BZT52-C4V3X
BZT52-C4V3X
    NEXPERIA(安世)
    SOD123
    稳压二极管 Vz=4.3V 4V~4.6V Izt=5mA P=590mW SOD123
BZT52-C4V3X 数据手册
BZT52 series Single Zener diodes in a SOD123 package Rev. 1 — 16 March 2017 1 Product data sheet Product profile 1.1 General description General-purpose Zener diodes in a SOD123 small Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits • • • • • Total power dissipation: ≤ 590 mW Wide working voltage range: nominal 2.4 V to 75 V (E24 range) Small plastic package suitable for surface-mounted design Low differential resistance AEC-Q101 qualified 1.3 Applications • General regulation functions 1.4 Quick reference data Table 1. Quick reference data Symbol VF Ptot [1] [2] [3] Parameter forward voltage total power dissipation Conditions Min Typ Max Unit IF = 10 mA [1] - - 0.9 V Tamb ≤ 25 °C [2] - - 350 mW [3] - - 590 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02. Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . BZT52 series Nexperia Single Zener diodes in a SOD123 package 2 Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode 2 A anode Simplified outline Graphic symbol [1] 1 2 2 1 006aaa152 [1] 3 The marking bar indicates the cathode. Ordering information Table 3. Ordering information Type number Package BZT52-C2V4 to BZT52[1] C75 [1] 4 Name Description Version - plastic surface-mounted package; 2 leads SOD123 The series consists of 37 types with nominal working voltages from 2.4 V to 75 V. Marking Table 4. Marking codes Type number Marking code Type number Marking code Type number Marking code Type number Marking code BZT52-C2V4 C1 BZT52-C6V2 CB BZT52-C16 CM BZT52-C43 CY BZT52-C2V7 C2 BZT52-C6V8 CC BZT52-C18 CN BZT52-C47 D1 BZT52-C3V0 C3 BZT52-C7V5 CD BZT52-C20 CP BZT52-C51 D2 BZT52-C3V3 C4 BZT52-C8V2 CE BZT52-C22 CQ BZT52-C56 D3 BZT52-C3V6 C5 BZT52-C9V1 CF BZT52-C24 CR BZT52-C62 D4 BZT52-C3V9 C6 BZT52-C10 CG BZT52-C27 CS BZT52-C68 D5 BZT52-C4V3 C7 BZT52-C11 CH BZT52-C30 CT BZT52-C75 D6 BZT52-C4V7 C8 BZT52-C12 CJ BZT52-C33 CU - - BZT52-C5V1 C9 BZT52-C13 CK BZT52-C36 CV - - BZT52-C5V6 CA BZT52-C15 CL BZT52-C39 CW - - BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package 5 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF Conditions Min Max Unit forward current - 250 mA IZSM non-repetitive peak reverse current - see Table 8, 9 and 10 PZSM non-repetitive peak power dissipation [1] - 40 W Ptot total power dissipation [2] - 350 mW [3] - 590 mW Tamb ≤ 25 °C Tj junction temperature - 150 Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] [2] [3] 6 tp = 100 μs; square wave; Tj = 25 °C prior to surge. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm Thermal characteristics Table 6. Thermal characteristics Symbol Rth(j-a) Rth(j-sp) [1] [2] [3] 7 Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 350 K/W [2] - - 210 K/W [3] - - 55 K/W Min Typ Max Unit - - 0.9 V Device mounted on an FR4 Printed-Circuit Board (PCB),single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Soldering point of cathode tab. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter VF [1] forward voltage Conditions IF = 10 mA [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package Table 8. Characteristics per type; BZT52-C2V4 to BZT52-C24 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); IZ = 5 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode capacitance coefficient [1] SZ (mV/K); Cd (pF) IZ = 5 mA Nonrepetitive peak reverse current [2] IZSM (A) Min Max IZ = 1 mA IZ = 5 mA Max VR (V) Min Max Max Max 2V4 C 2.2 2.6 400 85 50 1 −3.5 0.0 450 6.0 2V7 C 2.5 2.9 500 83 20 1 −3.5 0.0 450 6.0 3V0 C 2.8 3.2 500 95 10 1 −3.5 0.0 450 6.0 3V3 C 3.1 3.5 500 95 5 1 −3.5 0.0 450 6.0 3V6 C 3.4 3.8 500 95 5 1 −3.5 0.0 450 6.0 3V9 C 3.7 4.1 500 95 3 1 −3.5 0.0 450 6.0 4V3 C 4.0 4.6 500 95 3 1 −3.5 0.0 450 6.0 4V7 C 4.4 5.0 500 78 3 2 −3.5 0.2 300 6.0 5V1 C 4.8 5.4 480 60 2 2 −2.7 1.2 300 6.0 5V6 C 5.2 6.0 400 40 1 2 −2.0 2.5 300 6.0 6V2 C 5.8 6.6 150 10 3 4 0.4 3.7 200 6.0 6V8 C 6.4 7.2 80 8 2 4 1.2 4.5 200 6.0 7V5 C 7.0 7.9 80 10 1 5 2.5 5.3 150 4.0 8V2 C 7.7 8.7 80 10 0.7 5 3.2 6.2 150 4.0 9V1 C 8.5 9.6 100 10 0.5 6 3.8 7 150 3.0 10 C 9.4 10.6 70 10 0.2 7 4.5 8 90 3.0 11 C 10.4 11.6 70 10 0.1 8 5.4 9.0 85 2.5 12 C 11.4 12.7 90 10 0.1 8 6.0 10.0 85 2.5 13 C 12.4 14.1 110 10 0.1 8 7.0 11.0 80 2.5 15 C 13.8 15.6 110 15 0.05 10.5 9.2 13.0 75 2.0 16 C 15.3 17.1 170 20 0.05 11.2 10.4 14.0 75 1.5 18 C 16.8 19.1 170 20 0.05 12.6 12.4 16.0 70 1.5 20 C 18.8 21.2 220 20 0.05 14 14.4 18.0 60 1.5 22 C 20.8 23.3 220 25 0.05 15.4 16.4 20.0 60 1.25 24 C 22.8 25.6 220 30 0.05 16.8 18.4 22.0 55 1.25 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package Table 9. Characteristics per type; BZT52-C27 to BZT52-C51 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); IZ = 2 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode capacitance coefficient [1] Cd (pF) SZ (mV/K); IZ = 5 mA Nonrepetitive peak reverse current [2] IZSM (A) Min Max IZ = 1 mA IZ = 5 mA Max VR (V) Min Max Max Max 27 C 25.1 28.9 250 40 0.05 18.9 21.4 25.3 50 1.0 30 C 28.0 32.0 250 40 0.05 21 24.4 29.4 50 1.0 33 C 31.0 35.0 250 40 0.05 23.1 27.4 33.4 45 0.9 36 C 34.0 38.0 250 60 0.05 25.2 30.4 37.4 45 0.8 39 C 37.0 41.0 300 75 0.05 27.3 33.4 41.2 45 0.7 43 C 40.0 46.0 325 80 0.05 30.1 37.6 46.6 40 0.6 47 C 44.0 50.0 325 90 0.05 32.9 42.0 51.8 40 0.5 51 C 48.0 54.0 350 100 0.05 35.7 46.6 57.2 40 0.4 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. Table 10. Characteristics per type; BZT52-C56 to BZT52-C75 Tj = 25 °C unless otherwise specified. BZT52 Sel Working -xxx voltage VZ (V); IZ = 2 mA Maximum differential resistance rdif (Ω) Reverse current IR (μA) Temperature Diode capacitance coefficient [1] Cd (pF) SZ (mV/K); IZ = 5 mA Nonrepetitive peak reverse current [2] IZSM (A) Min Max IZ = 0.5 mA IZ = 2 mA Max VR (V) Min Max Max Max 56 C 52.0 60.0 375 120 0.05 39.2 52.2 63.8 40 0.3 62 C 58.0 66.0 400 140 0.05 43.4 58.8 71.6 35 0.3 68 C 64.0 72.0 400 160 0.05 47.6 65.6 79.8 35 0.25 75 C 70.0 79.0 400 175 0.05 52.5 73.4 88.6 35 0.20 [1] [2] f = 1 MHz; VR = 0 V. tp = 100 μs; Tamb = 25 °C. BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package mbg801 103 PZSM (W) mbg781 300 IF (mA) 102 200 (1) 10 100 (2) 1 10- 1 1 10 tp (ms) (1) Tj = 25 °C (prior to surge) (2) Tj = 150 °C (prior to surge) 0.8 VF (V) 1 Tj = 25 °C Figure 1. Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values mbg783 0 SZ (mV/K) 0 0.6 mbg782 10 12 SZ (mV/K) 4V3 -1 Figure 2. Forward current as a function of forward voltage; typical values 11 10 9V1 5 3V9 8V2 7V5 6V8 3V6 -2 3V3 6V2 5V6 5V1 0 4V7 3V0 2V4 2V7 -3 0 20 40 IZ (mA) 60 -5 0 4 8 12 16 IZ (mA) 20 BZT52-C2V4 to BZT52-C4V3 Tj = 25 °C to 150 °C BZT52-C4V7 to BZT52-C12 Tj = 25 °C to 150 °C Figure 3. Temperature coefficient as a function of working current; typical values Figure 4. Temperature coefficient as a function of working current; typical values 8 Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package 9 Package outline 3.75 3.45 2.80 2.55 1 1.3 1.0 2 1.7 1.5 Dimensions in mm 16-10-13 Figure 5. Package outline SOD123 10 Packing information Table 11. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. Type number BZT52-C2V4 to BZT52C75 BZT52_SER Product data sheet Package SOD123 Description 4 mm pitch, 8 mm tape and reel All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 Packing quantity 3000 10000 -115 -118 © Nexperia B.V. 2017. All rights reserved. 7 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package 11 Soldering SOD123 4.58 3.27 3.1 2.1 1.62 1.12 1.22 1.42 0.81 0.91 0.81 2.36 0.91 4.18 1.11 occupied area solder resist Cu pad solder paste Dimensions in mm 1.11 16-05-10 16-08-31 sod123_fr Reflow soldering is the only recommended soldering method. Dimensions in mm. Figure 6. Reflow soldering footprint SOD123 BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package 12 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BZT52_SER v.1 20170316 Product data sheet - - BZT52_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package 13 Legal information 13.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical BZT52_SER Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer BZT52_SER Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package Tables Tab. 1. Tab. 2. Tab. 3. Tab. 4. Tab. 5. Tab. 6. Tab. 7. Quick reference data .........................................1 Pinning ...............................................................2 Ordering information ..........................................2 Marking codes ...................................................2 Limiting values .................................................. 3 Thermal characteristics ..................................... 3 Characteristics ...................................................3 Tab. 8. Tab. 9. Tab. 10. Tab. 11. Tab. 12. Characteristics per type; BZT52-C2V4 to BZT52-C24 ........................................................ 4 Characteristics per type; BZT52-C27 to BZT52-C51 ........................................................ 5 Characteristics per type; BZT52-C56 to BZT52-C75 ........................................................ 5 Packing methods ...............................................7 Revision history .................................................9 Figures Fig. 1. Fig. 2. Non-repetitive peak reverse power dissipation as a function of pulse duration; maximum values ............................................... 6 Forward current as a function of forward voltage; typical values ....................................... 6 BZT52_SER Product data sheet Fig. 3. Fig. 4. Fig. 5. Fig. 6. Temperature coefficient as a function of working current; typical values .......................... 6 Temperature coefficient as a function of working current; typical values .......................... 6 Package outline SOD123 ..................................7 Reflow soldering footprint SOD123 ................... 8 All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 13 BZT52 series Nexperia Single Zener diodes in a SOD123 package Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 Product profile .................................................... 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Quick reference data ......................................... 1 Pinning information ............................................ 2 Ordering information .......................................... 2 Marking .................................................................2 Limiting values .................................................... 3 Thermal characteristics ......................................3 Characteristics .................................................... 3 Test information .................................................. 6 Quality information .............................................6 Package outline ...................................................7 Packing information ............................................7 Soldering ..............................................................8 Revision history .................................................. 9 Legal information .............................................. 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 March 2017 Document identifier: BZT52_SER
BZT52-C4V3X 价格&库存
很抱歉,暂时无法提供与“BZT52-C4V3X”相匹配的价格&库存,您可以联系我们找货
BZT52-C4V3X
    • 5+1.21965
    • 50+1.19816
    • 150+1.18390
    库存:183
    BZT52-C4V3X
    • 1+1.856051+0.24128
    • 10+1.1381710+0.14796
    • 100+0.70040100+0.09105
    • 500+0.50969500+0.06626
    • 1000+0.447841000+0.05822
    库存:2783
