HSDL-3602
IrDA® Data 1.4 Compliant 4 Mb/s 3V Infrared Transceiver
Data Sheet
Description
Features
The HSDL-3602 is a low profile infrared transceiver module that provides interface between logic and IR signals
for through-air, serial, half-duplex IR data link. The module is compliant to IrDA Data Physical Layer Specifications 1.4 and IEC825-Class 1 Eye Safety Standard.
• Fully compliant to IrDA 1.1 specifications:
— 9.6 kb/s to 4 Mb/s operation
— Excellent nose-to-nose operation
• Typical link distance > 1.5 m
• IEC825-Class 1 eye safe
• Wide operating voltage range — 2.7 V to 3.6 V
• Small module size — 4.0 x 12.2 x 4.9 mm (H x W x D)
• Complete shutdown — TXD, RXD, PIN diode
• Low shutdown current — 10 nA typical
• Adjustable optical power management — Adjustable LED drive-current to maintain link integrity
• Single Rx data output — FIR select pin switch to FIR
• Integrated EMI shield — Excellent noise immunity
• Edge detection input — Prevents the LED from long
turn-on time
• Interface to various super I/O and controller devices
• Designed to accommodate light loss with cosmetic
window
• Only 2 external components are required
• Lead
freeand
package
Pb-free
EU RoHS compliant
The HSDL-3602 contains a high-speed and high-efficiency 870 nm LED, a silicon PIN diode, and an integrated circuit. The IC contains an LED driver and a receiver
providing a single output (RXD) for all data rates supported.
Applications
• Digital imaging
— Digital still cameras
— Photo-imaging printers
• Data communication
— Notebook computers
— Desktop PCs
— Win CE handheld products
— Personal Digital Assistants (PDAs)
— Printers
— Fax machines, photocopiers
— Screen projectors
— Auto PCs
— Dongles
— Set-top box
• Telecommunication products
— Cellular phones
— Pagers
• Small industrial and medical instrumentation
— General data collection devices
— Patient and pharmaceutical data collection
devices
• IR LANs
VCC
R1
LEDA (10)
TXD (9)
SP
MD0 (4)
HSDL-3602
MD1 (5)
RXD (8)
FIR_SEL (3)
CX1
GND (7)
CX2
VCC (1)
AGND (2)
HSDL-3602 Functional block diagram
The HSDL-3602 can be completely shut down to
achieve very low power consumption. In the shut down
mode, the PIN diode is inactive, thus producing very little photo-current even under very bright ambient light.
The HSDL-3602 also incorporates the capability for
adjustable optical power. With two programming pins;
MODE 0 and MODE 1, the optical power output can be
adjusted lower when the nominal desired link distance
is one-third or two-third of the full IrDA link.
Application Support Information
The Application Engineering group in Lite-On Technology is available to assist you with the Technical
understanding associated with HSDL-3602 infrared
transceiver module. You can contact them through your
local Lite-On Technologies' sales representatives for additional details.
The HSDL-3602 comes with a front view packaging
option (HSDL-3602-007/-037) and a top view packaging option (HSDL-3602-008/-038). It has an integrated
shield that helps to ensure low EMI emission and high
immunity to EMI field, thus enhancing reliable performance.
Ordering Information
Package Option
Package
Front View
Part Number
HSDL-3602-007
Standard Package Increment
400
HSDL-3602-037
1800
Front View
Top View
HSDL-3602-008
400
Top View
HSDL-3602-038
1800
I/O Pins Configuration Table
10
9
8
7
6
5
4
3
2
1
Back view
BACK
VIEW (HSDL-3602 #007/#017)
10
9
8
7
6
5
4
3
2
Bottom view (HSDL-3602-008/-038)
BOTTOM VIEW (HSDL-3602-008/-038)
1
Pin
1
2
3
4
5
6
7
8
9
10
Description
Supply Voltage
Analog Ground
FIR Select
Mode 0
Mode 1
No Connection
Ground
Receiver Data Output
Transmitter Data Output
LED Anode
Symbol
VCC
AGND
FIR_SEL
MD0
MD1
NC
GND
RXD
TXD
LEDA
Transceiver Control Truth Table
Mode 0
Mode 1
FIR_SEL
1
X
1
1
1
1
1
X = Don't Care
Transceiver I/O Truth Table
Transceiver Mode
FIR_SEL
Active
X
Active
Active
1
Active
X
Shutdown
X
RX Function
Shutdown
SIR
SIR
SIR
MIR/FIR
MIR/FIR
MIR/FIR
TX Function
Shutdown
Full Distance Power
2/3 Distance Power
1/3 Distance Power
Full Distance Power
2/3 Distance Power
1/3 Distance Power
Inputs
TXD
EI
1
X
High[1]
High[2]
Low
X[4]
Low
Outputs
LED
On
Off
Off
Off
Not Valid
RXD
Not Valid
Low[3]
Low[3]
High
Not Valid
X = Don't Care EI = In-Band Infrared Intensity at detector
Notes:
1. In-Band EI ≤ 115.2 kb/s and FIR_SEL = 0.
2. In-Band EI ≥ 0.576 Mb/s and FIR_SEL = 1.
3. Logic Low is a pulsed response. The condition is maintained for duration dependent on the pattern and strength of the incident intensity.
4. To maintain low shutdown current, TXD needs to be driven high or low and not left floating.
Recommended Application Circuit Components
Component
Recommended Value
R1
2.2 Ω ± 5%, 0.5 Watt, for 2.7 ≤ VCC ≤ 3.3 V operation
2.7 Ω ± 5%, 0.5 Watt, for 3.0 ≤ VCC ≤ 3.6 V operation
CX1[5]
0.47 µF ± 20%, X7R Ceramic
CX2[6]
6.8 µF ± 20%, Tantalum
Notes:
5. CX1 must be placed within 0.7 cm of the HSDL-3602 to obtain optimum noise immunity.
6. In "HSDL-3602 Functional Block Diagram" on page 1 it is assumed that Vled and VCC share the same supply voltage and filter capacitors. In case
the 2 pins are powered by different supplies CX2 is applicable for Vled and CX1 for VCC. In environments with noisy power supplies, including
CX2 on the VCC line can enhance supply rejection performance.
LEDA vs LEDA
LIGHT OUTPUT POWER (LOP) vs ILED
450
0.7
400
0.6
350
LOP (mW/sr)
ILED (A)
0.5
0.4
0.3
0.2
250
200
150
100
0.1
300
50
1.5
1.7
1.9
2.1
2.3
LEDA VOLTAGE (V)
0.2
0.3
0.4
0.5
0.6
0.7
ILED (A)
Marking Information
HSDL-3602 Graph 1
The HSDL-3602-007/-037 is marked ‘3602YYWW’ on
the shield where ‘YY’ indicates the unit’s manufacturing
year, and ‘WW’ refers to the work week in which the unit
is tested.
HSDL-3602 Graph 2
Absolute Maximum Ratings[7]
Parameter
Symbol
Minimum
Maximum
Unit
Storage Temperature
TS
–40
+100
˚C
Operating Temperature
TA
–20
+70
˚C
DC LED Current
ILED (DC)
165
mA
Peak LED Current
ILED (PK)
650
mA
750
mA
LED Anode Voltage
VLEDA
–0.5
7
V
Supply Voltage
VCC
V
Transmitter Data Input Current ITXD (DC)
–12
12
mA
Receiver Data Output Voltage
VO –0.5
VCC + 0.5
V
Conditions
≤ 90 µs pulse width,
≤ 25% duty cycle
≤ 2 µs pulse width,
≤ 10% duty cycle
|IO(RXD)| = 20 µA
Note:
7. For implementations where case to ambient thermal resistance ≤ 50˚C/W.
Caution: The BiCMOS inherent to the design of this component increases the component’s susceptibility to damage
from electrostatic discharge (ESD). It is advised that normal static precautions be taken in handling and assembly of
this component to prevent damage and/or degradation, which may be induced by ESD.
Recommended Operating Conditions
Parameter
Symbol
TA
Supply Voltage
VCC
Logic High Input Voltage
VIH
for TXD, MD0, MD1, and
FIR_SEL
Logic Low Transmitter
VIL
Input Voltage
LED (Logic High) Current
ILEDA
Pulse Amplitude
Receiver Signal Rate
Minimum
–20
2.7
2 VCC/3
Maximum
+70
3.6
VCC
Unit
˚C
V
V
VCC/3
V
400
650
mA
0.0024
4
Mb/s
Conditions
Electrical & Optical Specifications
Specifications hold over the Recommended Operating Conditions unless otherwise noted. Unspecified test conditions can be anywhere in their operating range. All typical values are at 25˚C and 3.3 V unless otherwise noted.
Parameter
Symbol
Min. Typ.
Max. Units
Conditions
Transceiver
Supply Current Shutdown
ICC1
10
200
nA
VSD ≥ VCC – 0.5
Idle
ICC2
2.5
5
mA
VI(TXD) ≤ VIL, EI = 0
Digital Input
Logic
IL/IH
–1
1
µA
0 ≤ VI ≤ VCC
Current
Low/High
Transmitter
Transmitter
Logic High
EIH
100
250
400
mW/sr VIH = 3.0 V
Radiant
Intensity
ILEDA = 400 mA
Intensity
θ1/2 ≤ 15˚
Peak
λp
875
nm
Wavelength
Spectral Line
∆λ1/2
35
nm
Half Width
Viewing Angle 2θ1/2
30
60 ˚
Optical
tpw (EI)
1.5
1.6
1.8
µs
tpw(TXD) = 1.6 µs at 115.2 kb/s
Pulse Width
148
217
260
ns
tpw(TXD) = 217 ns at 1.15 Mb/s
115
125
135
ns
tpw(TXD) = 125 ns at 4.0 Mb/s
Rise and
tr (EI),
40
ns
Fall Times
tf (EI)
tr/f(TXD) = 10 ns
Maximum
tpw (max)
µs
TXD pin stuck high
Optical
Pulse Width
LED Anode On State Voltage
VON(LEDA)
2.4
V
ILEDA = 400 mA, VI(TXD) ≥ VIH
LED Anode Off State Leakage
ILK(LEDA)
1
100
nA
VLEDA = VCC = 3.6 V,
Current
VI(TXD) ≤ VIL
Parameter
Symbol Min.
Typ.
Max.
Units
Conditions
Receiver
Receiver Data
Logic Low VOL
V
IOL = 1.0 mA,
Output Voltage
EI ≥ 3.6 µW/cm2,
θ1/2 ≤ 15˚
Logic High VOH
VCC – 0.2 —
VCC
V
IOH = –20 µA,
EI ≤ 0.3 µW/cm2,
θ1/2 ≤ 15˚
Viewing
2θ1/2
30
Angle
Logic High Receiver Input
EIH
0.0036
500
mW/cm2 For in-band signals
Irradiance
≤ 115.2 kb/s[8]
0.0090
500
mW/cm2 0.576 Mb/s ≤ in-band
signals ≤ 4 Mb/s[8]
2
Logic Low Receiver Input
EIL
0.3
µW/cm For in-band signals[8]
Irradiance
Receiver Peak Sensitivity
λP
880
nm
Wavelength
Receiver SIR Pulse Width
tpw (SIR) 1
4.0
µs
θ1/2 ≤ 15˚[10], CL = 10 pF
Receiver MIR Pulse Width
tpw (MIR) 100
500
ns
θ1/2 ≤ 15˚[11], CL = 10 pF
Receiver FIR Pulse Width
tpw (FIR) 85
165
ns
θ1/2 ≤ 15˚[12], CL = 10 pF,
VCC = 3 to 3.6 V
190
ns
VCC = 2.7 V
Receiver ASK Pulse Width
tpw (ASK)
1
µs
500 kHz/50% duty cycle
carrier ASK[13]
Receiver Latency Time for FIR
tL (FIR)
40
50
µs
Receiver Latency Time for SIR
tL (SIR)
µs
Receiver Rise/Fall Times
tr/f (RXD)
25
ns
[14]
Receiver Wake Up Time
tW
100
µs
Notes:
8. An in-band optical signal is a pulse/sequence where the peak wavelength, λp, is defined as 850 ≤ λp ≤ 900 nm, and the pulse characteristics are
compliant with the IrDA Serial Infrared Physical Layer Link Specification.
9. Logic Low is a pulsed response. The condition is maintained for duration dependent on pattern and strength of the incident intensity.
10. For in-band signals ≤ 115.2 kb/s where 3.6 µW/cm2 ≤ EI ≤ 500 mW/cm2.
11. For in-band signals at 1.15 Mb/s where 9.0 µW/cm2 ≤ EI ≤ 500 mW/cm2.
12. For in-band signals of 125 ns pulse width, 4 Mb/s, 4 PPM at recommended 400 mA drive current.
13. Pulse width specified is the pulse width of the second 500 kHz carrier pulse received in a data bit. The first 500 kHz carrier pulse may exceed
2 µs in width, which will not affect correct demodulation of the data stream. An ASK or DASK system using the HSDL-3602 has been shown to
correctly receive all data bits for 9 µW/cm2 ≤ EI ≤ 500 mW/cm2 incoming signal strength. ASK or DASK should use the FIR channel enabled.
14. The wake up time is the time between the transition from a shutdown state to an active state, and the time when the receiver is active and ready
to receive infrared signals.
TXD "Stuck ON" Protection
RXD Output Waveform
TXD
tpw
VOH
90%
50%
LED
VOL
tf
tpw (MAX.)
tpw
RX
LIGHT
90%
50%
LED OFF
tr
Receiver Wake Up Time Definition
(when MD0 ≠ 1 and MD1 ≠ 0)
LED Optical Waveform
LED ON
10%
10%
RXD
tr
VALID DATA
tf
tw
HSDL-3602-007 and HSDL-3602-037 Package Outline with Dimension and Recommended PC Board Pad Layout
MOUNTING
CENTER
6.10
1.17
4.18
4.98
TOP VIEW
2.55
R 2.00
R 1.77
4.00
1.90
1.90
PIN
1
0.80
1.20
1.70
3.24
4.05
PIN
10
0.80
3.84
12.20
SIDE VIEW
FRONT VIEW
ALL DIMENSIONS IN MILLIMETERS (mm).
DIMENSION TOLERANCE IS 0.20 mm
UNLESS OTHERWISE SPECIFIED.
MOUNTING CENTER
PIN 1
PIN 10
0.70
MID OF LAND
0.43
1.05
PIN 10
2.40
PIN 1
2.08
0.70
4.95
10 CASTELLATION:
PITCH 1.1 ± 0.1
CUMULATIVE 9.90 ± 0.1
BACK VIEW
0.45
2.35
2.84
LAND PATTERN
HSDL-3602-008 and HSDL-3602-038 Package Outline with Dimension and Recommended PC Board Pad Layout
11.7
5
0.36
0.53
2.5
0.47
0.85
R2
.3
0.31
0.31
0.83
2.08
0.84
3.85
.1
R2
0.3
+0.05
4.16 -0.00
2.08
1.46
0.42
2.57
0.28
1.77
0.94
3.24
3.84
5
2.15 +0.05
- 0.00
5
12.2 +0.10
-0.00
+0.05
11.7 -0.00
0.1
4.65
R2
R1
.77
0.1
0.94
0.8
0.73
1.95
Tape and Reel Dimensions (HSDL-3602-007, -037)
QUANTITY = 400 PIECES PER REEL (HSDL-3602-007)
1800 PIECES PER TAPE (HSDL-3602-037)
13.00 ± 0.50
R 1.00
(40 mm MIN.)
EMPTY
(400 mm MIN.)
LEADER
PARTS
MOUNTED
21.00 ± 0.80
EMPTY
(40 mm MIN.)
2.00 ± 0.50
DIRECTION OF PULLING
CONFIGURATION OF TAPE
LABEL
SHAPE AND DIMENSIONS OF REELS
A
10
4
Æ1.55 ± 0.05
5
2.00 ± 0.10
6
4.00 ± 0.10
B
3
1.75 ± 0.10
5 (MAX.)
11.50 ± 0.10
2
A 3.8
24.00 ± 0.30
1
Æ1.5 ± 0.1
A
A
8.00 ± 0.10
7
8
B
10
11
0.40 ± 0.10
4.25 ± 0.10
SECTION B-B
5 (MAX.)
4.4 A
5.20 ± 0.10
SECTION A-A
10
A
12 12.50 ± 0.10
9
A
Tape and Reel Dimensions (HSDL-3602-008, -038)
QUANTITY = 400 PIECES PER REEL (HSDL-3602-008)
1800 PIECES PER TAPE (HSDL-3602-038)
13.00 ± 0.50
R 1.00
(40 mm MIN.)
EMPTY
(400 mm MIN.)
LEADER
PARTS
MOUNTED
21.00 ± 0.80
EMPTY
(40 mm MIN.)
2.00 ± 0.50
LABEL
Do
Po
P2
D1
B
E
5 (MAX.)
F
W
Bo
8 ± 0.10
A
A
T
B
P1
5.4 ± 0.15
Ko
5 (MAX.)
SECTION B-B
Ao
SECTION A-A
SYMBOL
Ao
Bo
Ko
Po
P1
P2
T
SPEC
4.4 ± 0.10
12.50 ± 0.10
4.85 ± 0.10
4.0 ±0.10
8.0 ± 0.10
2.0 ± 0.10
0.35 ± 0.10
SYMBOL
E
F
Do
D1
W
10Po
SPEC
1.75 ± 0.10
11.5 ± 0.10
1.55 ± 0.10
1.5 ± 0.10
24.0 ± 0.3
40.0 ± 0.20
NOTES:
1. I.D. sprocket hole pitch cumulative tolerance is ± 0.2 mm.
2. Corner camber shall be not more than 1 mm per 100 mm through a length of 250 mm.
3. Ao and Bo measured on a place 0.3 mm above the bottom of the pocket.
4. Ko measured from a place on the inside bottom of the pocket to top surface of carrier.
5. Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole.
11
Moisture Proof Packaging
Baking Conditions
All HSDL-3602 options are shipped in moisture proof
package. Once opened, moisture absorption begins.
If the parts are not stored in dry conditions, they must
be baked before reflow to prevent damage to the parts.
UNITS IN A SEALED
MOISTURE-PROOF
PACKAGE
Package
Temp.
Time
In reels
60°C
≥ 48 hours
In bulk
100°C
≥ 4 hours
125°C
≥ 2 hours
150°C
≥ 1 hour
Baking should be done only once.
PACKAGE IS
OPENED (UNSEALED)
Recommended Storage Conditions
ENVIRONMENT
LESS THAN 30 C,
AND LESS THAN
60% RH
YES
NO BAKING
IS NECESSARY
YES
PACKAGE IS
OPENED LESS
THAN 72
HOURS
168H
12
10°C to 30°C
Relative
Humidity
below 60% RH
Time from Unsealing to Soldering
NO
PERFORM RECOMMENDED
BAKING CONDITIONS
Storage
Temperature
NO
After
bag,the
shouldshould
be soldered
After removal
removalfrom
fromthethe
bag, parts
the parts
be solwithin
7
days
if
stored
at
recommended
storage
conditions.If
dered within 3 days if stored at the recommended
storage
conditions.
times
72 hours
are
times
longer
than 168Ifhours
arelonger
needed,than
the parts
must be
needed,
stored
in athe
dryparts
box.must be stored in a dry box.
Recommended Reflow Profile
MAX. 260 C
T – TEMPERATURE – ( C)
255
R3
230
220
200
R2
180
60 sec.
MAX.
ABOVE
220 C
160
R1
120
R4
R5
80
25
100
150
200
250
300
t-TIME (SECONDS)
P1
HEAT
UP
P2
SOLDER PASTE DRY
P3
SOLDER
REFLOW
P4
COOL
DOWN
Process Zone
Symbol
∆T
Heat Up
P1, R1
25˚C to 160˚C
Solder Paste Dry
P2, R2
160˚C to 200˚C
Solder Reflow
P3, R3
200˚C to 255˚C
(260˚C at 10 seconds max.)
P3, R4
255˚C to 200˚C
Cool Down
P4, R5
200˚C to 25˚C
The reflow profile is a straight-line representation of
a nominal temperature profile for a convective reflow
solder process. The temperature profile is divided into
four process zones, each with different ∆T/∆time temperature change rates. The ∆T/∆time rates are detailed
in the following table. The temperatures are measured
at the component to printed circuit board connections.
In process zone P1, the PC board and HSDL-3602 castellation pins are heated to a temperature of 160°C to
activate the flux in the solder paste. The temperature
ramp up rate, R1, is limited to 4°C per second to allow
for even heating of both the PC board and HSDL-3602
castellations.
Process zone P2 should be of sufficient time duration
(60 to 120 seconds) to dry the solder paste. The temperature is raised to a level just below the liquidus point
of the solder, usually 200°C (392°F).
Process zone P3 is the solder reflow zone. In zone P3, the
temperature is quickly raised above the liquidus point
of solder to 255°C (491°F) for optimum results. The
dwell time above the liquidus point of solder should
13
Maximum
∆T/∆time
4˚C/s
0.5˚C/s
4˚C/s
–6˚C/s
–6˚C/s
be between 20 and 60 seconds. It usually takes about
20 seconds to assure proper coalescing of the solder
balls into liquid solder and the formation of good solder
connections. Beyond a dwell time of 60 seconds, the
intermetallic growth within the solder connections becomes excessive, resulting in the formation of weak and
unreliable connections. The temperature is then rapidly
reduced to a point below the solidus temperature of
the solder, usually 200°C (392°F), to allow the solder
within the connections to freeze solid.
Process zone P4 is the cool down after solder freeze. The
cool down rate, R5, from the liquidus point of the solder
to 25°C (77°F) should not exceed 6°C per second maximum. This limitation is necessary to allow the PC board
and HSDL-3602 castellations to change dimensions
evenly, putting minimal stresses on the HSDL-3602
transceiver.
Appendix A: HSDL-3602-007/-037 SMT Assembly Application Note
1.0. Solder Pad, Mask, and Metal Solder Stencil Aperture
METAL STENCIL
FOR SOLDER PASTE
PRINTING
STENCIL
APERTURE
LAND PATTERN
SOLDER
MASK
PCBA
Figure 1. Stencil and PCBA.
HSDL-3602 fig 1.0
1.1. Recommended Land Pattern for HSDL-3602-007/-037
Dim.
a
b
c (pitch)
d
e
f
g
mm
2.40
0.70
1.10
2.35
2.80
3.13
4.31
inches
0.095
0.028
0.043
0.093
0.110
0.123
0.170
SHIELD SOLDER PAD
e
d
g
Y
Rx LENS
b
Tx LENS
theta
f
X
h
a
FIDUCIAL
10x PAD
Figure 2. Top view of land pattern.
14
c
FIDUCIAL
1.2. Adjacent Land Keep-out and Solder Mask Areas
Dim.
mm
inches
h
min. 0.2
min. 0.008
j
13.4
0.528
k
4.7
0.185
l
3.2
0.126
• Adjacent land keep-out is the maximum space occupied by the unit relative to the land pattern. There
should be no other SMD components within this
area.
• “h” is the minimum solder resist strip width required
to avoid solder bridging adjacent pads.
• It is recommended that 2 fiducial cross be placed at
mid-length of the pads for unit alignment.
Note : Wet/Liquid Photo-Imagineable solder resist/mask
is recommended.
j
Tx LENS
LAND
Rx LENS
SOLDER
MASK
h
k
Y
DIM.
mm
INCHES
h
MIN. 0.2
MIN. 0.008
j
13.4
0.528
k
4.7
0.185
l
3.2
0.126
• ADJACENT LAND KEEP-OUT IS THE
MAXIMUM SPACE OCCUPIED BY THE
UNIT RELATIVE TO THE LAND PATTERN.
THERE SHOULD BE NO OTHER SMD
COMPONENTS WITHIN THIS AREA.
• "h" IS THE MINIMUM SOLDER RESIST
STRIP WIDTH REQUIRED TO AVOID
SOLDER BRIDGING ADJACENT PADS.
l
Figure 3. HSDL-3602-007/-037 PCBA-Adjacent land keep-out and solder mask.
15
• IT IS RECOMMENDED THAT 2 FIDUCIAL
CROSS BE PLACED AT MID-LENGTH OF
THE PADS FOR UNIT ALIGNMENT.
2.0. Recommended solder paste/cream volume for castellation joints
Based on calculation and experiment, the printed solder paste volume required per castellation pad is 0.30
cubic mm (based on either no-clean or aqueous solder
cream types with typically 60 to 65% solid content by
volume).
2.1. Recommended Metal Solder Stencil Aperture
It is recommended that only 0.152 mm (0.006 inches) or
0.127 mm (0.005 inches) thick stencil be used for solder
paste printing. This is to ensure adequate printed solder
paste volume and no shorting. The following combination of metal stencil aperture and metal stencil thickness should be used:
See Figure 4
t, nominal stencil thickness
l, length of aperture
mm
inches
mm
inches
0.152
0.006
2.8 ± 0.05
0.110 ± 0.002
0.127
0.005
3.4 ± 0.05
0.134 ± 0.002
w, the width of aperture is fixed at 0.70 mm (0.028 inches)
Aperture opening for shield pad is 2.8 mm x 2.35 mm as per land dimension.
APERTURE AS PER
LAND
t (STENCIL THICKNESS)
SOLDER
PASTE
w
l
Figure 4. Solder paste stencil aperture.
HSDL-3602 fig 4.0
3.0. Pick and Place Misalignment Tolerance
and Product
Self-Alignment after Solder Reflow
If the printed solder paste volume is adequate, the
unit will self-align in the X-direction after solder reflow.
Units should be properly reflowed in IR Hot Air convection oven using the recommended reflow profile. The
direction of board travel does not matter.
16
Allowable Misalignment Tolerance
X-direction
≤ 0.2 mm (0.008 inches)
Theta-direction
± 2 degrees
3.1. Tolerance for X-axis Alignment of Castellation
Misalignment of castellation to the land pad should not exceed 0.2 mm or approximately half the width of the castellation during placement of the unit. The castellations will completely self-align to the pads during solder reflow as
seen in the pictures below.
Picture 1. Castellation misaligned to land pads in X-axis before
reflow.
Picture 2. Castellation self-align to land pads after reflow.
3.2. Tolerance for Rotational (Theta) Misalignment
Units when mounted should not be rotated more than ± 2 degrees with reference to center X-Y as specified in Figure 2. Pictures 3 and 4 show units before and after reflow. Units with a Theta misalignment of more than 2 degrees
do not completely self-align after reflow. Units with ± 2 degree rotational or Theta misalignment self-aligned completely after solder reflow.
Picture 3. Unit is rotated before reflow.
17
Picture 4. Unit self-aligns after reflow.
3.3. Y-axis Misalignment of Castellation
In the Y-direction, the unit does not self-align after solder reflow. It is recommended that the unit be placed
in line with the fiducial mark (mid-length of land pad).
This will enable sufficient land length (minimum of 1/2
land length) to form a good joint. See Figure 5.
LENS
EDGE
FIDUCIAL
Y
MINIMUM 1/2 THE LENGTH
OF THE LAND PAD
Figure 5. Section of a castellation in Y-axis.
fig 5.0
3.4. Example of Good HSDL-3602
HSDL-3602-007/-037
Castellation
Solder Joints
This joint is formed when the printed solder paste
volume is adequate, i.e., 0.30 cubic mm and reflowed
properly. It should be reflowed in IR Hot-air convection
reflow oven. Direction of board travel does not matter.
Picture 5. Good solder joint.
4.0. Solder Volume Evaluation and Calculation
Geometery of an HSDL-3602-007/-037 solder fillet.
0.45
0.20
0.8
0.4
18
1.2
0.70
0.7
Appendix B: HSDL-3602-008/-038 SMT Assembly Application Note
METAL STENCIL
FOR SOLDER PASTE
PRINTING
STENCIL
APERTURE
LAND PATTERN
SOLDER
MASK
PCBA
HSDL-3602 fig 1.0
1.1. Recommended Land Pattern for HSDL-3602-008/-038
Dim.
a
b
c (pitch)
d
e
f
g
mm
1.95
0.60
1.10
1.60
5.70
3.80
2.40
inches
0.077
0.024
0.043
0.063
0.224
0.123
0.170
SHIELD SOLDER PAD
e
d
g
Y
Rx LENS
b
Tx LENS
theta
f
X
h
a
FIDUCIAL
19
10x PAD
c
FIDUCIAL
2.0 Y-axis Misalignment of Castellation
land length) to form a good joint. See Figure 2.
Y
FIDUCIAL
1/2 THE LENGTH OF THE
CASTELLATION PAD
Figure 2. Section of a castellation in Y-axis.
Appendix C: General Application Guide for the HSDL-3602
Infrared IrDA® Compliant 4 Mb/s Transceiver
Description
The HSDL-3602 wide voltage operating range infrared
transceiver is a low-cost and small form factor that is
designed to address the mobile computing market such
as notebooks, printers and LAN access as well as small
embedded mobile products such as digital cameras,
cellular phones, and PDAs. It is fully compliant to IrDA
1.1 specification up to 4 Mb/s, and supports HP-SIR,
Sharp ASK, and TV Remote modes. The design of the
HSDL-3602 also includes the following unique features:
• Low passive component count.
• Adjustable Optical Power Management (full, 2/3, 1/3
power).
• Shutdown mode for low power consumption requirement.
• Single-receive output for all data rates.
The HSDL-3602 transmitter offers user-adjustable optical power levels. The use of two logic-level mode-select
input pins, MODE 0 and MODE 1, offers shutdown mode
as well as three transmit power levels as shown in the
following Table. The power levels are setup to correspond nominally to maximum, two-third, and one-third
of the transmission distance. This unique feature allows
lower optical power to be transmitted at shorter link
distances to reduce power consumption.
MODE
MODE 1
Transmitter
1
Shutdown
Full Power
2/3 Power
1
1
1/3 Power
There are 2 basic means to adjust the optical power of
the HSDL-3602:
Dynamic: This implementation enables the transceiver
pair to adjust their transmitter power according to the
link distance. However, this requires the IrDA protocol
stack (mainly the IrLAP layer) to be modified. Please
contact Agilent Application group for further details.
Static: Pre-program the ROM BIOS of the system (e.g.
notebook PC, digital camera, cell phones, or PDA) to
allow the end user to select the desired optical power
during the system setup stage.
21
Selection of Resistor R1
Resistor R1 should be selected to provide the appropriate peak pulse LED current over different ranges of Vcc.
The recommended R1 for the voltage range of 2.7 V to
3.3 V is 2.2 Ω while for 3.0 V to 3.6 V is 2.7 Ω. The HSDL3602 typically provides 250 mW/sr of intensity at the
recommended minimum peak pulse LED current of 400
mA.
Interface to Recommended I/O chips
The HSDL-3602’s TXD data input is buffered to allow
for CMOS drive levels. No peaking circuit or capacitor is
required.
Data rate from 9.6 kb/s up to 4 Mb/s is available at the
RXD pin. The FIR_SEL pin selects the data rate that is
receivable through RXD. Data rates up to 115.2 kb/s can
be received if FIR_SEL is set to logic low. Data rates up
to 4 Mb/s can be received if FIR_SEL is set to logic high.
Software driver is necessary to program the FIR_SEL to
low or high at a given data rate.
4 Mb/s IR link distance of greater than 1.5 meters have
been demonstrated using typical HSDL-3602 units with
National Semiconductor’s PC87109 3 V Endec and Super
I/Os, and the SMC Super I/O chips.
(A) National Semiconductor Super I/O and Infrared
Controller
For National Semiconductor Super I/O and Infrared
Controller chips, IR link can be realized with the
following connections:
• Connect IRTX of the National Super I/O or IR Controller to TXD (pin 9) of the HSDL-3602.
• Connect IRRX1 of the National Super I/O or IR Controller to RXD (pin 8) of the HSDL-3602.
• Connect IRSL0 of the National Super I/O or IR Controller to FIR_SEL (pin 3) of the HSDL-3602.
Please refer to the table below for the IR pin assignments for the National Super I/O and IR Controllers that
support IrDA 1.1 up to 4 Mb/s:
(B) HSDL-3602 Interoperability with National Semiconductor PC97338VJG SIO Evaluation R eport
Introduction
The objective of this report is to demonstrate the interoperability of the HSDL-3602 IR transceiver IR module as wireless communication ports at the speed of 2.4
kb/s - 4 Mb/s with NS’s PC97338VJG Super I/O under
typical operating conditions.
(2)
The test software used in this interoperability test
is provided by National Semiconductor. A file size
of 1.7M byte from the master device, with the
PC97338VJG performing the framing, encoding is
transmitted to the slave device. The slave device,
with the PC97338VJG performing the decoding,
and CRC checksum, will receive the file. The file is
then checked for error by comparing the received
file with the original file using the DOS “fc” command.
(3)
The link distance is measured by adjusting the distance between the master and slave for errorless
data communications.
Test Procedures
(1)
Two PC97338VJG evaluation boards were connected to the ISA Bus of two PCs (Pentium 200
MHz) running Microsoft’s DOS operating system.
One system with an HSDL-3602 IR transceiver
connected to the PC97338VJG evaluation board
will act as the master device. Another system with
an HSDL-3602 IR transceiver connected to the
PC97338VJG will act as the slave device (i.e. Device Under Test).
PC97/87338VJG
PC87308VUL
PC87108AVHG
PC87109VBE
IRTX
63
81
39
15
IRRX1
65
80
38
16
Please refer to the National Semiconductor data sheets and application notes for updated information.
VCC
R1
LEDA (10)
TXD (9)
SP
IRTX
NATIONAL
SEMICONDUCTOR
SUPER I/O
OR
IR CONTROLLER
MD0 (4)
IRRX1
HSDL-3602
MD1 (5)
RXD (8)
IRSL0
FIR_SEL (3)
CX1
GND (7)
CX2
* MODE GROUND FOR
FULL POWER OPERATION
VCC (1)
AGND (2)
HSDL-3600
FUNCTIONAL BLOCK DIAGRAM
22
HSDL-3602 FUNCTIONAL DIAGRAM (A)
IRSL0
66
79
37
14
HSDL-3602 Interoperability with NS PC97338 Report
HSDL-3602 Interoperability with SMC 669/769 Report
(i) Test Conditions
(i) Test Conditions
(ii) Test Result
(ii) Test Result
VCC = 3.0 – 3.6 V
RLED = 2.7 Ω
Optical transmitter pulse width = 125 ns
Mode set to full power
Vcc = 3.0 – 3.6 V
RLED = 2.2 Ω
The interoperability test results show that HSDL-3602 IR
transceiver can operate ≥ 1.5 meter link distance from
3 V to 3.6 V with NS’s PC97338 at any IrDA 1.1 data rate
without error.
3 V to 3.6 V with SMC 669/769 at any IrDA 1.1 data rate
without error.
(C) Standard Micro System
Corporation (SMC) Super and Ultra I/O Controllers
For SMC Super and Ultra I/O Controller chips, IR link can
be realized with the following connections:
• Connect IRTX of the SMC Super or Ultra I/O Controller
• Connect IRRX of the SMC Super or Ultra I/O Controller
• Connect IRMODE of the Super or Ultra I/O Controller
Please refer to the table below for the IR pin assignments for the SMC Super or Ultra I/O Controllers that
support IrDA 1.1 up to 4Mb/s:
VCC
14.314 MHz
CLOCK
R1
LEDA (10)
A0 - A3
TXD (9)
SYSTEM BUS
D0 - D7
DRQ
DACK, TC
IRQ
SP
IRTX (63)
RD, WR, CS
NATIONAL
SEMICONDUCTOR
PC97338VJG
SUPER I/O
MD0 (4)
IRRX1 (65)
HSDL-3602
MD1 (5)
RXD (8)
IRSL0 (66)
FIR_SEL (3)
CX1
GND (7)
* MODE GROUND FOR
CX2
VCC (1)
AGND (2)
HSDL-3602
23
HSDL-3602 FUNCTIONAL DIAGRAM (B)
FDC37C669FR
FDC37N769
FDC37C957/8FR
IRTX
89
87
204
IRRX
88
86
203
HSDL-3602 Interoperability with SMC's Super I/O or IR Controller
VCC
R1
LEDA (10)
IRRX
STANDARD
MICROSYSTEM
CORPORATION
SUPER I/O
OR
IR CONTROLLER
IRMODE
RXD (8)
FIR_SEL (3)
HSDL-3602
IRTX
TXD (9)
SP
MD0
MD1
CX1
GND (7)
MODE GROUND
FOR FULL POWER
OPERATION
CX2
4
5
VCC (1)
AGND (2)
24
IRMODE
23
21
145 or 190
Appendix D: Optical Port Dimensions for HSDL-3602:
To ensure IrDA compliance, some constraints on the
height and width of the window exist. The minimum
dimensions ensure that the IrDA cone angles are met
without vignetting. The maximum dimensions minimize the effects of stray light. The minimum size corresponds to a cone angle of 300 and the maximum size
corresponds to a cone angle of 60º.
The above equations assume that the thickness of the
window is negligible compared to the distance of the
module from the back of the window (Z). If they are
comparable, Z' replaces Z in the above equation. Z' is
defined as
In the figure below, X is the width of the window, Y is
the height of the window and Z is the distance from
the HSDL-3602 to the back of the window. The distance
from the center of the LED lens to the center of the
photodiode lens, K, is 7.08mm. The equations for computing the window dimensions are as follows:
where ‘t’ is the thickness of the window and ‘n’ is the refractive index of the window material.
Z'=Z+t/n
X = K + 2*(Z+D)*tanA
Y = 2*(Z+D)*tanA
OPAQUE MATERIAL
IR TRANSPARENT WINDOW
X
K
Z
A
D
HSDL-3602 Optical Port Dimensions
25
OPAQUE MATERIAL
The depth of the LED image inside the HSDL-3602, D, is
8mm. ‘A’ is the required half angle for viewing. For IrDA
compliance, the minimum is 150 and the maximum is
300. Assuming the thickness of the window to be negligible, the equations result in the following tables and
graphs:
Module Depth, (z) mm
2
3
4
5
6
7
8
9
Aperture Width
(x, mm)
max.
min.
16.318
11.367
17.472
11.903
18.627
12.439
19.782
12.975
20.936
13.511
22.091
14.047
23.246
14.583
24.401
15.118
25.555
15.654
26.710
16.190
APERTURE WIDTH (X) vs MODULE DEPTH
APERTURE HEIGHT (Y) vs MODULE DEPTH
26
25
25
APERTURE HEIGHT (Y) – mm
APERTURE WIDTH (X) – mm
30
10
X MAX.
X MIN.
5
Aperture height
(y, mm)
max.
min.
9.238
4.287
10.392
4.823
11.547
5.359
12.702
5.895
13.856
6.431
15.011
6.967
16.166
7.503
17.321
8.038
18.475
8.574
19.630
9.110
2
3
4
5
6
7
8
9
10
5
Y MAX.
Y MIN.
2
3
4
5
6
7
MODULE DEPTH (Z) – mm
HSDL-3602 Width vs Depth
HSDL-3602 Height vs Depth
8
9
Window Material
Almost any plastic material will work as a window material. Polycarbonate is recommended. The surface finish
of the plastic should be smooth, without any texture.
An IR filter dye may be used in the window to make it
look black to the eye, but the total optical loss of the
window should be 10 percent or less for best optical
performance. Light loss should be measured at 875 nm.
Shape of the Window
From an optics standpoint, the window should be flat.
This ensures that the window will not alter either the
radiation pattern of the LED, or the receive pattern of
the photodiode.
If the window must be curved for mechanical or industrial design reasons, place the same curve on the
back side of the window that has an identical radius as
the front side. While this will not completely eliminate
the lens effect of the front curved surface, it will significantly reduce the effects. The amount of change in
the radiation pattern is dependent upon the material
chosen for the window, the radius of the front and back
curves, and the distance from the back surface to the
transceiver. Once these items are known, a lens design
can be made which will eliminate the effect of the front
surface curve.
The following drawings show the effects of a curved
window on the radiation pattern. In all cases, the center
thickness of the window is 1.5 mm, the window is made
of polycarbonate plastic, and the distance from the
transceiver to the back surface of the window is 3 mm.
Flat Window
Curved Front and Back
Curved Front, Flat Back
(First choice)
(Second choice)
(Do not use)
HSDL-3602 Curved Window
HSDL-3602 Curved/Flat Window
HSDL-3602 Flat Window
For company and product information, please go to our web site: WWW.liteon.com or
http://optodatabook.liteon.com/databook/databook.aspx
Data subject to change. Copyright © 2007 Lite-On Technology Corporation. All rights reserved.
27
