HSDL-3208-S21
Ultra Small Profile Package
IrDA® Data Compliant Low Power
115.2 kbit/s Infrared Transceiver
Data Sheet
Description
Features
The HSDL-3208 is an ultra-small low cost infrared
transceiver module that provides the interface between logic and infrared (IR) signals for through air,
serial, half-duplex IR data link. The module is compliant to IrDA Physical Layer Specifications version
1.4 Low Power from 9.6 kbit/s to 115.2 kbit/s with
extended link distance and it is IEC 825-Class 1
eye safe.
• Fully compliant to IrDA 1.4 low power specification from
• Miniature package
– Height: 1.60 mm
– Width: 7.00 mm
– Depth: 2.8 mm
• Miniature package (with shield)
– Height: 1.80 mm
– Width: 7.4 mm
– Depth: 2.90 mm
• Guaranteed temperature performance, -25 to +70°C
– Critical parameters are guaranteed over temperature
and supply voltage
• Low power consumption
– Low shutdown current (1 nA typical)
– Complete shutdown of TXD, RXD, and PIN diode
• Withstands >100 mVp-p power supply ripple typically
• Excellent EMI performance without shield
• VCC supply 2.4 to 3.6 volts
• LED stuck-high protection
• Designed to accommodate light loss with cosmetic
windows
• IEC 825-class 1 eye safe
The HSDL-3208 can be shut down completely to
achieve very low power consumption. In the shutdown mode, the PIN diode will be inactive and thus
producing very little photocurrent even under very
bright ambient light. Such features are ideal for
battery operated handheld products.
VCC
CX2
CX1
VCC (6)
RECEIVER
SD (5)
GND (7)
RXD (4)
Applications
HSDL-3208
TXD (3)
LED C (2)
VCC
TRANSMITTER
R1
LED A (1)
Figure 1. Functional block diagram of HSDL-3208.
7
6
5
4
3
2
1
Figure 2. Rear view diagram with pinout.
• IRFM
• Mobile telecom
– Cellular phones
– Pagers
– Smart phones
• Data communication
– PDAs
– Portable printers
• Digital imaging
– Digital cameras
– Photo-imaging printers
Application Support
Information
technical understanding
associated with HSDL-3208
infrared transceiver module. You
can contact them through your
local Avago sales representatives
for additional details.
The Application Engineering
group in Avago Technologies is
available to assist you with the
Order Information
Part Number
Packaging Type
Package
Quantity
HSDL-3208-021
Tape and Reel
Front View
2500
HSDL-3208-S21
Tape and Reel
Front View
2500
Marketing Information
The unit is marked with yww on
the back of the PCB.
y=year
ww=work week
I/O Pins Configuration Table
Pin
Symbol
Description
I/O Type
Notes
1
LED A
LED Anode
Input
1
2
LED C
LED Cathode
3
TXD
Transmit Data
Input, Active High
3
4
RXD
Receive Data
Output, Active Low
4
5
SD/Mode
Shutdown
Input, Active High
5
6
VCC
Supply Voltage
Supply Voltage
6
7
GND
Ground
Ground
7
2
Notes:
1. This pin can be connected directly to VCC (i.e. without series resistor) at less than 3 V.
2. Internally connected to the LED driver.
3. This pin is used to transmit serial data when SD pin is low. Do not float the pin. This pin has an internal 500 kΩ pulldown with a typical input
capacitance of 2 pF.
4. This pin is capable of driving a standard CMOS or TTL load. No external pull-up or pull down resistor is required. It is in tri-state
mode when the transceiver is in shutdown mode. This pin tristates with a weak 500 kΩ pullup resistor.
5. The transceiver is in shutdown mode if this pin is high. Do not float the pin.
6. Regulated, 2.4 to 3.6 volts.
7. Connect to system ground.
Recommended Application Circuit Components
Component
Recommended Value
Notes
R1
30 Ω ± 5%, 0.25 Watt for 2.4
很抱歉,暂时无法提供与“HSDL-3208-S21”相匹配的价格&库存,您可以联系我们找货
