CT7-Y6Y5U0E102MSE
CT7-Y6Y5U0E102MSE
    FH(风华)
    CAP-D9XT5MM_TM
    安规电容 CAP_D15X5MM_TM 1nF ±20% 400V
CT7-Y6Y5U0E102MSE 数据手册
CERAMIC DISC CAPACITOR Product Part Number Expression M 2 CT81 1 1 5 3 Y5V 4 5 5 B 6 102 7 M 8 T 9 E 10 Product Type Product Type Type code CC81 High voltage temperature compensation capacitor CT1 Low voltage high dielectric constant disk ceramic capacitor CT81 High voltage high dielectric constant disk ceramic capacitor CS1 Semiconductor disk ceramic capacitor CT7 Alternating current disk ceramic capacitor 2 Voltage Code F Code Rated Voltage 50V L N M 500V 1KV 2KV Q P 3KV 4KV S 6KV U W X Y 250 VAC 400VAC Z 8KV 10KV 15KV The Code Chip Diameter Range 3 Code 5 6 10 12 Diameter(mm) 4.5-5.4 5.5-6.4 9.5-10.4 11.5-12.4 4 ( EIA ) Temperature Characteristics ( temperature coefficient and EIA code): TemperatureCharacteristics USE code Temperature range EIA code Capacitance with temperature change rate NP0 C0H N750 U2J SL S2L Y5P Y5P Y5R Y5R Y5U Y5U +22/-56% Y5V Y5V +22/-82% 0 60PPM/ 750 120PPM/ +140~-1000PPM/ -25~-+85 10% 15% 207 5 Lead style Code lead Style 1 (16-28mm) Straight lead (16~28m) 3 short lead( cut the feet) 4 Tape straight lead 5 Tape small inside kink 6 Tape large inside kink Special Straight lead 7 6 9 Outside kink 0 vertical kink lead Lead Spacing B Code D 7.5 0.5 5.0 0.5 7 E K 10.0 0.5 12.5 0.5 Standard capacitance 100 10PF 560 56PF 821 820PF 102 1000PF ----- ----- pF 3 0 Note: The unit of standard capacitance if consisting of 3 digits, the first and second digits stand for effective value of the Standard capacitance;third digit indicates the number of zeros. 8 Capacitance Tolerance Code Tolerance 9 K 10% Z 20% +80%~-20% Packing style Code Packing style 10 M S T bulk Taping Coating style code Coating style E P Epoxy resin 208 Phenol resin CERAMIC DISC CAPACITOR Product Structure and Overall Dimensions Lead shape 209 Packing style Bulk Taping products Taping products ( P 0 =12.7mm F=5.0mm,F=7.5mm) Taping products(P 0 =15.0mm,F=7.5mm) Taping products(P 0 =15.0mm,F=10.0mm) 210 CERAMIC DISC CAPACITOR Packing style products paking Packing style Lead spacing F=5.0 Bulk F=7.5 Bulk Taping(P0=12.7mm D
CT7-Y6Y5U0E102MSE
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,用于红外线发射,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:主要参数包括波长940nm,功率等级5mW,工作电流20mA。
5. 功能详解:EL817主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为3.4mm x 1.6mm。
CT7-Y6Y5U0E102MSE 价格&库存
很抱歉,暂时无法提供与“CT7-Y6Y5U0E102MSE”相匹配的价格&库存,您可以联系我们找货
CT7-Y6Y5U0E102MSE
    • 10+0.37282
    • 100+0.31331
    • 500+0.26115
    • 1000+0.23879
    • 5000+0.22097
    • 10000+0.21201
    CT7-Y6Y5U0E102MSE
    • 6+0.31068
