MB1S-MB10S
RECTIFIER
Glass Passivated Bridge Rectifiers
ROHS
MBS
Features
B
A
L
J
K
G
MB-S
Dim
Min
Max
4.50
4.95
A
3.60
4.10
B
0.15
0.35
C
0.20
D
6.40
7.00
E
G 0.50
1.10
1.30
1.70
H
2.30
2.70
J
2.30
2.70
K
3.00
L
All Dimensions in mm
Mechanical Data
Case: MB-S, Molded Plastic
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: As Marked on Case
Weight: 0.22 grams (approx.)
Mounting Position: Any
Marking: Type Number
Lead Free: For RoHS / Lead Free Version,
H
D
Glass Passivated Die Construction
Low Forward Voltage Drop
High Current Capability
High Surge Current Capability
Designed for Surface Mount Application
Plastic Material – UL Flammability 94V-O
E
C
Maximum Ratings & Thermal Characteristics
(Ratings at 25℃ ambient temperature unless otherwise specified.)
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current (Note 1) @TA = 40°C
Average Rectified Output Current (Note 2) @TA = 40°C
Symbo
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S
Unit
VRRM
VRWM
VR
100
200
400
600
800
1000
V
VR(RMS)
70
140
280
420
560
700
V
IO
0.5
0.8
A
IFSM
30
A
I2t
5.0
A2s
@IF = 0.5A
VFM
1.0
V
@TA = 25°C
@TA = 125°C
IRM
5.0
500
µA
Cj
13
pF
Typical Thermal Resistance per leg (Note 1)
RJA
RJL
70
°C/W
Operating and Storage Temperature Range
Tj, TSTG
-55 to +150
°C
Non-Repetitive Peak Forward Surge Current 8.3ms
Single half sine-wave superimposed on rated load
(JEDEC Method)
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage per element
Peak Reverse Current
At Rated DC Blocking Voltage
Typical Junction Capacitance per leg (Note 3)
Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.
2. Mounted on aluminum substrate PC board with 1.3mm2 solder pad.
3. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 2
MB1S-MB10S
0.8
IF, INSTANTANEOUS FORWARD CURRENT (A)
I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A
RECTIFIER
0.6
Al. Substrate PC Board
0.4
Glass Epoxy PC Board
0.2
Resistive or Inductive Load
80
120
10
1.0
0.1
Tj = 25°C
Pulse Width = 300µs
0.01
0.2
160
0.4
0.6
0.8
1.0
1.2
1.4
1.6
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Typical Forward Characteristics (per leg)
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Output Current Derating Curve
35
100
Tj = 25°C
f = 1.0MHz
30
Cj, JUNCTION CAPACITANCE (pF)
IFSM, PEAK FORWARD SURGE CURRENT (A)
ROHS
TA = 25°C
Single Half Sine-Wave
Pulse Width = 5.3ms
(JEDEC Method)
1
1.0
1
10
10
IR, INSTANTANEOUS REVERSE CURRENT (µA)
100
VR, REVERSE VOLTAGE (V)
Fig. 4 Typical Junction Capacitance
NUMBER OF CYCLES AT 60 Hz
Fig. 3 Maximum Peak Forward Surge Current (per leg)
100
Tj = 125°C
10
1.0
Tj = 25°C
0.1
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig. 5 Typical Reverse Characteristics (per element)
Rev 8: Nov 2014
www.born-tw.com
Page 2 of 2
很抱歉,暂时无法提供与“MB10S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20531
- 200+0.16157
- 600+0.13727
- 3000+0.12323
- 9000+0.11060
- 21000+0.10368
- 国内价格
- 20+0.18820
- 300+0.14810
- 1200+0.12583
- 3000+0.11296
- 国内价格
- 1+0.63365
- 200+0.21160
- 1500+0.13225
- 3000+0.10488
