680 680 680 680 Typ. 990 1200 1300 1300 1300 1300 1200 30 639 632 624 621 611 595 588 631 624 618 615 605 592 587 20 20 18 18 17 16 15 1.9 2.0 2.0 2.0 2.0 2.0 2.0 40 Max. Unit Test Condition
Luminous Intensity
Iv
Viewing Angle
2 θ1/2
deg
Note 3 (Fig.5)
λP
nm
Dominant Wavelength
λd
nm
Note 5
∆λ
nm
Forward Voltage
VF
V
IF = 20mA
IR C
µA pF
8
Typical Electrical / Optical Characteristics Curves
(25 Ambient Temperature Unless Otherwise Noted)
很抱歉,暂时无法提供与“LTL2R3VEKNT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.67716
- 200+0.27022
- 500+0.26115
- 1000+0.25672
