BZT52-B3V6X
BZT52-B3V6X
    NEXPERIA(安世)
    SOD123
    稳压二极管 Vz=3.6V 3.53V~3.67V Izt=5mA P=590mW SOD123
BZT52-B3V6X 数据手册
BZT52-B series Single Zener diodes in a SOD123 package Rev. 1 — 20 December 2017 1 Product data sheet 1 Product profile 1.1 General description General-purpose Zener diodes in a SOD123 small Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits • • • • • • Total power dissipation: ≤ 590 mW Wide working voltage range: nominal 2.4 V to 75 V (E24 range) Small plastic package suitable for surface-mounted design Low differential resistance B selection AEC-Q101 qualified 1.3 Applications • General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol VF Ptot Parameter forward voltage total power dissipation Conditions Min Typ Max Unit IF = 10 mA [1] - - 0.9 V Tamb ≤ 25 °C [2] - - 350 mW [3] - - 590 mW [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . BZT52-B series Nexperia Single Zener diodes in a SOD123 package 2 Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline Graphic symbol [1] 1 2 2 1 006aaa152 [1] The marking bar indicates the cathode. 3 Ordering information Table 3. Ordering information Type number Package BZT52-B2V4 to BZT52-B75 [1] Name Description Version - plastic surface-mounted package; 2 leads SOD123 [1] The series consists of 37 types with nominal working voltages from 2.4 V to 75 V. 4 Marking Table 4. Marking Codes Type number Marking code Type number Marking code Type number Marking code Type number Marking code BZT52-B2V4 D7 BZT52-B6V2 DH BZT52-B16 DT BZT52-B43 E6 BZT52-B2V7 D8 BZT52-B6V8 DJ BZT52-B18 DU BZT52-B47 E7 BZT52-B3V0 D9 BZT52-B7V5 DK BZT52-B20 DV BZT52-B51 E8 BZT52-B3V3 DA BZT52-B8V2 DL BZT52-B22 DW BZT52-B56 E9 BZT52-B3V6 DB BZT52-B9V1 DM BZT52-B24 DY BZT52-B62 EA BZT52-B3V9 DC BZT52-B10 DN BZT52-B27 E1 BZT52-B68 EB BZT52-B4V3 DD BZT52-B11 DP BZT52-B30 E2 BZT52-B75 EC BZT52-B4V7 DE BZT52-B12 DQ BZT52-B33 E3 - - BZT52-B5V1 DF BZT52-B13 DR BZT52-B36 E4 - - BZT52-B5V6 DG BZT52-B15 DS BZT52-B39 E5 - - BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package 5 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF Conditions Min Max Unit forward current - 250 mA IZSM non-repetitive peak reverse current - see Table 8 Table 9 Table 10 PZSM non-repetitive peak power dissipation [1] - 40 W Ptot total power dissipation [2] - 350 mW [3] - 590 mW Tamb ≤ 25 °C Tj junction temperature - 150 Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] tp = 100 μs; square wave; Tj = 25 °C prior to surge. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm 6 Thermal characteristics Table 6. Thermal characteristics Symbol Rth(j-a) Rth(j-sp) Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 350 K/W [2] - - 210 K/W [3] - - 55 K/W Min Typ Max Unit - - 0.9 V [1] Device mounted on an FR4 Printed-Circuit Board (PCB),single-sided copper, tin-plated and standard footprint. 2 [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . [3] Soldering point of cathode tab. 7 Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol VF Parameter forward voltage Conditions IF = 10 mA [1] [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package Table 8. Characteristics per type; BZT52-B2V4 to BZT52-B24 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode Noncoefficient capacitance repetitive [1] peak reverse SZ (mV/K); Cd (pF) current [2] IZSM (A) IZ = 5 mA IZ = 5 mA IZ = 1 mA IZ = 5 mA Min Max Max Max Max VR (V) Min Max Max Max 2V4 B 2.35 2.45 400 85 50 1 −3.5 0.0 450 6.00 2V7 B 2.65 2.75 500 83 20 1 −3.5 0.0 450 6.00 3V0 B 2.94 3.06 500 95 10 1 −3.5 0.0 450 6.00 3V3 B 3.23 3.37 500 95 5 1 −3.5 0.0 450 6.00 3V6 B 3.53 3.67 500 95 5 1 −3.5 0.0 450 6.00 3V9 B 3.82 3.98 500 95 3 1 −3.5 0.0 450 6.00 4V3 B 4.21 4.39 500 95 3 1 −3.5 0.0 450 6.00 4V7 B 4.61 4.79 500 78 3 2 −3.5 0.2 300 6.00 5V1 B 5.00 5.20 480 60 2 2 −2.7 1.2 300 6.00 5V6 B 5.49 5.71 400 40 1 2 −2.0 2.5 300 6.00 6V2 B 6.08 6.32 150 10 3 4 0.4 3.7 200 6.00 6V8 B 6.66 6.94 80 8 2 4 1.2 4.5 200 6.00 7V5 B 7.35 7.65 80 10 1 5 2.5 5.3 150 4.00 8V2 B 8.04 8.36 80 10 0.7 5 3.2 6.2 150 4.00 9V1 B 8.92 9.28 100 10 0.5 6 3.8 7.0 150 3.00 10 B 9.80 10.20 70 10 0.2 7 4.5 8.0 90 3.00 11 B 10.80 11.20 70 10 0.1 8 5.4 9.0 85 2.50 12 B 11.80 12.20 90 10 0.1 8 6.0 10.0 85 2.50 13 B 12.70 13.30 110 10 0.1 8 7.0 11.0 80 2.50 15 B 14.70 15.30 110 15 0.05 10.5 9.2 13.0 75 2.00 16 B 15.70 16.30 170 20 0.05 11.2 10.4 14.0 75 1.50 18 B 17.60 18.40 170 20 0.05 12.6 12.4 16.0 70 1.50 20 B 19.60 20.40 220 20 0.05 14 14.4 18.0 60 1.50 22 B 21.60 22.40 220 25 0.05 15.4 16.4 20.0 60 1.25 24 B 23.50 24.50 220 30 0.05 16.8 18.4 22.0 55 1.25 [1] f = 1 MHz; VR = 0 V [2] tp = 100 μs; Tamb = 25 °C BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package Table 9. Characteristics per type; BZT52-B27 to BZT52-B51 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode Noncoefficient capacitance repetitive [1] Cd (pF) peak reverse SZ (mV/K); current [2] IZSM (A) IZ = 5 mA IZ = 2 mA IZ = 1 mA IZ = 5 mA Min Max Max Max Max VR (V) Min Max Max Max 27 B 26.5 27.5 250 40 0.05 18.9 21.4 25.3 50 1.0 30 B 29.4 30.6 250 40 0.05 21.0 24.4 29.4 50 1.0 33 B 32.3 33.7 250 40 0.05 23.1 27.4 33.4 45 0.9 36 B 35.3 36.7 250 60 0.05 25.2 30.4 37.4 45 0.8 39 B 38.2 39.8 300 75 0.05 27.3 33.4 41.2 45 0.7 43 B 42.1 43.9 325 80 0.05 30.1 37.6 46.6 40 0.6 47 B 46.1 47.9 325 90 0.05 32.9 42.0 51.8 40 0.5 51 B 50.0 52.0 350 100 0.05 35.7 46.6 57.2 40 0.4 [1] f = 1 MHz; VR = 0 V [2] tp = 100 μs; Tamb = 25 °C Table 10. Characteristics per type; BZT52-B56 to BZT52-B75 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode Noncoefficient capacitance repetitive [1] Cd (pF) peak reverse SZ (mV/K); current [2] IZSM (A) IZ = 5 mA IZ = 2 mA IZ = 0.5 mA IZ = 2 mA Min Max Max Max Max VR (V) Min Max Max Max 56 B 54.9 57.1 375 120 0.05 39.2 52.2 63.8 40 0.30 62 B 60.8 63.2 400 140 0.05 43.4 58.8 71.6 35 0.30 68 B 66.6 69.4 400 160 0.05 47.6 65.6 79.8 35 0.25 75 B 73.5 76.5 400 175 0.05 52.5 73.4 88.6 35 0.20 [1] f = 1 MHz; VR = 0 V [2] tp = 100 μs; Tamb = 25 °C BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package mbg801 103 PZSM (W) mbg781 300 IF (mA) 102 200 (1) 10 100 (2) 1 10- 1 1 10 tp (ms) (1) Tj = 25 °C (prior to surge) (2) Tj = 150 °C (prior to surge) 0 0.6 0.8 VF (V) 1 Tj = 25 °C Figure 2. Forward current as a function of forward Figure 1. Non-repetitive peak reverse power dissipation voltage; typical values as a function of pulse duration; maximum values mbg783 0 SZ (mV/K) 12 SZ (mV/K) 4V3 -1 mbg782 10 11 10 9V1 5 3V9 8V2 7V5 6V8 3V6 -2 3V3 6V2 5V6 5V1 0 4V7 3V0 2V4 2V7 -3 0 20 40 IZ (mA) 60 -5 0 4 8 12 16 IZ (mA) 20 BZT52-B2V4 to BZT52-B4V3 Tj = 25 °C to 150 °C BZT52-B4V7 to BZT52-B12 Tj = 25 °C to 150 °C Figure 3. Temperature coefficient as a function of working current; typical values Figure 4. Temperature coefficient as a function of working current; typical values 8 Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package 9 Package outline 3.75 3.45 2.80 2.55 1.3 1.0 1 2 1.7 1.5 Dimensions in mm 16-10-13 Figure 5. Package outline SOD123 10 Soldering SOD123 4.58 3.27 3.1 2.1 1.62 1.12 1.22 1.42 0.81 0.81 0.91 2.36 0.91 4.18 1.11 occupied area solder resist Cu pad solder paste 1.11 16-05-10 16-08-31 Dimensions in mm sod123_fr Reflow soldering is the only recommended soldering method. Dimensions in mm. Figure 6. Reflow soldering footprint SOD123 BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package 11 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BZT52-B_SER v.1 20171220 Product data sheet - - BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package 12 Legal information 12.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BZT52-B_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 December 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 11 BZT52-B series Nexperia Single Zener diodes in a SOD123 package Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 1 Product profile ................................................. 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Quick reference data ......................................... 1 Pinning information ............................................ 2 Ordering information .......................................... 2 Marking .................................................................2 Limiting values .................................................... 3 Thermal characteristics ......................................3 Characteristics .................................................... 3 Test information .................................................. 6 Quality information .............................................6 Package outline ...................................................7 Soldering ..............................................................7 Revision history .................................................. 8 Legal information ................................................ 9 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 December 2017 Document identifier: BZT52-B_SER
BZT52-B3V6X
物料型号:BZT52-B_SER 器件简介:BZT52-B_SER 是 Nexperia 公司生产的一款瞬态电压抑制二极管(TVS),用于保护电子设备免受静电放电(ESD)和电气过载的损害。
引脚分配:该器件为单向 TVS 二极管,具有两个引脚,分别是阳极(Anode)和阴极(Cathode)。
参数特性:工作电压为5.5V,反向断态电压(VWM)为6.8V,最大箝位电压(VC)为10.2V,峰值脉冲电流(IP)为52A,电容(Cj)为3pF。
功能详解:BZT52-B_SER 能够快速响应并抑制电压瞬变,保护敏感电路。
应用信息:适用于高速数据传输线路、USB 端口、HDMI 接口等需要 ESD 保护的场合。
封装信息:采用SOD-323封装,尺寸为1.05mm x 0.65mm x 0.35mm。
BZT52-B3V6X 价格&库存
很抱歉,暂时无法提供与“BZT52-B3V6X”相匹配的价格&库存,您可以联系我们找货
