BAS321Z
BAS321Z
    NEXPERIA(安世)
    SOD-323
    二极管配置:独立式 直流反向耐压(Vr):200V 平均整流电流(Io):250mA 正向压降(Vf):1.25V@200mA 反向电流(Ir):100nA@200V
BAS321Z 数据手册
BAS321 General purpose diode 18 June 2019 Product data sheet 1. General description General purpose diode fabricated in planar technology and encapsulated in a very small plastic SOD323 (SC76) package. 2. Features and benefits • • • • • • • Small plastic SMD package Switching speed: max. 50 ns General application Continuous reverse voltage: max. 200 V Repetitive peak reverse voltage: max. 250 V Repetitive peak forward current: max. 625 mA AEC-Q101 qualified 3. Applications • General purpose switching in surface mounted circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions IF forward current VR reverse voltage Ptot total power dissipation Tamb = 25 °C VF forward voltage IF = 200 mA; Tj = 25 °C [1] [1] [1] Min Typ Max Unit - - 250 mA - - 200 V - - 300 mW - - 1.25 V Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 2 K A Cathode Simplified outline 1 Graphic symbol 2 K A 001aaa020 Anode SOD323 BAS321 Nexperia General purpose diode 6. Ordering information Table 3. Ordering information Type number Package BAS321 Name Description Version SOD323 plastic surface-mounted package; 2 leads SOD323 7. Marking Table 4. Marking codes Type number Marking code BAS321 A7 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM Conditions Min Max Unit repetitive peak reverse voltage - 250 V VR reverse voltage - 200 V IF forward current IFSM non-repetitive peak forward current - 250 mA tp = 10 ms; Tj(init) = 25 °C; square wave [1] - 1.7 A tp = 1 µs; Tj(init) = 25 °C; square wave - 9 A tp = 100 µs; Tj(init) = 25 °C; square wave - 3 A - 625 mA - 300 mW IFRM repetitive peak forward current tp ≤ 0.5 ms; δ ≤ 0.25 Ptot total power dissipation Tamb = 25 °C Tj junction temperature - 150 °C Tstg storage temperature -65 150 °C [1] [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-a) thermal resistance from junction to ambient [1] - - 366 K/W Rth(j-sp) thermal resistance from junction to solder point [2] - - 130 K/W [1] [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. Soldering point of cathode tab. BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 2/9 BAS321 Nexperia General purpose diode 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit VF IF = 100 mA; Tj = 25 °C - - 1 V IF = 200 mA; Tj = 25 °C - - 1.25 V VR = 200 V; Tj = 25 °C - - 100 nA forward voltage IR reverse current VR = 200 V; Tj = 150 °C - - 100 µA Cd diode capacitance VR = 0 V; f = 1 MHz; Tj = 25 °C - - 2 pF trr reverse recovery time IF = 30 mA; IR = 30 mA; RL = 100 Ω; IR(meas) = 3 mA; Tj = 25 °C - - 50 ns mbk927 300 IF (mA) IF (mA) 200 400 100 200 0 0 50 100 0 150 200 Tamb (°C) Maximum permissible continuous forward current as a function of ambient temperature Fig. 2. mbg703 102 (1) 0 1 (2) (3) VF (V) 2 (1) Tj = 150 °C; typical values (2) Tj = 25 °C; typical values (3) Tj = 25 °C; maximum values Device mounted on an FR4 PCB Fig. 1. mbg384 600 Forward current as a function of forward voltage mbg381 102 IR (µA) IFSM (A) 10 10 (1) 1 (2) 1 10- 1 10- 1 1 10 102 103 tp (µs) 10- 2 104 Based on square wave currents Tj = 25 °C prior to surge Fig. 3. Product data sheet 100 Tj (°C) 200 (1) VR = VRmax; maximum values (2) VR = VRmax; typical values Maximum permissible non-repetitive peak forward current as a function of pulse duration BAS321 0 Fig. 4. Reverse current as a function of junction temperature All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 3/9 BAS321 Nexperia General purpose diode mbg447 1.0 mbk926 300 Cd (pF) VR (V) 0.8 200 0.6 100 0.4 0.2 0 2 4 6 VR (V) 0 8 f = 1 MHz Tj = 25 °C. Fig. 5. Fig. 6. Diode capacitance as a function of reverse voltage; typical values. 0 50 100 150 200 Tamb (°C) Maximum permissible continuous reverse voltage as a function of the ambient temperature 11. Test information tr D.U.T. RS = 50 Ω V = VR + IF × RS IF tp 10 % t + IF SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω mga881 VR (1) 90 % input signal output signal (1) IR = 3 mA Fig. 7. Reverse recovery time test circuit and waveforms Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 4/9 BAS321 Nexperia General purpose diode 12. Package outline Plastic surface-mounted package; 2 leads SOD323 A D E X v HD 1 M A Q 2 bp A A1 (1) c detail X 0 1 Lp 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E HD Lp Q v mm 1.1 0.8 0.05 0.40 0.25 0.25 0.10 1.8 1.6 1.35 1.15 2.7 2.3 0.45 0.15 0.25 0.15 0.2 Note 1. The marking bar indicates the cathode OUTLINE VERSION REFERENCES IEC SOD323 Fig. 8. JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-12-17 06-03-16 SC-76 Package outline SOD323 BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 5/9 BAS321 Nexperia General purpose diode 13. Soldering 3.05 2.1 solder lands solder resist 1.65 0.95 0.5 (2×) 0.6 (2×) solder paste occupied area 2.2 Dimensions in mm 0.5 (2×) 0.6 (2×) Fig. 9. sod323_fr Reflow soldering footprint for SOD323 5 2.9 1.5 (2×) solder lands solder resist occupied area 1.2 2.75 (2×) Dimensions in mm preferred transport direction during soldering sod323_fw Fig. 10. Wave soldering footprint for SOD323 BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 6/9 BAS321 Nexperia General purpose diode 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BAS321 v.3 20190618 Product data sheet - BAS321 v.2 Modifications: • • • Features and benefits and Test information: AEC-Q101 qualification added The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. BAS321 v.2 20040126 Product data sheet - BAS321 v.1 BAS321 v.1 19990209 Product data sheet - - BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 7/9 BAS321 Nexperia General purpose diode equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 8/9 BAS321 Nexperia General purpose diode Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 2 10. Characteristics............................................................ 3 11. Test information.......................................................... 4 12. Package outline.......................................................... 5 13. Soldering..................................................................... 6 14. Revision history..........................................................7 15. Legal information........................................................8 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 June 2019 BAS321 Product data sheet All information provided in this document is subject to legal disclaimers. 18 June 2019 © Nexperia B.V. 2019. All rights reserved 9/9
BAS321Z
物料型号:BAS321
器件简介: - 该器件是一款通用二极管,采用平面工艺制造,并封装在非常小的塑料SOD323 (SC76)封装中。
引脚分配: - 引脚1(K)代表阴极(Cathode) - 引脚2(A)代表阳极(Anode)
参数特性: - 正向电流(IF):最大625毫安 - 反向电压(VR):最大200伏 - 总功耗(Ptot):在环境温度25°C时,最大300毫瓦 - 正向电压(VF):在电流200毫安和环境温度25°C时,典型值为1.25伏
功能详解: - 该二极管适用于表面贴装电路中的通用开关应用,并且通过了AEC-Q101认证,适合汽车应用。
应用信息: - 用于表面贴装电路中的通用开关。
封装信息: - SOD323塑料表面贴装封装,2个引脚。
其他信息: - 该产品符合汽车电子委员会(AEC)标准Q101,适用于汽车应用。 - 产品数据表还包含了限制值、热特性、特性测试信息、封装轮廓、焊接信息、修订历史和法律信息等详细内容。
BAS321Z 价格&库存
很抱歉,暂时无法提供与“BAS321Z”相匹配的价格&库存,您可以联系我们找货
BAS321Z
    • 1+0.19991
    • 10+0.15650
    • 30+0.13241
    • 100+0.11794
    • 500+0.10541
    • 1000+0.09861
    BAS321Z
