TYS5020220M-10
TYS5020220M-10
    LAIRD(莱尔德)
    SMD,5x5mm
    功率电感 22µH ±20% IND_5X5MM_SM 2.00mm 5.00 x 5.00mm 252mΩ 1.1A 14MHz
TYS5020220M-10 数据手册
TYS -Low Profile SMT Power Inductor TYS5020 Series FEATURES AND APPLICATIONS Laird TYS series high current power inductors improve performance, reliability and power efficiency. A lower profile benefits consumer electronics, industrial and telecom design. Products feature extremely low DCR with greater efficiency and enable a large current in a small size. Inductors are of magnetic shielding and wire wound construction and perform in operating temperatures ranging from -40 C to 125 C including self-heating rise in temperature. FEATURES • • • • Magnetic shielded structure Low DCR and high efficiency Low profile and small size Ferrite core with high saturation APPLICATIONS • • • • • • DC-DC Converter and Power Suppliers LCD TV’S and Gaming Console Tablet, Notebooks, Servers and Printers Networking and Data storage GPS, Set-top-box and Base stations Smart meters and Medical instruments PART NUMBER EXPLANATION T Y S 5020 Product series code Product size code 4R7 Inductance value code (i.e. 4R7: 4.7 M - 10 Tolerance % (i.e. M: 20%) Standard Catalog P.N ELECTRICAL SPECIFICATIONS • Tolerance: M: ±20% or N: ±30% • Inductance tested at 1MHz, 1.0Vrms • Heat Rated Current (Irms) is defined based on temperature rise approximate 40°C (ambient temperature 25±5°C) • Saturation Current (Isat) is the DC current at which the inductance drops off approximately 30% from its value without current. (ambient temperature 25±5°C) • Operating temperature range: -40°C~+125°C (including self-heating temperature rise) • Storage temperature range (packaging conditions): -10°C~+40°C and RH 70%(MAX.) Note: Heat Rated Current (Irms) is tested on a typical PCB and apply a constant current in still air. The temperature rise is dependent on the application system condition including PCB PAD pattern, trace width and thickness and adjacent components etc. It’s suggested to verify the temperature rise of the component under the real operation application conditions. Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A SPECIFICATION 1.MECHANICAL & DIMENSIONS (UNIT: mm) A 5.00±0.20 B 5.00±0.20 C 2.0+0.2/-0.3 D 4.00±0.30 E 1.25±0.30 F 2.50±0.30 G 4.2 REF H 2.3 REF T 1.4 REF REMARK 2.PART NUMBER NOMENCLATOR: D: Inductance Tolerance. (M=±20% ,N=±30%) E: "X"=0:Standard catalog part number A: Product Series. B: Series number, part size C: Inductance code 3.EQUIVALENT CIRCUIT: "X"=1-9:Controlled customized part or different performance than std catalog part. Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A SPECIFICATION PART NUMBER INDUCTANCE (uH) Irms(A) Typ. Isat(A) Typ. DCR(mΩ) TYP DCR(mΩ) Max SRF MHz TYS5020R47N-10 0.47 4.60 6.15 15.00 17.0 160 TYS5020R75N-10 0.75 4.00 5.50 19.00 22.0 117 TYS50201R0N-10 1.00 3.80 4.10 22.40 26.0 114 TYS50201R5N-10 1.50 3.20 4.10 30.20 34.0 68 TYS50202R2N-10 2.20 2.90 3.20 38.30 41.6 57 TYS50202R7N-10 2.70 2.70 2.90 44.10 50.0 52 TYS50203R3N-10 3.30 2.50 2.55 50.00 56.0 46 TYS50204R3M-10 4.30 2.20 2.50 65.00 74.0 37 TYS50204R7M-10 4.70 2.20 2.50 65.00 74.0 37 TYS50205R6M-10 5.60 2.05 2.30 72.00 83.0 32 TYS50206R8M-10 6.80 1.80 2.05 92.00 108.0 30 TYS50207R5M-10 7.50 1.75 1.85 95.00 117.0 26 TYS50208R2M-10 8.20 1.65 1.85 100.00 127.0 26 TYS5020100M-10 10.00 1.55 1.70 125.00 143.0 24 TYS5020120M-10 12.00 1.40 1.50 158.00 182.0 22 TYS5020150M-10 15.00 1.25 1.35 193.00 215.0 20 TYS5020220M-10 22.00 1.10 1.15 252.00 294.0 14 • Tolerance: M: ±20% or N: ±30% • Inductance tested at 100KHz, 1.0Vrms • Heat Rated Current (Irms) is defined based on temperature rise approximate 40°C (ambient temperature 25±5°C) • Saturation Current (Isat) is the DC current at which the inductance drops off approximately 30% from its value without current. (ambient temperature 25±5°C) • Operating temperature range: -40°C~+125°C (including self-heating temperature rise) • Storage temperature range (packaging conditions): -10°C~+40°C and RH 70%(MAX.) Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A SPECIFICATION Characteristics Curve 40 0.3 30 0.2 20 0.1 10 0.0 0 3.2 4.8 6.4 0.8 40 0.6 30 0.4 20 0.2 10 0.0 8 0 0 1.6 IDC(A) 48 0.9 36 0.6 24 0.3 12 0.0 Inductance (uH) 1.2 0 1.6 2.4 3.2 50 1.6 40 1.2 30 0.8 20 0.4 10 0.0 4 0 0 0.8 40 1.5 30 1.0 20 0.5 10 0.0 0 IDC(A) 4 5 Inductance (uH) 2.0 3 2.4 3.2 4 TYS50202R7N-10 50 Temperature Rise (℃) Inductance (uH) TYS50202R2N-10 2 1.6 IDC(A) 2.5 1 8 2.0 IDC(A) 0 6.4 TYS50201R5N-10 60 Temperature Rise (℃) Inductance (uH) TYS50201R0N-10 0.8 4.8 IDC(A) 1.5 0 3.2 Temperature Rise (℃) 1.6 50 3.0 50 2.4 40 1.8 30 1.2 20 0.6 10 0.0 0 0 1 2 3 IDC(A) 4 5 Temperature Rise (℃) 0 1.0 Temperature Rise (℃) 0.4 Inductance (uH) TYS5020R75N-10 50 Temperature Rise (℃) Inductance (uH) TYS5020R47N-10 0.5 Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A SPECIFICATION Characteristics Curve 40 2.4 30 1.6 20 0.8 10 0.0 Inductance (uH) 3.2 0 1.6 2.4 3.2 4.0 40 3.0 30 2.0 20 1.0 10 0.0 4 0 0 0.8 IDC(A) 4.0 40 3.0 30 2.0 20 1.0 10 0.0 0 1.6 2.4 3.2 4 30 3 20 2 10 1 0 0 0.8 20 2 10 0 0 3.2 4 Inductance (uH) 30 4 Temperature Rise (℃) Inductance (uH) 40 6 IDC(A) 2.4 3.2 4 TYS50207R5M-10 50 2.4 1.6 IDC(A) TYS50206R8M-10 1.6 50 40 4 8 0.8 4 5 IDC(A) 0 3.2 TYS50205R6M-10 6 Inductance (uH) 50 Temperature Rise (℃) Inductance (uH) TYS50204R7M-10 0.8 2.4 IDC(A) 5.0 0 1.6 Temperature Rise (℃) 0.8 50 10 50 8 40 6 30 4 20 2 10 0 0 0 0.4 0.8 1.2 IDC(A) 1.6 2 Temperature Rise (℃) 0 TYS50204R3M-10 5.0 Temperature Rise (℃) Inductance (uH) 50 Temperature Rise (℃) TYS50203R3N-10 4.0 Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A SPECIFICATION Characteristics Curve TYS50208R2M-10 6 30 4 20 2 10 0 0 0.4 0.8 1.2 1.6 50 12 40 9 30 6 20 3 10 0 0 0 2 0.4 IDC(A) 40 9 30 6 20 3 10 0 0 1.2 1.6 2 50 20 40 15 30 10 20 5 10 0 0 1.2 IDC(A) 1.6 2 Temperature Rise (℃) Inductance (uH) TYS5020220M-10 0.8 50 12.8 40 9.6 30 6.4 20 3.2 10 0.0 0 0.4 0.8 1.2 IDC(A) 25 0.4 2 16.0 0 IDC(A) 0 Inductance (uH) 12 0.8 1.6 TYS5020150M-10 50 Temperature Rise (℃) Inductance (uH) TYS5020120M-10 0.4 1.2 IDC(A) 15 0 0.8 1.6 2 Temperature Rise (℃) 0 15 Temperature Rise (℃) 40 Inductance (uH) 8 Inductance (uH) 50 Temperature Rise (℃) TYS5020100M-10 10 Laird Performance Materials Shielded Power Inductor www.laird.com Recommended Soldering Conditions 1 2 3 4 5 ■ For Lead-Free Application Figure 1 . Re-flow Soldering Within 4 sec TYS5020 Series Rev: A Laird Performance Materials Shielded Power Inductor www.laird.com Reliability and Testing Conditions / Pin Type Power Inductors TYS5020 Series Rev: A SMD series(Consumer) Item Reference Additional Requirements Operating temperature -40℃~ +125℃(Including self-temperature rise) range Storage temperature and humidity range High Temperature Exposure (Storage) -10℃ to +40℃ , 70% RH Max MIL-STD-202 Method 108 85±2℃, 168+24hours JESD22 Method JA-104 -40℃→+85, transforming interval:20s, 100cycles Operational Life MIL-PRF-2 85±℃, 168+24hours Apply maximum rated voltage and current according part drawing External Visual MIL-STD-883 Method 2009 Inspect device construction, marking and workmanship. Electrical Test not required. JESD22 Method JB-100 Verify physical dimensions to the applicable device detail specification. Note: User(s) and Suppliers spec. Electrical Test not required MIL-STD-202 Method 204 10~55Hz,1.5mm, 2 hours in each 3mutually perpendicular directions (total of 6 hours) Temperature Cycling Physical Dimension Vibration Resistance to Soldering MIL-STD-202 Method 210 Heat 1. Max. 260±5℃,10±1s, 2 times 2.Solder Composition: Sn/3Ag/0.5Cu Solderability J-STD-002 245±5℃, 5±1sec, Solder: Sn/3.0Ag/0.5Cu Electrical Characterization Print Spec Parametrically test per lot and sample size requirements, summary to show Min, Max, Mean and Standard deviation at room as well as Min and Max Operating temperatures AEC-Q200-005 2mm,30±1s Board Flex Terminal Strength(SMD) AEC-Q200-006 10N, 5S, X,Y direct Laird Performance Materials Shielded Power Inductor www.laird.com TYS5020 Series Rev: A PACKAGING Reel Dimension 330 REF 100 REF 13 REF 12.4 REF A(mm) B(mm) C(mm) D(mm) Tape Dimension W E F P P1 P2 T D 12.0±0.3 5.5±0.1 1.75±0.1 4.0±0.1 2.0±0.1 8.0±0.1 0.3±0.05 1.5±0.1 Packaging Quantity P/N Chip/Reel TYS5020 series 2500pcs Peeling Off Force The force peeling off cove tape is 10 to 100 grams in the arrow direction under the following conditions Room Temp Room Humidity (%) Room atrn (hPa) Teaming Speed (mm/min) 5~35 45~85 860~1060 300 ※Storage Conditions 1. Temperature and humidity conditions: -10-+40℃ and 70% RH. 2. Recommended products should be used within 12 months from the time of manufacturing. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. 4. Allowable stacking condition of Packaging box:max height 1.5m or 5 boxes stacking
TYS5020220M-10 价格&库存
很抱歉,暂时无法提供与“TYS5020220M-10”相匹配的价格&库存,您可以联系我们找货
TYS5020220M-10
  • 1+3.894451+0.50240
  • 10+3.2204110+0.41544
  • 100+2.64459100+0.34116
  • 1000+2.175021000+0.28059
库存:142736
TYS5020220M-10
  • 2500+2.012422500+0.25961
  • 5000+1.897725000+0.24481
  • 7500+1.833767500+0.23656
  • 12500+1.7562912500+0.22657
  • 17500+1.7071217500+0.22023
  • 25000+1.6565425000+0.21370
库存:142736
