MCL1608NR56JT
MCL1608NR56JT
    SUNLORD(顺络)
    功率电感 560nH ±5% 0603 0.80mm 1.60 x 0.80mm 520mΩ 400mA
MCL1608NR56JT 数据手册
Multilayer Chip Inductor for Choke– MCL-N Series Operating Temp. : -40℃~+85℃ FEATURES Monolithic structure for high reliability ● ● Excellent solderability and high heat resistance ● No cross coupling due to magnetic shield ● High DC bias current due to developed material ● Low AC resistance, low power loss. APPLICATIONS  NFC output filtering and matching circuit, Power line, etc. PRODUCT IDENTIFICATION MCL ① 1608 N ② ③ ① R16 ④ ② MCL Chip Power Inductor ④ T ⑤ ⑥ ③ External Dimensions (L×W) (mm) Type J 1005 [0402] 1.0×0.5 1608 [0603] 1.6×0.8 Feature Type N NFC ⑤ Nominal Inductance Example Nominal Value Inductance Tolerance R16 0.16μH ※R= decimal point J K ±5% ±10% ⑥ M ±20% T Packing Tape & Reel SHAPE AND DIMENSIONS Unit: mm [inch] Sunlord Type L W T a MCL1005N [0402] 1.0±0.15 [0.039±0.006] 0.5±0.15 [0.020±0.006] 0.5±0.15 [0.020±0.006] 0.25±0.1 [0.010±0.004] MCL1608N [0603] 1.60±0.15 [0.063±0.006] 0.8±0.15 [0.031±0.006] 0.8±0.15 [0.031±0.006] 0.3±0.2 [0.012±0.008] Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS MCL1005N TYPE Part Number Inductance L Test Freq. DC Resistance Max. Min. Selfresonant Frequency Units nH MHz Ω Symbol MCL1005N77N□T MCL1005N96N□T MCL1005NR10□T MCL1005NR11□T MCL1005NR12□T MCL1005NR13□T MCL1005NR14□T MCL1005NR15□T MCL1005NR16□T MCL1005NR18□T MCL1005NR20□T MCL1005NR22□T MCL1005NR27□T MCL1005NR33□T MCL1005NR39□T MCL1005NR47□T MCL1005NR56□T Saturation Current Typ. Heat Rating Current Max. MHz mA mA Isat L 77 96 100 110 120 130 140 150 160 180 200 220 270 330 390 470 560 Freq. 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 DCR 0.27 0.35 0.35 0.39 0.39 0.39 0.45 0.45 0.52 0.58 0.58 0.58 0.65 0.65 0.97 0.97 1.40 S.R.F 200 200 200 200 200 200 200 200 200 200 200 180 180 120 120 120 120 550 500 500 450 450 450 450 450 550 370 370 370 350 300 300 250 250 Irms 550 500 500 450 450 450 450 450 400 400 400 400 350 350 300 300 250 Part Number Inductance L Test Freq. DC Resistance Max. Min. Selfresonant Frequency Saturation Current Typ. Heat Rating Current Max. Units nH MHz Ω MHz mA mA Symbol MCL1608N77N□T MCL1608N85N□T MCL1608NR10□T MCL1608NR12□T MCL1608NR16□T MCL1608NR20□T MCL1608NR21□T MCL1608NR22□T MCL1608NR27□T MCL1608NR33□T MCL1608NR39□T MCL1608NR47□T MCL1608NR56□T MCL1608NR65□T MCL1608NR82□T L 77 85 100 120 160 200 210 220 270 330 390 470 560 650 820 Freq. 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 DCR 0.11 0.11 0.12 0.14 0.156 0.22 0.26 0.26 0.286 0.312 0.36 0.494 0.52 0.65 0.75 S.R.F 200 200 200 200 200 200 200 200 200 180 180 120 120 100 80 Isat 1100 1100 1000 1000 1100 700 700 700 650 650 600 600 550 450 400 Irms 1100 1100 1000 800 700 650 600 600 550 500 450 400 400 350 300 MCL1608N TYPE ※Isat: DC current at which the inductance drops approximate 10% from its value without current; ※Irms : DC current that causes the temperature rise (△T =25°C) from 20°C ambient. ※□: Please specify the inductance tolerance code (J=±5%,K=±10%,M=±20%). Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com TYPICAL ELECTRICAL CHARACTERISTICS Inductance vs. Frequency Characteristics Impedance vs. Frequency Characteristics Inductance vs. DC Current Characteristics Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
MCL1608NR56JT 价格&库存
很抱歉,暂时无法提供与“MCL1608NR56JT”相匹配的价格&库存,您可以联系我们找货
MCL1608NR56JT
  • 1+0.56100
  • 200+0.36190
  • 2000+0.31460
  • 4000+0.27830
库存:598
MCL1608NR56JT
  • 4000+0.453814000+0.05890
MCL1608NR56JT
  • 10+0.34075
库存:10
MCL1608NR56JT
  • 1+0.48960
  • 10+0.36720
  • 30+0.29380
  • 100+0.26710
  • 500+0.24490
  • 1000+0.22600
库存:82
