BZT52-B series
Single Zener diodes in a SOD123 package
Rev. 1 — 20 December 2017
1
Product data sheet
1 Product profile
1.1 General description
General-purpose Zener diodes in a SOD123 small Surface-Mounted Device (SMD)
plastic package.
1.2 Features and benefits
Total power dissipation: ≤ 590 mW
Wide working voltage range: nominal 2.4 V to 75 V (E24 range)
Small plastic package suitable for surface-mounted design
Low differential resistance
B selection
AEC-Q101 qualified
1.3 Applications
• General regulation functions
1.4 Quick reference data
Table 1. Quick reference data
Symbol
VF
Ptot
Parameter
forward voltage
total power dissipation
Conditions
Min
Typ
Max
Unit
IF = 10 mA
[1]
0.9
V
Tamb ≤ 25 °C
[2]
350
mW
[3]
590
mW
[1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
2
[3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
BZT52-B series
Nexperia
2
Pinning information
Table 2. Pinning
Pin Symbol
Description
1
K
cathode
2
A
anode
Simplified outline
Graphic symbol
[1]
1
2
2
1
006aaa152
[1] The marking bar indicates the cathode.
3
Ordering information
Table 3. Ordering information
Type number
Package
BZT52-B2V4 to BZT52-B75
[1]
Name
Description
Version
plastic surface-mounted package; 2 leads
SOD123
[1] The series consists of 37 types with nominal working voltages from 2.4 V to 75 V.
4
Marking
Table 4. Marking Codes
Type number Marking
code
Type number Marking
code
Type number Marking
code
Type number Marking
code
BZT52-B2V4
D7
BZT52-B6V2
DH
BZT52-B16
DT
BZT52-B43
E6
BZT52-B2V7
D8
BZT52-B6V8
DJ
BZT52-B18
DU
BZT52-B47
E7
BZT52-B3V0
D9
BZT52-B7V5
DK
BZT52-B20
DV
BZT52-B51
E8
BZT52-B3V3
DA
BZT52-B8V2
DL
BZT52-B22
DW
BZT52-B56
E9
BZT52-B3V6
DB
BZT52-B9V1
DM
BZT52-B24
DY
BZT52-B62
EA
BZT52-B3V9
DC
BZT52-B10
DN
BZT52-B27
E1
BZT52-B68
EB
BZT52-B4V3
DD
BZT52-B11
DP
BZT52-B30
E2
BZT52-B75
EC
BZT52-B4V7
DE
BZT52-B12
DQ
BZT52-B33
E3
BZT52-B5V1
DF
BZT52-B13
DR
BZT52-B36
E4
BZT52-B5V6
DG
BZT52-B15
DS
BZT52-B39
E5
BZT52-B_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 11
BZT52-B series
Nexperia
5
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
IF
Conditions
Min
Max
Unit
forward current
250
mA
IZSM
non-repetitive peak reverse current
see Table 8
Table 9
Table 10
PZSM
non-repetitive peak power
dissipation
[1]
40
W
Ptot
[2]
350
mW
[3]
590
mW
Tamb ≤ 25 °C
Tj
junction temperature
150
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1] tp = 100 μs; square wave; Tj = 25 °C prior to surge.
[2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2.
6
Thermal characteristics
Table 6. Thermal characteristics
Symbol
Rth(j-a)
Rth(j-sp)
Parameter
Conditions
thermal resistance from junction
to ambient
in free air
to solder point
Min
Typ
Max
Unit
[1]
350
K/W
[2]
210
K/W
[3]
55
K/W
Min
Typ
Max
Unit
0.9
V
[1] Device mounted on an FR4 Printed-Circuit Board (PCB),single-sided copper, tin-plated and standard footprint.
2
[2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
[3] Soldering point of cathode tab.
7
Characteristics
Table 7. Characteristics
Tj = 25 °C unless otherwise specified.
Symbol
VF
Parameter
forward voltage
Conditions
IF = 10 mA
[1]
BZT52-B_SER
Product data sheet
3 / 11
BZT52-B series
Nexperia
Table 8. Characteristics per type; BZT52-B2V4 to BZT52-B24
BZT52 Sel Working
-xxx
voltage
VZ (V);
Maximum
differential
resistance
rdif (Ω)
Reverse
current
IR (μA)
Temperature Diode
Noncoefficient
capacitance repetitive
[1]
peak reverse
SZ (mV/K);
Cd (pF)
current
[2]
IZSM (A)
IZ = 5 mA
IZ = 5 mA
IZ = 1 mA IZ = 5 mA
Min
Max
Max
Max
Max
VR (V) Min
Max
Max
Max
2V4
B
2.35
2.45
400
85
50
1
−3.5
0.0
450
6.00
2V7
B
2.65
2.75
500
83
−3.5
0.0
450
6.00
3V0
B
2.94
3.06
500
95
10
1
−3.5
0.0
450
6.00
3V3
B
3.23
3.37
500
95
5
1
−3.5
0.0
450
6.00
3V6
B
3.53
3.67
500
95
5
1
−3.5
0.0
450
6.00
3V9
B
3.82
3.98
500
95
3
1
−3.5
0.0
450
6.00
4V3
B
4.21
4.39
500
95
3
1
−3.5
0.0
450
6.00
4V7
B
4.61
4.79
500
78
3
2
−3.5
0.2
300
6.00
5V1
B
5.00
5.20
480
60
2
2
−2.7
1.2
300
6.00
5V6
B
5.49
5.71
400
40
1
2
−2.0
2.5
300
6.00
6V2
B
6.08
6.32
150
10
3
4
0.4
3.7
200
6.00
6V8
B
6.66
6.94
80
8
2
4
1.2
4.5
200
6.00
7V5
B
7.35
7.65
80
10
1
5
2.5
5.3
150
4.00
8V2
B
8.04
8.36
80
10
0.7
5
3.2
6.2
150
4.00
9V1
B
8.92
9.28
100
10
0.5
6
3.8
7.0
150
3.00
10
B
9.80
10.20 70
10
0.2
7
4.5
8.0
90
3.00
11
B
10.80 11.20 70
10
0.1
8
5.4
9.0
85
2.50
12
B
11.80 12.20 90
10
0.1
8
6.0
10.0
85
2.50
13
B
12.70 13.30 110
10
0.1
8
7.0
11.0
80
2.50
15
B
14.70 15.30 110
15
0.05
10.5
9.2
13.0
75
2.00
16
B
15.70 16.30 170
11.2
10.4
14.0
75
1.50
18
B
17.60 18.40 170
12.6
12.4
16.0
70
1.50
B
19.60 20.40 220
14
14.4
18.0
60
1.50
22
B
21.60 22.40 220
25
0.05
15.4
16.4
20.0
60
1.25
24
B
23.50 24.50 220
30
0.05
16.8
18.4
22.0
55
1.25
[1] f = 1 MHz; VR = 0 V
[2] tp = 100 μs; Tamb = 25 °C
BZT52-B_SER
Product data sheet
4 / 11
BZT52-B series
Nexperia
Table 9. Characteristics per type; BZT52-B27 to BZT52-B51
BZT52 Sel Working
-xxx
voltage
VZ (V);
Maximum
differential
resistance
rdif (Ω)
Reverse
current
IR (μA)
Temperature Diode
Noncoefficient
[1]
Cd (pF)
peak reverse
SZ (mV/K);
current
[2]
IZSM (A)
IZ = 5 mA
IZ = 2 mA
IZ = 1 mA IZ = 5 mA
Min
Max
Max
Max
Max
VR (V) Min
Max
Max
Max
27
B
26.5
27.5
250
40
0.05
18.9
21.4
25.3
50
1.0
30
B
29.4
30.6
250
40
0.05
21.0
24.4
29.4
50
1.0
33
B
32.3
33.7
250
40
0.05
23.1
27.4
33.4
45
0.9
36
B
35.3
36.7
250
60
0.05
25.2
30.4
37.4
45
0.8
39
B
38.2
39.8
300
75
0.05
27.3
33.4
41.2
45
0.7
43
B
42.1
43.9
325
80
0.05
30.1
37.6
46.6
40
0.6
47
B
46.1
47.9
325
90
0.05
32.9
42.0
51.8
40
0.5
51
B
50.0
52.0
350
100
0.05
35.7
46.6
57.2
40
0.4
Table 10. Characteristics per type; BZT52-B56 to BZT52-B75
BZT52 Sel Working
-xxx
voltage
VZ (V);
Maximum
differential
resistance
rdif (Ω)
Reverse
current
IR (μA)
Temperature Diode
Noncoefficient
[1]
Cd (pF)
peak reverse
SZ (mV/K);
current
[2]
IZSM (A)
IZ = 5 mA
IZ = 2 mA
IZ = 0.5
mA
IZ = 2 mA
Min
Max
Max
Max
Max
VR (V) Min
Max
Max
Max
56
B
54.9
57.1
375
120
0.05
39.2
52.2
63.8
40
0.30
62
B
60.8
63.2
400
140
0.05
43.4
58.8
71.6
35
0.30
68
B
66.6
69.4
400
160
0.05
47.6
65.6
79.8
35
0.25
75
B
73.5
76.5
400
175
0.05
52.5
73.4
88.6
35
0.20
BZT52-B_SER
Product data sheet
5 / 11
BZT52-B series
Nexperia
mbg801
103
PZSM
(W)
mbg781
300
IF
(mA)
102
200
(1)
10
100
(2)
1
10- 1
1
10
tp (ms)
(1) Tj = 25 °C (prior to surge)
(2) Tj = 150 °C (prior to surge)
0.8
VF (V)
1
Tj = 25 °C
Figure 2. Forward current as a function of forward
Figure 1. Non-repetitive peak reverse power dissipation voltage; typical values
as a function of pulse duration; maximum values
mbg783
SZ
(mV/K)
12
SZ
(mV/K)
4V3
-1
mbg782
10
11
10
9V1
5
3V9
8V2
7V5
6V8
3V6
-2
3V3
6V2
5V6
5V1
4V7
3V0
2V4
2V7
-3
IZ (mA)
60
-5
8
12
16
IZ (mA)
BZT52-B2V4 to BZT52-B4V3
Tj = 25 °C to 150 °C
BZT52-B4V7 to BZT52-B12
Figure 3. Temperature coefficient as a function of
working current; typical values
Figure 4. Temperature coefficient as a function of
8
Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
BZT52-B_SER
Product data sheet
6 / 11
BZT52-B series
Nexperia
9
Package outline
3.75
3.45
2.80
2.55
1.3
1.0
1
2
1.7
1.5
Dimensions in mm
16-10-13
Figure 5. Package outline SOD123
10 Soldering
SOD123
4.58
3.27
3.1
2.1 1.62
1.12 1.22 1.42
0.81
0.81
0.91
2.36
0.91
4.18
1.11
occupied area
solder resist
Cu pad
solder paste
1.11
16-05-10
16-08-31
Dimensions in mm
sod123_fr
Reflow soldering is the only recommended soldering method.
Dimensions in mm.
Figure 6. Reflow soldering footprint SOD123
BZT52-B_SER
Product data sheet
7 / 11
BZT52-B series
Nexperia
11 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BZT52-B_SER v.1
20171220
Product data sheet
BZT52-B_SER
Product data sheet
8 / 11
BZT52-B series
Nexperia
12 Legal information
12.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
BZT52-B_SER
Product data sheet
9 / 11
BZT52-B series
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BZT52-B_SER
Product data sheet
10 / 11
BZT52-B series
Nexperia
Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
1 Product profile ................................................. 1
General description ............................................1
Features and benefits ........................................1
Applications ........................................................1
Quick reference data ......................................... 1
Pinning information ............................................ 2
Ordering information .......................................... 2
Marking .................................................................2
Limiting values .................................................... 3
Thermal characteristics ......................................3
Characteristics .................................................... 3
Test information .................................................. 6
Quality information .............................................6
Package outline ...................................................7
Soldering ..............................................................7
Revision history .................................................. 8
Legal information ................................................ 9
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 20 December 2017
Document identifier: BZT52-B_SER
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
BZT52-B11J BZT52-B39X BZT52-B4V7X BZT52-B75J BZT52-B75X BZT52-B7V5X BZT52-B68X BZT52-B6V2X
BZT52-B8V2J BZT52-B13J BZT52-B27J BZT52-B3V6J BZT52-B4V3X BZT52-B5V6J BZT52-B9V1J BZT52-B16X
BZT52-B18X BZT52-B36X BZT52-B3V3J BZT52-B5V1J BZT52-B7V5J BZT52-B12J BZT52-B2V4J BZT52-B33X
BZT52-B47X BZT52-B6V8X BZT52-B10J BZT52-B20X BZT52-B24X BZT52-B3V0X BZT52-B51J BZT52-B56J
BZT52-B43J BZT52-B43X BZT52-B68J BZT52-B11X BZT52-B3V3X BZT52-B8V2X BZT52-B6V8J BZT52-B9V1X
BZT52-B13X BZT52-B15X BZT52-B2V7J BZT52-B3V9J BZT52-B12X BZT52-B18J BZT52-B27X BZT52-B3V6X
BZT52-B4V7J BZT52-B6V2J BZT52-B5V1X BZT52-B2V7X BZT52-B30X BZT52-B3V9X BZT52-B47J BZT52-B62J
BZT52-B20J BZT52-B2V4X BZT52-B33J BZT52-B36J BZT52-B4V3J BZT52-B56X BZT52-B22J BZT52-B22X
BZT52-B24J BZT52-B39J BZT52-B3V0J BZT52-B51X BZT52-B15J BZT52-B16J BZT52-B30J BZT52-B5V6X
BZT52-B62X BZT52-B10X
