R
REF
FILE
JD-2020080501
EDITION NO: A
规 格 承 认 书
SPECIFICATION FOR APPROVAL
客
户
CUSTOMER NAME
项
目
DESCRIPTION
客
金属化聚丙烯膜抗干扰电容器
户
料
号
CUSTOMER’S P/N
鸿
志
料
METALLIZED POLYPROPYLENE FILM
X2 电容
号
HEL’S P/N
※This specification will be invalidated assuming that it is not accepted when it is not returned with one year from the date of issue
CUSTOMER
APPROVAL
PREPARE
HEL
APPROVAL
PREPARE
林意杰
林俊松
HEL
HONG ZHI ENTERPRISE CO
ADD: No6,Pujiang Rd,Longhu Industrial Park, Shantou,Guangdong, China
TEL: 0754-88788046 88857416
http: www.hongzhi.net
FAX: 0754-88888417
ADD: Unit 10,11/F,BlkA..Hoil Luen Industrial Center ,55 HoiYuen Road,Kwun Tong
TEL: 0852-23412900
emquiry:hongzhi@hongzhi.net
FAX: 0852-27903481
issed date:2020-8-5 Edit:A
NO:
HEL
HONGZHI
ELECTRONIC
Ltd
PLASTIC FILM CAPACITORS
TYPE: MPX
T
15.0MIN
H
H max
W
A
CUSTOMER
CAP
P/N
(μF)
B
CAP
RATED
1KHZ
TOL
VOLTAGE
DF%
(VAC)
(MAX)
DIMENSION(mm)
HongZhi
W+0.4/0.7
C333838
0.1
5
100
0.1
D
C
7.2
H±0.4
T±0.4
P
Ød
7.5
3.5
5.0
0.5
1
P/N
MEM104J2A-7-50R0
issed date: 2020-8-5
Edit:A
Fig
A
HONGZHI
HEL
ELECTRONIC
Ltd
1.SAFETY APPROVAL STANDARDS
Specification
Subject
File No
CQC(GB/T 14472-1998)
Interference suppression capacitor
CQC07001018754
UL(UL1414)
Across the line ,Antenna coupling and line by pass capacitor
E192572
CSA (CSA C22.2 NO-104)
Across the line,Audio and Video equipment
2052630
VDE(IEC60384-14-Ⅲ EN132400)
Fixed capacitor for electromagnetic interference suppression and
40023936
connection to the supply mains
ENEC(IEC60384-14-Ⅲ EN132400)
NO2154
2.NUMBER DECODE REGULATION
MEM 104 J
2A 7
5 0 R 0 0
1. SERIES
PEI PES PEN MPE MES MEM MMB MEB MET MEF PPL PPN PPT MPP MPB MPT MPF
MPS MSB PST PSC PPS PSM PSB PSH PHB MPX MX1 MPY SKC PSA PSR PCC PAC
2.
RATED CAPACITANCE
CODE
101
PF
100PF
NF
μF
102
1000PF
1 NF
0.001μF
3.
TOLERANCE
Tolerance
Symbols
±2%
G
4.
RATED VOLTAGE
A
B
C
±1%
F
103
10000PF
10 NF
0.01μF
104
100000PF
100 NF
0.1μF
±2.5%
H
±3%
I
105
1000000PF
1000 NF
1.0μF
±5%
J
I
106
10μF
±10%
K
±20%
M
D
E
F
G
H
J
K
1.25
1.6
2.0
2.5
3.15
4.0
5.0
6.3
8.0
1
10
12.5
16
31.5
40
50
63
80
2
100
125
160
200
250
315
400
500
630
800
3
1000
1250
1600
2000
2500
3150
4000
5000
6300
8000
4
10000 12500 16000 20000 25000 31500 40000 50000
175V 275V
AC
AC
7
5.
L
63000 80000
WIDTH OR DIAMETED mm
A
B
C
D
E
A1=11mm,
40
50
-1=1mm ,
1
1
11
21
31
41
51
2
2.5
12.5
22.5
32.5
42.5
52.5
3
3
13
23
33
43
53
-2=2.5mm, -7=7.5mm
4
4
14
24
34
44
54
5
5
15
25
35
45
55
6
6
16
26
36
46
56
7
7.5
17.5
27.5
37.5
47.5
57.5
8
8
18
28
38
48
58
9
9
19
29
39
49
59
B3=23mm
2
Edit:A
HEL
HONGZHI
ELECTRONIC
Ltd
6.
PITCH OF LENGTH mm
A
B
1
10
11
C
2
1
D
3
2.5
4
3
12.5
5
4
13
6
5
14
7
6
15
8
7.5
16
9
8
17.5
9
18
19
21
22.5
23
24
25
26
27.5
28
29
41
42.5
43
44
45
46
47.5
48
49
31
40
32.5
33
34
35
36
37.5
38
39
E
50
51
52.5
53
54
55
56
57.5
58
59
G
70
71
72.5
73
74
75
76
77.5
78
79
95
96
97.5
98
99
F
60
H
A1=11mm,
61
80
I
7.
81
90
82.5
91
-1=1mm ,
63
64
83
92.5
84
93
-2=2.5mm, -7=7.5mm
65
66
85
94
67.5
86
68
87.5
69
88
89
B3=23mm
LEAD STYLE
0. no forming;
1. strait forming;
2. out kink & flat forming;
3. in kink & stand kink;
4. strait cut short lead;
forming and short lead ;
6. out forming short lead;
8.
7. in kink short lead & stand form short lead;
8. double king short lead.
LEAD LENGTH mm
Code
T
2
3
4
5
Meaning
Tapping
3.5
3.8±0.3
4±0.5
4.5
5±0.5
5±1
Meaning
10
11
12
13
14
15
Meaning
21
22
23
24
25
30
Meaning
60above
Code
Code
Code
A
M
Z
B
N
C
P
D
Q
E
R
F
S
6
7
6
7
16
17
35
40
G
U
H
V
8
9
8
9
18
19
50
55
J
W
K
X
L
Y
9.10. CONSTRUCTION CODE (internal use)
3
Edit:A
5. inner
HONGZHI
HEL
ELECTRONIC
3. SPECIFICATIONS:
1.
OPERATING TEMPERATURE: -40℃~+105℃
2.
CAPACITANCE RANGE: 0.01μF~2.2μF
3.
CAPACITANCE TOLERANCE: ±5%(J), ±10%(K), ±20%(M)
4.
RATED VOLTAGE: 250VAC~, 275VAC
5.
DISSIPATION FACTOR: 0.1% MAX AT 1KHZ, 25℃
6.
INSULATION RESISTANCE: >35000 MΩ(C≦0.33μF); 1000 MΩ·μF (C>0.33μF)
7.
7.
MAX. Pulse rise time (dv/dt) :
VR
(ac)
10mm
500
275VAC
4. PERFORMANCE
Test Characteristics
Withstand voltage: Between terminals
(4.3Ur )
Withstand voltage: Between terminals &
enclosure
Insulation resistance: Between terminals
Insulation resistance: Between terminals &
enclosure
Heat proof: Insulation resistance at 85℃
Heat proof:
Rate of variation of capacitance at 85℃
Impulse voltage
15mm
400
Lead spacing
22.5mm 27.5mm
200
140
Performance
For1800VDC
Shall be no abnormality
2 sec.
For 2.0UR+1500VAC 2 sec
Apply rated voltage
±15% for 60 sec. When rated voltage under 100V. Apply
100V ±15% when rated voltage from 100V to 500V at
20 ℃
≧30,000MΩ
Testing temperature: 85±2℃.
According to fig.1, before endurance
Vibration
Bump
4000 bumps at 390m/s2
Upper and lower rated temperature 5
cycles
Change or temperature
Solderability
Solder globule method
Passive flammability
Flame exposure
severity
Active flammability
time
depending
on
Surge pulses +URVAC
Humidity
37.5mm
100
GB/T 14472 (IEC 60384-14)
According to fig.2 with U2=1000VAC X:
U1=1.25UR VAC
3 directions at 2 hours each 10-500Hz
at 0.75mm or 98m/s2
Endurance
5.
+40℃ and 9-95% R.H.
≧30,000MΩ
+5%
Within-2% of the value before
test
No permanent breakdown or
flashover
Voltage proof C, DF and
insulation
No visible damage; No open or;
Short circuit
No visible damage ; No open or
Short circuit
No visible damage
Wetting time for d≦0.80.80.022 1000 PCS
EIA STANDARD RS-296-D
Optional
B
Arbor hole
6.35m
+5
A
B
C
50-2
260±2
330±2
C≦0.047 1500 PCS
C>0.047 1000 PCS
Hub recess I. D.
“E”
Label
Dia
“D”
A
Recess depth
9.5mm
(0.374”)
minimum
≦0.8mm
1. Reel label consists of:
2. Component type
3. Electrical values;
5. Date
EIA Std.
RF Spec
4. Manufacturer’s name
Core
6. Component quantity
diameter ”F”
CAPACITOR BODY DIAMETER
≧5mm
(≧ 0.197”)
5.01~10mm (0.197~0.394”)
10.01~15mm (0.394~0.591”)
CAPACITOR PITCH”A”±0.5mm (0.020”)
5mm or 0.200”
10mm or 0.400”
15mm or 0.600”
CAPACITOR BODY LENGTH
INSIDE TAPE SPACING “B” ±1.5mm (0.059”)
≧16.50mm
(≧0.65”)
16.51~28.45mm (0.651~1.12”)
28.46~37.00mm (1.121~1.45”)
52.44mm or 2.062”
63.5mm or 2.500”
76.0mm or 2.874”
C
13.9~38.1mm
(0.54~1.50”)
14.50mm (0.570”)
CAPACITOR BODY DIA.
≧ 5.0mm
5.1~7.0mm
7.1~9.5mm
D
76.2~355.6mm
(3.0~14.0”)
381.0mm (15”)
E
28.6~78.0mm
(1.126~3.071”)
54.2mm (2.130”)
PITCH
6mm
10mm
10mm
F
34.5~92.0mm(1.374’3.626”)
61.0mm (2.401”)
QUANTITY PCS/REEL
4000 max
2000 max
1000 max
6
Edit:A
HEL
HONGZHI
ELECTRONIC
Ltd
10.METALLIZED POLYPROPYLENE FILM INTERFERENCE SUPPRESSION CAPACITOR- -X2
Permissible
Characteristics of voltage derating to frequency --- MPX
V(rms)
275VAC
1000
474
100
103
225
1K
10K
100K
1000K
683
Frequency
NOTE:
The graphs illustrated above are for
reference only wave form of current and
temperature rise of capacitor are key factors
to determine permissible current. For actual
applicant on. Consult our sales represent
ative or sales office.
7
EditA
很抱歉,暂时无法提供与“MPP105J2GA8A50R0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.57035
- 50+0.45630
- 150+0.39928
- 500+0.35651
- 2500+0.32238
- 5000+0.30521
- 国内价格
- 5+0.51754
- 50+0.41405
- 150+0.36231
