ORH-G36A
ORH-G36A
    ORIENT(奥伦德)
    发光二极管/LED 翠绿色 0603 518nm~527nm 800mcd~1100mcd 正贴
ORH-G36A 数据手册
PLCC LED Series Datasheet ORH-G36A(IF=20mA) 1. Features:         Emitted Color : AlInGaN. Lens Appearance :Green. Mono-color type. 1.6x0.8x0.6mm(0603) standard package. Suitable for all SMT assembly methods. Compatible with infrared and vapor phase reflow solder process. Compatible with automatic placement equipment. This product doesn’t contain restriction substance, comply ROHS standard. 2.Applications:     Automotive : Dashboards, stop lamps, turn signals. Backlighting : LCDs, Key pads advertising. Status indicators : Comsumer & industrial electronics. General use. Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 3. Package Dimensions: NOTES: 1).All dimensions are in millimeters (inches). 2).Tolerance is ± 0.10mm (0.004”) unless otherwise specified. 3).Specifications are subject to change without notice. 4.Absolute Maximum Ratings(Ta=25℃) Parameter Symbol Rating Unit Power Dissipation Pd 120 mW Forward Current IF 30 mA Peak Forward Current *1 IFP 100 mA Reverse Volage VR 5 V Operating Temperature Topr -25℃~80℃ - Storage Temperature Tstg -30℃~85℃ - Soldering Temperature Tsol 260℃ - *1 Condition for IFp is pulse of 1/10 duty and 0.1msec width. 5. Electrical and optical characteristics(Ta=25℃) Parameter Symbol Condition Min. Typ. Max. Unit Forward Voltage Vf IF=20mA 2.8 - 3.1 V Luminous Intensity Iv IF=20mA 800 - 1100 mcd Peak Wave Length λp IF=20mA - 522 - nm Dominant Wave Length λd IF=20mA 518 - 527 nm Spectral Line Half-width Δλ IF=20mA - 30 - nm Veiwing Angle 2θ1/2 IF=20mA - 120 - deg Copyright© 2018 Orient Tech Corporation. All rights Reserved 2 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 6.Typical Electro-Optical Characteristics Curves Copyright© 2018 Orient Tech Corporation. All rights Reserved 3 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 7. Judgment criteria of failure for the reliability Measuring items Forward voltage Reverse current Luminous intensity Symbol VF ( V) IR(uA) Iv ( mcd ) Measuring conditions IF=20mA VR=5V IF=20mA Judgement criteria for failure Over Ux1.2 Over Ux2 Below SX0.5 Note: 1).U means the upper limit of specified characteristics. S means initial value. 2).Measurment shall be taken between 2 hours and after the test pieces have been returned to normal ambient conditions after completion of each test. 8.Bin Limits In t e n s i t y Bi n Li m i t s (A t 20 mA ) BI N CO D E Mi n . (m c d ) Ma x . (m c d ) Q 800 90 0 W 900 1000 E 1000 11 0 0 To l e r a n c e for ea c h Bi n li m i t is ± 15 %. Co l o r Bi n Li m i t s (A t 20 mA ) BI N CO D E Mi n . (n m ) Ma x . (n m ) 1 518 521 2 521 524 3 524 527 To l e r a n c e for ea c h Bi n li m i t is ± 1 nm V F Bi n Li m i t s (A t 20 mA ) BI N CO D E Mi n . ( v ) Ma x . ( v ) S 2.8 2.9 D 2.9 3.0 F 3.0 3.1 To l e r a n c e for ea c h Bi n li m i t is ± 0. 0 5 V. 9. BI N : x x x VF BIN CO DE Co lor BIN CODE Intensity BIN CODE Copyright© 2018 Orient Tech Corporation. All rights Reserved 4 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 10.Tapping and packaging specifications(Units: mm) 13.0∮0.5 0.5 ∮ 0.05 0.9 ∮ 0.05 4.0∮0.1 8.0∮0.3 3.5∮0.05 1.5! O0.1 1.75∮0.1 CATHODE 4.0∮0.1 TRAILER 179∮1 13.0∮0.5 71.0∮1 END 5.3∮0.05 START 1.75∮ 0.05 ANODE USER DIRECTION OF FEED LEADER 0.3 2.0! O0.05 FIXING TAPE NOTE: 3000 pcs PER REEL 11.Package Method:(unit: mm)Vacuum Copyright© 2018 Orient Tech Corporation. All rights Reserved 5 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 12.Package and Label of Products: (1) Package: Products are packed in one bag of 4000 pcs (one taping reel) and a label is attached on each bag. (2) Label: ORIENT LOGO Part No. Quantity BIN Sealing Date x xx xx xx Year Month Day Manufacture Location Copyright© 2018 Orient Tech Corporation. All rights Reserved 6 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 13.Reliability Test Classification Test Item Operation Life Reference Standard MIL-STD-750:1026 Connect with a power If=20mA MIL-STD-883:1005 Ta=Under room temperature JIS-C-7021 Test time=1,000hrs :B-1 Endurance Test Storage High Temperature Storage JIS-C-7021 :B-11 JIS-C-7021 :B-10 JIS-C-7021 Temperature MIL-STD-202:107D :B-12 MIL-STD-750:1051 JIS-C-7021 MIL-STD-202:107D 0/20 -35℃ ~ +25℃ ~ +85℃ ~ +25℃ 60min 20min 60min 20min 0/20 -35℃±5℃ ~+85℃±5℃ 20min 20min 0/20 Test Time=10cycle Preheating: MIL-STD-202:201A 140℃-160℃,within 2 minutes. MIL-STD-750:2031 JIS-C-7021 Test time=1,000hrs :A-4 MIL-STD-883:1011 Solder Resistance 0/20 Test Time=5cycle MIL-STD-750:1051 Test Test time=1,000hrs Low Ta=-35℃±5℃ Storage Thermal Shock 0/20 Test time=240hrs High Ta=+85℃±5℃ MIL-STD-883:1008 MIL-STD-883:1010 Environmental 0/20 RH=90%-95% MIL-STD-202:103B Low Temperature Cycling Result Ta=+65℃±5℃ High Temperature High Humidity Test Conditions 0/20 Operation heating: :A-1 260℃(Max.), within 10seconds. (Max.) 14. Soldering : 1). Manual Of Soldering The temperature of the iron tip should not be higher than 300 ℃ (572 ℉ ) and Soldering within 3 seconds per solder-land is to be observed. 2). Reflow Soldering Preheating : 140℃~160℃±5℃,within 2 minutes. Operation heating : 260℃(Max.) within 10 seconds.(Max) Gradual Cooling (Avoid quenching). Copyright© 2018 Orient Tech Corporation. All rights Reserved 7 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 10 SEC. MAX. Temperature 140~160℃ 260℃ MAX. 4℃ /SEC. MAX. 4℃ /SEC. MAX. OVER 2 MIN. Time 3). DIP soldering (Wave Soldering) : Preheating : 120℃~150℃,within 120~180 sec. Operation heating : 245℃±5℃ within 5 sec.260℃ (Max) Gradual Cooling (Avoid quenching). Temperature Soldering heat Max. 260 ℃ 245 ±5℃ within 5 sec. 120~150℃ Preheat 120~180 sec. Time 15.Handling : Care must be taken not to cause to the epoxy resin portion of BRIGHT LEDs while it is exposed to high temperature. Care must be taken not rub the epoxy resin portion of BRIGHT LEDs with hard or sharp article such as the sand blast and the metal hook. 16. Notes for designing: Care must be taken to provide the current limiting resistor in the circuit so as to drive the BRIGHT LEDs within the rated figures. Also, caution should be taken not to overload BRIGHT LEDs with instantaneous voltage at the turning ON and OFF of the circuit. When using the pulse drive care must be taken to keep the average current within the rated figures. Also, the circuit should be designed so as be subjected to reverse voltage when turning off the BRIGHT LEDs. Copyright© 2018 Orient Tech Corporation. All rights Reserved 8 Ver, A0 SHENZHEN ORIENT ELECTRONICS CO. ,LTD. ORH-G36A 17. Storage: In order to avoid the absorption of moisture, it is recommended to solder BRIGHT LEDs as soon as possible after unpacking the sealed envelope. If the envelope is still packed, to store it in the environment as following: (1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max. (2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or equivalent soldering process must be: a....Completed within 24 hours. b....Stored at less than 30% RH. (3) Devices require baking before mounting, if: (2) a or (2) b is not met. (4) If baking is required, devices must be baked under below conditions: 12 hours at 60℃±3℃. Copyright© 2018 Orient Tech Corporation. All rights Reserved 9 Ver, A0
ORH-G36A
物料型号: ORH-G36A
器件简介: - 发光颜色: AlInGaN - 透镜外观: 绿色 - 单色类型 - 标准封装尺寸: 1.6x0.8x0.6mm (0603) - 适用于所有SMT组装方法 - 兼容红外和蒸汽相再流焊工艺 - 兼容自动贴装设备 - 产品不含限制物质,符合ROHS标准
引脚分配: 未在文档中明确列出
参数特性: - 功率耗散: Pd = 120 mW - 正向电流: IF = 30 mA - 峰值正向电流: IFP = 100 mA - 反向电压: VR = 5 V - 工作温度范围: -25°C~80°C - 存储温度范围: -30°C~85°C - 焊接温度: Tsol = 260°C
功能详解: - 应用领域包括汽车仪表盘、刹车灯、转向灯、LCD背光、键盘广告、状态指示器、消费和工业电子产品等。
封装信息: - 封装类型: 0603标准封装 - 封装尺寸: 长度9.6mm,宽度0.8mm,高度0.7mm - 公差: ±0.10mm - 标记: 阴极标记
电气和光学特性 (在25℃下): - 正向电压: Vf = 2.8V至3.1V - 发光强度: Iv = 800mcd至1100mcd - 峰值波长: λp = 522nm - 主波长: λd = 518nm至527nm - 光谱线半宽: Δλ = 30nm - 视角: 120°
可靠性测试: - 包括操作寿命、高温高湿存储、高温存储、低温存储、温度循环、热冲击、焊接耐性等测试
焊接说明: - 手动焊接: 烙铁尖端温度不超过300℃,每个焊点焊接时间不超过3秒 - 回流焊接: 预热140℃~160℃,持续2分钟;操作加热260℃(最大),持续10秒;逐渐冷却(避免淬火) - 波峰焊接(DIP焊接): 预热120℃~150℃,持续120~180秒;操作加热245℃±5℃,持续5秒;260℃(最大)
使用注意事项: - 在高温下避免对环氧树脂部分造成损伤 - 避免使用硬物或尖锐物品如砂轮和金属钩刮擦环氧树脂部分
设计注意事项: - 在电路中提供限流电阻以确保LED在额定参数下工作 - 注意避免在电路的开启和关闭时瞬时电压超过LED的承受能力 - 使用脉冲驱动时,确保平均电流在额定参数内,并设计电路以承受关闭LED时的反向电压
存储: - 避免吸湿,建议在打开密封包装后尽快焊接LED - 如果包装仍然密封,存储环境应为温度5℃-30℃,湿度最大60%RH - 如果需要红外再流、蒸汽相再流或等效焊接工艺,必须在24小时内完成 - 如果需要烘烤,设备必须在60℃±3℃下烘烤12小时
ORH-G36A 价格&库存
很抱歉,暂时无法提供与“ORH-G36A”相匹配的价格&库存,您可以联系我们找货
ORH-G36A
    • 50+0.08230
    • 500+0.06362
    • 1500+0.05325
    • 4000+0.04979
    • 24000+0.04439
    • 48000+0.04148
    库存:5056
    ORH-G36A
      • 1+0.20130
      • 200+0.06710
      • 2000+0.04202
      • 4000+0.03333
      库存:5612
      ORH-G36A
      • 50+0.07544
      • 800+0.05831
      • 1600+0.04881
      • 4000+0.04564
      库存:5876
      ORH-G36A
        库存:35
        ORH-G36A
          • 1+0.05630
          库存:35
          ORH-G36A
            • 1+0.061901+0.00810
            库存:35
