BZX84W-C39X
BZX84W-C39X
    NEXPERIA(安世)
    SOT-323-3
    稳压二极管 Vz=39V 37V~41V Izt=2mA P=275mW SOT323
BZX84W-C39X 数据手册
BZX84W series Voltage regulator diodes Rev. 1 — 29 May 2018 1 Product data sheet Product profile 1.1 General description General-purpose Zener diodes in an SOT323 (SC-70) leadless very small SurfaceMounted Device (SMD) plastic package. 1.2 Features and benefits • Wide working voltage range: nominal 2.4 V to 75 V (E24 range) • Two tolerance series: ± 2 % and ± 5 % • AEC-Q101 qualified 1.3 Applications • General regulation functions • High-frequency applications 2 Pinning information Table 1. Pinning Pin Symbol Description 1 A anode 2 n.c. not connected 3 K cathode Simplified outline Graphic symbol K 3 A n.c. aaa-006592 1 3 2 Ordering information Table 2. Ordering information Type number BZX84W-B2V4 to [1] BZX84W-C75 Package Name Description Version SC-70 Plastic surface-mounted package; 3 leads SOT323 [1] The series consists of 74 types with nominal working voltages from 2.4 V to 75 V. BZX84W series Nexperia Voltage regulator diodes 4 Marking Table 3. Marking Codes Type number Marking Code Type number Marking Code Type number Marking Code Type number Marking Code BZX84W-B2V4 D3% BZX84W-B15 J5% BZX84W-C2V4 M3% BZX84W-C15 R8% BZX84W-B2V7 D4% BZX84W-B16 J6% BZX84W-C2V7 M4% BZX84W-C16 R9% BZX84W-B3V0 D5% BZX84W-B18 J7% BZX84W-C3V0 M5% BZX84W-C18 S2% BZX84W-B3V3 D6% BZX84W-B20 J8% BZX84W-C3V3 M6% BZX84W-C20 S3% BZX84W-B3V6 D7% BZX84W-B22 J9% BZX84W-C3V6 M7% BZX84W-C22 S4% BZX84W-B3V9 D8% BZX84W-B24 K5% BZX84W-C3V9 M9% BZX84W-C24 S5% BZX84W-B4V3 D9% BZX84W-B27 K6% BZX84W-C4V3 N3% BZX84W-C27 S6% BZX84W-B4V7 E4% BZX84W-B30 K7% BZX84W-C4V7 P3% BZX84W-C30 S7% BZX84W-B5V1 E5% BZX84W-B33 K8% BZX84W-C5V1 P4% BZX84W-C33 S8% BZX84W-B5V6 E6% BZX84W-B36 K9% BZX84W-C5V6 P5% BZX84W-C36 S9% BZX84W-B6V2 E7% BZX84W-B39 L2% BZX84W-C6V2 P6% BZX84W-C39 U2% BZX84W-B6V8 E8% BZX84W-B43 L3% BZX84W-C6V8 P7% BZX84W-C43 U3% BZX84W-B7V5 E9% BZX84W-B47 L5% BZX84W-C7V5 P8% BZX84W-C47 U4% BZX84W-B8V2 F5% BZX84W-B51 L6% BZX84W-C8V2 P9% BZX84W-C51 U5% BZX84W-B9V1 F7% BZX84W-B56 L7% BZX84W-C9V1 R3% BZX84W-C56 U6% BZX84W-B10 F9% BZX84W-B62 L8% BZX84W-C10 R4% BZX84W-C62 U7% BZX84W-B11 J2% BZX84W-B68 L9% BZX84W-C11 R5% BZX84W-C68 U8% BZX84W-B12 J3% BZX84W-B75 M2% BZX84W-C12 R6% BZX84W-C75 U9% BZX84W-B13 J4% - - BZX84W-C13 R7% - - % = placeholder for manufacturing site code BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 14 BZX84W series Nexperia Voltage regulator diodes 5 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit IF forward current - 200 mA PZSM non-repetitive peak reverse power dissipation tp = 100 µs; square wave; Tamb = 25 °C; prior to surge - 40 W Ptot total power dissipation Tamb = 25 °C - 275 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C Min Typ Max Unit - - 455 K/W [1] [1] Device mounted on an FR4 Printed -Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6 Thermal characteristics Table 5. Thermal characteristics Symbol Rth(j-a) Parameter Conditions thermal resistance from junction to ambient in free air [1] [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 14 BZX84W series Nexperia Voltage regulator diodes 7 Characteristics Table 6. Electrical characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions Max Unit VF forward voltage IF = 10 mA 0.9 V IR reverse current BZX84W-B/C2V4 VR = 1 V 50 µA BZX84W-B/C2V7 VR = 1 V 20 µA BZX84W-B/C3V0 VR = 1 V 10 µA BZX84W-B/C3V3 VR = 1 V 5 µA BZX84W-B/C3V6 VR = 1 V 5 µA BZX84W-B/C3V9 VR = 1 V 3 µA BZX84W-B/C4V3 VR = 1 V 3 µA BZX84W-B/C4V7 VR = 2 V 3 µA BZX84W-B/C5V1 VR = 2 V 2 µA BZX84W-B/C5V6 VR = 2 V 1 µA BZX84W-B/C6V2 VR = 4 V 3 µA BZX84W-B/C6V8 VR = 4 V 2 µA BZX84W-B/C7V5 VR = 5 V 1 µA BZX84W-B/C8V2 VR = 5 V 700 nA BZX84W-B/C9V1 VR = 6 V 500 nA BZX84W-B/C10 VR = 7 V 200 nA BZX84W-B/C11 VR = 8 V 100 nA BZX84W-B/C12 VR = 8 V 100 nA BZX84W-B/C13 VR = 8 V 100 nA BZX84W-B/C15 to 75 VR = 0.7 VZnom 50 nA BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 14 BZX84W series Nexperia Voltage regulator diodes Table 7. Electrical characteristics per type BZX84WB or C Working voltage VZ (V); at IZ = 5 mA Differential resistance rdiff (Ω); Temperature Diode coefficient capacit. [1] SZ (mV/K); Cd (pF) IZtest = 5 mA Nonrepetitive peak reverse current IZSM (A) at tp = 100 µs; Tamb = 25°C Tol. ± 2% (B) Tol. ± 5% (C) at IZtest = 1 mA at IZtest = 5 mA Min Max Min Max Typ Max Typ Max Typ Max Max 2V4 2.35 2.45 2.2 2.6 275 600 70 100 -1.6 450 6 2V7 2.65 2.75 2.5 2.9 300 600 75 100 -2.0 450 6 3V0 2.94 3.06 2.8 3.2 325 600 80 95 -2.1 450 6 3V3 3.23 3.37 3.1 3.5 350 600 85 95 -2.4 450 6 3V6 3.53 3.67 3.4 3.8 375 600 85 90 -2.4 450 6 3V9 3.82 3.98 3.7 4.1 400 600 85 90 -2.5 450 6 4V3 4.21 4.39 4.0 4.6 410 600 80 90 -2.5 450 6 4V7 4.61 4.79 4.4 5.0 425 500 50 80 -1.4 300 6 5V1 5.00 5.20 4.8 5.4 400 480 40 60 -0.8 300 6 5V6 5.49 5.71 5.2 6.0 80 400 15 40 1.2 300 6 6V2 6.08 6.32 5.8 6.6 40 150 6 10 2.3 200 6 6V8 6.66 6.94 6.4 7.2 30 80 6 15 3.0 200 6 7V5 7.35 7.65 7.0 7.9 30 80 6 15 4.0 150 4 8V2 8.04 8.36 7.7 8.7 40 80 6 15 4.6 150 4 9V1 8.92 9.28 8.5 9.6 40 100 6 15 5.5 150 3 10 9.80 10.20 9.4 10.6 50 150 8 20 6.4 90 3 11 10.8 11.2 10.4 11.6 50 150 10 20 7.4 85 2.5 12 11.8 12.2 11.4 12.7 50 150 10 25 8.4 85 2.5 13 12.7 13.3 12.4 14.1 50 170 10 30 9.4 80 2.5 15 14.7 15.3 13.8 15.6 50 200 10 30 11.4 75 2.0 16 15.7 16.3 15.3 17.1 50 200 10 40 12.4 75 1.5 18 17.6 18.4 16.8 19.1 50 225 10 45 14.4 70 1.5 20 19.6 20.4 18.8 21.2 60 225 15 55 16.4 60 1.5 22 21.6 22.4 20.8 23.3 60 250 20 55 18.4 60 1.25 24 23.5 24.5 22.8 25.6 60 250 25 70 20.4 55 1.25 [1] f = 1 MHz; VR = 0 V BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 14 BZX84W series Nexperia Voltage regulator diodes BZX84W- Working voltage B or C VZ (V); Differential resistance rdiff (Ω); at IZ = 2 mA Temperature Diode coefficient capacit. [1] SZ (mV/K); Cd (pF) IZtest = 2 mA Nonrepetitive peak reverse current IZSM (A) at tp = 100 µs; Tamb = 25°C Tol. ± 2% (B) Tol. ± 5% (C) at IZtest = 0.5 mA at IZtest = 2 mA Min Max Min Max Typ Max Typ Max Typ Max Max 27 26.5 27.5 25.1 28.9 65 300 25 80 23.4 50 1.0 30 29.4 30.6 28.5 32.0 70 300 30 80 26.6 50 1.0 33 32.3 33.7 31.0 35.0 75 325 35 80 29.7 45 0.9 36 35.3 36.7 34.0 38.0 80 350 35 90 33.0 45 0.8 39 38.2 39.8 37.0 41.0 80 350 40 130 36.4 45 0.7 43 42.1 43.9 40.0 46.0 85 375 45 150 41.2 40 0.6 47 46.1 47.9 44.0 50.0 85 375 50 170 46.1 40 0.5 51 50.0 52.0 48.0 54.0 90 400 60 180 51.0 40 0.4 56 54.9 57.1 52.0 60.0 100 425 70 200 57.0 40 0.3 62 60.8 63.2 58.0 66.0 120 450 80 215 64.4 35 0.3 68 66.6 69.4 64.0 72.0 150 475 90 240 71.7 35 0.25 75 73.5 76.5 70.0 79.0 170 500 95 255 80.2 35 0.2 [1] f = 1 MHz; VR = 0 V aaa-028521 103 PZSM (W) 102 aaa-028550 103 IF (mA) 102 10 1 10-1 10 10-2 1 10-1 Tj = 25 °C (before surge) 1 tp (ms) 10 10-3 0.4 0.6 0.8 VF (V) 1.0 Tj = 25 °C Figure 1. Non-repetitive peak reverse power dissipation Figure 2. Forward current as a function of forward voltage; typical values (BZX84W-B/C2V4) as a function of pulse duration; maximum values BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 14 BZX84W series Nexperia Voltage regulator diodes aaa-028551 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) aaa-028552 103 IF (mA) 102 1.0 10-3 0.4 0.6 0.8 VF (V) 1.0 Tj = 25 °C Tj = 25 °C Figure 3. Forward current as a function of forward voltage; typical values (BZX84W-B/C6V8) Figure 4. Forward current as a function of forward voltage; typical values (BZX84W-B/C7V5) aaa-028553 103 IF (mA) 102 mbg783 0 SZ (mV/K) 10 4V3 -1 3V9 3V6 1 10-1 -2 3V3 10-2 10-3 0.4 2V4 2V7 0.6 0.8 VF (V) 1.0 -3 0 20 Tj = 25 °C BZX84W_B/C2V4 to B/C4V3 Figure 5. Forward current as a function of forward voltage; typical values (BZX84W-B/C75) Tj = 25 °C to 150 °C BZX84W_SER Product data sheet 3V0 40 IZ (mA) 60 Figure 6. Temperature coefficient as a function of working current; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 14 BZX84W series Nexperia Voltage regulator diodes mbg782 10 12 SZ (mV/K) 11 10 9V1 5 8V2 7V5 6V8 6V2 5V6 5V1 0 -5 4V7 0 4 8 12 16 IZ (mA) 20 BZX84W_B/C4V7 to B/C12 Tj = 25 °C to 150 °C Figure 7. Temperature coefficient as a function of working current; typical values BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 14 BZX84W series Nexperia Voltage regulator diodes 8 Package outline Plastic surface-mounted package; 3 leads SOT323 D B E A X HE y v M A 3 Q A A1 1 c 2 e1 bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w mm 1.1 0.8 0.1 0.4 0.3 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.23 0.13 0.2 0.2 OUTLINE VERSION REFERENCES IEC SOT323 JEDEC JEITA SC-70 EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 Figure 8. Package outline SOT323 BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 14 BZX84W series Nexperia Voltage regulator diodes 9 Soldering 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 1 occupied area 0.5 (3×) Dimensions in mm 0.55 (3×) sot323_fr Figure 9. Reflow soldering footprint SOT323 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Figure 10. Wave soldering footprint SOT323 BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 14 BZX84W series Nexperia Voltage regulator diodes 10 Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX84W_SER v.1 20180529 Product data sheet - - BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 14 BZX84W series Nexperia Voltage regulator diodes 11 Legal information 11.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 11.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 14 BZX84W series Nexperia Voltage regulator diodes Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BZX84W_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 29 May 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 14 BZX84W series Nexperia Voltage regulator diodes Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 8 9 10 11 Product profile .................................................... 1 General description ............................................1 Features and benefits ........................................1 Applications ........................................................1 Pinning information ............................................ 1 Ordering information .......................................... 1 Marking .................................................................2 Limiting values .................................................... 3 Thermal characteristics ......................................3 Characteristics .................................................... 4 Package outline ...................................................9 Soldering ............................................................10 Revision history ................................................ 11 Legal information .............................................. 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 29 May 2018 Document identifier: BZX84W_SER
BZX84W-C39X 价格&库存
很抱歉,暂时无法提供与“BZX84W-C39X”相匹配的价格&库存,您可以联系我们找货
