SLW3012S2R2NST
SLW3012S2R2NST
    SUNLTECH(顺磁)
    SMD,3x3mm
    功率电感 2.2µH ±30% IND_3X3MM_SM 1.20mm 3.00 x 3.00mm 67mΩ 1.26A 84MHz
SLW3012S2R2NST 数据手册
SLW3012S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW (1) (1) (2) (3) (4) 3012 (2) S (3) 100 M S T (4) (5) (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series SLW3012 Rev.01 A B C D E F a Typ. b Typ. c Typ. 3.0±0.2 3.0±0.2 1.2Max. 2.5±0.2 0.75±0.2 1.50±0.2 1.5 0.8 2.7 Page 1 of 3 www. sunltech.com SLW3012S Series ◆ Specification Inductance Part Number @100KHz, 1V (µH) DC Resistance ±30% (Ω) DCR Frequency(MHz) Saturation Current(A) Heat Rating Current (A) S.R.F Isat Irms Min.Self-resonant SLW3012 Series SLW3012SR82NST 0.82±30% 0.027 180 2.47 2.84 SLW3012S1R0NST 1.0±30% 0.036 120 2.25 2.53 SLW3012S1R2NST 1.2±30% 0.040 120 2.68 2.31 SLW3012S1R5NST 1.5±30% 0.040 110 1.96 2.31 SLW3012S1R8NST 1.8±30% 0.049 90 1.83 2.12 SLW3012S2R2NST 2.2±30% 0.067 84 1.45 1.78 SLW3012S2R4NST 2.4±30% 0.061 100 1.39 1.73 SLW3012S2R7NST 2.7±30% 0.076 65 1.38 1.70 SLW3012S3R3MST 3.3±20% 0.089 64 1.27 1.56 SLW3012S4R7MST 4.7±20% 0.107 61 1.09 1.43 SLW3012S6R8MST 6.8±20% 0.169 61 0.91 1.13 SLW3012S100MST 10±20% 0.236 42 0.72 0.95 SLW3012S120MST 12±20% 0.307 32 0.58 0.84 SLW3012S150MST 15±20% 0.320 27 0.54 0.82 SLW3012S180MST 18±20% 0.485 25 0.52 0.67 SLW3012S220MST 22±20% 0.574 23 0.51 0.61 SLW3012S270MST 27±20% 0.685 21 0.48 0.56 SLW3012S330MST 33±20% 0.779 18 0.44 0.53 SLW3012S360MST 36±20% 0.846 18 0.41 0.51 SLW3012S390MST 39±20% 1.184 18 0.37 0.43 SLW3012S470MST 47±20% 1.228 14 0.32 0.41 SLW3012S560MST 56±20% 1.228 14 0.31 0.41 SLW3012S620MST 62±20% 1.362 12 0.30 0.40 SLW3012S680MST 68±20% 1.486 12 0.29 0.38 SLW3012S820MST 82±20% 2.261 12 0.26 0.31 SLW3012S101MST 100±20% 2.545 12 0.25 0.29 ◆ Note 1:All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△ T =40°C) from 20°C ambient. Rev.01 Page 2 of 3 www. sunltech.com SLW3012S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW3012 Series Rev.01 Page 3 of 3 www. sunltech.com
