MES105J2A-7-50R0
MES105J2A-7-50R0
    HEL(鸿志)
    CAP_7.2X6MM_TM
    薄膜电容 CAP_7.2X6MM_TM 1µF ±5% 7.20 x 6.00mm 100V
MES105J2A-7-50R0 数据手册
R REF FILE JD-2020080501 EDITION NO: A 规 格 承 认 书 SPECIFICATION FOR APPROVAL 客 户 CUSTOMER NAME 项 : 目 DESCRIPTION : 客 金属化聚丙烯膜抗干扰电容器 户 料 号 CUSTOMER’S P/N 鸿 志 料 : METALLIZED POLYPROPYLENE FILM X2 电容 号 HEL’S P/N : ※This specification will be invalidated assuming that it is not accepted when it is not returned with one year from the date of issue CUSTOMER APPROVAL PREPARE HEL APPROVAL PREPARE 林意杰 林俊松 HEL HONG ZHI ENTERPRISE CO ADD: No6,Pujiang Rd,Longhu Industrial Park, Shantou,Guangdong, China TEL: 0754-88788046 88857416 http: www.hongzhi.net FAX: 0754-88888417 ADD: Unit 10,11/F,BlkA..Hoil Luen Industrial Center ,55 HoiYuen Road,Kwun Tong TEL: 0852-23412900 emquiry:hongzhi@hongzhi.net FAX: 0852-27903481 issed date:2020-8-5 Edit:A NO: HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS TYPE: MPX T 15.0MIN H H max W A CUSTOMER CAP P/N (μF) B CAP RATED 1KHZ TOL VOLTAGE DF% (±%) (VAC) (MAX) DIMENSION(mm) HongZhi W+0.4/0.7 C333838 0.1 http: www.hongzhi.net 5 100 0.1 D C 7.2 H±0.4 T±0.4 P Ød 7.5 3.5 5.0 0.5 emquiry:hongzhi@hongzhi.net 1 P/N MEM104J2A-7-50R0 issed date: 2020-8-5 Edit:A Fig A HONGZHI HEL ELECTRONIC Ltd PLASTIC FILM CAPACITORS 1.SAFETY APPROVAL STANDARDS Specification Subject File No CQC(GB/T 14472-1998) Interference suppression capacitor CQC07001018754 UL(UL1414) Across the line ,Antenna coupling and line by pass capacitor E192572 CSA (CSA C22.2 NO-104) Across the line,Audio and Video equipment 2052630 VDE(IEC60384-14-Ⅲ EN132400) Fixed capacitor for electromagnetic interference suppression and 40023936 connection to the supply mains Fixed capacitor for electromagnetic interference suppression and ENEC(IEC60384-14-Ⅲ EN132400) NO2154 connection to the supply mains 2.NUMBER DECODE REGULATION MEM 104 J    2A 7 5 0 R 0 0   . . .  1. SERIES PEI PES PEN MPE MES MEM MMB MEB MET MEF PPL PPN PPT MPP MPB MPT MPF MPS MSB PST PSC PPS PSM PSB PSH PHB MPX MX1 MPY SKC PSA PSR PCC PAC 2. RATED CAPACITANCE CODE 101 PF 100PF NF μF 102 1000PF 1 NF 0.001μF 3. TOLERANCE Tolerance Symbols ±2% G 4. RATED VOLTAGE A B C ±1% F 103 10000PF 10 NF 0.01μF 104 100000PF 100 NF 0.1μF ±2.5% H ±3% I 105 1000000PF 1000 NF 1.0μF ±5% J I 106 10μF ±10% K ±20% M D E F G H J K 0 1.0 1.25 1.6 2.0 2.5 3.15 4.0 5.0 6.3 8.0 1 10 12.5 16 20 25 31.5 40 50 63 80 2 100 125 160 200 250 315 400 500 630 800 3 1000 1250 1600 2000 2500 3150 4000 5000 6300 8000 4 10000 12500 16000 20000 25000 31500 40000 50000 175V 275V AC AC 7 5. L 63000 80000 WIDTH OR DIAMETED mm A B C D E A1=11mm, 0 10 20 30 40 50 -1=1mm , http: www.hongzhi.net 1 1 11 21 31 41 51 2 2.5 12.5 22.5 32.5 42.5 52.5 3 3 13 23 33 43 53 -2=2.5mm, -7=7.5mm 4 4 14 24 34 44 54 5 5 15 25 35 45 55 6 6 16 26 36 46 56 7 7.5 17.5 27.5 37.5 47.5 57.5 8 8 18 28 38 48 58 9 9 19 29 39 49 59 B3=23mm emquiry:hongzhi@hongzhi.net 2 issed date: 2020-8-5 Edit:A HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS 6. PITCH OF LENGTH mm - A B 1 10 11 C 2 1 20 30 D 3 2.5 4 3 12.5 5 4 13 6 5 14 7 6 15 8 7.5 16 9 8 17.5 9 18 19 21 22.5 23 24 25 26 27.5 28 29 41 42.5 43 44 45 46 47.5 48 49 31 40 32.5 33 34 35 36 37.5 38 39 E 50 51 52.5 53 54 55 56 57.5 58 59 G 70 71 72.5 73 74 75 76 77.5 78 79 95 96 97.5 98 99 F 60 H A1=11mm, 61 80 I 7. 0 62.5 81 90 82.5 91 -1=1mm , 63 64 83 92.5 84 93 -2=2.5mm, -7=7.5mm 65 66 85 94 67.5 86 68 87.5 69 88 89 B3=23mm LEAD STYLE   0. no forming;  1. strait forming;   2. out kink & flat forming;   3. in kink & stand kink;   4. strait cut short lead; forming and short lead ; 6. out forming short lead; 8. 7. in kink short lead & stand form short lead; 8. double king short lead. LEAD LENGTH mm Code T 0 1 2 3 4 5 Meaning Tapping 3.5 3.8±0.3 4±0.5 4.5 5±0.5 5±1 Meaning 10 11 12 13 14 15 Meaning 21 22 23 24 25 30 Meaning 60above Code Code Code A M Z B N C P D Q E R F S 6 7 6 7 16 17 35 40 G U H V 8 9 8 9 18 19 20 45 50 55 J W K X L Y 9.10. CONSTRUCTION CODE (internal use) http: www.hongzhi.net emquiry:hongzhi@hongzhi.net 3 issed date: 2020-8-5 Edit:A 5. inner HONGZHI HEL ELECTRONIC PLASTIC FILM CAPACITORS 3. SPECIFICATIONS: 1. OPERATING TEMPERATURE: -40℃~+105℃ 2. CAPACITANCE RANGE: 0.01μF~2.2μF 3. CAPACITANCE TOLERANCE: ±5%(J), ±10%(K), ±20%(M) 4. RATED VOLTAGE: 250VAC~, 275VAC 5. DISSIPATION FACTOR: 0.1% MAX AT 1KHZ, 25℃ 6. INSULATION RESISTANCE: >35000 MΩ(C≦0.33μF); 1000 MΩ·μF (C>0.33μF) 7. 7. MAX. Pulse rise time (dv/dt) : VR (ac) 10mm 500 275VAC 4. PERFORMANCE Test Characteristics Withstand voltage: Between terminals (4.3Ur ) Withstand voltage: Between terminals & enclosure Insulation resistance: Between terminals Insulation resistance: Between terminals & enclosure Heat proof: Insulation resistance at 85℃ Heat proof: Rate of variation of capacitance at 85℃ Impulse voltage 15mm 400 Lead spacing 22.5mm 27.5mm 200 140 Performance For1800VDC Shall be no abnormality 2 sec. For 2.0UR+1500VAC 2 sec Shall be no abnormality Apply rated voltage ±15% for 60 sec. When rated voltage under 100V. Apply 100V ±15% when rated voltage from 100V to 500V at 20 ℃ ≧30,000MΩ Testing temperature: 85±2℃. According to fig.1, before endurance Vibration Bump 4000 bumps at 390m/s2 Upper and lower rated temperature 5 cycles Change or temperature Solderability Solder globule method Passive flammability Flame exposure severity Active flammability time depending on Surge pulses +URVAC Humidity 37.5mm 100 GB/T 14472 (IEC 60384-14) According to fig.2 with U2=1000VAC X: U1=1.25UR VAC 3 directions at 2 hours each 10-500Hz at 0.75mm or 98m/s2 Endurance 5. +40℃ and 9-95% R.H. ≧30,000MΩ +5% Within-2% of the value before test No permanent breakdown or flashover Voltage proof C, DF and insulation No visible damage; No open or; Short circuit No visible damage ; No open or Short circuit No visible damage Wetting time for d≦0.80.80.022 1000 PCS EIA STANDARD RS-296-D Optional B Arbor hole 6.35m +5 A B C 50-2 260±2 330±2 C≦0.047 1500 PCS C>0.047 1000 PCS Hub recess I. D. “E” ≦ Label Dia “D” A Recess depth 9.5mm (0.374”) minimum ≦0.8mm 1. Reel label consists of: 2. Component type 3. Electrical values; 5. Date EIA Std. RF Spec ; 4. Manufacturer’s name Core 6. Component quantity diameter ”F” CAPACITOR BODY DIAMETER ≧5mm (≧ 0.197”) 5.01~10mm (0.197~0.394”) 10.01~15mm (0.394~0.591”) CAPACITOR PITCH”A”±0.5mm (0.020”) 5mm or 0.200” 10mm or 0.400” 15mm or 0.600” CAPACITOR BODY LENGTH INSIDE TAPE SPACING “B” ±1.5mm (0.059”) ≧16.50mm (≧0.65”) 16.51~28.45mm (0.651~1.12”) 28.46~37.00mm (1.121~1.45”) 52.44mm or 2.062” 63.5mm or 2.500” 76.0mm or 2.874” C 13.9~38.1mm (0.54~1.50”) 14.50mm (0.570”) CAPACITOR BODY DIA. ≧ 5.0mm 5.1~7.0mm 7.1~9.5mm http: www.hongzhi.net D 76.2~355.6mm (3.0~14.0”) 381.0mm (15”) E 28.6~78.0mm (1.126~3.071”) 54.2mm (2.130”) PITCH 6mm 10mm 10mm F 34.5~92.0mm(1.374’3.626”) 61.0mm (2.401”) QUANTITY PCS/REEL 4000 max 2000 max 1000 max emquiry:hongzhi@hongzhi.net 6 issed date: 2020-8-5 Edit:A HEL HONGZHI ELECTRONIC Ltd PLASTIC FILM CAPACITORS 10.METALLIZED POLYPROPYLENE FILM INTERFERENCE SUPPRESSION CAPACITOR- -X2 Permissible Characteristics of voltage derating to frequency --- MPX V(rms) 275VAC 1000 474 100 103 225 1K 10K 100K 1000K 683 Frequency NOTE: The graphs illustrated above are for reference only wave form of current and temperature rise of capacitor are key factors to determine permissible current. For actual applicant on. Consult our sales represent ative or sales office. http: www.hongzhi.net emquiry:hongzhi@hongzhi.net 7 issed date: 2020-8-5 EditA
MES105J2A-7-50R0 价格&库存
很抱歉,暂时无法提供与“MES105J2A-7-50R0”相匹配的价格&库存,您可以联系我们找货
MES105J2A-7-50R0
  • 5+0.81500
  • 20+0.74000
  • 100+0.66500
  • 500+0.59000
  • 1000+0.55500
  • 2000+0.53000
库存:2175
MES105J2A-7-50R0
    • 5+0.85007
    • 50+0.69941
    • 150+0.62198
    • 1000+0.47218
    • 2000+0.44993
    • 5000+0.43481
    库存:35152
