BAS70 series;
1PS7xSB70 series
General-purpose Schottky diodes
Rev. 09 — 13 January 2010
Product data sheet
1. Product profile
1.1 General description
General-purpose Schottky diodes in small Surface-Mounted Device (SMD) plastic
packages.
Table 1.
Product overview
Type number
Package
Configuration
Nexperia
JEITA
1PS76SB70
SOD323
SC-76
single diode
1PS79SB70
SOD523
SC-79
single diode
BAS70
SOT23
single diode
BAS70H
SOD123F
single diode
BAS70L
SOD882
single diode
BAS70W
SOT323
SC-70
single diode
BAS70-04
SOT23
dual series
BAS70-04W
SOT323
SC-70
dual series
BAS70-05
SOT23
dual common cathode
BAS70-05W
SOT323
SC-70
dual common cathode
BAS70-06
SOT23
dual common anode
BAS70-06W
SOT323
SC-70
dual common anode
BAS70-07
SOT143B
dual isolated
BAS70-07S
SOT363
SC-88
dual isolated
BAS70-07V
SOT666
dual isolated
BAS70VV
SOT666
triple isolated
BAS70XY
SOT363
SC-88
quadruple; 2 series
1.2 Features
High switching speed
High breakdown voltage
Low leakage current
Low capacitance
1.3 Applications
Ultra high-speed switching
Voltage clamping
BAS70 series; 1PS7xSB70 series
Nexperia
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
70
mA
Per diode
forward current
IF
VF
forward voltage
VR
reverse voltage
[1]
[1]
IF = 1 mA
410
mV
70
V
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
2. Pinning information
Table 3.
Pin
Pinning
Description
Simplified outline
Symbol
BAS70H; 1PS76SB70; 1PS79SB70
1
cathode
2
anode
[1]
1
1
2
2
sym001
001aab540
BAS70L
1
cathode
2
anode
[1]
1
1
2
2
sym001
Transparent
top view
BAS70; BAS70W
1
anode
2
not connected
3
cathode
3
3
2
n.c.
1
006aaa436
1
2
006aaa144
BAS70-04; BAS70-04W
1
anode (diode 1)
2
cathode (diode 2)
3
cathode (diode 1),
anode (diode 2)
3
3
1
2
006aaa437
1
2
006aaa144
BAS70_1PS7XSB70_SER_9
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 20
Nexperia
Table 3.
Pin
Pinning …continued
Description
Simplified outline
Symbol
BAS70-05; BAS70-05W
1
anode (diode 1)
2
anode (diode 2)
3
cathode (diode 1),
cathode (diode 2)
3
3
1
2
006aaa438
1
2
006aaa144
BAS70-06; BAS70-06W
1
cathode (diode 1)
2
cathode (diode 2)
3
anode (diode 1),
anode (diode 2)
3
3
1
2
006aaa439
1
2
006aaa144
BAS70-07
1
cathode (diode 1)
2
cathode (diode 2)
3
anode (diode 2)
4
anode (diode 1)
4
1
3
4
2
1
3
2
006aaa434
BAS70-07S; BAS70-07V
1
anode (diode 1)
2
not connected
3
cathode (diode 2)
4
anode (diode 2)
5
not connected
6
cathode (diode 1)
6
5
4
1
2
3
6
5
4
1
2
3
006aaa440
001aab555
BAS70VV
1
anode (diode 1)
2
anode (diode 2)
3
anode (diode 3)
4
cathode (diode 3)
5
cathode (diode 2)
6
cathode (diode 1)
1
5
2
4
6
5
1
2
4
3
sym046
3
Product data sheet
6
3 of 20
Nexperia
Table 3.
Pinning …continued
Pin
Description
Simplified outline
Symbol
BAS70XY
1
anode (diode 1)
2
cathode (diode 2)
3
anode (diode 3),
cathode (diode 4)
4
anode (diode 4)
5
cathode (diode 3)
6
cathode (diode 1),
anode (diode 2)
[1]
6
5
4
1
2
3
6
5
4
1
2
3
006aaa256
The marking bar indicates the cathode.
3. Ordering information
Table 4.
Type number
1PS76SB70
Package
Name
Description
Version
SC-76
plastic surface-mounted package; 2 leads
SOD323
1PS79SB70
SC-79
SOD523
BAS70
plastic surface-mounted package; 3 leads
SOT23
BAS70H
SOD123F
BAS70L
leadless ultra small plastic package; 2 terminals;
body 1.0 × 0.6 × 0.5 mm
SOD882
BAS70W
SC-70
SOT323
BAS70-04
SOT23
BAS70-04W
SC-70
SOT323
BAS70-05
SOT23
BAS70-05W
SC-70
SOT323
BAS70-06
SOT23
BAS70-06W
SC-70
SOT323
BAS70-07
plastic surface-mounted package; 4 leads
SOT143B
BAS70-07S
SC-88
plastic surface-mounted package; 6 leads
SOT363
BAS70-07V
SOT666
BAS70VV
SOT666
BAS70XY
SC-88
SOT363
Product data sheet
4 of 20
Nexperia
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
Type number
Marking code[1]
1PS76SB70
S2
BAS70-05W
75*
1PS79SB70
G
BAS70-06
76*
BAS70
73*
BAS70-06W
76*
BAS70H
AH
BAS70-07
77*
BAS70L
S8
BAS70-07S
77*
BAS70W
73*
BAS70-07V
77
BAS70-04
74*
BAS70VV
N1
BAS70-04W
74*
BAS70XY
70*
BAS70-05
75*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
70
V
70
mA
70
mA
100
mA
Per diode
VR
reverse voltage
IF
forward current
IFRM
repetitive peak forward
current
tp ≤ 1 s; δ ≤ 0.5
IFSM
non-repetitive peak forward
current
tp ≤ 10 ms
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Tj = 25 °C prior to surge.
Product data sheet
[1]
5 of 20
Nexperia
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
SOT23
500
K/W
SOT143B
500
K/W
Per device
Rth(j-a)
thermal resistance from
junction to ambient
in free air
[1]
SOT363 (BAS70-07S)
416
K/W
SOT666 (BAS70VV)
[2]
700
K/W
SOT666 (BAS70-07V)
[2]
416
K/W
SOD123F
[2]
330
K/W
SOD323
450
K/W
SOD523
[2]
450
K/W
SOD882
[2]
500
K/W
625
K/W
260
K/W
SOT323
Rth(j-sp)
junction to solder point
[3]
SOT363 (BAS70XY)
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Reflow soldering is the only recommended soldering method.
[3]
Soldering point at pins 2, 3, 5 and 6.
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF = 1 mA
410
mV
IF = 10 mA
750
mV
IF = 15 mA
1
V
VR = 50 V
100
nA
VR = 70 V
10
μA
VR = 0 V; f = 1 MHz
2
pF
Per diode
VF
IR
Cd
[1]
[1]
forward voltage
reverse current
diode capacitance
Product data sheet
6 of 20
Nexperia
mra803
102
IF
(mA)
mra805
102
IR
(μA)
(1)
10
10
(2)
1
1
10−1
10−1
10−2
(1)
10−2
(2)
(3)
(4)
0.2
0.4
0.6
0.8
1
10−3
60
80
VR (V)
VF (V)
(1) Tamb = 125 °C
(1) Tamb = 125 °C
(2) Tamb = 85 °C
(2) Tamb = 85 °C
(3) Tamb = 25 °C
(3) Tamb = 25 °C
(4) Tamb = −40 °C
Fig 1.
Forward current as a function of forward
voltage; typical values
Fig 2.
mra802
103
Reverse current as a function of reverse
mra804
2
Cd
(pF)
rdif
(Ω)
1.5
102
1
10
0.5
1
10−1
1
10
IF (mA)
80
Tamb = 25 °C; f = 1 MHz
Differential forward resistance as a function of
forward current; typical values
Fig 4.
Diode capacitance as a function of reverse
Product data sheet
40
VR (V)
f = 10 kHz
Fig 3.
7 of 20
Nexperia
8. Package outline
1.35
1.15
0.45
0.15
1
2.7
2.3
0.85
0.75
1.1
0.8
1
1.65 1.25
1.55 1.15
1.8
1.6
2
2
0.40
0.25
0.25
0.10
0.34
0.26
Dimensions in mm
Fig 5.
0.65
0.58
03-12-17
Package outline SOD323 (SC-76)
3.0
2.8
0.17
0.11
Dimensions in mm
Fig 6.
02-12-13
Package outline SOD523 (SC-79)
1.7
1.5
1.1
0.9
1.2
1.0
1
3
0.55
0.35
0.45
0.15
2.5 1.4
2.1 1.2
3.6
3.4
1
2
0.48
0.38
1.9
2
0.15
0.09
Dimensions in mm
Fig 7.
2.7
2.5
04-11-04
Package outline SOT23 (TO-236AB)
0.70
0.55
Dimensions in mm
Fig 8.
04-11-29
Package outline SOD123F
2.2
1.8
0.50
0.46
0.62
0.55
0.25
0.10
1.1
0.8
0.45
0.15
3
2
0.30
0.22
0.65
0.30
0.22
2.2 1.35
2.0 1.15
1
0.55
0.47
1
Package outline SOD882
0.4
0.3
0.25
0.10
1.3
03-04-17
Dimensions in mm
04-11-04
Fig 10. Package outline SOT323 (SC-70)
Product data sheet
2
cathode marking on top side
Dimensions in mm
Fig 9.
1.02
0.95
8 of 20
Nexperia
3.0
2.8
2.2
1.8
1.1
0.9
1.9
6
4
2.5
2.1
1.1
0.8
5
4
2
3
0.45
0.15
3
0.45
0.15
1.4
1.2
1
2.2 1.35
2.0 1.15
pin 1
index
2
0.88
0.78
1
0.48
0.38
0.15
0.09
0.25
0.10
0.3
0.2
0.65
1.3
1.7
Dimensions in mm
04-11-16
Fig 11. Package outline SOT143B
Dimensions in mm
06-03-16
Fig 12. Package outline SOT363 (SC-88)
1.7
1.5
6
0.6
0.5
5
4
0.3
0.1
1.7
1.5
1.3
1.1
pin 1 index
1
2
3
0.27
0.17
0.5
0.18
0.08
1
Dimensions in mm
04-11-08
Fig 13. Package outline SOT666
Product data sheet
9 of 20
Nexperia
9. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number Package
Description
Packing quantity
3000 4000 8000 10000
1PS76SB70
SOD323
4 mm pitch, 8 mm tape and reel
-115
-135
1PS79SB70
SOD523
2 mm pitch, 8 mm tape and reel
-315
-115
-135
-215
-235
BAS70
SOT23
BAS70H
SOD123F 4 mm pitch, 8 mm tape and reel
-115
-135
BAS70L
SOD882
-315
BAS70W
SOT323
-115
-135
BAS70-04
SOT23
-215
-235
BAS70-04W
SOT323
-115
-135
BAS70-05
SOT23
-215
-235
BAS70-05W
SOT323
-115
-135
BAS70-06
SOT23
-215
-235
BAS70-06W
SOT323
-115
-135
BAS70-07
SOT143B 4 mm pitch, 8 mm tape and reel
-215
-235
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
-135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
-315
-115
-315
BAS70-07S
BAS70-07V
BAS70VV
SOT363
SOT666
SOT666
BAS70XY
SOT363
-115
[2]
-115
-135
[3]
-125
-165
[1]
For further information and the availability of packing methods, see Section 13.
[2]
T1: normal taping
[3]
T2: reverse taping
Product data sheet
10 of 20
Nexperia
10. Soldering
3.05
2.80
2.10
1.60
solder lands
solder resist
1.65
0.95
0.50
0.60
occupied area
solder paste
0.50
(2×)
msa433
Dimensions in mm
Fig 14. Reflow soldering footprint SOD323 (SC-76)
5.00
4.40
1.40
solder lands
solder resist
occupied area
2.75 1.20
msa415
preferred transport direction during soldering
Dimensions in mm
Fig 15. Wave soldering footprint SOD323 (SC-76)
2.15
0.50 0.60
1.20
solder lands
solder paste
0.30
0.40
solder resist
occupied area
1.80
1.90
mgs343
Dimensions in mm
Fig 16. Reflow soldering footprint SOD523 (SC-79)
Product data sheet
11 of 20
Nexperia
2.90
2.50
solder lands
solder resist
2
0.85
1
2.70
1.30
3.00
0.85
3
occupied area
solder paste
0.60
(3x)
0.50 (3x)
0.60 (3x)
1.00
3.30
MSA439
Dimensions in mm
Fig 17. Reflow soldering footprint SOT23 (TO-236AB)
3.40
1.20 (2x)
solder lands
solder resist
occupied area
2
1
4.60 4.00 1.20
3
2.80
4.50
MSA427
Dimensions in mm
Fig 18. Wave soldering footprint SOT23 (TO-236AB)
Product data sheet
12 of 20
Nexperia
4.4
4
2.9
1.6
solder lands
solder resist
2.1 1.6
1.1 1.2
solder paste
occupied area
1.1
(2×)
Dimensions in mm
Fig 19. Reflow soldering footprint SOD123F
1.30
R = 0.05 (8×)
0.30
0.60 0.70 0.80
(2×) (2×) (2×)
0.90
solder lands
solder paste
solder resist
R = 0.05 (8×)
0.30
(2×)
0.40
(2×)
0.50
(2×)
occupied area
mbl872
Dimensions in mm
Fig 20. Reflow soldering footprint SOD882
Product data sheet
13 of 20
Nexperia
2.65
0.75
1.325
1.30
solder lands
2
solder paste
0.60
2.35 0.85
(3×)
0.50
(3×) 1.90
3
solder resist
occupied area
1
Dimensions in mm
0.55
(3×)
2.40
msa429
Dimensions in mm
Fig 21. Reflow soldering footprint SOT323 (SC-70)
4.60
4.00
1.15
2
3.65
3
2.10
2.70
solder lands
1
0.90
(2×)
solder resist
occupied area
Dimensions in mm
msa419
Dimensions in mm
Fig 22. Wave soldering footprint SOT323 (SC-70)
Product data sheet
14 of 20
Nexperia
3.25
0.60 (3x)
0.50 (3x)
solder lands
0.60
(4x)
solder resist
4
3
2.70
occupied area
1.30 3.00
1
2
solder paste
msa441
0.90
1.00
2.50
Dimensions in mm
Fig 23. Reflow soldering footprint SOT143B
4.45
1.20 (3×)
4
3
1.15 4.00 4.60
solder lands
1
solder resist
2
occupied area
Dimensions in mm
1.00
3.40
msa422
Dimensions in mm
Fig 24. Wave soldering footprint SOT143B
Product data sheet
15 of 20
Nexperia
2.65
0.60
(2×)
0.40 0.90 2.10
(2×)
2.35
0.50
(4×)
solder paste
solder lands
0.50
(4×)
solder resist
1.20
2.40
occupied area
MSA432
Dimensions in mm
Fig 25. Reflow soldering footprint SOT363 (SC-88)
1.5
solder lands
0.3 2.5
4.5
solder resist
occupied area
1.5
Dimensions in mm
1.3
1.3
preferred transport
2.45
5.3
sot363_fw
Fig 26. Wave soldering footprint SOT363 (SC-88)
Product data sheet
16 of 20
Nexperia
2.75
2.45
2.1
1.6
solder lands
0.4
(6×) 0.25
(2×)
0.538
2
1.7 1.075
0.3
(2×)
placement area
0.55
(2×)
solder paste
occupied area
0.325 0.375
(4×) (4×)
Dimensions in mm
1.7
0.45
(4×)
0.6
(2×)
0.5
(4×)
0.65
(2×)
sot666_fr
Fig 27. Reflow soldering footprint SOT666
Product data sheet
17 of 20
Nexperia
11. Revision history
Table 10.
Revision history
Document ID
Release date
BAS70_1PS7XSB70_SER_9 20100113
Modifications:
Data sheet status
Change notice
Supersedes
Product data sheet
BAS70_1PS7XSB70_SER_8
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
BAS70_1PS7XSB70_SER_8 20060504
Product data sheet
BAS70_1PS7XSB70_SER_7
BAS70_1PS7XSB70_SER_7 20050718
Product data sheet
1PS76SB70_2
1PS79SB70_1 BAS70H_1
BAS70L_1 BAS70-07V_1
BAS70VV_1 BAS70W_3
BAS70-07S_4
BAS70_SERIES_6
1PS76SB70_2
20040126
Product specification
1PS76SB70_1
1PS79SB70_1
19980716
BAS70H_1
20050425
Product data sheet
BAS70L_1
20030520
BAS70-07V_1
20020117
BAS70VV_1
20040910
Product data sheet
BAS70W_3
19990326
BAS70W_2
BAS70-07S_4
20030411
BAS70_07S_3
BAS70_SERIES_6
20011011
BAS70_5
Product data sheet
18 of 20
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
12.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published at
http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Product data sheet
19 of 20
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 4
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Thermal characteristics . . . . . . . . . . . . . . . . . . 6
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information . . . . . . . . . . . . . . . . . . . . 10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18
Legal information. . . . . . . . . . . . . . . . . . . . . . . 19
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Contact information. . . . . . . . . . . . . . . . . . . . . 19
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Date of release: 13 January 2010
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
1PS76SB70,135 1PS76SB70,115 1PS79SB70,115 BAS70-05,235 BAS70,235 BAS70-04,215 BAS70-04W,115
BAS70-05,215 BAS70-05W,135 BAS70-05W,115 BAS70-06,215 BAS70-06W,115 BAS70-07S,115 BAS70-07,215
BAS70-07V,115 BAS70H,115 BAS70L,315 BAS70,215 BAS70VV,115 BAS70W,115 BAS70XY,115
1PS79SB70,315 BAS70-04,235 BAS70-04WF
