PD4436
PD4436
    AMSOSRAM(艾迈斯半导体)
    插件
    DISPLAY PROGR 4CHAR .42" RED
PD4436 数据手册
PD2435/PD3535/PD4435 RED PD2436/PD3536/PD4436 BRIGHT GREEN PD2437/PD3537/PD4437 HER 0.200" Character, PD2435/6/7 0.270" Character, PD3535/6/7 0.45" Character, PD4435/6/7 4-Character 5 x 7 Dot Matrix Alphanumeric Programmable Display™ with Built-in CMOS Control Functions PD243X FEATURES • Four Dot Matrix Characters in High Efficiency Red, Red, and Bright Green – PD2435/6/7, 0.200" High – PD3535/6/7, 0.270" High – PD4435/6/7, 0.45" High • Built-in Memory, Decoders, Multiplexer and Drivers • Wide Viewing Angle, X Axis ±55°, Y Axis ±65° • Categorized for Luminous Intensity • 128 Character ASCII Format (Upper and Lower Case Characters) • 8 Bit Bidirectional Data BUS • READ/WRITE Capability • Dual In-Line Package Configuration, 0.600" Wide, 0.100" Pin Centers • End-Stackable Package PD353X PD443X • • • • • • Internal or External Clock Built-in Character Generator ROM TTL Compatible Easily Cascaded for Multidisplay Operation Less CPU Time Required Software Controlled Features: – Programmable Highlight Attribute (Blinking, Non-Blinking) – Asynchronous Memory Clear Function – Lamp Test – Display Blank Function – Single or Multiple Character Blinking Function – Programmable Intensity Three Brightness Levels • Extended Operating Temperature Range: – PD243X, PD353X: –40°C to +85°C – PD443X: –40°C to +70°C  2001 OSRAM Opto Semiconductors Inc.• San Jose, CA www.infineon.com/opto • 408-456-4000 OSRAM Opto Semiconductors GmbH & Co. OHG • Regensburg, Germany www.osram-os.com • +49-941-202-7178 1 July 5, 2001-14 DESCRIPTION These Programmable Displays are four digit display system modules. The characters are 0.20" by 0.14" (PD243X), 0.27" by 0.20" (PD353X), and 0.45" by 0.27" (PD443X) 5 x 7 dot matrix arrays constructed with the latest solid state technology in light emitting diodes. Driving and controlling the LED arrays is a silicon gate CMOS integrated circuit. This integrated circuit provides all necessary LED drivers and complete multiplexing control logic. Additionally, the IC has the necessary ROM to decode 128 ASCII alphanumeric characters and enough RAM to store the display’s complete four digit ASCII message with special attributes. These attributes, all software programmable at the user’s discretion, include a lamp test, brightness control, displaying cursors, alternating cursors and characters, and flashing cursors or characters. The CMOS IC also incorporates special interface control circuitry to allow the user to control the module as a fully supported microprocessor peripheral. The module, under internal or external clock control, has asynchronous read, write, and memory clear over an eight bit parallel, TTL compatible, bi-directional data bus. Each module is fully encapsulated within a package 1.0" x 0.7" x 0.2" (PD253X), 1.4" x 0.72" x 0.285" (PD353X), and 1.5" x 0.82" x 0.285" (PD443X). The standard 20 pin DIP construction with two rows spaced at 0.6" on 0.1" centers is wave solderable. See the end of this data sheet or refer to Appnotes 18, 19, 22, and 23 for further details on handling and assembling OSRAM Programmable Displays. Dimensions in Inches (mm) 1.000 max. (25.40) .140 (3.56) .250 (6.35) .200 (5.08) .700 (17.78) .200 (5.08) at seating plane and centered on package .600 (15.24) .125 (3.18) Pin 1 location Pin 1 Indicator PD243X OSRAM YYWW EIA date code Luminous Intensity Code Z .160 ±.020 (4.06 ±.51) .050 (1.27) .100 typ. (2.54) .070 ±.004 typ. (1.78 ±.10) .018 x .012 typ. (.46 x .31) Tolerance: .XXX=0.02 (.51) 1.400 max. (35.56) .175 (4.45) .350 (8.89) typ. .200 (5.08) typ. .285 (7.24) .270 typ. (6.86) .720 max. (18.29) .450 (11.43) at seating plane and centered on package .600 typ. (15.24) Pin 1 Identifier and ESD warning Part No. EIA date code Luminous Intensity PD3537 Code OSRAM YYWW Z .250 (6.35) .018 x .012 typ. (.46 x .31) .100 (2.54) typ. .160 ±.020 (4.06 ±.51) Tolerance: .XXX=0.010 (.25) unless max. .050 (1.27) 1.500 max. (38.1) .375 .270 (9.53) (6.86) typ. typ. .285 (7.24) .45 ±.010 (11.43) .600 (15.24) at seating plane and centered on package .600 typ. (15.24) .820 max. (20.83) Pin 1 Indicator Part No. EIA date code Luminous Intensity Code PD4437 OSRAM YYWW Z .160 ±.020 (4.06 ±.51) .300 (7.62) .018 x .012 ±.002 typ. (.46 x .31 ±.05) .100 (2.54) typ. Tolerance: .XXX=0.020 (.51)  2001 OSRAM Opto Semiconductors Inc.• San Jose, CA www.infineon.com/opto • 408-456-4000 OSRAM Opto Semiconductors GmbH & Co. OHG • Regensburg, Germany www.osram-os.com • +49-941-202-7178 PD2535/6/7, PD3535/6/7, PD4435/6/7 2 July 5, 2001-14 Maximum Ratings DC Supply Voltage.........................................–0.5 V to +7.0 Vdc Input Voltage Relative to GND (all inputs)...............................–0.5 V to VCC +0.5 Vdc Operating Temperature PD243X/353X................................................. –40 °C to +85°C PD443X .......................................................... –40 °C to +70°C Storage Temperature....................................... –40°C to +100°C Maximum Solder Temperature, .063" (1.59 mm) below Seating Plane, t
PD4436 价格&库存
很抱歉,暂时无法提供与“PD4436”相匹配的价格&库存,您可以联系我们找货
