Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
dbook, halfpage
M3D088
PMBT4401
NPN switching transistor
Product data sheet
Supersedes data of 1999 Apr 15
2004 Jan 21
NXP Semiconductors
Product data sheet
PMBT4401
FEATURES
PINNING
• High current (max. 600 mA)
PIN
• Low voltage (max. 40 V).
APPLICATIONS
DESCRIPTION
1
base
2
emitter
3
collector
• Industrial and consumer switching applications.
DESCRIPTION
handbook, halfpage
NPN switching transistor in a SOT23 plastic package.
PNP complement: PMBT4403.
3
3
1
MARKING
MARKING CODE(1)
TYPE NUMBER
PMBT4401
1
2
2
*2X
Top view
MAM255
Note
1. * = p : Made in Hong Kong.
* = t : Made in Malaysia.
* = W : Made in China.
Fig.1 Simplified outline (SOT23) and symbol.
ORDERING INFORMATION
TYPE
NUMBER
PMBT4401
PACKAGE
NAME
DESCRIPTION
VERSION
plastic surface mounted package; 3 leads
SOT23
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCBO
collector-base voltage
open emitter
60
V
VCEO
collector-emitter voltage
open base
40
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current (DC)
600
mA
ICM
peak collector current
800
mA
IBM
peak base current
200
mA
Ptot
total power dissipation
250
mW
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
operating ambient temperature
−65
+150
°C
Tamb ≤ 25 °C; note 1
Note
1. Transistor mounted on an FR4 printed-circuit board.
2004 Jan 21
2
NXP Semiconductors
Product data sheet
PMBT4401
THERMAL CHARACTERISTICS
SYMBOL
Rth (j-a)
PARAMETER
CONDITIONS
thermal resistance from junction to ambient
VALUE
UNIT
500
K/W
note 1
Note
CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
ICBO
collector-base cut-off current
IE = 0; VCB = 60 V
50
nA
IEBO
emitter-base cut-off current
IC = 0; VEB = 6 V
50
nA
hFE
DC current gain
VCE = 1 V; (see Fig.2)
IC = 0.1 mA
IC = 1 mA
40
IC = 10 mA
80
IC = 150 mA; note 1
100
300
IC = 500 mA; VCE = 2 V; note 1
40
VCEsat
collector-emitter saturation
voltage
IC = 150 mA; IB = 15 mA; note 1
400
mV
IC = 500 mA; IB = 50 mA; note 1
750
mV
VBEsat
base-emitter saturation voltage
950
mV
1.2
V
Cc
collector capacitance
IE = Ie = 0; VCB = 5 V; f = 1 MHz
8
pF
Ce
emitter capacitance
IC = Ic = 0; VEB = 500 mV; f = 1 MHz
30
pF
fT
transition frequency
IC = 20 mA; VCE = 10 V; f = 100 MHz
250
MHz
35
ns
15
ns
Switching times (between 10% and 90% levels); (see Fig.3)
ton
turn-on time
ICon = 150 mA; IBon = 15 mA;
IBoff = −15 mA
td
delay time
tr
rise time
ns
toff
turn-off time
250
ns
ts
storage time
200
ns
tf
fall time
60
ns
Note
1. Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
2004 Jan 21
3
NXP Semiconductors
Product data sheet
PMBT4401
MGD811
300
handbook, full pagewidth
hFE
VCE = 1 V
200
100
10−1
1
102
10
Fig.2 DC current gain; typical values.
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
R2
Vi
DUT
R1
MLB826
Vi = 9.5 V; T = 500 µs; tp = 10 µs; tr = tf ≤ 3 ns.
R1 = 68 Ω; R2 = 325 Ω; RB = 325 Ω; RC = 160 Ω.
VBB = −3.5 V; VCC = 29.5 V.
Oscilloscope: input impedance Zi = 50 Ω.
Fig.3 Test circuit for switching times.
2004 Jan 21
4
oscilloscope
IC mA
103
NXP Semiconductors
Product data sheet
PMBT4401
PACKAGE OUTLINE
Plastic surface-mounted package; 3 leads
SOT23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
bp
c
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
OUTLINE
VERSION
SOT23
2004 Jan 21
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
TO-236AB
5
NXP Semiconductors
Product data sheet
PMBT4401
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
DISCLAIMERS
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2004 Jan 21
6
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal
definitions and disclaimers. No changes were made to the technical content, except for package outline
drawings which were updated to the latest version.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R75/04/pp7
Date of release: 2004 Jan 21
Document order number:
9397 750 12462
很抱歉,暂时无法提供与“PMBT4401,235”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.237901+0.16066
- 10+0.7587510+0.09848
- 100+0.46507100+0.06036
- 500+0.33588500+0.04359
- 1000+0.293781000+0.03813
- 2000+0.258222000+0.03352
- 5000+0.219585000+0.02850
- 国内价格 香港价格
- 10000+0.1956010000+0.02539
- 20000+0.1753820000+0.02276
- 30000+0.1650730000+0.02143
- 50000+0.1534750000+0.01992
- 70000+0.1466070000+0.01903
- 100000+0.13992100000+0.01816
