SLO0520H1R0MTT
SLO0520H1R0MTT
    SUNLTECH(顺磁)
    IND_5.4X5.1MM_SM
    功率电感 1.0 μH ±20% IND_5.4X5.1MM_SM 2.00mm 5.40 x 5.10mm 15mΩ 5A
SLO0520H1R0MTT 数据手册
SLO0520H Series SMD Molding Power Inductor ◆ Features Pb 1、Magnetically shielded construction, low DC resistance; 2、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 ◆ Applications 1、Smart phone、MID; 2、Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras; 3、Flat-screen TVs, blue-ray disc recorders, set top box; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems; 7、Telecomm base stations。 ◆ Lead Free Part Numbering SLO 0520 (1) (2) H (3) 2R2 M (4) (5) T T (6) (7) (1) (2) (3) (4) Series Type Dimension:A X C Material Code Inductance:2R2=2.2μH; 100=10μH;101=100μH (5) Inductance Tolerance:M=±20%, Y=±30% (6) Company Code (7) Packaging:packed in embossed carrier tape ◆ Dimensions Series SLO0520H Rev.01 A±0.2(mm) 5.4 B±0.2 (mm) 5.1 Page 1 of 4 C (mm) 2.0 Max D±0.1 (mm) 2.0 E±0.1 (mm) 1.0 www.sunltech.com SLO0520H Series ◆ Specification Ω Rdc (m ) Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) μ Typ. Max SLO0520HR68MTT 0.68 15 20 100KHz/1V 5.0 10.0 SLO0520H1R0MTT 1.0 15 21 100KHz/1V 5.0 8.0 SLO0520H1R2MTT 1.2 17 27 100KHz/1V 5.0 8.0 SLO0520H1R5MTT 1.5 20 26 100KHz/1V 4.0 6.0 SLO0520H2R2MTT 2.2 32 42 100KHz/1V 3.5 6.0 SLO0520H3R3MTT 3.3 44 58 100KHz/1V 3.5 5.5 SLO0520H4R7MTT 4.7 68 90 100KHz/1V 3.2 4.5 SLO0520H5R6MTT 5.6 75 97 100KHz/1V 3.0 4.0 SLO0520H6R8MTT 6.8 105 130 100KHz/1V 2.5 3.0 SLO0520H100MTT 10 170 221 100KHz/1V 2.0 3.0 △ ℃ Part Number INDUCTANCE Lo( H) SLO0520H Series NOTES: 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -55 to +150 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ℃ Rev.01 ℃ ℃ Page 2 of 4 ℃ www.sunltech.com SLO0520H Series ◆ Wave Soldering ◆ Hand soldering Rev.01 Page 3 of 4 www.sunltech.com SLO0520H Series ◆ Reliability Mechanical ℃ ~+125℃ -45℃ ~ + 1 2 5 ℃ -55 Rev.01 Page 4 of 4 www.sunltech.com
SLO0520H1R0MTT 价格&库存
很抱歉,暂时无法提供与“SLO0520H1R0MTT”相匹配的价格&库存,您可以联系我们找货
