PLCC LED Series Datasheet
ORH-G36G(IF=5mA)
1. Features:
Emitted Color : AlInGaN.
Lens Appearance :Green.
Mono-color type.
1.6x0.8x0.4mm(0603) standard package.
Suitable for all SMT assembly methods.
Compatible with infrared and vapor phase reflow solder process.
Compatible with automatic placement equipment.
This product doesn’t contain restriction substance, comply ROHS standard.
2.Applications:
Automotive : Dashboards, stop lamps, turn signals.
Backlighting : LCDs, Key pads advertising.
Status indicators : Comsumer & industrial electronics.
General use.
Ver, A0
SHENZHEN ORIENT ELECTRONICS CO. ,LTD.
ORH-G36G
3. Package Dimensions:
NOTES:
1).All dimensions are in millimeters (inches).
2).Tolerance is ± 0.10mm (0.004”) unless otherwise specified.
3).Specifications are subject to change without notice.
4.Absolute Maximum Ratings(Ta=25℃)
Parameter
Symbol
Rating
Unit
Power Dissipation
Pd
120
mW
Forward Current
IF
30
mA
Peak Forward Current *1
IFP
100
mA
Reverse Volage
VR
5
V
Operating Temperature
Topr
-25℃~80℃
Storage Temperature
Tstg
-30℃~85℃
Soldering Temperature
Tsol
260℃
*1 Condition for IFp is pulse of 1/10 duty and 0.1msec width.
5. Electrical and optical characteristics(Ta=25℃)
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
Vf
IF=5mA
2.6
3.2
V
Luminous Intensity
Iv
IF=5mA
140
210
315
mcd
Reverse Current
IR
VR=5V
1
μA
Peak Wave Length
λp
IF=5mA
520
nm
Dominant Wave Length
λd
IF=5mA
515
520
525
nm
Spectral Line Half-width
Δλ
IF=5mA
30
nm
Veiwing Angle
2θ1/2
IF=5mA
120
deg
Copyright© 2018 Orient Tech Corporation.
All rights Reserved
2
Ver,
A0
ORH-G36G
6.Typical Electro-Optical Characteristics Curves
Fig.2 Forward current derating curve
Fig.1 Relative intensity vs. wavelength
vs. ambient temperature
1.0
60
Forward current (mA)
Relative radiant intensity
50
0.5
40
30
525
Wavelength (nm)
50
80
100
3.0
2.5
Relative Luminous intensity
(Normalized @20mA)
40
30
2.0
1.5
1.0
0.5
2
3
4
5
-20
60
Ambient temperature Ta( C)
Forward voltage(V)
Fig.5 Relative luminous intensity
vs. forward current
Fig.6 Radiation diagram
10
1.5
Relative luminous intensity (@20mA)
60
Fig.4 Relative luminous intensity vs.
ambient temperature
Fig.3 Forward current vs. forward voltage
40
1.0
0.5
1.0
40
0.9
50
0.8
60
70
0.7
80
90
40
50
0.5
0.3
0.1
0.2
0.4
0.6
All rights Reserved
3
Ver,
A0
ORH-G36G
7. Judgment criteria of failure for the reliability
Measuring items
Forward voltage
Reverse current
Luminous intensity
Symbol
VF ( V)
IR(uA)
Iv ( mcd )
Measuring conditions
IF=20mA
VR=5V
IF=20mA
Judgement criteria for failure
Over Ux1.2
Over Ux2
Below SX0.5
Note: 1).U means the upper limit of specified characteristics. S means initial value.
2).Measurment shall be taken between 2 hours and after the test pieces have been returned to
normal ambient conditions after completion of each test.
8.Bin Limits
In t e n s i t y Bi n Li m i t s (A t 5m A )
BI N CO D E
Mi n . (m c d )
Ma x . (m c d )
R
140
21 0
S
210
31 5
To l e r a n c e for ea c h Bi n li m i t is ± 15 %.
Co l o r Bi n Li m i t s (A t 5m A )
BI N CO D E
Mi n . (n m )
Ma x . (n m )
4
510
515
5
515
520
6
520
525
To l e r a n c e for ea c h Bi n li m i t is ± 1 nm
V F Bi n Li m i t s (A t 5m A )
BI N CO D E
Mi n . ( v )
Ma x . ( v )
F
2.6
2.8
G
2.8
3.0
H
3.0
3.2
To l e r a n c e for ea c h Bi n li m i t is ± 0. 0 5 V.
9. BI N : x
x
x
VF BIN CO DE
Co lor BIN CODE
Intensity BIN CODE
All rights Reserved
4
Ver,
A0
ORH-G36G
10.Tapping and packaging specifications(Units: mm)
13.0∮0.5
0.5 ∮ 0.05
0.9 ∮ 0.05
4.0∮0.1
8.0∮0.3
3.5∮0.05
1.5! O0.1
1.75∮0.1
CATHODE
4.0∮0.1
TRAILER
179∮1
13.0∮0.5
71.0∮1
END
5.3∮0.05
START
1.75∮ 0.05
ANODE
USER DIRECTION OF FEED
LEADER
0.3
2.0! O0.05
FIXING TAPE
NOTE: 3000 pcs PER REEL
11.Package Method:(unit: mm)Vacuum
All rights Reserved
5
Ver,
A0
ORH-G36G
12.Package and Label of Products:
(1) Package: Products are packed in one bag of 3000 pcs (one taping reel) and a label is attached on
each bag.
(2) Label:
ORIENT LOGO
Part No.
Quantity
BIN
Sealing Date
x
xx
xx
xx
Year Month Day
All rights Reserved
6
Ver,
A0
ORH-G36G
13.Reliability Test
Classification
Test Item
Operation Life
Reference Standard
MIL-STD-750:1026
Connect with a power If=20mA
MIL-STD-883:1005
Ta=Under room temperature
JIS-C-7021
Test time=1,000hrs
:B-1
Endurance
Test
Storage
High Temperature
Storage
JIS-C-7021
:B-11
JIS-C-7021
:B-10
JIS-C-7021
Temperature
MIL-STD-202:107D
:B-12
MIL-STD-750:1051
JIS-C-7021
MIL-STD-202:107D
0/20
-35℃ ~ +25℃ ~ +85℃ ~ +25℃
60min 20min
60min
20min
0/20
-35℃±5℃ ~+85℃±5℃
20min
20min
0/20
Test Time=10cycle
Preheating:
MIL-STD-202:201A
140℃-160℃,within 2 minutes.
MIL-STD-750:2031
JIS-C-7021
Test time=1,000hrs
:A-4
MIL-STD-883:1011
Solder Resistance
0/20
Test Time=5cycle
MIL-STD-750:1051
Test
Test time=1,000hrs
Low Ta=-35℃±5℃
Storage
Thermal Shock
0/20
Test time=240hrs
High Ta=+85℃±5℃
MIL-STD-883:1008
MIL-STD-883:1010
Environmental
0/20
RH=90%-95%
MIL-STD-202:103B
Low Temperature
Cycling
Result
Ta=+65℃±5℃
High Temperature
High Humidity
Test Conditions
0/20
Operation heating:
:A-1
260℃(Max.), within 10seconds. (Max.)
14. Soldering :
1). Manual Of Soldering
The temperature of the iron tip should not be higher than 300 ℃ (572 ℉ ) and Soldering within 3
seconds per solder-land is to be observed.
2). Reflow Soldering
Preheating : 140℃~160℃±5℃,within 2 minutes.
Operation heating : 260℃(Max.) within 10 seconds.(Max)
Gradual Cooling (Avoid quenching).
All rights Reserved
7
Ver,
A0
ORH-G36G
10 SEC. MAX.
Temperature
140~160℃
260℃ MAX.
4℃ /SEC. MAX.
4℃ /SEC. MAX.
OVER 2 MIN.
Time
3). DIP soldering (Wave Soldering) :
Preheating : 120℃~150℃,within 120~180 sec.
Operation heating : 245℃±5℃ within 5 sec.260℃ (Max)
Temperature
Soldering heat Max. 260 ℃
245 ±5℃ within 5 sec.
120~150℃
Preheat
120~180 sec.
Time
15.Handling :
Care must be taken not to cause to the epoxy resin portion of BRIGHT LEDs while it is exposed to
high temperature.
Care must be taken not rub the epoxy resin portion of BRIGHT LEDs with hard or sharp article such
as the sand blast and the metal hook.
16. Notes for designing:
Care must be taken to provide the current limiting resistor in the circuit so as to drive the BRIGHT
LEDs within the rated figures. Also, caution should be taken not to overload BRIGHT LEDs with
instantaneous voltage at the turning ON and OFF of the circuit.
When using the pulse drive care must be taken to keep the average current within the rated figures.
Also, the circuit should be designed so as be subjected to reverse voltage when turning off the
BRIGHT LEDs.
All rights Reserved
8
Ver,
A0
ORH-G36G
17. Storage:
In order to avoid the absorption of moisture, it is recommended to solder BRIGHT LEDs as soon as
possible after unpacking the sealed envelope.
If the envelope is still packed, to store it in the environment as following:
(1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max.
(2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or
equivalent soldering process must be:
a....Completed within 24 hours.
b....Stored at less than 30% RH.
(3) Devices require baking before mounting, if:
(2) a or (2) b is not met.
(4) If baking is required, devices must be baked under below conditions:
12 hours at 60℃±3℃.
All rights Reserved
9
Ver,
A0
很抱歉,暂时无法提供与“ORH-G36G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06748
- 150+0.05756
- 1000+0.04764
- 5000+0.04367
