BWLS003025221R8J00
BWLS003025221R8J00
    CHILISIN(奇力新)
    IND_2.99X2.5MM_SM
    信号/去耦电感 1.8µH ±5% 1.05A 750mΩ IND_2.99X2.5MM_SM 2.99 x 2.50mm 2.20mm
BWLS003025221R8J00 数据手册
SMD Wire Wound Ferrite Chip Inductors - BWLS Series BWLS Series BWLS Series is the newest in open type ferrite wire wound chip inductors. The wire wound ferrite construction supports higher SRF, lower DCR and superior Q values than other ferrite chip inductors. Features Applications             RoHS compliant Very strong solderability by reflow soldering and soldering iron Highly accurate dimensions Can be mounted automatically Terminals are highly resistant to external forces Highly resistant to mechanical shocks and pressure Highly reliable in environments of sudden temperature change and humidity  Low DCR & better Q value in ferrite series Telecom and datacom applications such as xDSL Cable modem Set-top box CATV filter/tuner Wireless LAN, etc Product Identification Shape and Dimensions / Recommended Pattern BWLS00060404 BWLS00100606/161109/241715/302522 Dimensions in mm TYPE A Max B Max C Max D E F G H I J BWLS00060404 0.58 0.46 0.45 - 0.38 0.12 - 0.46 0.18 0.22 BWLS00100606 1.02±0.1 0.55±0.1 0.56±0.1 0.25 0.54 0.23 0.50 0.65 0.38 0.44 BWLS00161109 1.6+0.2-0.1 1.1±0.1 0.9+0.2-0.1 0.38 0.86 0.33 0.76 1.02 0.64 0.64 BWLS00241715 2.4 1.72 1.52 0.70 1.02 0.50 1.27 1.78 1.02 0.76 BWLS00302522 2.99 2.50 2.20 0.70 1.52 0.51 2.03 2.54 1.02 1.27 SMD Wire Wound Ferrite Chip Inductors – BWLS Series Electrical Characteristics Inductance Tolerance Test Frequency Q SRF RDC Irms (nH) (±%) (MHz) Typ. (MHz)Min. (Ω)Max. (mA)Typ. BWLS000604042N2□00 2.2 10 100 5 3000 0.09 1600 BWLS000604046N8□00 6.8 10 / 5 100 6 2400 0.11 950 BWLS000604047N8□00 7.8 10 / 5 100 7 2500 0.11 1050 BWLS0006040415N□00 15 10 / 5 100 7 2300 0.12 750 BWLS0006040417N□00 17 10 / 5 100 7 2400 0.13 750 BWLS0006040426N□00 26 10 / 5 100 7 2200 0.20 750 BWLS0006040428N□00 28 10 / 5 100 7 2400 0.2. 700 BWLS0006040439N□00 39 10 / 5 100 7 2300 0.24 580 BWLS0006040443N□00 43 10 / 5 100 7 2200 0.24 600 BWLS0006040456N□00 56 10 / 5 100 7 2200 0.26 550 BWLS0006040459N□00 59 10 / 5 100 7 2200 0.26 500 BWLS0006040476N□00 76 10 / 5 100 7 2000 0.30 500 BWLS0006040478N□00 78 10 / 5 100 7 2000 0.30 500 BWLS00060404R10□00 100 10 / 5 100 7 1500 0.41 430 BWLS00060404R13□00 130 10 / 5 100 7 1500 0.44 400 BWLS00060404R16□00 160 10 / 5 100 7 1400 0.71 350 BWLS00060404R20□00 200 10 / 5 50 9 1400 0.95 260 Part Number Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-25℃~105℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent E4991A RDC:HP4287 Irms:HP4284A+HP42841A Test Instruments:Agilent E4991A Material/Impedance Analyzer Typical L vs. Frequency Typical Q vs. Frequency 1000 16 14 R20 R20 100 12 56N 10 Q L(nH) 56N 10 56N 26N 8 26N 6 2N2 6N8 1 4 2N2 2 0 0.1 1 10 100 FREQUENCY (MHz) 1000 10000 1 10 100 FREQUENCY (MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 SMD Wire Wound Ferrite Chip Inductors – BWLS Series Electrical Characteristics Inductance Tolerance Test Frequency Q SRF RDC Irms (uH) (±%) (MHz) Typ. (MHz)Typ. (Ω) Max (mA)Typ. BWLS0010060618N00 0.018 10 / 5 100 10 2600 0.055 1600 BWLS0010060620N00 0.020 10 / 5 100 10 2600 0.050 1600 BWLS0010060622N00 0.022 10 100 10 2500 0.072 1300 BWLS0010060633N00 0.033 10 / 5 100 10 2300 0.060 1400 BWLS0010060636N00 0.036 10 / 5 100 10 2300 0.092 1000 BWLS0010060639N00 0.039 10 / 5 100 10 2200 0.150 830 BWLS0010060651N00 0.051 10 100 10 1930 0.070 1100 BWLS0010060656N00 0.056 10 100 10 1900 0.125 900 BWLS0010060672N00 0.072 10 / 5 100 10 1650 0.100 900 BWLS0010060678N00 0.078 10 / 5 100 10 1600 0.190 850 BWLS00100606R1000 0.10 10 100 9 1400 0.160 900 BWLS00100606R1400 0.14 10 / 5 50 11 1220 0.260 540 BWLS00100606R1800 0.18 10 50 11 1150 0.330 560 BWLS00100606R2000 0.20 10 / 5 50 11 1000 0.440 400 BWLS00100606R2200 0.22 10 / 5 50 11 1150 0.530 380 BWLS00100606R2500 0.25 10 / 5 25 11 900 0.360 520 BWLS00100606R2700 0.27 10 25 11 860 0.550 360 BWLS00100606R3000 0.30 10 / 5 25 11 860 0.410 420 BWLS00100606R3300 0.33 10 / 5 7.9 11 820 0.680 350 BWLS00100606R3600 0.36 10 / 5 7.9 11 810 0.575 360 BWLS00100606R3900 0.39 10 / 5 7.9 11 760 0.890 300 BWLS00100606R4200 0.42 10 / 5 7.9 11 700 1.100 340 BWLS00100606R4700 0.47 10 7.9 11 650 0.730 310 BWLS00100606R5600 0.56 10 / 5 7.9 11 600 1.100 200 Part Number Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-25℃~105℃(Including self - temperature rise)  Irms for a 15℃ temperature rise from 25℃ ambient with current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent E4991A RDC:Chroma 16502 Irms:HP4284A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – BWLS Series Test Instruments:Agilent E4991A Material/Impedance Analyzer Typical L vs. Frequency Typical Q vs. Frequency 1000 16 R56 14 R56 R27 R27 12 R10 100 L(nH) R10 10 Q 56N 20N 20N 8 6 10 56N 4 2 0 1 1 10 100 FREQUENCY (MHz) 1000 10000 1 10 100 FREQUENCY (MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 SMD Wire Wound Ferrite Chip Inductors – BWLS Series Electrical Characteristics Inductance Tolerance Test Frequency Q SRF RDC IDC (uH) (±%) (MHz) Typ. (MHz) Min (Ω) Max (mA) BWLS0016110947N00 0.047 10 / 5 7.9 17 1700 0.075 1500 Black BWLS0016110972N00 0.072 10 / 5 7.9 17 1700 0.12 1500 Brown BWLS00161109R1000 0.10 10 / 5 7.9 17 1650 0.13 1500 Red BWLS00161109R1200 0.12 10 / 5 7.9 17 1350 0.15 1500 Orange BWLS00161109R1500 0.15 10 / 5 7.9 17 1350 0.15 1450 Yellow BWLS00161109R1800 0.18 10 / 5 7.9 17 1150 0.15 1400 Green BWLS00161109R2200 0.22 10 / 5 7.9 17 1050 0.16 1350 Blue BWLS00161109R2400 0.24 10 / 5 7.9 17 1050 0.19 1300 Violet BWLS00161109R2700 0.27 10 / 5 7.9 17 1050 0.30 1050 Gray BWLS00161109R3300 0.33 10 / 5 7.9 17 850 0.46 1200 White BWLS00161109R3900 0.39 10 / 5 7.9 17 810 0.51 1200 Black BWLS00161109R4700 0.47 10 / 5 7.9 17 720 0.62 1050 Brown BWLS00161109R5600 0.56 10 / 5 7.9 17 600 0.44 850 Red BWLS00161109R6800 0.68 10 / 5 7.9 17 600 0.52 850 Orange BWLS00161109R7800 0.78 10 / 5 7.9 17 460 0.83 850 Yellow BWLS00161109R8200 0.82 10 / 5 7.9 17 480 0.69 750 Green BWLS00161109R9100 0.91 10 / 5 7.9 17 330 0.76 670 Black BWLS001611091R000 1.0 10 / 5 7.9 18 310 0.81 600 Blue BWLS001611091R200 1.2 10 / 5 7.9 17 270 0.87 550 Violet BWLS001611091R500 1.5 10 / 5 7.9 17 270 1.06 540 Gray BWLS001611091R800 1.8 10 / 5 7.9 17 230 1.10 520 White BWLS001611092R200 2.2 10 / 5 7.9 17 140 1.20 500 Black BWLS001611092R700 2.7 10 / 5 7.9 17 105 1.50 480 Brown BWLS001611093R300 3.3 10 / 5 7.9 17 84 1.50 440 Red BWLS001611093R900 3.9 10 / 5 7.9 17 80 1.60 430 Orange BWLS001611094R700 4.7 10 / 5 7.9 18 69 2.10 420 Yellow BWLS001611095R600 5.6 10 / 5 7.9 18 65 2.60 400 Green BWLS001611096R800 6.8 10 / 5 7.9 19 55 3.10 400 Blue BWLS001611097R800 7.8 10 / 5 7.9 17 47 3.50 400 Violet BWLS001611098R200 8.2 10 / 5 7.9 17 42 3.80 400 Gray BWLS0016110910000 10 10 / 5 7.9 19 40 4.80 300 White Part Number Color Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-25℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent HP8753D/Agilent E4991A RDC:Chroma 16502 IDC:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – BWLS Series Test Instruments:Agilent E4991A Material/Impedance Analyzer Typical L vs. Frequency Typical Q vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – BWLS Series Electrical Characteristics Inductance Tolerance Test Frequency Q SRF RDC IDC (uH) (±%) (MHz) Typ. (MHz) Min (Ω) Max (mA) BWLS0024171578N00 0.078 10 / 5 7.9 19 1440 0.06 2000 Black BWLS0024171590N00 0.090 10 7.9 19 1200 0.07 2000 Red BWLS00241715R1100 0.11 10 / 5 7.9 19 1200 0.07 2000 Brown BWLS00241715R4700 0.47 10 / 5 7.9 19 480 0.40 800 Red BWLS00241715R5600 0.56 10 / 5 7.9 35 480 0.40 800 Yellow BWLS00241715R6800 0.68 10 / 5 7.9 20 480 0.40 800 Orange BWLS00241715R9100 0.91 10 / 5 7.9 20 400 0.69 700 Yellow BWLS002417151R000 1.0 10 / 5 7.9 20 400 0.69 700 Yellow BWLS002417151R200 1.2 10 / 5 7.9 20 330 0.83 700 Red BWLS002417151R500 1.5 10 / 5 7.9 20 330 0.83 700 Green BWLS002417151R800 1.8 10 / 5 7.9 20 300 1.00 650 Blue BWLS002417152R200 2.2 10 / 5 7.9 20 250 1.10 650 Violet BWLS002417152R700 2.7 10 / 5 7.9 23 200 1.25 650 Gray BWLS002417153R300 3.3 10 / 5 7.9 23 160 1.45 650 White BWLS002417153R900 3.9 10 / 5 7.9 23 90 1.50 600 Black BWLS002417154R700 4.7 10 / 5 7.9 20 70 1.60 530 Brown BWLS002417155R600 5.6 10 / 5 7.9 20 65 1.70 500 Red BWLS002417156R800 6.8 10 / 5 7.9 20 45 1.95 470 Orange BWLS002417158R200 8.2 10 / 5 2.5 16 45 2.10 450 Yellow BWLS0024171510000 10 10 / 5 2.5 16 40 2.40 400 Green BWLS0024171512000 12 10 / 5 2.5 16 38 3.20 360 Red BWLS0024171515000 15 10 / 5 2.5 16 30 3.55 350 Blue BWLS0024171518000 18 10 / 5 2.5 16 25 4.90 300 Orange BWLS0024171522000 22 10 / 5 2.5 16 20 5.45 270 Violet BWLS0024171527000 27 10 / 5 2.5 16 19 7.80 240 Gray BWLS0024171533000 33 10 / 5 2.5 16 16 9.50 210 White BWLS0024171547000 47 10 / 5 2.5 16 15 14.50 180 Brown Part Number Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-25℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent E4991A RDC:HP4338B or Chroma 16502 IDC:HP4284A+HP42841A/HP4285A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Color SMD Wire Wound Ferrite Chip Inductors – BWLS Series Test Instruments:Agilent E4991A Material/Impedance Analyzer Typical L vs. Frequency Typical Q vs. Frequency 50 1000 40 220 100 1R0 6R8 Q L(uH) 30 10 20 1R0 6R8 1 10 220 0 0.1 1 10 100 FREQUENCY(MHz) 1000 1 10 100 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 SMD Wire Wound Ferrite Chip Inductors – BWLS Series Electrical Characteristics Part Number Inductance Tolerance Test Frequency Q SRF RDC IDC (MHz) Min (Ω) Max (mA) Color Coding (uH) (±%) BWLS003025221R200 1.2 10 / 5 7.9 55 50 350 0.50 1200 Brown BWLS003025221R500 1.5 10 / 5 7.9 58 50 300 0.65 1200 Brown Green Red BWLS003025221R800 1.8 10 / 5 7.9 54 50 280 0.75 1050 Brown Gray Red BWLS003025222R200 2.2 10 / 5 7.9 48 50 250 0.90 950 Red Red Red BWLS003025222R700 2.7 10 / 5 7.9 51 50 200 1.00 950 Red Violet Red BWLS003025223R300 3.3 10 / 5 7.9 58 50 200 1.15 900 Orange Orange Red BWLS003025223R900 3.9 10 / 5 7.9 37 7.9 170 1.25 850 Orange White Red BWLS003025224R700 4.7 10 / 5 7.9 37 7.9 130 1.35 700 Yellow Violet Red BWLS003025225R600 5.6 10 / 5 7.9 36 7.9 110 1.45 700 Green Blue Red BWLS003025226R800 6.8 10 / 5 7.9 33 7.9 105 1.60 600 Blue Gray Red BWLS003025228R200 8.2 10 / 5 7.9 40 7.9 90 1.80 550 Gray Red Red BWLS0030252210000 10 10 / 5 7.9 40 7.9 85 2.40 500 Brown Black Orange BWLS0030252212000 12 10 / 5 7.9 40 7.9 80 2.40 450 Brown Red BWLS0030252215000 15 10 / 5 7.9 35 7.9 38 2.40 450 Brown Green Orange BWLS0030252239000 39 10 / 5 2.5 33 2.5 26 10 170 Orange White Orange (MHz) Typ. Test Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10%  Operating temperature range-25℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: L & Q:Agilent E4991A+Agilent HP16197A SRF:Agilent E4991A RDC:HP4338B or Chroma 16502 IDC:HP4284A+HP42841A/HP4285A+HP42841A Test Instruments:Agilent E4991A Material/Impedance Analyzer Typical L vs. Frequency Typical Q vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1ST 2ND 3RD Red Red Orange SMD Wire Wound Ferrite Chip Inductors - BWLS Series Packaging Specifications Tape Dimensions Tape Material Figure 1 Figure 2 Reel Dimensions Figure 3 Dimensions in mm Tape Dimensions TYPE Reel Dimensions Quantity Fig. A B T W P F K A B C D PCS / REEL BWLS00060404 1 0.44 0.64 0.61 8 2 3.5 045 178 60 12 1.5 4000 BWLS00100606 1 0.67 1.20 0.75 8 2 3.5 0.59 178 60 12 1.5 4000 BWLS00161109 2 1.25 1.90 1.05 8 4 3.5 - 178 60 12 1.5 4000 BWLS00241715 3 1.60 2.42 0.22 8 4 3.5 1.45 178 60 12 1.5 2000 BWLS00302522 3 2.40 2.93 0.26 8 4 3.5 2.25 178 60 12 1.5 2000
BWLS003025221R8J00 价格&库存
很抱歉,暂时无法提供与“BWLS003025221R8J00”相匹配的价格&库存,您可以联系我们找货
