VC0201
VC0201
    VIMICRO(中星微)
    105-LGA
    一款 CMOS 传感器 105-LGA
VC0201 数据手册
VC0201 HD Starlight Sensor FEATURES APPLICATIONS  Best-in-class low-light performance   True single exposure wide dynamic range operation (25000:1) to avoid motion artifacts  Type 1/1.2-inch CMOS sensor  Support both Rolling Shutter mode and Global Shutter mode  High resolution imaging array: 1920(H) x 1080(V)  Up to 100 fps @1080P in Rolling Shutter mode and 50 fps in Global Shutter mode  Low noise: 1.2 e- RMS @ 30 fps in Rolling Shutter mode, 6.5 e- RMS @ 30 fps in Global Shutter mode  6.5μm by 6.5μm 5T active pixels  Peak quantum efficiency > 50% at 600nm  Protection against black-sun artifacts  Low power consumption ( 25000:1 < 3% RMS < 35 e-/pixel/sec < 65 e-/pixel/sec RMS < 2% RMS uncorrected High gain output − 1.7 at 30x − 0.55 at 10x Low gain output − 0.12 at 2x − 0.055 at 1x Notes at 75% of max output at 20ºC at 20ºC of the max output w/1.4V ADC input range (ADC input range is user programmable from 0.8V to 2V) (30x: 1.3DN/e- w/1.85V ADC default input range) Full well capacity (FWC) Lag Non-linearity Fill factor with microlens Microlens F-number Peak QE MTF Temporal read noise > 30,000 e< 0.1% < 1% > 0.9 1.5 > 0.50 > 0.4 < 1.2 e- RMS @ 50 fps Rolling Shutter readout, @T=30ºC Spectral sensitivity range 400 – 700nm of maximum output at 600nm at 600nm Median value of read noise distribution from high gain output (30x gain) See QE plots for spectral sensitivity in the Near IR out to 1100 nm Recommended Operating Condition Parameter AVDD AVDD_PIX Definition Analog circuits power supply (avg 90 mA, Peak at 170mA on 5% duty cycle) Pixel source follower power supply (10 mA avg) Min Nom Max Units 3.135 3.3 3.465 V 3.135 3.3 3.465 V 3.3 V AVDD_RST 1 Pixel reset power supply1 (1mA) 2.50 3.00 (RS) or 2.77 (GS) AVDD_RST 2 Pixel reset power supply2 (1mA) 2.50 3.0 3.3 V 1.71 1.8 1.89 V 1.71 1.8 1.89 V 3.135 3.3 3.465 V 3.135 3.3 3.465 V -1.5 -0.4 +0.3 V DVDD DVDD_IO VTX1_POS VTX2_POS VTX1_NEG Datasheet (V1.0) Digital circuits power supply (160mA) I/O circuits power supply (65 mA) (with no terminations on outputs) TX1 Transfer gate positive power supply (80 mA/ 1µsec pulse in GS, 50% from the mean 25 Low gain only 50 Low gain only 0 Low gain only Cold/Warm Pixels in Light Frame – Minor Defects Cold/Warm Pixels in Light Frame – Major Defects Small Cluster in Light Frame – Qty Allowed Large Cluster in Light Frame– Qty Allowed ± 6 sigma from the mean 2 < Size 20pix Column --Qty Allowed ± 10% gain variation from the mean 0 Row --Qty Allowed ± 10% gain variation from the mean 0 Comments Low gain only, Light frame – dark frame Low gain only, Light frame – dark frame Test conditions Blemish tests are performed in Rolling Shutter mode; light frame captured at 50% of saturation. Dark frame captured at 91 ms integration time. Defect measurements are performed on the full active pixel array Datasheet (V1.0) Copyright © Vimicro, Inc. 1999-2013 22
VC0201 价格&库存
很抱歉,暂时无法提供与“VC0201”相匹配的价格&库存,您可以联系我们找货
