SLW5040S101MST
SLW5040S101MST
    SUNLTECH(顺磁)
    SMD,5x5mm
    功率电感 100µH ±20% IND_5X5MM_SM 4.00mm 5.00 x 5.00mm 728mΩ 750mA 4MHz
SLW5040S101MST 数据手册
SLW5040S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW (1) (1) (2) (3) (4) 5040 (2) S (3) 100 M (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10μH;101=100μH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. SLW5040S 5.0±0.2 5.0±0.2 4.0Max. 4.0±0.2 1.25±0.2 2.50±0.2 2.1 1.5 4.4 Rev.01 Page 1 of 3 www. sunltech.com SLW5040S Series ◆ Electrical Characteristics ℃ ℃ 1) Operating temperature range(Including self-heating):-40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ℃ ℃ ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 3 www. sunltech.com SLW5040S Series ◆ Specification Inductance Part Number @100KHz,1V (μH) Frequency(MHz) Saturation Current(A) Heat Rating Current (A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant SLW5040 Series SLW5040S1R0MST 1.0±20% 0.012 117 7.35 4.90 SLW5040S1R5MST 1.5±20% 0.013 86 7.30 4.45 SLW5040S2R2MST 2.2±20% 0.017 42 6.50 3.95 SLW5040S3R3MST 3.3±20% 0.025 32 5.10 3.40 SLW5040S4R7MST 4.7±20% 0.029 28 4.40 3.10 SLW5040S6R8MST 6.8±20% 0.043 21 3.80 2.40 SLW5040S100MST 10±20% 0.055 18 2.90 2.10 SLW5040S150MST 15±20% 0.089 13 2.30 1.60 SLW5040S220MST 22±20% 0.126 9 1.90 1.40 SLW5040S330MST 33±20% 0.192 7 1.60 1.20 SLW5040S470MST 47±20% 0.283 6 1.30 0.94 SLW5040S680MST 68±20% 0.520 5 1.10 0.90 SLW5040S101MST 100±20% 0.728 4 0.80 0.75 SLW5040S151MST 150±20% 0.915 2 0.60 0.50 ◆ Note :All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△ T =40°C) from 20°C ambient. 1 ◆ Standard Packing Quantity: :1500 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW5040S Series Rev.01 Page 3 of 3 www. sunltech.com
