BCW66FVL
BCW66FVL
    NEXPERIA(安世)
    SOT-23
    三极管 NPN Ic=800mA Vceo=45V hfe=100~250 P=250mW SOT23
BCW66FVL 数据手册
BCW66 series 45 V, 800 mA NPN general-purpose transistor Rev. 1 — 21 April 2017 1 Product data sheet General description NPN general-purpose transistors in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. PNP complements: BCW68F/G/H 2 Features and benefits • High current • AEC-Q101 qualified 3 Applications • General-purpose switching and amplification 4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 45 V IC collector current - - 800 mA ICM peak collector current - - 1 A BCW66F 100 - 250 BCW66G 160 - 400 BCW66H 250 - 600 hFE [1] DC current gain pulsed: tp ≤ 300 μs, δ ≤ 0.02 single pulse; tp ≤ 1 ms VCE = 1 V; IC = 100 mA; Tamb = 25 °C [1] BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 5 Pinning information Table 2. Pinning Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B E 1 6 2 sym123 Ordering information Table 3. Ordering information Type number BCW66F Package Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 BCW66G BCW66H 7 Marking Table 4. Marking Type number Marking code BCW66F [1] EQ% BCW66G [1] ER% BCW66H [1] ES% [1] % = placeholder for manufacturing site code 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 45 V VEBO emitter-base voltage open collector - 5 V IC collector current - 800 mA ICM peak collector current - 1 A IB base current - 100 mA BCW66x_SER Product data sheet single pulse; tp ≤ 1 ms All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor Symbol Parameter Conditions IBM peak base current single pulse; tp ≤ 1 ms [1] Max Unit - 200 mA - 250 mW Ptot total power dissipation Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C Min Typ Max Unit - - 500 K/W [1] Tamb ≤ 25 °C Min Device mounted on an FR4 Printed-Circuit-Board (PCB), single-sided chopper, tin-plated and standard footprint. aaa-026537 400 Ptot (mW) 300 200 100 0 -75 -25 25 75 125 175 Tamb (°C) FR4 PCB, standard footprint Figure 1. Power derating curve 9 Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor aaa-026538 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.50 0.20 0.10 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Figure 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 10 Electrical characteristics Table 7. Electrical characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 40 V; IE = 0 A - - 20 nA VCB = 40 V; IE = 0 A; Tj = 150 °C - - 5 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 20 nA hFE DC current gain BCW66F/G/H VCE = 1 V; IC = 100 μA 75 - - BCW66F/G/H VCE = 1 V; IC = 1 mA 75 - - BCW66F/G/H VCE = 1 V; IC = 10 mA 75 - - [1] 100 - 250 BCW66G [1] 160 - 400 BCW66H [1] 250 - 630 BCW66F/G/H VCE = 1 V; IC = 500 mA [1] 40 - - IC = 100 mA; IB = 10 mA [1] - - 350 mV IC = 500 mA; IB = 50 mA [1] - - 450 mV base-emitter saturation voltage IC = 100 mA; IB = 10 mA [1] - - 1.25 V IC = 500 mA; IB = 50 mA [1] - - 1.25 V fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - 3 - pF BCW66F VCEsat VBEsat [1] collector-emitter saturation voltage VCE = 1 V; IC = 100 mA pulsed; tp≤ 300 μs; δ ≤ 0.02 BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor Table 8. 006aaa131 400 006aaa132 600 hFE hFE 300 (1) 200 (1) 400 (2) (2) 200 100 0 10- 1 (3) (3) 1 10 102 I C (mA) 103 0 10- 1 1 10 102 I C (mA) 103 VCE = 1 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C VCE = 1 V (1) amb = 150 °C (2) amb = 25 °C (3) amb = -55 °C Figure 3. BCW66F: DC current gain as a function of collector current; typical values Figure 4. BCW66G: DC current gain as a function of collector current; typical values 006aaa133 800 006aaa134 10 hFE 600 (1) VBEsat (V) 400 (2) 1 (1) (2) (3) 200 0 10- 1 1 (3) 10 102 I C (mA) 103 10- 1 10- 1 1 10 102 I C (mA) 103 VCE = 1 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Figure 5. BCW66H: DC current gain as a function of collector current; typical values Figure 6. BCW66F: Base-emitter saturation voltage as a function of collector current; typical values BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 006aaa135 10 006aaa136 10 VBEsat (V) VBEsat (V) 1 1 (1) 10- 1 10- 1 1 (1) (2) (2) (3) (3) 10 102 I C (mA) 103 10- 1 10- 1 1 102 10 I C (mA) 103 IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C IC/IB = 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Figure 7. BCW66G: Base-emitter saturation voltage as a function of collector current; typical values Figure 8. BCW66H: Base-emitter saturation voltage as a function of collector current; typical values 006aaa137 1 006aaa138 1 VCEsat (V) VCEsat (V) 10- 1 10- 1 (1) (2) 10- 2 (3) (1) (2) (3) 10- 2 10- 1 1 10 102 I C (mA) 103 10- 3 10- 1 1 10 102 I C (mA) 103 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Figure 9. BCW66F: Collector-emitter saturation voltage as a function of collector current; typical values Figure 10. BCW66G: Collector-emitter saturation voltage as a function of collector current; typical values BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 006aaa139 1 006aaa140 1.2 VCEsat (V) (5) IC (A) 10- 1 (4) (3) (2) 0.8 (1) (6) (7) (8) (1) (2) 10- 2 (9) 0.4 (3) (10) 10- 3 10- 1 1 10 102 I C (mA) 103 0 0 1 2 3 4 VCE (V) 5 IC/IB = 10 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Tamb = 25 °C (1) IB = 16.0 mA (2) IB = 14.4 mA (3) IB = 12.8 mA Figure 11. BCW66H: Collector-emitter saturation voltage (4) IB = 11.2 mA (5) IB = 9.6 mA as a function of collector current; typical values (6) IB = 8.0 mA (7) IB = 6.4 mA (8) IB = 4.8 mA (9) IB = 3.2 mA (10) IB = 1.6 mA Figure 12. BCW66F: Collector current as a function of collector-emitter voltage; typical values BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 006aaa141 1.2 (6) IC (A) (5) (4) (3) (2) 006aaa142 1.2 (1) (6) IC (A) 0.8 (5) (4) (3) (2) 0.8 (7) (7) (8) (8) (9) (9) 0.4 0.4 (10) (10) 0 0 1 2 3 4 VCE (V) (1) 0 5 0 1 2 3 4 VCE (V) 5 Tamb = 25 °C (1) IB = 13.0 mA (2) IB = 11.7 mA (3) IB = 10.4 mA (4) IB = 9.1 mA (5) IB = 7.8 mA (6) IB = 6.5 mA (7) IB = 5.2 mA (8) IB = 3.9 mA (9) IB = 2.6 mA (10) IB = 1.3 mA Tamb = 25 °C (1) IB = 12.0 mA (2) IB = 10.8 mA (3) IB = 9.6 mA (4) IB = 8.4 mA (5) IB = 7.2 mA (6) IB = 6.0 mA (7) IB = 4.8 mA (8) IB = 3.6 mA (9) IB = 2.4 mA (10) IB = 1.2 mA Figure 13. BCW66G: Collector current as a function of collector-emitter voltage; typical values Figure 14. BCW66H: Collector current as a function of collector-emitter voltage; typical values 11 Test information 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 12 Package outline Table 9. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 0.48 0.38 1.9 0.15 0.09 Dimensions in mm 04-11-04 Figure 15. Package outline TO-236 (SOT23) 13 Soldering Table 10. Soldering 3.3 2.9 1.9 solder lands 3 2 1.7 solder resist solder paste 0.6 (3×) 0.7 (3×) occupied area Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Figure 16. Reflow soldering footprint for SOT23 (TO-236AB) BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Figure 17. Wave soldering footprint for SOT23 (TO-236AB) 14 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BCW66x_SER v.1 21 April 2017 Product data sheet - - BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BCW66x_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor Tables Tab. 1. Tab. 2. Tab. 3. Tab. 4. Tab. 5. Tab. 6. Quick reference data .........................................1 Pinning ...............................................................2 Ordering information ..........................................2 Marking ..............................................................2 Limiting values .................................................. 2 Thermal characteristics ..................................... 3 Tab. 7. Tab. 8. Tab. 9. Tab. 10. Tab. 11. Electrical characteristics ....................................4 ............................................................................ 5 Package outline .................................................9 Soldering ........................................................... 9 Revision history ...............................................10 Fig. 9. BCW66F: Collector-emitter saturation voltage as a function of collector current; typical values .....................................................6 BCW66G: Collector-emitter saturation voltage as a function of collector current; typical values .....................................................6 BCW66H: Collector-emitter saturation voltage as a function of collector current; typical values .....................................................7 BCW66F: Collector current as a function of collector-emitter voltage; typical values .............7 BCW66G: Collector current as a function of collector-emitter voltage; typical values .............8 BCW66H: Collector current as a function of collector-emitter voltage; typical values .............8 Package outline TO-236 (SOT23) .....................9 Reflow soldering footprint for SOT23 (TO-236AB) ....................................................... 9 Wave soldering footprint for SOT23 (TO-236AB) ..................................................... 10 Figures Fig. 1. Fig. 2. Fig. 3. Fig. 4. Fig. 5. Fig. 6. Fig. 7. Fig. 8. Power derating curve ........................................ 3 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values .....................................................4 BCW66F: DC current gain as a function of collector current; typical values ......................... 5 BCW66G: DC current gain as a function of collector current; typical values ......................... 5 BCW66H: DC current gain as a function of collector current; typical values ......................... 5 BCW66F: Base-emitter saturation voltage as a function of collector current; typical values ................................................................ 5 BCW66G: Base-emitter saturation voltage as a function of collector current; typical values ................................................................ 6 BCW66H: Base-emitter saturation voltage as a function of collector current; typical values ................................................................ 6 BCW66x_SER Product data sheet Fig. 10. Fig. 11. Fig. 12. Fig. 13. Fig. 14. Fig. 15. Fig. 16. Fig. 17. All information provided in this document is subject to legal disclaimers. Rev. 1 — 21 April 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 14 BCW66 series Nexperia 45 V, 800 mA NPN general-purpose transistor Contents 1 2 3 4 5 6 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Quick reference data .......................................... 1 Pinning information ............................................ 2 Ordering information .......................................... 2 Marking .................................................................2 Limiting values .................................................... 2 Thermal characteristics ......................................3 Electrical characteristics ....................................4 Test information .................................................. 8 Quality information .............................................8 Package outline ...................................................9 Soldering ..............................................................9 Revision history ................................................ 10 Legal information .............................................. 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 April 2017 Document identifier: BCW66x_SER
BCW66FVL
物料型号:BCW66系列,包括BCW66F、BCW66G和BCW66H。
器件简介:这是一款NPN通用晶体管,采用小型SOT23(TO-236AB)表面贴装设备(SMD)塑料封装。
引脚分配:共有3个引脚,分别为: - 1号引脚:基极(B) - 2号引脚:发射极(E) - 3号引脚:集电极(C)
参数特性: - 集电极-发射极电压(VCEO):45V - 集电极电流(Ic):最大800mA - 峰值集电极电流(ICM):单脉冲条件下,最大1A - 直流电流增益(hFE):在VcE=1V,Ic=100mA条件下,BCW66F为100至250,BCW66G为160至400,BCW66H为250至630。
功能详解:该晶体管适用于通用开关和放大应用。
应用信息:适用于一般用途的开关和放大。
封装信息:提供TO-236AB塑料表面贴装封装,3个引脚。
BCW66FVL 价格&库存
很抱歉,暂时无法提供与“BCW66FVL”相匹配的价格&库存,您可以联系我们找货
BCW66FVL
  • 1+1.674541+0.21769
  • 10+1.0057910+0.13075
  • 100+0.62268100+0.08095
  • 500+0.45300500+0.05889
  • 1000+0.397701000+0.05170
  • 2000+0.351092000+0.04564
  • 5000+0.300395000+0.03905
BCW66FVL
  • 10000+0.2689510000+0.03497
  • 20000+0.2424820000+0.03153
  • 30000+0.2289830000+0.02977
  • 50000+0.2137950000+0.02780
  • 70000+0.2048070000+0.02663
  • 100000+0.19605100000+0.02549
BCW66FVL
  • 9260+0.373869260+0.04455
  • 10381+0.3332410381+0.03971
  • 100000+0.27970100000+0.03333
库存:20000
