C503C-WAS-CBBDA232
C503C-WAS-CBBDA232
    WOLFSPEED
    插件
    LED COOL WHITE CLEAR 5MM RND T/H
C503C-WAS-CBBDA232 数据手册
Cree® 5-mm Round LED C503C-WAS/WAN Data Sheet Round LEDs offer superior light output for excellent readability in sunlight and dependable performance. They provide extremely stable light output over long periods of time. These lamps are made with an advanced optical-grade epoxy offering superior high-temperature and high-moisture-resistance performance in lighting and illumination applications. FEATURES • • • • • • Size (mm): 5 Color Temperatures (K): » Cool White: Min. (4600) / Typical (9000) Luminous Intensity (mcd) » C503C-WAS/WAN (16800-39500) Viewing Angle: 15 degree Lead-Free RoHS-Compliant APPLICATIONS • • • • Torch Light Strip Channel Letter Retail Display Lighting 1 LD-CT1098.00 Data Sheet: C Subject to change without notice. www.cree.com/ledlamps 1 Absolute Maximum Ratings (TA = 25°C) Items Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Lead Soldering Temperature Note Symbol IF IFP VR PD Topr Tstg Tsol Absolute Maximum Rating 30 100 5 120 -40 ~ +95 -40 ~ +100 Unit mA mA V mW °C °C Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: Pulse width ≤0.1 msec, duty ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Forward Voltage Reverse Current Luminous Intensity Chromaticity Coordinates 50% Power Angle WAS/WAN WAS/WAN WAS/WAN WAS/WAN WAS/WAN Symbol VF IR IV x y 2θ½ Condition IF = 20 mA VR = 5 V IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA deg Unit V μA mcd 16800 24000 0.2895 0.2905 15 Minimum Typical 3.2 Maximum 4.0 100 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Intensity Bin Limit (IF = 20 mA) Cool White(C503C-WAS/WAN) Bin Code Ba Bb Ca Cb Da Min. (mcd) 16800 20150 23500 28200 32900 Max. (mcd) 20150 23500 28200 32900 39500 VF Bin Limit (IF = 20 mA) Cool White (C503C-WAS/WAN) Bin Code 27 28 29 2a 2b 2c Min. (V) 2.8 3.0 3.2 3.4 3.6 3.8 Max. (V) 3.0 3.2 3.4 3.6 3.8 4.0 Tolerance of measurement of luminous intensity is ±15%. Color Bin Limit (IF = 20 mA) Bin Code Subbin x 0.2545 Wa 0.2633 0.2545 0.2450 0.2633 Wb 0.2720 0.2640 0.2545 0.2545 Wc 0.2640 0.2720 0.2633 0.2633 Wd 0.2720 0.2800 0.2720 0.2640 We 0.2735 0.2808 0.2720 0.2720 Wf 0.2808 0.2880 0.2800 0.2735 Wg 0.2830 0.2895 0.2808 0.2808 Wh 0.2895 0.2960 0.2880 y 0.2480 0.2410 0.2245 0.2290 0.2410 0.2340 0.2200 0.2245 0.2480 0.2670 0.2575 0.2410 0.2410 0.2575 0.2480 0.2340 0.2670 0.2860 0.2740 0.2575 0.2575 0.2740 0.2620 0.2480 0.2860 0.3050 0.2905 0.2740 0.2740 0.2905 0.2760 0.2620 Ws W4 Wq Wp Wn W3 Wk Wj Bin Code Subbin Tolerance of measurement of VF is ±0.05 V. x 0.2830 0.2950 0.2998 0.2895 0.2895 0.2998 0.3045 0.2960 0.2950 y 0.3050 0.3210 0.3028 0.2905 0.2905 0.3028 0.2865 0.2760 0.3210 0.3370 0.3150 0.3028 0.3028 0.3150 0.2970 0.2865 0.3370 0.3485 0.3270 0.3150 0.3150 0.3270 0.3075 0.2970 0.3485 0.3600 0.3390 0.3270 0.3270 0.3390 0.3180 0.3075 Bin Code Subbin x 0.3300 y 0.3600 0.3725 0.3535 0.3390 0.3390 0.3535 0.3345 0.3180 0.3725 0.3850 0.3680 0.3535 0.3535 0.3680 0.3510 0.3345 Wt 0.3455 0.3443 0.3300 0.3300 Wu 0.3443 0.3430 0.3300 0.3455 W1 W5 Wm 0.3070 0.3100 0.2998 0.2998 0.3100 0.3130 0.3045 0.3070 0.3185 0.3200 0.3100 0.3100 0.3200 0.3215 0.3130 0.3185 Wv 0.3610 0.3585 0.3443 0.3443 Ww 0.3585 0.3560 0.3430 Tolerance of measurement of the color coordinates is ±0.01. W2 Wr 0.3300 0.3300 0.3200 0.3200 0.3300 0.3300 0.3215 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 3 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps CIE Chromaticity Diagram 0 .3 9 0 0 00 K 60 50 70 0 .3 5 0 0 K 00 80 00 W W W p q W rW s 4 t u W K K 00 W y 0 .2 7 0 0 n 3 10 W W c b W g W k W e d h W 2 W f 0 .1 9 0 0 0 .2 3 0 0 0 .2 7 0 0 W 0 .2 3 0 0 W aW 1 0 .3 1 0 0 x W 0 .3 1 0 0 0K 90 W W j W 00 m W W 0 .3 5 0 0 W 5 00 W K v w 0 .3 9 0 0 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Order Code Table* Color Cool White Cool White Cool White Cool White Cool White Cool White Cool White Cool White Cool White Cool White Cool White Cool White Kit Number C503C-WAS-CBaDa151 C503C-WAS-CBbDa231 C503C-WAS-CCaDa231 C503C-WAN-CBaDa151 C503C-WAN-CBbDa231 C503C-WAN-CCaDa231 C503C-WAS-CBaDa152 C503C-WAS-CBbDa232 C503C-WAS-CCaDa232 C503C-WAN-CBaDa152 C503C-WAN-CBbDa232 C503C-WAN-CCaDa232 Viewing Angle 15 15 15 15 15 15 15 15 15 15 15 15 Luminous Intensity (mcd) Min. 16800 20150 23500 16800 20150 23500 16800 20150 23500 16800 20150 23500 Max. 39500 39500 39500 39500 39500 39500 39500 39500 39500 39500 39500 39500 Color Bin Code W1,W2,W3,W4,W5 W2,W3 W2,W3 W1,W2,W3,W4,W5 W2,W3 W2,W3 W1,W2,W3,W4,W5 W2,W3 W2,W3 W1,W2,W3,W4,W5 W2,W3 W2,W3 Package Bulk Bulk Bulk Bulk Bulk Bulk Ammo Ammo Ammo Ammo Ammo Ammo Standoff Yes Yes Yes No No No Yes Yes Yes No No No Notes: 1. The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped in each bulk or ammo pack. And single intensity-bin code and single color-bin codes will not be orderable. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 5 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Graphs                                                                                                 The above data are collected from statistical figures which do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 6 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Mechanical Dimensions All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max. C503C-WAS: C503C-WAN: Notes RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 7 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Kit Number System Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 8 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Package Features: • • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water resistant, and they must be kept away from water and moisture. The Bulk or Ammo Pack types of packaging. Max 500 pcs per bulk and Max 2500 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT QTY RANK JOWAXXXXX -XX-XXX PCS Iv Vf Hue X XX XX ( ( ( ) ) ) AXXXXXXXXXXX ANODE Label (anti-electrostatic bag) xxx xxx COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT QTY RANK JOWAXXXXX -XX-XXX PCS Iv Vf Hue X XX XX ( ( ( ) ) ) 20 bags/carton AXXXXXXXXXXX Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 9 CLD-CT1098.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
C503C-WAS-CBBDA232 价格&库存
很抱歉,暂时无法提供与“C503C-WAS-CBBDA232”相匹配的价格&库存,您可以联系我们找货
