MPL2016S1R0MHT
MPL2016S1R0MHT
    SUNLORD(顺络)
    0806(2016公制)
    信号/去耦电感 1µH ±20% 1.4A 90mΩ 0806 2.00 x 1.60mm 0.90mm
MPL2016S1R0MHT 数据手册
Multilayer Chip Power Inductor – MPL Series Operating Temp. : -40℃~+85℃ FEATURES High DC bias current due to developed material Low DC resistance Low profile and thin thickness Monolithic structure for high reliability Excellent solderability and high heat resistance No cross coupling due to magnetic shield ● ● ● ● ● ● APPLICATIONS DC-DC converter circuits for mobile phones, DSCs, DVCs, HDDs, PDAs, etc. ● PRODUCT IDENTIFICATION MPL 2012 S 2R2 M ① ② ③ ④ ⑤ H ⑥ ② ① MPL Chip Power Inductor ③ Feature Type S L C 1608 [0603] 1.6×0.8 2012 [0805] 2.0×1.25 2016 [0806] 2.0×1.6 2520 [1008] 2.5×2.0 Nominal Inductance Example Nominal Value R47 0.47μH 4R7 4.7μH ⑥ (Internal Code) ⑤ ⑦ T ⑦ ④ External Dimensions (L×W) (mm) Type T D H W Y Inductance Tolerance M ±20% N ±30% Packing Tape & Reel Thickness 0.5mm 0.9mm 1.1mm 1.25mm SHAPE AND DIMENSIONS Unit: mm [inch] Sunlord Type L W 1608 [0603] 1.6±0.15 [.063±.006] 0.8±0.15 [.031±.006] 2012 [0805] 2.0 (+0.3, -0.1) [.079 (+.012, -.004)] 1.25±0.2 [.049±.008] 2016 [0806] 2.0 (+0.3, -0.1) [.079 (+.012, -.004)] 1.6±0.2 [.063±.008] 2520 [1008] 2.5±0.2 [.098±.008] 2.0 (+0.3, -0.1) [.079 (+.012, -.004)] T 0.5±0.1 [.020±.004] 0.8±0.15 [.031±.006] 0.5±0.1 [.020±.004] 0.9±0.1 [.035±.004] 1.25±0.2 [.049±.008] 0.9±0.1 [.035±.004] 0.9±0.1 [.035±.004] 1.1±0.1 [.043±.004] Specifications subject to change without notice. Please check our website for latest information. a 0.3±0.2 [.012±.008] 0.5±0.3 [.020±.012] 0.5±0.3 [.020±.012] 0.5±0.3 [.020±.012] Revised 2011/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS MPL1608 TYPE Part Number Inductance L Test Freq. Min. Self-resonant Frequency DC Resistance Max. Rated Current Thickness Units μH MHz MHz Ω mA mm [inch] Symbol L Freq. S.R.F DCR Ir* MPL1608SR47□DT 0.47 5 105 0.19±25% 900 T 0.5±0.1 MPL1608LR47□HT MPL1608SR47□HT MPL1608SR68□HT MPL1608S1R0□HT MPL1608S1R5□HT MPL1608S2R2□HT 0.47 0.47 0.68 1.0 1.5 2.2 5 5 5 1 1 1 105 105 90 75 50 40 0.12±25% 0.25±25% 0.16±25% 0.20±25% 0.25±25% 0.30±25% 1200 800 1000 950 800 750 0.8±0.15 [.031±.006] Part Number Inductance L Test Freq. Min. Self-resonant Frequency DC Resistance Max. Rated Current Thickness [.020±.004] MPL2012 TYPE Units μH MHz MHz Ω mA mm [inch] Symbol L Freq. S.R.F DCR Ir* T MPL2012SR47□DT MPL2012S1R0□DT MPL2012S1R5□DT MPL2012S2R2□DT MPL2012SR47□HT MPL2012S1R0□HT MPL2012S1R5□HT MPL2012S2R2□HT MPL2012S3R3□HT MPL2012S4R7□HT MPL2012C2R2□HT MPL2012S2R2□YT MPL2012S4R7□YT 0.47 1.0 1.5 2.2 0.47 1.0 1.5 2.2 3.3 4.7 2.2 2.2 4.7 1 1 1 1 1 1 1 1 1 1 1 1 1 100 60 50 40 100 60 50 40 30 30 40 40 25 0.12±25% 0.19±25% 0.26±25% 0.34±25% 0.09±25% 0.11±25% 0.16±25% 0.25±25% 0.19±25% 0.25±25% 0.45±25% 0.33±30% 0.50±30% 1100 800 700 600 1200 1000 900 800 900 800 500 640 600 Part Number Inductance L Test Freq. Min. Self-resonant Frequency DC Resistance Max. Rated Current Thickness Units μH MHz MHz Ω mA mm [inch] Symbol L Freq. S.R.F DCR Ir* T MPL2016SR47□HT MPL2016S1R0□HT MPL2016S1R5□HT MPL2016S2R2□HT MPL2016S3R3□HT MPL2016S4R7□HT 0.47 1.0 1.5 2.2 3.3 4.7 1 1 1 1 1 1 100 70 60 50 40 30 0.06±25% 0.09±25% 0.11±25% 0.11±25% 0.12±25% 0.14±25% 1600 1400 1200 1200 1200 1100 0.5±0.1 [.020±.004] 0.9±0.1 [.035±.004] 1.25±0.2 [.049±.008] MPL2016 TYPE Sunlord Specifications subject to change without notice. Please check our website for latest information. 0.9±0.1 [.035±.004] Revised 2011/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS MPL2520 TYPE Part Number Inductance L Test Freq. Min. Self-resonant Frequency DC Resistance Max. Rated Current Thickness Units μH MHz MHz Ω mA mm [inch] T Symbol L Freq. S.R.F DCR Ir* MPL2520SR47□HT MPL2520S1R0□HT MPL2520S1R5□HT MPL2520S2R2□HT MPL2520S3R3□HT MPL2520S4R7□HT MPL2520S1R0□WT MPL2520S2R2□WT MPL2520S3R3□WT MPL2520S4R7□WT 0.47 1.0 1.5 2.2 3.3 4.7 1.0 2.2 3.3 4.7 1 1 1 1 1 1 1 1 1 1 100 60 50 40 30 25 70 40 30 25 0.04±25% 0.06±25% 0.07±25% 0.08±25% 0.10±25% 0.11±25% 0.09±25% 0.12±25% 0.12±25% 0.14±25% 1800 1600 1500 1300 1200 1100 1500 1000 1000 900 MPL2520S100□WT 10 1 15 0.30±30% 800 0.9±0.1 [.035±.004] 1.1±0.1 [.043±.004] ※□: Please specify the inductance tolerance code (M=±20%, N=±30%). ※Ir* : DC current causes temperature rise of 40℃ from 20℃ ambient TYPICAL ELECTRICAL CHARACTERISTICS Inductance vs. Frequency Characteristics Sunlord Inductance vs. DC Current Characteristics Specifications subject to change without notice. Please check our website for latest information. Revised 2011/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com TYPICAL ELECTRICAL CHARACTERISTICS Inductance vs. Frequency Characteristics Sunlord Inductance vs. DC Current Characteristics Specifications subject to change without notice. Please check our website for latest information. Revised 2011/03/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
MPL2016S1R0MHT
物料型号: - MPL系列 - 型号示例:MPL1608SR47DT、MPL2012SR47HT、MPL2016SR47HT、MPL2520SR47HT
器件简介: - MPL系列是多层芯片功率电感器,适用于移动电话、DSC、DVC、HDD、PDA等的DC-DC转换器电路。 - 特点包括高直流偏置电流、低直流电阻、低轮廓和薄厚度、单片结构提高可靠性、优异的可焊性和高耐热性、无交叉耦合。
引脚分配: - 封装类型包括1608[0603]、2012[0805]、2016[0806]、2520[1008],具体引脚分配未在文档中详细说明。
参数特性: - 包括标称电感值、电感公差、厚度、直流电阻、最大额定电流等。 - 例如,MPL1608SR47DT的标称电感值为0.47uH,直流电阻为0.19欧姆,最大额定电流为900mA,厚度为0.5±0.1mm。
功能详解: - 电感值随频率变化的特性图和直流电流特性图提供了电感在不同条件下的性能表现。
应用信息: - 适用于移动电话、DSC、DVC、HDD、PDA等设备的DC-DC转换器电路。
封装信息: - 提供了不同封装尺寸的电感器,如1608[0603]、2012[0805]、2016[0806]、2520[1008],以及它们的外部尺寸和厚度。
MPL2016S1R0MHT 价格&库存
很抱歉,暂时无法提供与“MPL2016S1R0MHT”相匹配的价格&库存,您可以联系我们找货
MPL2016S1R0MHT
  • 20+0.36330
  • 100+0.27180
  • 500+0.21070
  • 3000+0.15270
  • 15000+0.13740
库存:6163
MPL2016S1R0MHT
  • 20+0.18959
  • 200+0.17759
  • 500+0.16559
  • 1000+0.15359
  • 3000+0.14759
  • 6000+0.13919
库存:2268
MPL2016S1R0MHT
    • 10+0.29333
    • 100+0.23933
    • 300+0.21233
    库存:990
