LTV-827S
LTV-827S
    LITE-ON(光宝)
    OC-8P_9.68X6.5MM_SM
    DC 5KV
LTV-827S 数据手册
L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only FEATURES * Current transfer ratio ( CTR : MIN. 50% at IF = 5mA, VCE = 5V ) * High input-output isolation voltage ( Viso = 5,000Vrms ) * Response time ( tr : TYP. 4µs at VCE = 2V, IC = 2mA, RL = 100Ω ) * Dual-in-line package : LTV-817 : 1-channel type LTV-827 : 2-channel type LTV-847 : 4-channel type * Wide lead spacing package : LTV-817M : 1-channel type LTV-827M : 2-channel type LTV-847M : 4-channel type * Surface mounting package : LTV-817S : 1-channel type LTV-827S : 2-channel type LTV-847S : 4-channel type * Tape and reel packaging : LTV-817S-TA1, LTV-827S-TA1 * UL approved * CSA approved * FIMKO approved * NEMKO approved * DEMKO approved * SEMKO approved * VDE approved * BSI approved - LTV-817 series only * RoHS compliance * ◇ Critical characteristic * ○ Safety or compliance characteristic. Nov. 2008 Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 1 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817 : TYPE I (INK MARK) TYPE II (LASER MARK) ◇ ◇ ◇ ◇ LTV-827 : ◇ ◇ *1. *2. *3. *4. Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Rank shall be or shall not be marked. Page : 2 of 14 Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-847 : ◇ ◇ LTV-817M : TYPE I (INK MARK) TYPE II (LASER MARK) ◇ ◇ ◇ ◇ *1. *2. *3. *4. Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Rank shall be or shall not be marked. Page : 3 of 14 Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-827M : ◇ ◇ LTV-847M : ◇ ◇ *1. *2. *3. *4. Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Rank shall be or shall not be marked. Page : 4 of 14 Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817S : TYPE I (INK MARK) TYPE II (LASER MARK) ◇ ◇ ◇ ◇ LTV-827S : ◇ ◇ *1. *2. *3. *4. Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 5 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-847S : ◇ ◇ *1. *2. *3. *4. Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 6 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only TAPING DIMENSIONS LTV-817S-TA1 : LTV-827S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16 ± 0.3 ( .63 ) 4 ± 0.1 ( .15 ) 7.5 ± 0.1 ( .295 ) 2 ± 0.1 ( .079 ) 12 ± 0.1 ( .472 ) Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 7 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25°C ) PARAMETER Forward Current INPUT Reverse Voltage Power Dissipation Collector - Emitter Voltage Emitter - Collector Voltage OUTPUT Collector Current Collector Power Dissipation Total Power Dissipation *1 Isolation Voltage ○ Operating Temperature(LTV- 827 / 847) Operating Temperature (LTV-817) Storage Temperature *2 Soldering Temperature IC PC Ptot Viso Topr Topr Tstg Tsol 50 150 200 5,000 -30 ~ +110 -30 ~ +110 -55 ~ +125 260 mA mW mW Vrms °C °C °C °C SYMBOL IF VR P VCEO VECO RATING 50 6 70 35 6 UNIT mA V mW V V *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 8 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25°C ) PARAMETER Forward Voltage INPUT Reverse Current Terminal Capacitance Collector Dark Current Collector-Emitter Breakdown Voltage Emitter-Collector Breakdown Voltage Collector Current *1 Current Transfer Ratio ◇ Collector-Emitter Saturation Voltage Isolation Resistance Floating Capacitance Cut-Off Frequency Response Time (Rise) Response Time (Fall) SYMBOL MIN. TYP. MAX. UNIT VF IR Ct ICEO BVCEO — — — — 35 1.2 — 30 — — 1.4 10 250 100 — V µA pF nA V CONDITIONS IF=20mA VR=4V V=0, f=1KHz VCE=20V, IF=0 IC=0.1mA IF=0 IE=10µA IF=0 IF=5mA VCE=5V IF=20mA IC=1mA DC500V 40 ~ 60% R.H. V=0, f=1MHz VCE=5V, IC=2mA RL=100Ω, -3dB VCE=2V, IC=2mA RL=100Ω OUTPUT BVECO IC CTR VCE(sat) 6 2.5 50 — — — — 0.1 — 30 600 0.2 V mA % V Ω pF kHz µs µs TRANSFER CHARACTERISTICS Riso Cf fc tr tf 5×1010 1×1011 — — — — 0.6 80 4 3 — 1 — 18 18 *1 CTR = IC × 100% IF Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 9 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only RANK TABLE OF CURRENT TRANSFER RATIO CTR MODEL NO. RANK MARK L A B CTR ( % ) 50 ~ 100 80 ~ 160 130 ~ 260 200 ~ 400 300 ~ 600 50 ~ 600 50~600 130 ~ 260 200 ~ 400 130~400 200~600 50~600 130~400 200~600 LTV-817 C D L or A or B or C or D No Bin B LTV-827 C BC CD No Bin LTV-847 BC CD IF = 5 mA CONDITIONS VCE = 5 V Ta = 25 °C Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 10 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only CHARACTERISTICS CURVES Fig.1 Forword Current vs. Ambient Temperatute 60 50 40 30 20 10 0 -30 Fig.2 Collector Power Dissiption vs. Ambient Temperature Collector Power dissipation Pc (mW) 200 Forward current IF (mA) 150 100 50 0 25 50 75 100 o 125 0 -30 0 25 50 75 100 125 o Ambient temperature Ta ( C) Ambient temperature Ta ( C) Fig.3 Collector-emitter Saturation Voltage vs. Forward Current 1mA 3mA 5mA Collecotr-emitter saturation voltage VCE (sat) (V) Ic= 0.5mA 7mA Fig.4 Forward Current vs. Forward Voltage O 6 5 4 3 2 1 Ta= 25 C Forward current IF (mA) 500 200 100 50 20 10 5 2 Ta= 75 C 50 C o o 25 C 0C -25 C o o o 0 0 5 10 15 Forward current IF (mA) 1 0 0.5 1.0 1.5 2.0 2.5 3.0 Forward voltage VF (V) Fig.5 Current Transfer Ratio vs. Forward Current 200 Current transfer ratio CTR (%) Fig.6 Collector Current vs. Collector-emitter Voltage 30 Collector current Ic (mA) 180 160 140 120 100 80 60 40 20 0 1 2 5 10 VCE= 5V Ta= 25 C o IF = 30mA 25 20 15 10 5mA 5 0 20mA Ta= 25 C Pc(MAX.) o 10mA 20 50 0 1 2 3 4 5 6 7 8 9 Forward current IF (mA) Collector-emitter voltage V (V) CE Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 11 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only CHARACTERISTICS CURVES Fig.7 Relative Current Transfer Ratio vs. Ambient Temperature 150 Relative current transfer ratio (%) Fig.8 Collector-emitter Saturation Voltage vs. Ambient Temperature Collector-emitter saturation voltage V (sat) (V) CE I F = 5mA VCE= 5V 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 -25 0 25 50 75 o I F= 20mA Ic= 1mA 100 50 0 -30 0 25 50 75 o 100 125 100 125 Ambient temperature Ta ( C) Ambient temperature Ta ( C) Fig.9 Collector Dark Current vs. Ambient Temperature 10 Collector dark current I CEO (A) -5 Fig.10 Response Time vs. Load Resistance 500 200 100 50 20 10 5 2 1 0.5 0.2 0.05 ts VCE = 2V Ic= 2mA Ta= 25 C o VCE = 20V Response time ( s) -6 10 -7 10 -8 tr tf td 10 -9 10 -10 10 -11 10 -25 0 25 50 75 o 100 125 0.1 0.2 0.5 1 2 5 10 Ambient temperature Ta ( C) Load resistance R L(k ) Fig.11 Frequency Response Test Circuit for Response Time Voltage gain Av (dB) 0 V = 2V CE Ic= 2mA Ta= 25 C o 10 RL 10k = 1k 100 20 0.5 1 2 5 10 20 50 100 500 Test Circuit for Frequency Response Frequency f (kHz) Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 12 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm 4 PIN 8 PIN 16 PIN Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 13 of 14 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only Notes: - Lite-On is continually improving the quality, reliability, function or design and Lite-On reserves the right to make changes without further notices. - The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation. - For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives. - When requiring a device for any ”specific” application, please contact our sales in advice. - If there are any questions about the contents of this publication, please contact us at your convenience. - The contents described herein are subject to change without prior notice. Part No. : LTV-817 / 827 / 847 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 14 of 14
LTV-827S 价格&库存
很抱歉,暂时无法提供与“LTV-827S”相匹配的价格&库存,您可以联系我们找货
LTV-827S
  • 1+1.791171+0.23107
  • 50+1.7735750+0.22880
  • 100+1.54157100+0.19887
  • 150+1.52637150+0.19691
  • 250+1.51117250+0.19495
  • 350+1.49597350+0.19299
  • 500+1.13678500+0.14665
库存:138
LTV-827S
  • 1+4.300101+0.55480
  • 10+2.8388010+0.36630
  • 100+2.12010100+0.27350
  • 500+1.96440500+0.25350
  • 1000+1.904501000+0.24570
  • 2500+1.832602500+0.23650
  • 5000+1.784705000+0.23030
  • 10000+1.6410010000+0.21170
  • 25000+1.5811025000+0.20400
库存:9452
LTV-827S
  • 43+1.8224143+0.23510
  • 50+1.8045050+0.23279
  • 100+1.56846100+0.20234
  • 150+1.55300150+0.20034
  • 250+1.53753250+0.19835
  • 350+1.52207350+0.19635
  • 500+1.15661500+0.14921
库存:138
LTV-827S
  • 50+2.8904850+0.37288
  • 100+2.63602100+0.34006
  • 150+2.50476150+0.32312
  • 250+2.35550250+0.30387
  • 350+2.26631350+0.29236
  • 500+2.17917500+0.28112
库存:31349
