CUSTOMER:
DATE:
APPROVAL SPECIFICATION
PRODUCT NAME: SMD power inductor
CUSTOMER PART NO.:
OUR PART NO.: MPIT252012 Series
RECEPTION
THE SPECIFICATION HAS BEEN ACCEPTED.
DATE:
COMPANY:
CFMD
CHKD
RCVD
MANUFACTURING NAME
深圳市麦捷微电子科技股份有限公司
SHENZHEN MICROGATE TECHNOLOGY CO.,LTD
Address: Yuxing road, Golf Street, Guanlan Town
Bao’an District Shenzhen P.R.C
Postcode :518110
TEL:86-755-28085000
FAX:86-755-28085605
CFMD.
CHKD.
DSGD.
目录 CATALOG
规格书版本控制 Component SPEC Version Record……………………………….. .. ..
2
1
适用范围 Scope.
. 3
2
品名构成 Product Identification.
. 3
3
形状、
. 3
形状、尺寸和材料 Appearance, Dimensions and Material.
4
测试条件 Testing Conditions.
3
5
电气特性 Electrical Characteristics.
4
6
工作条件 Condition of work.
. 4
7
信赖性试验 Reliable Performance.
8
焊接条件 Recommended Soldering Conditions.
. 7-8
9
包装 Packaging.
. 8-9
5-6
10 产品外观检查标准 Visual inspection standard of product.
. 10
11 存贮条件 Products Storage.
. 10
深圳市麦捷微电子科技股份有限公司
地址:深圳市宝安区观澜镇高尔夫大道裕新路
电话(Tel):0755-28085000
传真(Fax):0755-28085605
邮编(Postcode):518110
Rev.
Effective Date
Changed Contents
Change Reasons
Approved By
01
Dec. 10.2012
New released
Charles
2
SHENZHEN MICROGATE TECHNOLOGY CO.,LTD.
Add:Yuxing Road,Golf Street,Guanlan Town,Bao’an District,Shenzhen
Tel:+86-755-28085000
Fax:+86-755-28085605
Postcode:518110
1. Scope
This specification applies to the MPIT252012 series of SMD power inductor.
2. Product Identification
MPIT
252012 –
4R7
①
②
③
M - LF
④
⑤
Product Symbol (T type SMD power inductor)
Product dimensions (2.5×2.0×1.2mm)
Inductance Value: (4R7: 4.7uH 100: 10uH; 101: 100uH)
Induc tance Tolerance:(M: ±20% ; N: ±30%)
Lead free product.
3. Appearance, Dimensions and Material
3.1 Appearance and dimensions
Recommended Land Pattern
Model
MPIT252012
A
2.50±0.20
B
2.00±0.20
Dimensions in mm
C
D
E
1.20Max. 0.80±0.20 0.80±0.20
f
0.80 Typ.
g
2.50Typ.
h
2.00Typ.
3.2 Material List
No.
1
2
3
4
Item
Ferrite Core
Wire
Terminal Electrode
Magnetic Glue
Material
Ni-Zn Ferrite
Enameled Copper Wire
Ag/Ni/Sn/Cu
Epoxy resin and magnetic powder
4.Testing Conditions
Unless otherwise specified
Temperature : Ordinary Temperature
( 5 to 35℃)
Humidity : Ordinary Humidity
(25 to 85% RH)
Atmospheric Pressure : 86 to 106 kPa
In case of doubt
Temperature : 20±2℃
Humidity : 60 to 75% RH
3
Postcode:518110
5. Electrical Characteristics And Test Instruments
Microgate Part No.
Customer Part
No.
Inductance
(uH)
Isat
(A)
DCR
(Ω)
1
Irms
(A)
2
Max.
Typ.
Max.
Typ.
Max.
Typ.
SRF
(MHz)
MPIT252012-R47N-LF
0.47±30%
0.055
0.042
3.82
4.03
2.55
3.00
161
MPIT252012-R68N-LF
0.68±30%
0.068
0.057
3.28
3.43
2.25
2.70
140
MPIT252012-1R0N-LF
1.0±30%
0.083
0.069
2.59
2.65
2.00
2.60
110
MPIT252012-1R2N-LF
1.2±30%
0.119
0.099
2.38
2.68
1.65
2.10
99
MPIT252012-1R5M-LF
1.5±20%
0.135
0.110
2.24
2.51
1.50
2.02
96
MPIT252012-2R2M-LF
2.2±20%
0.198
0.165
1.85
2.05
1.20
1.64
69
MPIT252012-2R7M-LF
2.7±20%
0.220
0.180
1.72
1.90
1.15
1.45
63
MPIT252012-3R3M-LF
3.3±20%
0.240
0.200
1.61
1.80
1.10
1.40
61
MPIT252012-4R7M-LF
4.7±20%
0.348
0.290
1.15
1.35
0.90
1.17
47
MPIT252012-5R6M-LF
5.6±20%
0.490
0.405
1.15
1.26
0.78
1.04
38
MPIT252012-6R2M-LF
6.2±20%
0.500
0.415
1.03
1.16
0.78
0.95
38
MPIT252012-6R8M-LF
6.8±20%
0.535
0.445
0.98
1.10
0.73
0.85
37
MPIT252012-8R2M-LF
8.2±20%
0.605
0.505
0.98
1.10
0.70
0.80
36
MPIT252012-100M-LF
10±20%
0.640
0.535
0.79
0.84
0.65
0.77
34
MPIT252012-120M-LF
12±20%
0.990
0.825
0.78
0.88
0.51
0.55
28
MPIT252012-150M-LF
15±20%
1.465
1.220
0.68
0.76
0.45
0.50
25
MPIT252012-220M-LF
22±20%
1.820
1.520
0.53
0.55
0.40
0.45
Test instruments and remarks
* CHROMA 3302 meter for L adn DCR/CHROMA 3302 and 1320 meter for IDC.
* L test condition: 100KHz&1V at 20℃ambient;
* Rated current:Isat or Irms,whichever is smaller:
1
:Isat: direct current at which the inductance drops approximate 30% from its value without current;
2
:Irms: direct current when the temperature of the product rise (△T =40°C) from 20°C ambient.
6. Condition of work
1. The part normal work be allowed ambient temperature: -25℃ ~ +85℃.
2 .The part must be allowed high temperature: +125℃.
3. The part normal work be allowed temperature dependent: 40℃
4. Ambient temperature of the part is allowed storage temperature: -25℃ ~ +85℃.
5. Storage life: half a year
6 .The part be allowed work ambient frequency: 0.1MHz ~ 1MHz
4
Postcode:518110
7. Reliability and Test Condition
Item
Required Characteristics
Test Method/Condition
Temperature: 125±2℃
Time : 1000 hours
Tested not less than 1 hours, nor more than 2 hours
at room temperature.
High temperature
resistance
125℃
1000H
Temperature : -40±2℃
Time : 1000 hours
Tested not less than 1 hour, nor more than 2 hours at room
temperature.
Low temperature
resistance t
1. No case deformation or change in
appearance.
2. |∆L|/L≤10%
1000H
-40℃
1.
2.
3.
Exposure : Temperature:60±2℃, Humidity : 93±3%
RH Time : 1000 hours.
Tested while the specimens are still in the chamber.
room temperature.
Humidity test
1000H
First -40℃ for T time, last 125℃ T time as 1 cycle. Go
through 100 cycles.
1.
Thermal
test
shock
2.
in appearance.
|∆L|/L≤10%
30 min.
30 min.
125
Ambient
Temperature
-40℃
30 min.
20sec. (max.)
5
Postcode:518110
Item
Solderability test
Terminal area must have 90% min.
solder coverage.
Dip pads in flux then dip in solder pot at 245±5℃ for
0.1mm. NG.
AQL=0.65
l
L
l >L/6 or w >W/6, NG.
H
11.Products Storage
⑴ Storage period
Products which inspected in MICROGATE over 6 months ago should be examined and used, which
can be confirmed with inspection No. marked on the container. Solderability should be checked if this
period is exceeded.
⑵ Storage conditions
Products should be storage in the warehouse on the following conditions:
Temperature: -10 ~+ 40℃
Humidity
: Less than 80% relative and humidity
No rapid change on temperature and humidity
⑶ Don’t keep products in corrosive gases such as sulfur, chlorine gas or acid, or it may cause oxidization of
electrode, resulting in poor solderability.
⑷ Products should be storage on the palette for the prevention of the influence from humidity, dust and so on.
⑸ Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
⑹ Products should be storage under the airtight packaged condition.
10
Postcode:518110
很抱歉,暂时无法提供与“MPIT252012-4R7M-LF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26683
- 100+0.21094
- 300+0.18300
- 2000+0.16205
- 4000+0.14522
- 10000+0.13685
- 国内价格
- 10+0.18426
- 100+0.16761
- 500+0.15096
- 1000+0.13431
- 2000+0.12321
- 4000+0.11988
