74VHC541-Q100;
74VHCT541-Q100
Octal buffer/line driver; 3-state
Rev. 1 — 4 June 2013
Product data sheet
1. General description
The 74VHC541-Q100; 74VHCT541-Q100 are high-speed Si-gate CMOS devices.
The 74VHC541-Q100; 74VHCT541-Q100 are octal non-inverting buffer/line drivers with
3-state bus compatible outputs.
The output enable inputs OE0 and OE1 control the 3-state outputs.
A HIGH on OEn causes the outputs to assume a high-impedance OFF-state.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Balanced propagation delays
All inputs have a Schmitt-trigger action
Inputs accept voltages higher than VCC
The 74VHC541-Q100 operates with CMOS input level
The 74VHCT541-Q100 operates with TTL input level
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
Nexperia
3. Ordering information
Table 1.
Type number
Package
74VHC541D-Q100
Temperature range
Name
Description
Version
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
40 C to +125 C
TSSOP20
plastic thin shrink small outline package; 20 leads; SOT360-1
body width 4.4 mm
40 C to +125 C
DHVQFN20 plastic dual-in-line compatible thermal enhanced
very thin quad flat package; no leads; 20
terminals; body 2.5 4.5 0.85 mm
74VHCT541D-Q100
74VHC541PW-Q100
74VHCT541PW-Q100
74VHC541BQ-Q100
74VHCT541BQ-Q100
SOT764-1
4. Functional diagram
2
3
4
5
6
A0
Y0
A1
Y1
A2
Y2
A3
Y3
A4
Y4
18
17
16
15
14
1
19
7
8
9
A5
A6
A7
Y5
Y6
Y7
13
12
11
OE0
1
19
Fig 1.
OE1
Logic symbol
74VHC_VHCT541_Q100
Product data sheet
EN
2
18
3
17
4
16
5
15
6
14
7
13
8
12
9
11
mna179
mna180
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 17
Nexperia
5. Pinning information
5.1 Pinning
2(
WHUPLQDO
LQGH[DUHD
9+&4
9+&74
9&&
9+&4
9+&74
2(
很抱歉,暂时无法提供与“74VHC541D-Q100J”相匹配的价格&库存,您可以联系我们找货
