NJM3359D
NJM3359D
    NJR(新日本无线)
    DIP18
    IC FM-IF NARROW BAND LP 18DIP
NJM3359D 数据手册
NJM3359 LOW POWER NARROW BAND FM IF ■ GENERAL DESCRIPTION The NJM3359 is a low power narrow band FM detector integrated circuit. for FM dual conversion of communication equipment. The NJM3359 includes oscillator, limiting amplifier, AFC circuit, quadrature detect, operational amplifier, squelch circuit, scan-control and muting switch. The NJM3359 is a circuit of NJM3357 plus one stage limiting IF amplifier and AFC output terminal. ■ PACKAGE OUTLINE NJM3359D ■ FEATURES ● Low Operating Current ● Input Limiting Voltage ● Minimum other parts. ● Package Outline ● Bipolar Technology (3.6mA typ@V+=6V) (2.0µVrms typ@-3dB) DIP18 ■ RECOMMENDED OPERATIONAL CODITION ● Operating Voltage 4 to 9V ■ PIN CONFIGURATION NJM3359D Ver.2003-12-09 -1- NJM3359 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER Supply Voltage Input Voltage Muting Function Operating Temperature Range Storage Temperature Range SYMBOL V + (Ta=25°C) RATINGS 12 1.0 -0.7 to 12 -40 to 85 -40 to 125 UNIT V Vrms VPK °C °C V18 V16 Topr Tstg ■ ELECTRICAL CHARACTERISTICS PARAMETER Operating Current Squelch OFF Squelch ON Input Sensitivity (S / N : 20dB) Input Limitting Voltage (-3dB) Mixer Voltage Gain Mixer Intercept Point Mixer Input Resistance Mixer Input Capacitance Recovered Audio Output Voltage Detector Center Frequency Slope AFC Center Frequency Slope Filter Gain Squelch Threshold Voltage Scan Control Current PIN 10, VIN=1.0mVrms PIN 10 PIN 11, RL=∞ fIN=10kHz, VIN=5mV PIN 14, 10kΩ PIN 15 PIN 14 - High - Low Mute Switch Impedance PIN 16 - GND PIN14 - High - Low PIN 18 - PIN 3 Open 50Ω input PIN 4,8 PIN (V+=6V, fO=10.7MHz, ∆f=±3.0kHz, fmod=1.0kHz, Ta=25°C) MIN. TYP. MAX. UNIT 450 40 2.0 - 3.6 5.4 8.0 2.0 33 -1.0 3.6 2.2 700 0.3 12 51 0.62 0.01 2.4 5.0 1.5 6.0 7.0 1.0 10 - mA mA µVrms µVrms dB dBm kΩ pF mVrms V / kHz V / kHz dB Vdc µA mA Ω MΩ -2- Ver.2003-12-09 NJM3359 ■ TEST CIRCUIT ■ APPLICATION EXAMPLE Ver.2003-12-09 -3- NJM3359 ■ TYPICAL CHARACTERISTICS Input - Output Local OSC Frequency AFC Characteristics Mixer Gain vs. Input Frequency Temperature Characteristics Demodulator Output [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2003-12-09
NJM3359D 价格&库存
很抱歉,暂时无法提供与“NJM3359D”相匹配的价格&库存,您可以联系我们找货
