MPIM252010HR47M-LF
MPIM252010HR47M-LF
    MICROGATE(麦捷科技)
    SMD,2.5x2mm
    功率电感 470nH ±20% 5.5A 32mΩ SMD,2.5x2mm
MPIM252010HR47M-LF 数据手册
Reference Only CUSTOMER: DATE: APPROVAL SPECIFICATION ROHS COMPLIANT PRODUCT NAME: SMD power inductor YOUR PART NO.: OUR PART NO.: MPIM252010H series VERSION: V1.0 RECEPTION THE SPECIFICATION HAS BEEN ACCEPTED. DATE: COMPANY: CFMD CHKD RCVD MANUFACTURING NAME SHENZHEN MICROGATE TECHNOLOGY CO.,LTD Address: Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Postcode: 518110 CFMD. CHKD. DSGD. TEL: 86-755-28085000 Charles Wang Yusheng Liu Wei FAX: 86-755-28085605 Reference Only CATALOG Component SPEC Version Record……………………………………………………… 3 1 Scope……………………………………………………………………………………… 4 2 Product Identification…………………………………………………………………… 4 3 Appearance and Dimensions…………………………………………………………… 4 4 Testing Conditions………………………………………………………………………… 4 5 Electrical Characteristics And Test Instruments……………………………………… 5 6 Condition of work………………………………………………………………………… 5 7 Reliability ………………………………………………………………………………… 6-8 8 Recommended Soldering Conditions…………………………………………………… 8 9 Package Information……………………………………………………………………… 9 10 Products Storage………………………………………………………………………… SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 2/10 10 Reference Only Component SPEC Version Record Rev. Effective Date Changed Contents Change Reasons Approved By 1.0 May.18.2016 New released / Charles SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 3/10 Reference Only 1. Scope This specification applies to the MPIM252010H series of SMD power inductor. 2. Product Identification MPIM ① ① ② ③ ④ ⑤ ⑥ 252010 H ② ③ 1R0 M - LF ④ ⑤ ⑥ Product Symbol Product dimensions Special process code Inductance Value (R47:0.47 uH; 1R0: 1.0uH ) Induc tance Tolerance (M: ±20% ; N: ±30%) Lead free product. 3. Appearance and Dimensions h f g Recommended A B C Dimensions in mm D 2.50±0.20 2.00±0.20 1.00Max. 0.60±0.20 Land Pattern f g h 1.20 Typ. 2.80 Typ. 2.00 Typ. 4. Testing Conditions Unless otherwise specified, the standard conditions for measurement/test as: Ambient Temperature : 5 to 35℃ Relative Humidity: 25 to 85% RH Atmospheric Pressure: 86 to 106 kPa If any doubt on the results, measurements/tests should be made within the following limits: Ambient Temperature : 25±1℃ Relative Humidity: 60 to 70% RH Atmospheric Pressure: 86 to 106 kPa SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 4/10 Reference Only 5. Electrical Characteristics And Test Instruments Inductance L0 (uH) 1MHz &1V Max. Typ. Max. Typ. Max. Typ. MPIM252010HR22M-LF 0.22±20% 0.015 0.014 6.50 6.90 5.00 5.40 MPIM252010HR33M-LF 033±20% 0.024 0.020 5.70 6.20 4.20 4.50 MPIM252010HR47M-LF 0.47±20% 0.032 0.028 5.00 5.50 3.60 3.90 MPIM252010HR68M-LF 0.68±20% 0.048 0.044 4.10 4.60 3.00 3.30 MPIM252010H1R0M-LF 1.0±20% 0.054 0.048 3.80 4.20 2.70 3.00 MPIM252010H1R5M-LF 1.5±20% 0.082 0.075 3.00 3.40 2.10 2.40 MPIM252010H2R2M-LF 2.2±20% 0.115 0.107 2.40 2.70 1.70 2.00 Microgate Part No. DCR(Ω) Isat (A) Irms (A) Test instruments and remarks * L test by CHROMA 3302 meter or equivalent. * DCR test by Tonghui TH2516B meter or equivalent. * CHROMA 3302 and 1320 meter for IDC. * Rated current: Isat or Irms, whichever is smaller:  Isat: DC current (A) that will cause L0 to drop approximately 30%.  Irms: DC current (A) that will cause an approximate ΔT of 40℃. * Maximum rated voltage: DC 20 V. * The part temperature (ambient + temp rise) should not exceed 125℃ under worse case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. Isat test schematic diagram Irms test schematic diagram 6. Condition of work Operating temperature range: -55℃ ~ +125℃ (Including self-heating) . SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 5/10 Reference Only 7. Reliability No. 1 Item Requirements Solderability (1) No case deformation or change in appearance. (2) Terminal area must have 95% min. solder coverage. Test Methods and Remarks Reference Sample Size ①Temperature:255± 5℃, flux 5-10 s. ②Sample immersion tin furnace 5 ±0.5s. ③Immersed and in and out of speed: 25 AEC-Q200 (J-STD-002) 15 AEC-Q200 (MIL-STD-20 2 Method 210) 30 AEC-Q200 (MIL-STD -202 Method 108) 77 ±6mm/s. ①The peak temperature: 260+5/-0℃. ②Reflow:3times. ③Temperature curve is as below: Peak 265℃ max. 265℃ -5℃ Max. Ramp Down Rate=-6℃/s 30 sec. min. Max. Ramp Up Rate=3℃/s 217℃ 60~150 sec. Temperature 2 Resistance to Soldering Heat 200℃ 150℃ 60~180 sec. 25℃ . Time 25 ℃ to Peak =8 min max. Time ①Temperature: 125±2℃. ②Time : 1000 hours. ③Measurement at 24±4 hours after test conclusion. 3 High Temperature Storage Temp. 125℃ High temperature Room Temp. 24H (1) No case deformation or change in appearance. (2)∣ΔL0/L0∣≤10% 0 1000H Time ①Temperature: -55±2℃. ②Time : 1000 hours. ③Measurement at 24±4 hours after test conclusion. 4 Low Temperature Storage Room Temp. 77 JESD22-A119 1000H 0 Time -55℃ Low temperature 24H Temp. ①First -40℃ for 15 minutes, last 125℃ 5 Thermal shock 15minutes as 1 cycle. Go through 300 cycles. ②Max transfer time is 20 second. ③Measurement at 24±4 hours after test conclusion. 125℃ 15 min. 15 min. MIL-STD -202 Method 107 30 Ambient Temperature -40℃ 15 min. 20 s (max.) SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 6/10 Reference Only No. Item Requirements Test Methods and Remarks Reference Sample Size AEC-Q200 (MIL-STD -202 Method 103) 77 AEC-Q200 (AEC-Q200-0 06) 30 AEC-Q200 (AEC-Q200-0 05) 30 JESD22-B111 30 AEC-Q200 (MIL-STD-20 2 Method 204) 30 ①1000 hours, 85°C/85%RH. ②Unpowered. ③Measurement at 24±4 hours after test conclusion. 6 Humidity Resistance High temperature High humidity Temp. 85℃ Room Temp. 24H 0 1000H Time ①The test samples shall be soldered to the board. ②17.64N, 60s,X,Ydirect. Radius 1.5mm 7 DUT Terminal Strength Substrate Press tools Shear force ①Part mounted on a 100mm*40mm FR4 (1) No case deformation or change in appearance. (2)∣ΔL0/L0∣≤10% 8 PCB board, which is 1.6±0.2 mm thick and as a Layer-thickness 35 µm ±10 µm. ②Bending speed is 1mm/s. ③Keeping the P.C Board 2 mm minimum for 60 seconds. Support Board Flex Solder Printed circuit board before testing Chip 45±2 45±2 20 Probe to exert bending force 1.6 Radius 340 0 Printed circuit board under test Displacement Unit: mm 9 10 Drop Vibration ①Height: 1 m, Free fall, 10times. ②Direction: 1 Angle, 1side, 2surface. ①Frequency range : 10~2000Hz. ②Amplitude: 1.5mm or 20 G. ③Sweep time and duration: 10~2000~10Hz for 20 minutes. ④Each four hours(12 times) in X,Y,Z direction, 12 hours in total. SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 7/10 Reference Only No. Item Requirements 11 Loading at High Temperature (1) No case deformation or change in appearance. (2)∣ΔL0/L0∣≤10% Test Methods and Remarks ①Temperature: 85±2℃. ②Time : 1000 hours. ③Applied Current : Rated current. ④Measurement at 24±4 hours after test Reference Sample Size AEC-Q200 (MIL-PRF-27) 77 conclusion. *All above experiments items need 3 Lot., sample size is as specified in the table above. *Sample size standard is from AEC-Q200 : qualification sample size requirements. 8. Recommended Soldering Conditions (1) Reflow soldering conditions *Above reflow soldering curve is from J-STD-020D. (2) Iron soldering The following conditions must be strictly followed when using a soldering iron. Pre-heating 150℃ 1 minute Tip temperature 350℃ max Soldering iron output End of soldering iron 30w max φ1mm max Soldering time 3 seconds max SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 8/10 Reference Only 9. Package Information (1) Dimension of tape (Unit: mm) W A0 B0 K0 E F P P0 D0 T 8.0±0.3 2.40±0.10 2.80±0.10 1.20±0.1 1.75±0.1 3.5±0.05 4.0±0.1 4.0±0.1 1.5+0.1/-0.0 0.18±0.03 (2) Dimension of reel (Unit: mm) C B A G Symbol A B C G Dimension 178±2 58±2 13.5±0.2 9.0±1.5 (3) Taping figure and drawing direction (4) Packaging quantities: 2000PCS/Reel. (5) Peeling strength of cover tape: The peel force of top cover tape shall be between 0.10N to 1.0N *the peel force standard is from EIA-481-D F 165 ° to 180° Top cover tape Base tape Room Temp. (℃) 5-35 Room Humidity (%) 45-85 Room aim (hpa) 860-1060 Peel Speed mm/min 300 SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 9/10 Reference Only 10. Products Storage (1) Storage period Products which inspected in MICROGATE over 12 months ago should be examined and used, which can be confirmed with inspection No. marked on the container. Solderability should be checked if this period is exceeded. (2) Storage conditions Products should be storage in the warehouse on the following conditions: Temperature: -10 ~+ 35℃ Humidity : Less than 70% relative and humidity No rapid change on temperature and humidity. (3) Don’t keep products in corrosive gases such as sulfur, chlorine gas or acid, or it may cause oxidization of electrode, resulting in poor solderability. (4) Products should be storage on the palette for the prevention of the influence from humidity, dust and so on. (5) Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. (6) Products should be storage under the airtight packaged condition. SHENZHEN MICROGATE TECHNOLOGY CO., LTD. Add:Yuxing road, Golf Street, Guanlan Town Longhua District Shenzhen P.R.C Tel:+86-755-28085000 Fax:+86-755-28085605 Postcode:518110 10/10
MPIM252010HR47M-LF 价格&库存
很抱歉,暂时无法提供与“MPIM252010HR47M-LF”相匹配的价格&库存,您可以联系我们找货
MPIM252010HR47M-LF
  • 10+0.30212
  • 100+0.27482
  • 500+0.24752
  • 1000+0.22022
  • 2000+0.20202
  • 4000+0.19656
