PBSS4041PZ,115
PBSS4041PZ,115
    NEXPERIA(安世)
    SOT-223
    PNP低VCEsat(BISS)晶体管 VCEO=60V IC=5.7A VEBO=5V SOT223
PBSS4041PZ,115 数据手册
PBSS4041PZ 60 V, 5.7 A PNP low VCEsat (BISS) transistor Rev. 01 — 31 March 2010 Product data sheet 1. Product profile 1.1 General description PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a SOT223 (SC-73) medium power Surface-Mounted Device (SMD) plastic package. NPN complement: PBSS4041NZ. 1.2 Features and benefits „ „ „ „ „ „ Very low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM High collector current gain (hFE) at high IC High energy efficiency due to less heat generation AEC-Q101 qualified Smaller required Printed-Circuit Board (PCB) area than for conventional transistors 1.3 Applications „ „ „ „ „ Loadswitch Battery-driven devices Power management Charging circuits Power switches (e.g. motors, fans) 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - −60 V IC collector current - - −5.7 A ICM peak collector current single pulse; tp ≤ 1 ms - - −15 A RCEsat collector-emitter saturation resistance IC = −5 A; IB = −500 mA - 29 43.5 mΩ [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 2. Pinning information Table 2. Pinning Pin Description 1 base 2 collector 3 emitter 4 collector Simplified outline Graphic symbol 4 2, 4 1 1 2 3 3 sym028 3. Ordering information Table 3. Ordering information Type number Package Name Description Version PBSS4041PZ SC-73 plastic surface-mounted package with increased heat sink; 4 leads SOT223 4. Marking Table 4. Marking codes Type number Marking code PBSS4041PZ PB4041PZ 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). PBSS4041PZ_1 Product data sheet Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - −60 V VCEO collector-emitter voltage open base - −60 V VEBO emitter-base voltage open collector - −5 V IC collector current - −5.7 A ICM peak collector current - −15 A IB base current - −1 A single pulse; tp ≤ 1 ms All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Ptot Parameter Conditions total power dissipation Tamb ≤ 25 °C Min Max Unit [1] - 770 mW [2] - 1700 mW [3] - 2600 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aac060 3.0 (1) Ptot (W) 2.0 (2) 1.0 0 −75 (3) −25 25 75 125 175 Tamb (°C) (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm2 (3) FR4 PCB, standard footprint Fig 1. PBSS4041PZ_1 Product data sheet Power derating curves All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions thermal resistance from junction to ambient Rth(j-a) in free air Min Typ Max Unit [1] - - 160 K/W [2] - - 75 K/W [3] - - 50 K/W - - 11 K/W thermal resistance from junction to solder point Rth(j-sp) [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2. [3] Device mounted on a ceramic PCB, Al2O3, standard footprint. 006aac061 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.33 0.2 0.1 10 0.05 0.02 0.01 1 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 006aac062 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.2 10 0.1 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for collector 6 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac063 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.50 0.33 10 0.20 0.10 0.05 0.02 1 0.01 0 10−1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter ICBO Conditions collector-base cut-off VCB = −60 V; IE = 0 A current VCB = −60 V; IE = 0 A; Tj = 150 °C Max Unit - - −100 nA - - −55 μA collector-emitter cut-off current VCE = −48 V; VBE = 0 V - - −100 nA IEBO emitter-base cut-off current VEB = −5 V; IC = 0 A - - −100 nA hFE DC current gain VCE = −2 V; IC = −500 mA 200 300 - VCE = −2 V; IC = −1 A 200 300 - VCE = −2 V; IC = −2 A 200 300 - VCE = −2 V; IC = −4 A 150 250 - 120 200 - IC = −1 A; IB = −50 mA - −42 −63 mV IC = −1 A; IB = −10 mA - −82 −125 mV IC = −2 A; IB = −40 mA - −98 −150 mV IC = −4 A; IB = −200 mA - −130 −195 mV IC = −4 A; IB = −400 mA - −115 −175 mV [1] VCE = −2 V; IC = −6 A collector-emitter saturation voltage [1] IC = −6 A; IB = −300 mA - −190 −285 mV - 29 43.5 mΩ RCEsat collector-emitter IC = −5 A; IB = −500 mA saturation resistance [1] VBEsat base-emitter saturation voltage IC = −1 A; IB = −100 mA [1] - −0.82 −0.9 V IC = −4 A; IB = −400 mA [1] - −0.98 −1.05 V VBEon base-emitter turn-on voltage VCE = −2 V; IC = −2 A [1] - −0.74 −0.85 V td delay time - 60 - ns tr rise time - 60 - ns ton turn-on time VCC = −12.5 V; IC = −1 A; IBon = −0.05 A; IBoff = 0.05 A - 120 - ns ts storage time - 530 - ns tf fall time - 100 - ns toff turn-off time - 630 - ns fT transition frequency - 110 - MHz Cc collector capacitance VCB = −10 V; IE = ie = 0 A; f = 1 MHz - 85 - pF [1] Product data sheet Typ ICES VCEsat PBSS4041PZ_1 Min VCE = −10 V; IC = −100 mA; f = 100 MHz Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 006aac164 500 hFE 006aac165 −16.0 IB (mA) = −170 IC (A) (1) 400 −136 −12.0 300 −102 −68 (2) −8.0 −153 −119 −85 −51 −34 200 (3) −17 −4.0 100 0 −10−1 −1 −10 −102 −103 0.0 0.0 −104 −105 IC (mA) VCE = −2 V −1.0 −2.0 −3.0 −4.0 −5.0 VCE (V) Tamb = 25 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 5. DC current gain as a function of collector current; typical values 006aac166 −1.2 VBE (V) Fig 6. Collector current as a function of collector-emitter voltage; typical values 006aac167 −1.3 VBEsat (V) −0.8 −0.9 (1) (1) (2) (2) (3) −0.4 0.0 −10−1 −1 −10 −0.5 −102 −103 −104 −105 IC (mA) (3) −0.1 −10−1 VCE = −2 V −1 −10 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values Product data sheet −104 −105 IC (mA) (1) Tamb = −55 °C (3) Tamb = 100 °C PBSS4041PZ_1 −103 IC/IB = 20 (2) Tamb = 25 °C Fig 7. −102 Fig 8. Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 006aac168 −1 006aac169 −1 VCEsat (V) VCEsat (V) −10−1 −10−1 (1) −10−2 (2) (2) (1) (3) −10−2 (3) −10−3 −10−1 −1 −10 −102 −103 −104 −105 IC (mA) −10−3 −10−1 −1 −102 −103 −104 −105 IC (mA) Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 9. −10 Collector-emitter saturation voltage as a function of collector current; typical values 006aac170 103 Fig 10. Collector-emitter saturation voltage as a function of collector current; typical values 006aac171 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 (1) (2) 10−1 10−1 (1) (3) (2) (3) 10−2 −10−1 −1 −10 −102 −103 −104 −105 IC (mA) 10−2 −10−1 −1 (1) Tamb = 100 °C (1) IC/IB = 100 (2) Tamb = 25 °C (2) IC/IB = 50 (3) Tamb = −55 °C (3) IC/IB = 10 Fig 11. Collector-emitter saturation resistance as a function of collector current; typical values Product data sheet −102 −103 −104 −105 IC (mA) Tamb = 25 °C IC/IB = 20 PBSS4041PZ_1 −10 Fig 12. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 8. Test information − IB input pulse (idealized waveform) 90 % − I Bon (100 %) 10 % − I Boff output pulse (idealized waveform) − IC 90 % − I C (100 %) 10 % t td ts tr t on tf t off 006aaa266 Fig 13. BISS transistor switching time definition VBB RB oscilloscope VCC RC Vo (probe) 450 Ω (probe) 450 Ω oscilloscope R2 VI DUT R1 mgd624 Fig 14. Test circuit for switching times 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 9 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 9. Package outline 6.7 6.3 3.1 2.9 1.8 1.5 4 1.1 0.7 7.3 6.7 3.7 3.3 1 2 3 2.3 4.6 0.8 0.6 Dimensions in mm 0.32 0.22 04-11-10 Fig 15. Package outline SOT223 (SC-73) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PBSS4041PZ [1] PBSS4041PZ_1 Product data sheet Package Description SOT223 8 mm pitch, 12 mm tape and reel Packing quantity 1000 4000 -115 -135 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 10 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 11. Soldering 7 3.85 3.6 3.5 0.3 1.3 1.2 (4×) (4×) solder lands 4 solder resist 3.9 6.1 7.65 solder paste occupied area 1 2 3 Dimensions in mm 2.3 2.3 1.2 (3×) 1.3 (3×) 6.15 sot223_fr Fig 16. Reflow soldering footprint SOT223 (SC-73) 8.9 6.7 1.9 solder lands 4 solder resist 6.2 8.7 occupied area Dimensions in mm 1 2 3 preferred transport direction during soldering 1.9 (3×) 2.7 2.7 1.1 1.9 (2×) sot223_fw Fig 17. Wave soldering footprint SOT223 (SC-73) PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 11 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PBSS4041PZ_1 20100331 Product data sheet - - PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 12 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or PBSS4041PZ_1 Product data sheet malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 13 of 15 PBSS4041PZ Nexperia 60 V, 5.7 A PNP low VCEsat (BISS) transistor 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PBSS4041PZ_1 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 01 — 31 March 2010 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PBSS4041PZ 60 V, 5.7 A PNP low VCEsat (BISS) transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 31 March 2010
PBSS4041PZ,115 价格&库存
很抱歉,暂时无法提供与“PBSS4041PZ,115”相匹配的价格&库存,您可以联系我们找货
PBSS4041PZ,115
    PBSS4041PZ,115
      PBSS4041PZ,115
