C4SMK-RJS-CS24QBB1
C4SMK-RJS-CS24QBB1
    WOLFSPEED
    插件
    LED RED CLEAR 4MM OVAL T/H
C4SMK-RJS-CS24QBB1 数据手册
Cree® Screen Master® 4-mm Oval LED C4SMK-RJS/GJS/BJS C4SMJ-RJS Data Sheet This oval LED is specifically designed for full color video screens, variablemessage signs and passenger-information signs. The oval-shaped radiation pattern and high luminous intensity ensure that these devices are excellent for wide-field-of-view outdoor applications where a wide viewing angle and readability in sunlight are essential These lamps are made with an advanced optical-grade epoxy that offers superior high-temperature and high-moisture-resistance performance in outdoor signal and sign applications. The encapsulation resin contains anti-UV material in order to reduce the effects of long-term exposure to direct sunlight. FEATURES • • Size (mm): 4 Color and Typical Dominant Wavelength (nm): » Red (621) » Green (527) » Blue (470) Luminous Intensity (mcd) » C4SMK - Red (550-2130) Green (1100-4180) Blue (390-1520) » C4SMJ - Red (390-1520) Lead-Free RoHS-Compliant APPLICATIONS • • • • • • Electronic Signs & Signals (ESS) Full-Color Video Screen Motorway Signs Variable-Message Sign (VMS) Advertising Signs Petrol Signs • • • 0 LD-CT1114.00 Data Sheet: C Subject to change without notice. www.cree.com/ledlamps 1 Absolute Maximum Ratings (TA = 25°C) Items Symbol Absolute Maximum Rating Red Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Lead Soldering Temperature Electrostatic Discharge Classification (MIL-STD-883E) Note2 Unit Blue and Green 35 100 5 140 -40 ~ +95 -40 ~ +100 Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Class 2 mA mA V mW °C °C IF IFP VR PD Topr Tstg Tsol ESD 50 Note1 200 5 130 Note: 1. 2. For long-term performance, the drive currents between 10 mA and 30 mA are recommended. Please contact a Cree sales representative for more information on recommended drive conditions. Pulse width ≤0.1 msec, duty ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Color Red Forward Voltage Green Blue Reverse Current Red Blue/Green Red Dominant Wavelength Green Blue C4SMK- Red Luminous Intensity C4SMJ - Red Green Blue Symbol VF VF VF IR IR λD λD λD IV IV IV IV Condition IF = 20 mA IF = 20 mA IF = 20 mA VR = 5 V VR = 5 V IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA Unit V V V μA μA nm nm nm mcd mcd mcd mcd 619 520 460 550 390 1100 390 621 527 470 1300 800 2900 780 Minimum Typical 2.0 3.4 3.2 Maximum 2.6 4.0 4.0 100 100 624 535 475 Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Intensity Bin Limit (IF = 20 mA) Red: C4SMK Bin Code Subbin R1 R0 R2 R3 R4 S1 S0 S2 S3 S4 T1 T0 T2 T3 T4 U1 U0 U2 U3 U4 Min. (mcd) 550 605 660 715 770 852 934 1017 1100 1205 1310 1415 1520 1672 1824 1976 Max. (mcd) 605 660 715 770 852 934 1017 1100 1205 1310 1415 1520 1672 1824 1976 2130 W0 V0 U0 T0 Green: C4SMK Bin Code Subbin T1 T2 T3 T4 U1 U2 U3 U4 V1 V2 V3 V4 W1 W2 W3 W4 Min. (mcd) 1100 1205 1310 1415 1520 1672 1824 1976 2130 2347 2564 2781 3000 3295 3590 3885 Max. (mcd) 1205 1310 1415 1520 1672 1824 1976 2130 2347 2564 2781 3000 3295 3590 3885 4180 Blue: C4SMK Bin Code Subbin Q1 Q0 Q2 Q3 Q4 R1 R0 R2 R3 R4 S1 S0 S2 S3 S4 T1 T0 T2 T3 T4 Min. (mcd) 390 430 470 510 550 605 660 715 770 852 934 1017 1100 1205 1310 1415 Max. (mcd) 430 470 510 550 605 660 715 770 852 934 1017 1100 1205 1310 1415 1520 Red: C4SMJ Bin Code Subbin Q1 Q0 Q2 Q3 Q4 R1 R0 R2 R3 R4 S1 S0 S2 S3 S4 T1 T0 T2 T3 T4 Min. (mcd) 390 430 470 510 550 605 660 715 770 852 934 1017 1100 1205 1310 1415 Max. (mcd) 430 470 510 550 605 660 715 770 852 934 1017 1100 1205 1310 1415 1520 Tolerance of measurement of luminous intensity is ±15% Color Bin Limit (IF = 20 mA) Red Bin Code RB Min.(nm) 619 Max.(nm) 624 Green Bin Code G7 G8 G9 Min.(nm) 520 525 530 Max.(nm) 525 530 535 Blue Bin Code B3 B4 B5 Min.(nm) 460 465 470 Max.(nm) 465 470 475 Tolerance of measurement of dominant wavelength is ±1 nm Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 3 CLD-CT1114.000 Order Code Table* C4SMK Luminous Intensity (mcd) Color Red Red Red Red Red Red Red Red Kit Number C4SMK-RJS-CR0U0BB1 C4SMK-RJS-CS24QBB1 C4SMK-RJS-CS44QBB1 C4SMK-RJS-CT24QBB1 C4SMK-RJS-CR0U0BB2 C4SMK-RJS-CS24QBB2 C4SMK-RJS-CS44QBB2 C4SMK-RJS-CT24QBB2 Min. 550 Max. 2130 Color Bin RB RB RB RB RB RB RB RB Dominant Wavelength Min. (nm) 619 619 619 619 619 619 619 619 Color Bin RB RB RB RB RB RB RB RB Max. (nm) 624 624 624 624 624 624 624 624 Package Bulk Bulk Bulk Bulk Ammo Ammo Ammo Ammo Any 4 consecutive sub-bins: S2 (852) - T3 (1415) Any 4 consecutive sub-bins: S4 (1017) - U1 (1672) Any 4 consecutive sub-bins: T2 (1205) - U3 (1976) 550 2130 Any 4 consecutive sub-bins: S2 (852) - T3 (1415) Any 4 consecutive sub-bins: S4 (1017) - U1 (1672) Any 4 consecutive sub-bins: T2 (1205) - U3 (1976) Luminous Intensity (mcd) Dominant Wavelength Color Bin G7 Min. (nm) 520 Color Bin G9 Max. (nm) 535 Color Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Green Kit Number C4SMK-GJS-CT0W0791 C4SMK-GJS-CU34Q7S1 C4SMK-GJS-CU34Q7T1 C4SMK-GJS-CU34Q8T1 C4SMK-GJS-CV14Q7S1 C4SMK-GJS-CV14Q7T1 C4SMK-GJS-CV14Q8T1 C4SMK-GJS-CV34Q7S1 C4SMK-GJS-CV34Q7T1 C4SMK-GJS-CV34Q8T1 C4SMK-GJS-CT0W0792 C4SMK-GJS-CU34Q7S2 C4SMK-GJS-CU34Q7T2 C4SMK-GJS-CU34Q8T2 C4SMK-GJS-CV14Q7S2 C4SMK-GJS-CV14Q7T2 C4SMK-GJS-CV14Q8T2 C4SMK-GJS-CV34Q7S1 C4SMK-GJS-CV34Q7T1 C4SMK-GJS-CV34Q8T1 Min. 1100 Max. 4180 Package Bulk Bulk Bulk Bulk Bulk Bulk Bulk Bulk Bulk Bulk Ammo Ammo Ammo Ammo Ammo Ammo Ammo Ammo Ammo Ammo Any 4 consecutive sub-bins:U3 (1824) - V4 (3000) Any 4 consecutive sub-bins: U3 (1824) - V4 (3000) Any 4 consecutive sub-bins: U3 (1824) - V4 (3000) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) 1100 4180 Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) G7 520 G9 535 Any 4 consecutive sub-bins:U3 (1824) - V4 (3000) Any 4 consecutive sub-bins: U3 (1824) - V4 (3000) Any 4 consecutive sub-bins: U3 (1824) - V4 (3000) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V1 (2130) - W2 (3590) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) Any 4 consecutive sub-bins:V3 (2564) - W4 (4180) Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G9 (535 nm) Any 1 color bin from G7 (520 nm) to G8 (530 nm) Any 1 color bin from G8 (525 nm) to G9 (535 nm) Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Order Code Table* Luminous Intensity (mcd) Color Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Blue Kit Number C4SMK-BJS-CQ0T0351 C4SMK-BJS-CQ34Q3S1 C4SMK-BJS-CQ34Q4T1 C4SMK-BJS-CR14Q3S1 C4SMK-BJS-CR14Q4T1 C4SMK-BJS-CR34Q3S1 C4SMK-BJS-CR34Q4T1 C4SMK-BJS-CS14Q3S1 C4SMK-BJS-CS14Q4T1 C4SMK-BJS-CQ0T0352 C4SMK-BJS-CQ34Q3S2 C4SMK-BJS-CQ34Q4T2 C4SMK-BJS-CR14Q3S2 C4SMK-BJS-CR14Q4T2 C4SMK-BJS-CR34Q3S2 C4SMK-BJS-CR34Q4T2 C4SMK-BJS-CS14Q3S2 C4SMK-BJS-CS14Q4T2 Min. 390 Max. 1520 Color Bin B3 Dominant Wavelength Min. (nm) 460 Color Bin B5 Max. (nm) 475 Package Bulk Bulk Bulk Bulk Bulk Bulk Bulk Bulk Bulk Ammo Ammo Ammo Ammo Ammo Ammo Ammo Ammo Ammo Any 4 consecutive sub-bins: Q3 (470) - R4 (770) Any 4 consecutive sub-bins: Q3 (470) - R4 (770) Any 4 consecutive sub-bins: R1 (550) - S2 (934) Any 4 consecutive sub-bins: R1 (550) - S2 (934) Any 4 consecutive sub-bins: R3 (660) - S4(1100) Any 4 consecutive sub-bins: R3 (660) - S4(1100) Any 4 consecutive sub-bins: S1 (770) - T2(1310) Any 4 consecutive sub-bins: S1 (770) - T2(1310) 390 1520 Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) B3 460 B5 475 Any 4 consecutive sub-bins: Q3 (470) - R4 (770) Any 4 consecutive sub-bins: Q3 (470) - R4 (770) Any 4 consecutive sub-bins: R1 (550) - S2 (934) Any 4 consecutive sub-bins: R1 (550) - S2 (934) Any 4 consecutive sub-bins: R3 (660) - S4(1100) Any 4 consecutive sub-bins: R3 (660) - S4(1100) Any 4 consecutive sub-bins: S1 (770) - T2(1310) Any 4 consecutive sub-bins: S1 (770) - T2(1310) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) Any 1 color bin from B3 (460 nm) to B5 (475 nm) Any 1 color bin from B4 (465 nm) to B5 (475 nm) C4SMJ Luminous Intensity (mcd) Color Red Red Red Red Red Red Red Red Kit Number C4SMJ-RJS-CQ0T0BB1 C4SMJ-RJS-CR34QBB1 C4SMJ-RJS-CS14QBB1 C4SMJ-RJS-CS34QBB1 C4SMJ-RJS-CQ0T0BB2 C4SMJ-RJS-CR34QBB2 C4SMJ-RJS-CS14QBB2 C4SMJ-RJS-CS34QBB2 Min. 390 Max. 1520 Color Bin RB RB RB RB RB RB RB RB Dominant Wavelength Min. (nm) 619 619 619 619 619 619 619 619 Color Bin RB RB RB RB RB RB RB RB Max. (nm) 624 624 624 624 624 624 624 624 Package Bulk Bulk Bulk Bulk Ammo Ammo Ammo Ammo Any 4 consecutive sub-bins: R3 (660) - S4 (1100) Any 4 consecutive sub-bins: S1 (770) - T2 (1310) Any 4 consecutive sub-bins: S3 (934) - T4 (1520) 390 1520 Any 4 consecutive sub-bins: R3 (660) - S4 (1100) Any 4 consecutive sub-bins: S1 (770) - T2 (1310) Any 4 consecutive sub-bins: S3 (934) - T4 (1520) Notes: 1. The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-sub-bin code and one color-bin code will be shipped on each reel. Selected single intensity-bin, single color-bin codes will be orderable in certain quantities. For example, any four consecutive sub-bins from V1 to W2 mean only one intensity bin with four sub-bins of the following brightness ranges (V1-V4, V2-W1, V3-W2) will be shipped by Cree. For example, any one-color bin from G7 to G9 means only one color bin (G7 or G8 or G9) will be shipped by Cree. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 5 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Graphs 100.0 80.0 60.0 40.0 20.0 0.0 IF (mA) (RELATIVE LUMINOUS INTENSITY) 5.0 4.0 3.0 Red Red Blue Green Blue 2.0 1.0 Green VF(V) 1.6 2.2 2.8 3.4 4.0 4.6 5.0 0.0 IF(mA) 0.0 15 30 45 60 75 90 FIG.1 FORWARD CURRENT VS. FORWARD VOLTAGE. Vr(V) -60 -50 -40 -30 -20 -10 0 FIG.2 RELATIVE LUMINOUS INTENSITY VS. FORWARD CURRENT 0 -10 -20 -30 -40 -50 Vr(V) -60 -50 -40 -30 -20 -10 0 0 -10 -20 -30 -40 -50 FIG.3a RED REVERSE CURRENT VS. REVERSE VOLTAGE. IF(mA) 100 80 60 40 20 Ir(uA) Ir(uA) FIG.3b BLUE & GREEN REVERSE CURRENT VS. REVERSE VOLTAGE. IF(mA) 50 40 30 20 10 20 40 60 80 100 0 FIG.4a RED MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=105 C) 0 Ta( C) 120 20 40 60 80 100 120 0 FIG.4b BLUE & GREEN MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=105 C) 0 Ta( C) (RELATIVE LUMINOUS INTENSITY) 100% 80% 60% Green C4SMK-BJS/GJS: (RELATIVE LUMINOUS INTENSITY) H-H V-V 0 10 1.0 20 30 40 50 C4SMK-RJS&C4SMJ-RJS: (RELATIVE LUMINOUS INTENSITY) H-H V-V 0 10 1.0 20 30 40 50 Blue Red 0.5 40% 20% 0% 300 400 500 600 700 800 WL(nm) 900 0 -90 -60 -30 0 0.5 60 70 80 90 1.0 0.5 60 70 80 0 -90 -60 -30 0 0.5 90 1.0 FIG.5 RELATIVE LUMINOUS INTENSITY VS. WAVELENGTH. FIG.6 RED & BLUE&GREEN FAR FIELD PATTERN The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 6 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Mechanical Dimensions All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. Notes RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 7 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Kit Number System Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 8 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Package Features: • • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water resistant, and they must be kept away from water and moisture. There are two types of packaging: Bulk Pack and Ammo Pack. Max 500 pcs per bulk and max 3000 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT QTY RANK JOWAXXXXX -XX-XXX PCS Iv Vf Hue X XX XX ( ( ( ) ) ) AXXXXXXXXXXX ANODE Label (anti-electrostatic bag) xxx xxx COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT QTY RANK JOWAXXXXX -XX-XXX PCS Iv Vf Hue X XX XX ( ( ( ) ) ) 20 bags/carton AXXXXXXXXXXX Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 9 CLD-CT1114.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
C4SMK-RJS-CS24QBB1 价格&库存
很抱歉,暂时无法提供与“C4SMK-RJS-CS24QBB1”相匹配的价格&库存,您可以联系我们找货
