PDZ-GW series
Single Zener diodes in a SOD123 package
Rev. 1 — 4 September 2017
1
Product data sheet
Product profile
1.1 General description
General-purpose Zener diodes in a SOD123 small Surface-Mounted Device (SMD)
plastic package.
1.2 Features and benefits
• Non-repetitive peak reverse power dissipation: PZSM ≤ 40 W
• Total power dissipation: Ptot ≤ 365 mW
• Tolerance series:
B2: approximately ± 2 %
• Wide working voltage range: nominal 2.4 V to 36 V (E24 range)
• Low reverse current IR range
• Small plastic package suitable for surface-mounted design
• AEC-Q101 qualified
1.3 Applications
• General regulation functions
1.4 Quick reference data
Table 1. Quick reference data
Symbol
VF
Ptot
Parameter
forward voltage
total power dissipation
Conditions
Min
Typ
Max
Unit
IF = 10 mA
[1]
0.9
V
Tamb ≤ 25 °C
[2]
365
mW
[3]
625
mW
[1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
2
[3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
PDZ-GW series
Nexperia
2
Pinning information
Table 2. Pinning
Pin Symbol
Description
1
K
cathode
2
A
anode
Simplified outline
Graphic symbol
[1]
1
2
2
1
006aaa152
[1] The marking bar indicates the cathode.
3
Ordering information
Table 3. Ordering information
Type number
Package
PDZ2.4BGW to
[1]
PDZ36BGW
Name
Description
Version
plastic surface-mounted package; 2 leads
SOD123
[1] The series consists of 29 types with nominal working voltages from 2.4 V to 36 V.
4
Marking
Table 4. Marking Codes
Type number
Marking Code
Type number
Marking Code
Type number
Marking Code
PDZ2.4BGW
B1
PDZ6.2BGW
BB
PDZ16BGW
BM
PDZ2.7BGW
B2
PDZ6.8BGW
BC
PDZ18BGW
BN
PDZ3.0BGW
B3
PDZ7.5BGW
BD
PDZ20BGW
BP
PDZ3.3BGW
B4
PDZ8.2BGW
BE
PDZ22BGW
BQ
PDZ3.6BGW
B5
PDZ9.1BGW
BF
PDZ24BGW
BR
PDZ3.9BGW
B6
PDZ10BGW
BG
PDZ27BGW
BS
PDZ4.3BGW
B7
PDZ11BGW
BH
PDZ30BGW
BT
PDZ4.7BGW
B8
PDZ12BGW
BJ
PDZ33BGW
BU
PDZ5.1BGW
B9
PDZ13BGW
BK
PDZ36BGW
BV
PDZ5.6BGW
BA
PDZ15BGW
BL
PDZ-GW_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 12
PDZ-GW series
Nexperia
5
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
IF
Conditions
Min
Max
Unit
forward current
200
mA
IZSM
non-repetitive peak reverse current
see
characteristics
table
PZSM
non-repetitive peak power
dissipation
[1]
40
W
Ptot
[2]
365
mW
[3]
625
mW
Tamb ≤ 25 °C
Tj
junction temperature
150
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1] tp = 100 μs; square wave; Tj = 25 °C prior to surge.
[2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2.
6
Thermal characteristics
Table 6. Thermal characteristics
Symbol
Rth(j-a)
Rth(j-sp)
Parameter
Conditions
thermal resistance from junction
to ambient
in free air
to solder point
Min
Typ
Max
Unit
[1]
340
K/W
[2]
200
K/W
[3]
50
K/W
[1] Device mounted on an FR4 Printed-Circuit Board (PCB),single-sided copper, tin-plated and standard footprint.
2
[2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
[3] Soldering point of cathode tab.
7
Characteristics
Table 7. Characteristics
Tj = 25 °C unless otherwise specified.
Symbol
VF
VF
Parameter
forward voltage
forward voltage
Conditions
Min
Typ
Max
Unit
IF = 10 mA
[1]
0.9
V
IF = 100 mA
[1]
1.1
V
PDZ-GW_SER
Product data sheet
3 / 12
PDZ-GW series
Nexperia
Table 8. Characteristics per type; PDZ2.4BGW to PDZ36BGW
PDZx
BGW
Sel Working
voltage
VZ (V);
IZ = 5 mA
Maximum
differential
resistance
rdif (Ω)
Reverse
current
IR (μA)
Temperature Diode
coefficient
capacitance
[1]
SZ (mV/K);
Cd (pF)
IZ = 5 mA
Nonrepetitive
peak
reverse
current
[2]
IZSM (A)
Min
Max
IZ = 0.5
mA
IZ = 5 mA Max
VR (V) Typ
Max
Max
2.4
B
2.43
2.63
1000
100
50
1.0
−1.6
450
8.0
2.7
B
2.69
2.91
1000
100
−2.0
440
8.0
3.0
B
2.85
3.07
1000
95
10
1.0
−2.1
425
8.0
3.3
B
3.32
3.53
1000
95
5
1.0
−2.4
410
8.0
3.6
B
3.60
3.85
500 @ 1
mA
90
5
1.0
−2.4
390
8.0
3.9
B
3.89
4.16
500 @ 1
mA
90
3
1.0
−2.5
370
8.0
4.3
B
4.17
4.48
600 @ 1
mA
90
3
1.0
−2.5
350
8.0
4.7
B
4.55
4.75
600 @ 1
mA
90
2
1.0
−1.4
325
8.0
5.1
B
4.96
5.20
250
60
2
1.5
0.3
300
5.5
5.6
B
5.48
5.73
100
50
1
2.5
1.9
275
5.5
6.2
B
6.06
6.33
80
50
0.5
3.0
2.7
250
5.5
6.8
B
6.65
6.93
60
40
0.5
3.5
3.4
215
5.5
7.5
B
7.28
7.60
60
10
0.5
4.0
4.0
170
3.5
8.2
B
8.02
8.36
60
10
0.5
5.0
4.6
150
3.5
9.1
B
8.85
9.23
60
10
0.5
6.0
5.5
120
3.5
10
B
9.77
10.21 60
10
0.1
7.0
6.4
110
3.5
11
B
10.78 11.22 60
10
0.1
8.0
7.4
108
3.0
12
B
11.74 12.24 80
10
0.1
9.0
8.4
105
3.0
13
B
12.91 13.49 80
10
0.1
10.0
9.4
103
2.5
15
B
14.34 14.98 80
15
0.05
11.0
11.4
99
2.0
16
B
15.85 16.51 80
12.0
12.4
97
1.5
18
B
17.56 18.35 80
13.0
14.4
93
1.5
B
19.52 20.39 100
15.0
16.4
88
1.5
22
B
21.54 22.47 100
25
0.05
17.0
18.4
84
1.3
24
B
23.72 24.78 120
30
0.05
19.0
20.4
80
1.3
PDZ-GW_SER
Product data sheet
4 / 12
PDZ-GW series
Nexperia
PDZx
BGW
Sel Working
voltage
VZ (V);
IZ = 5 mA
Min
Maximum
differential
resistance
rdif (Ω)
Max
IZ = 0.5
mA
Temperature Diode
coefficient
capacitance
[1]
SZ (mV/K);
Cd (pF)
IZ = 5 mA
Reverse
current
IR (μA)
Nonrepetitive
peak
reverse
current
[2]
IZSM (A)
IZ = 5 mA Max
VR (V) Typ
Max
Max
27
B
26.19 27.53 150
40
0.05
21.0
23.4
73
1.0
30
B
29.19 30.69 200
40
0.05
23.0
26.6
66
1.0
33
B
32.15 33.79 250
40
0.05
25.0
29.7
60
0.9
36
B
35.07 36.87 300
60
0.05
27.0
33.0
59
0.8
[1] f = 1 MHz; VR = 0 V.
[2] tp = 100 μs; Tamb = 25 °C.
aaa-027340
103
PZSM
(W)
IF
(mA)
102
200
10
100
1
10-1
mbg781
300
1
tp (ms)
10
0.8
VF (V)
1
Tj = 25 °C (prior to surge)
Tj = 25 °C
Figure 1. Non-repetitive peak reverse power dissipation
as a function of pulse duration; maximum values
Figure 2. Forward current as a function of forward
voltage; typical values
PDZ-GW_SER
Product data sheet
5 / 12
PDZ-GW series
Nexperia
mgl273
SZ
(mV/K)
12
SZ
(mV/K)
4.3
-1
mgl274
10
11
10
9.1
8.2
7.5
6.8
5
3.9
3.6
-2
3.3
6.2
5.6
5.1
3.0
2.4
2.7
-3
60
IZ (mA)
-5
8
12
16
IZ (mA)
PDZ2.4BGW to PDZ4.3BGW
Tj = 25 °C to 150 °C
PDZ4.7BGW to PDZ12BGW
Figure 3. Temperature coefficient as a function of
working current; typical values
Figure 4. Temperature coefficient as a function of
006aab246
102
IZ
(mA)
VZ(nom) (V) = 4.7
IZ
(mA)
VZ(nom) (V) = 2.4
10
006aab247
102
2.7
3.0
3.6
3.3
3.9
4.3
10
5.6 6.8
6.2
1
1
10- 1
10- 1
10- 2
10- 2
10- 3
2
3
4
VZ (V)
5
10- 3
5.1
4
6
9.1
8.2
7.5
8
11
10
10
12
12
14
VZ (V)
Tj = 25 °C
Tj = 25 °C
Figure 5. Working current as a function of working
Figure 6. Working current as a function of working
PDZ-GW_SER
Product data sheet
6 / 12
PDZ-GW series
Nexperia
aaa-026621
102
IZ
(mA)
VZ(nom) (V) = 13
10
1
15
16
18
22
24
33
30
36
10 -1
10 -2
10 -3
10
40
VZ (V)
PDZ13BGW to PDZ36BGW
Tj = 25 °C
Figure 7. Working current as a function of working voltage; typical values
8
Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9
Package outline
3.75
3.45
2.80
2.55
1
1.3
1.0
2
1.7
1.5
Dimensions in mm
16-10-13
Figure 8. Package outline SOD123
PDZ-GW_SER
Product data sheet
7 / 12
PDZ-GW series
Nexperia
10 Soldering
SOD123
4.58
3.27
3.1
2.1 1.62
1.12 1.22 1.42
0.81
0.91
0.81
2.36
0.91
4.18
1.11
occupied area
solder resist
Cu pad
solder paste
Dimensions in mm
1.11
16-05-10
16-08-31
sod123_fr
Reflow soldering is the only recommended soldering method.
Dimensions in mm.
Figure 9. Reflow soldering footprint SOD123
PDZ-GW_SER
Product data sheet
8 / 12
PDZ-GW series
Nexperia
11 Revision history
Table 9. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PDZ-GW_SER v.1
20170904
Product data sheet
PDZ-GW_SER
Product data sheet
9 / 12
PDZ-GW series
Nexperia
12 Legal information
12.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
PDZ-GW_SER
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
10 / 12
PDZ-GW series
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
PDZ-GW_SER
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
PDZ-GW series
Nexperia
Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
Product profile .................................................... 1
General description ............................................1
Features and benefits ........................................1
Applications ........................................................1
Quick reference data ......................................... 1
Pinning information ............................................ 2
Ordering information .......................................... 2
Marking .................................................................2
Limiting values .................................................... 3
Thermal characteristics ......................................3
Characteristics .................................................... 3
Test information .................................................. 7
Quality information .............................................7
Package outline ...................................................7
Soldering ..............................................................8
Revision history .................................................. 9
Legal information .............................................. 10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 September 2017
Document identifier: PDZ-GW_SER
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PDZ10BGWX PDZ12BGWJ PDZ15BGWX PDZ16BGWJ PDZ18BGWJ PDZ3.9BGWX PDZ4.7BGWJ
PDZ5.1BGWX PDZ5.6BGWJ PDZ6.2BGWX PDZ2.4BGWX PDZ16BGWX PDZ36BGWX PDZ33BGWJ
PDZ20BGWJ PDZ11BGWJ PDZ27BGWX PDZ3.3BGWJ PDZ12BGWX PDZ5.6BGWX PDZ6.2BGWJ
PDZ7.5BGWJ PDZ27BGWJ PDZ6.8BGWJ PDZ3.6BGWX PDZ3.0BGWX PDZ2.7BGWX PDZ7.5BGWX
PDZ24BGWX PDZ13BGWX PDZ2.4BGWJ PDZ36BGWJ PDZ20BGWX PDZ2.7BGWJ PDZ22BGWJ PDZ30BGWX
PDZ9.1BGWJ PDZ4.7BGWX PDZ10BGWJ PDZ33BGWX PDZ4.3BGWJ PDZ24BGWJ PDZ4.3BGWX
PDZ30BGWJ PDZ5.1BGWJ PDZ15BGWJ PDZ22BGWX PDZ13BGWJ PDZ11BGWX PDZ3.0BGWJ PDZ3.6BGWJ
PDZ8.2BGWX PDZ18BGWX PDZ9.1BGWX PDZ6.8BGWX PDZ3.3BGWX PDZ8.2BGWJ PDZ3.9BGWJ
