PBSS8110T,215
PBSS8110T,215
    NEXPERIA(安世)
    SOT-23
    NPN低VCEsat晶体管 VCEO=100V VEBO=5V IC=1A SOT23
PBSS8110T,215 数据手册
PBSS8110T 100 V, 1 A NPN low VCEsat transistor 13 May 2022 Product data sheet 1. General description NPN low VCEsat transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. PNP complement: PBSS9110T 2. Features and benefits • • • Low collector-emitter saturation voltage VCEsat High collector current capability: IC and ICM AEC-Q101 qualified 3. Applications • • • Major application segments • Automotive 42 V power • Telecom infrastructure • Industrial Power management • DC/DC converters • Supply line switching • Battery charger • LCD backlighting Peripheral drivers • Driver in low supply voltage applications (e.g. lamps and LEDs) • Inductive load driver (e.g. relays, buzzers and motors) 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 100 V IC collector current - - 1 A ICM peak collector current single pulse; tp ≤ 1 ms - - 3 A RCEsat collector-emitter saturation resistance IC = 1 A; IB = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C - 165 200 mΩ PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B 1 E 2 sym123 SOT23 6. Ordering information Table 3. Ordering information Type number Package PBSS8110T Name Description Version SOT23 plastic, surface-mounted package; 3 terminals; 1.9 mm pitch; 2.9 mm x 1.3 mm x 1 mm body SOT23 7. Marking Table 4. Marking codes Type number Marking code[1] PBSS8110T %U8 [1] % = placeholder for manufacturing site code 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 120 V VCEO collector-emitter voltage open base - 100 V VEBO emitter-base voltage open collector - 5 V IC collector current - 1 A ICM peak collector current - 3 A IB base current - 300 mA Ptot total power dissipation [1] - 300 mW [2] - 480 mW single pulse; tp ≤ 1 ms Tamb ≤ 25 °C Tj junction temperature - 150 °C Tamb ambient temperature -65 150 °C Tstg storage temperature -65 150 °C [1] [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm . PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 2 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor mle354 500 Ptot (mW) 400 (1) 300 (2) 200 100 0 0 40 80 2 120 160 Tamb (°C) (1) FR4 PCB; 1 cm copper mounting pad for collector. (2) Standard footprint. Fig. 1. Power derating curves 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) [1] [2] Conditions thermal resistance from in free air junction to ambient Min Typ Max Unit [1] - - 417 K/W [2] - - 260 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm . PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 3 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor mle356 103 (1) Zth (K/W) (2) (3) 102 (4) (5) (6) (7) 10 P (8) δ= tp T (9) tp (10) 1 10- 5 10- 4 10- 3 10- 2 10- 1 1 t T 102 10 tp (s) 103 (1) δ = 1.0 (2) δ = 0.75 (3) δ = 0.5 (4) δ = 0.3 (5) δ = 0.2 (6 )δ = 0.1 (7) δ = 0.05 (8) δ = 0.02 (9) δ = 0.01 (10) δ = 0.0 Fig. 2. Transient thermal impedance as a function of pulse time for standard PCB footprint mle355 103 Zth (K/W) 102 (1) (2) (3) (4) (5) (6) 10 P (7) (8) (9) (10) 1 10- 5 δ= tp 10- 4 10- 3 10- 2 10- 1 1 t T 102 10 tp T tp (s) 103 (1) δ = 1.0 (2) δ = 0.75 (3) δ = 0.5 (4) δ = 0.3 (5) δ = 0.2 (6) δ = 0.1 (7) δ = 0.05 (8) δ = 0.02 (9) δ = 0.01 (10) δ = 0.0 Fig. 3. 2 Transient thermal impedance as a function of pulse time for collector 1 cm copper mounting pad PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 4 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = 100 µA; IE = 0 A; Tamb = 25 °C 120 - - V V(BR)CEO collector-emitter breakdown voltage IC = 10 mA; IB = 0 A; pulsed; tp ≤ 300 μs; δ ≤ 0.02;; Tamb = 25 °C 100 - - V V(BR)EBO emitter-base breakdown voltage (collector open) IE = 100 µA; IC = 0 A; Tamb = 25 °C 5 - - V ICBO collector-base cut-off current VCB = 80 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 80 V; IE = 0 A; Tj = 150 °C - - 50 µA ICES collector-emitter cut-off VCE = 80 V; VBE = 0 V; Tamb = 25 °C current - - 100 nA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 10 V; IC = 1 mA; Tamb = 25 °C 150 - - VCE = 10 V; IC = 250 mA; Tamb = 25 °C 150 - 500 VCE = 10 V; IC = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C 100 - - VCE = 10 V; IC = 1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C 80 - - IC = 100 mA; IB = 10 mA; Tamb = 25 °C - - 40 mV IC = 500 mA; IB = 50 mA; Tamb = 25 °C - - 120 mV IC = 1 A; IB = 100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C - - 200 mV - 165 200 mΩ VCEsat collector-emitter saturation voltage RCEsat collector-emitter saturation resistance VBEsat base-emitter saturation IC = 1 A; IB = 100 mA; Tamb = 25 °C voltage - - 1.05 V VBEon base-emitter turn-on voltage VCE = 10 V; IC = 1 A; Tamb = 25 °C - - 0.9 V fT transition frequency VCE = 10 V; IC = 50 mA; f = 100 MHz; Tamb = 25 °C 100 - - MHz Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - - 7.5 pF PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 5 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor mle352 600 mle362 1.2 VBE (V) hFE (1) (1) 400 0.8 (2) (2) 200 (3) 0.4 (3) 0 10- 1 1 10 102 0 10- 1 103 104 IC (mA) VCE = 10 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 4. 1 10 102 103 104 IC (mA) VCE = 10 V (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C DC current gain as a function of collector current; typical values Fig. 5. mle366 1 Base-emitter voltage as a function of collector current; typical values mle353 1 VCEsat (V) VCEsat (V) 10- 1 10- 1 (1) (2) (3) 10- 2 10- 1 1 10 102 Fig. 7. Collector-emitter saturation voltage as a function of collector current; typical values PBSS8110T Product data sheet 1 10 102 103 104 IC (mA) IC/IB = 20 Tamb = 25 °C IC/IB = 10 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 6. 10- 2 10- 1 103 104 IC (mA) Collector-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 6 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor mle357 10 VCEsat (V) mle363 10 VBEsat (V) 1 1 (1) (2) 10- 1 10- 2 10- 1 (3) 1 10 10- 2 10- 1 10- 1 10- 3 10- 4 IC (mA) IC/IB = 50 Tamb = 25 °C Fig. 8. Collector-emitter saturation voltage as a function of collector current; typical values VBEsat (V) 10 102 103 104 IC (mA) IC/IB = 10 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig. 9. mle364 10 1 Base-emitter saturation voltage as a function of collector current; typical values mle365 1 VBEsat (V) 1 10- 1 10- 1 1 10 102 10- 1 10- 1 103 104 IC (mA) 10 10 102 103 104 IC (mA) IC/IB = 50 Tamb = 25 °C IC/IB = 20 Tamb = 25 °C Fig. 10. Base-emitter saturation voltage as a function of Fig. 11. Base-emitter saturation voltage as a function of collector current; typical values collector current; typical values PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 7 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor IC mle358 2 (2) RCEsat (Ω) (3) (4) (5) (6) (A) 1.6 mle359 103 (1) 102 (7) 1.2 (8) 10 (9) 0.8 (10) 1 0.4 (1) 0 0 1 2 3 4 VCE (V) 10- 1 10- 1 5 Tamb = 25 °C (1) IB = 3500 μA (2) IB = 3150 μA (3) IB = 2800 μA (4) IB = 2450 μA (5) IB = 2100 μA (6) IB = 1750 μA (7) IB = 1400 μA (8) IB = 1050 μA (9) IB = 700 μA (10) IB = 350 μA (2) (3) 1 10 102 103 104 IC (mA) IC/IB = 10 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 13. Collector-emitter equivalent on-resistance as a function of collector current; typical values Fig. 12. Collector current as a function of collectoremitter voltage; typical values mle360 103 mle361 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 10- 1 10- 1 1 10 102 10- 1 10- 1 103 104 IC (mA) IC/IB = 20 Tamb = 25 °C Product data sheet 10 102 103 104 IC (mA) IC/IB = 50 Tamb = 25 °C Fig. 14. Collector-emitter equivalent on-resistance as a function of collector current; typical values PBSS8110T 1 Fig. 15. Collector-emitter equivalent on-resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 8 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 0.48 0.38 1.9 Dimensions in mm 0.15 0.09 18-03-12 Fig. 16. Package outline SOT23 13. Soldering 3.3 2.9 1.9 solder lands 3 2 1.7 solder resist solder paste 0.6 (3×) 0.7 (3×) occupied area Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 17. Reflow soldering footprint for SOT23 PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 9 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 18. Wave soldering footprint for SOT23 PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 10 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PBSS8110T v.3 20220513 Product data sheet - PBSS8110T v.2 Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. PBSS8110T v.2 20031222 Product data sheet - PBSS8110T v.1 PBSS8110T v.1 20030728 Product data sheet - - PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 11 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 12 / 13 PBSS8110T Nexperia 100 V, 1 A NPN low VCEsat transistor Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 5 11. Test information.......................................................... 9 12. Package outline.......................................................... 9 13. Soldering..................................................................... 9 14. Revision history........................................................11 15. Legal information......................................................12 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 May 2022 PBSS8110T Product data sheet All information provided in this document is subject to legal disclaimers. 13 May 2022 © Nexperia B.V. 2022. All rights reserved 13 / 13
PBSS8110T,215 价格&库存
很抱歉,暂时无法提供与“PBSS8110T,215”相匹配的价格&库存,您可以联系我们找货
PBSS8110T,215
  • 1+4.754811+0.61811
  • 10+3.9203310+0.50963
  • 100+3.39009100+0.44070
  • 500+2.59038500+0.33674
  • 1000+2.346991000+0.30510
  • 3000+2.155753000+0.28024
库存:2500
PBSS8110T,215
  • 1+1.20775
PBSS8110T,215
  • 5+8.81570
  • 50+6.12234
  • 100+3.97478
  • 500+2.76455
  • 1500+2.05265
PBSS8110T,215
  • 1+6.575901+0.85470
  • 10+4.5636010+0.59320
  • 100+2.88670100+0.37520
  • 500+1.78470500+0.23200
  • 1000+1.317601000+0.17130
  • 3000+1.175003000+0.15280
