NMB2227A
40 V, 600 mA NPN/PNP general-purpose transistors
15 September 2016
Product data sheet
1. General description
NPN/PNP general-purpose transistors in a small SOT457 (SC-74) Surface-Mounted Device (SMD)
plastic package.
2. Features and benefits
General-purpose transistor
High current
Reduces component count on Printed-Circuit Board (PCB)
Reduces pick and place costs
AEC-Q101 qualified
3. Applications
General-purpose switching and amplification
Complementary driver
Half-bridge and full-bridge driver
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
40
V
hFE
DC current gain
VCE = 10 V; IC = 150 mA; pulsed; tp ≤
300 µs; δ ≤ 0.02 ; Tamb = 25 °C
100
300
VCEO
collector-emitter
voltage
open base
-60
hFE
DC current gain
VCE = -10 V; IC = -150 mA; pulsed; tp ≤
100
300
600
TR1 (NPN)
TR2 (PNP)
V
Per transistor; for the PNP transistor with negative polarity
IC
collector current
mA
NMB2227A
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
B1
base TR1
2
E2
emitter TR2
3
B2
base TR2
4
C2
collector TR2
5
E1
emitter TR1
6
C1
collector TR1
Simplified outline
Graphic symbol
6
5
4
1
2
3
C1
E1
C2
TR1
TR2
TSOP6 (SOT457)
B1
E2
B2
aaa-022995
6. Ordering information
Table 3. Ordering information
Type number
NMB2227A
Package
Name
Description
Version
TSOP6
plastic surface-mounted package (TSOP6); 6 leads
SOT457
7. Marking
Table 4. Marking codes
Type number
Marking code
NMB2227A
3B
NMB2227A
Product data sheet
All information provided in this document is subject to legal disclaimers.
15 September 2016
Nexperia B.V. 2017. All rights reserved
2 / 17
NMB2227A
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
75
V
VCEO
collector-emitter voltage
open base
40
V
VCBO
open emitter
-60
V
VCEO
open base
-60
V
6
V
600
mA
800
mA
200
mA
TR1 (NPN)
TR2 (PNP)
VEBO
emitter-base voltage
open collector
IC
collector current
ICM
peak collector current
IBM
peak base current
Ptot
total power dissipation
Tamb ≤ 25 °C
[1]
200
mW
Ptot
Tamb ≤ 25 °C
[1]
300
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
single pulse; tp ≤ 1 ms
Per device
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
aaa-023571
400
Ptot
(mW)
300
200
100
-25
25
75
125
175
Tamb (°C)
FR4 PCB; standard footprint
Fig. 1.
Power derating curve
NMB2227A
Product data sheet
15 September 2016
3 / 17
NMB2227A
Nexperia
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
thermal resistance
from junction to
ambient
in free air
thermal resistance
from junction to
ambient
in free air
Min
Typ
Max
Unit
[1]
625
K/W
[1]
417
K/W
Per transistor
Rth(j-a)
Per device
Rth(j-a)
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
NMB2227A
Product data sheet
15 September 2016
4 / 17
NMB2227A
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
collector-base cut-off
current
VCB = 60 V; IE = 0 A; Tamb = 25 °C
10
nA
VCB = 60 V; IE = 0 A; Tj = 125 °C
10
µA
IEBO
emitter-base cut-off
current
VEB = 5 V; IC = 0 A; Tamb = 25 °C
10
nA
hFE
DC current gain
VCE = 10 V; IC = 1 mA; Tamb = 25 °C
50
VCE = 10 V; IC = 10 mA; Tamb = 25 °C
75
100
300
VCE = 10 V; IC = 500 mA; pulsed; tp ≤
40
IC = 150 mA; IB = 15 mA; pulsed; tp ≤
300
mV
IC = 500 mA; IB = 50 mA; pulsed; tp ≤
1
V
0.6
1.2
V
2
V
IC = 150 mA; IBon = 15 mA;
IBoff = -15 mA; VCC = 10 V;
Tamb = 25 °C
15
ns
ns
35
ns
TR1 (NPN)
ICBO
VCEsat
VBEsat
collector-emitter
saturation voltage
base-emitter saturation IC = 150 mA; IB = 15 mA; pulsed; tp ≤
voltage
td
delay time
tr
rise time
ton
turn-on time
ts
storage time
200
ns
tf
fall time
60
ns
toff
turn-off time
250
ns
CC
collector capacitance
VCB = 10 V; IE = 0 A; ie = 0 A;
f = 1 MHz; Tamb = 25 °C
8
pF
CE
emitter capacitance
VEB = 500 mV; IC = 0 A; ic = 0 A;
25
pF
fT
transition frequency
VCE = 20 V; IC = 20 mA; f = 100 MHz;
Tamb = 25 °C
300
MHz
current
VCB = -50 V; IE = 0 A; Tamb = 25 °C
-10
nA
VCB = -50 V; IE = 0 A; Tj = 125 °C
-10
µA
IEBO
current
VEB = -5 V; IC = 0 A; Tamb = 25 °C
-50
nA
hFE
DC current gain
VCE = -10 V; IC = -0.1 mA; Tamb = 25 °C
75
VCE = -10 V; IC = -1 mA; Tamb = 25 °C
100
VCE = -10 V; IC = -10 mA; Tamb = 25 °C
100
TR2 (PNP)
ICBO
NMB2227A
Product data sheet
15 September 2016
5 / 17
NMB2227A
Nexperia
Symbol
Parameter
VCEsat
Conditions
Min
Typ
Max
100
300
VCE = -10 V; IC = -500 mA; pulsed; tp ≤
50
IC = -150 mA; IB = -15 mA; pulsed; tp ≤
-400
mV
IC = -500 mA; IB = -50 mA; pulsed; tp ≤
-1.6
V
base-emitter saturation IC = -150 mA; IB = -15 mA; pulsed; tp ≤
voltage
-1.3
V
-2.6
V
IC = -150 mA; IBon = -15 mA;
IBoff = 15 mA; VCC = -10 V;
Tamb = 25 °C
12
ns
30
ns
40
ns
collector-emitter
saturation voltage
VBEsat
Unit
td
delay time
tr
rise time
ton
turn-on time
ts
storage time
300
ns
tf
fall time
65
ns
toff
turn-off time
365
ns
CC
VCB = -10 V; IE = 0 A; ie = 0 A;
8
pF
CE
emitter capacitance
VEB = -2 V; IC = 0 A; ic = 0 A; f = 1 MHz;
Tamb = 25 °C
30
pF
fT
VCE = -20 V; IC = -50 mA; f = 100 MHz;
Tamb = 25 °C
200
MHz
aaa-017357
900
aaa-017359
0.9
hFE
IB = 13 mA
11.7 mA
10.4 mA
IC
(A)
600
9.1 mA
7.8 mA 6.5 mA
0.6
5.2 mA
2.6 mA
(1)
300
3.9 mA
0.3
(2)
1.3 mA
(3)
1
10
102
IC (mA)
0.0
103
VCE = 10 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 2.
4
6
8
VCE (V)
10
Tamb = 25 °C
Fig. 3.
NPN transistor: Collector current as a function
of collector-emitter voltage; typical values
NPN transistor: DC current gain as a function
of collector current; typical values
NMB2227A
Product data sheet
15 September 2016
6 / 17
NMB2227A
Nexperia
aaa-017361
1.0
VBE
(V)
aaa-017362
1.2
VBEsat
(V)
(1)
0.8
1.0
(2)
(1)
0.6
0.8
(2)
(3)
0.4
0.6
0.2
0.4
(3)
0.0
10-1
1
10
102
IC (mA)
0.2
10-1
103
VCE = 10 V
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Fig. 4.
1
102
IC (mA)
103
IC/IB = 10
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
NPN transistor: Base-emitter voltage as a
function of collector current; typical values
Fig. 5.
aaa-017363
1
NPN transistor: Base-emitter saturation voltage
as a function of collector current; typical
values
aaa-017364
1
VCEsat
(V)
VCEsat
(V)
(1)
(1)
(2)
(2)
10-1
10-1
(3)
10-2
10-1
1
10
102
IC (mA)
Product data sheet
1
10
102
IC (mA)
103
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(3) IC/IB = 10
NPN transistor: Collector-emitter saturation
voltage as a function of collector current;
typical values
NMB2227A
(3)
10-2
10-1
103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 6.
10
Fig. 7.
typical values
15 September 2016
7 / 17
NMB2227A
Nexperia
aaa-014480
400
hFE
aaa-014481
-1
IB = -20 mA
IC
(A)
(1)
-18
300
-14
-16
-0.8
-12
-8
-0.6
-6
(2)
200
-4
-0.4
-2
(3)
100
-0.2
-1
-102
-10
IC (mA)
VCE = -10 V
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 8.
-10
-4
-6
-8
-10
VCE (V)
Tamb = 25 °C
Fig. 9.
PNP transistor: Collector current as a function
PNP transistor: DC current gain as a function
aaa-014482
-1.2
aaa-014483
-1.2
VBEsat
(V)
VBE
(V)
-1.0
(1)
-0.8
-0.4
(1)
(2)
-0.8
(3)
-0.6
(2)
(3)
-0.4
-1
-10
-102
IC (mA)
-0.2
-10-1
-103
VCE = -10 V
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Product data sheet
-10
-102
IC (mA)
-103
IC/IB = 10
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 150 °C
Fig. 10. PNP transistor: Base-emitter voltage as a
NMB2227A
-1
Fig. 11. PNP transistor: Base-emitter saturation voltage
values
15 September 2016
8 / 17
NMB2227A
Nexperia
aaa-014484
-1
aaa-014699
-1
VCEsat
(V)
VCEsat
(V)
-10-1
-10-1
(1)
(2)
(1)
(2)
(3)
-10-2
-10-1
-1
(3)
-10
-102
IC (mA)
-10-2
-10-1
-103
IC/IB = 20
(1) Tamb = 150 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Product data sheet
-10
-102
IC (mA)
-103
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(3) IC/IB = 10
Fig. 12. PNP transistor: Collector-emitter saturation
typical values
NMB2227A
-1
Fig. 13. PNP transistor: Collector-emitter saturation
typical values
15 September 2016
9 / 17
NMB2227A
Nexperia
11. Test information
IB
input pulse
(idealized waveform)
90 %
IBon (100 %)
10 %
IBoff
output pulse
IC
90 %
IC (100 %)
10 %
t
td
ts
tr
ton
tf
toff
006aaa003
Fig. 14. TR1 (NPN): Transistor switching time definition
VBB
RB
(probe)
oscilloscope
450 Ω
VCC
RC
Vo
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mlb826
Fig. 15. TR1 (NPN): Test circuit for switching times
NMB2227A
Product data sheet
15 September 2016
10 / 17
NMB2227A
Nexperia
- IB
input pulse
90 %
- I Bon (100 %)
10 %
- I Boff
output pulse
- IC
90 %
- I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig. 16. TR2 (PNP): Transistor switching time definition
VBB
RB
(probe)
oscilloscope
450 Ω
VCC
RC
Vo
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mgd624
Fig. 17. TR2 (PNP): Test circuit for switching times
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
NMB2227A
Product data sheet
15 September 2016
11 / 17
NMB2227A
Nexperia
12. Package outline
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.95
1.9
0.40
0.25
Dimensions in mm
0.26
0.10
14-10-03
Fig. 18. Package outline TSOP6 (SOT457)
13. Soldering
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
sot457_fr
Fig. 19. Reflow soldering footprint for TSOP6 (SOT457)
NMB2227A
Product data sheet
15 September 2016
12 / 17
NMB2227A
Nexperia
5.3
1.5
(4×)
solder lands
1.475
0.45
(2×)
5.05
1.475
solder resist
occupied area
Dimensions in mm
preferred transport
direction during soldering
1.45
(6×)
2.85
sot457_fw
Fig. 20. Wave soldering footprint for TSOP6 (SOT457)
NMB2227A
Product data sheet
15 September 2016
13 / 17
NMB2227A
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
NMB2227A v.1
20160915
Product data sheet
NMB2227A
Product data sheet
15 September 2016
14 / 17
NMB2227A
Nexperia
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
15. Legal information
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
NMB2227A
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15 September 2016
15 / 17
NMB2227A
Nexperia
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
NMB2227A
Product data sheet
15 September 2016
16 / 17
NMB2227A
Nexperia
16. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 5
11. Test information....................................................... 10
12. Package outline........................................................ 12
13. Soldering................................................................... 12
14. Revision history........................................................14
15. Legal information..................................................... 15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 September 2016
NMB2227A
Product data sheet
15 September 2016
17 / 17
