SFH7051
SFH7051
    AMSOSRAM(艾迈斯半导体)
    CHIPONBOARDBIOMON
SFH7051 数据手册
! 2007-05-23 BioMon Sensor Datasheet Version 1.1 SFH 7051 Features: • Multi chip package featuring 3 green emitters and one detector • Small package:(WxDxH) 4.7 mm x 2.5 mm x 0.9 mm • Light Barrier to block optical crosstalk Applications 7 • Heart rate monitoring for: • Wearable devices (e.g. smart watches, fitness trackers, ...) • Mobile devices Ordering Information SFH 7051 Type SFH 7051 2016-04-25 Ordering Code Q65111A7792 1 Version 1.1 SFH 7051 Pin configuration Pin Name Function 1 G1A Green LED Anode 2 G1C Green LED Cathode 3 G2C Green LED Cathode 4 PA Photodiode Anode 5 PC Photodiode Cathode 6 G2A Green LED Anode 7 G3C Green LED Cathode 8 G3A Green LED Anode Block diagram 2016-04-25 2 Version 1.1 SFH 7051 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit  General Operating temperature range Top -40 … 85 °C Storage temperature range Tstg -40 … 85 °C ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2 kV  Green Emitters Reverse voltage VR 5 V Forward current (single emitter operation) IF (DC) 25 mA Forward current (all emitters active) IF (DC) 15 mA Surge current (tp = 100 µs, D = 0) IFSM 300 mA VR 16 V  Detector Reverse voltage 2016-04-25 3 Version 1.1 SFH 7051 Characteristics (TA = 25 °C) Parameter Symbol Value Unit Green Emitter (single emitter) Wavelength of peak emission (IF = 20 mA) (typ.) peak Centroid Wavelength (IF = 20 mA) (typ. (max.)) centroid Spectral bandwidth at 50% of Imax (IF = 20 mA) (typ.) Half angle 530 nm 535 (±10) nm  34 nm (typ.)  ± 60 Rise and fall time of Ie  (10% and 90% of Ie max) (IF = 100 mA, tp = 16 µs, RL = 50 ) (typ.) t r, tf 32 ns Forward voltage (IF = 20 mA) (typ. (max.)) VF 3.2 (≤ 3.7) V IR not designed for reverse operation µA Reverse current (VR = 5 V) ° Radiant intensity (IF = 20 mA, tp = 20 ms) (typ.) Ie 1.4 mW / sr Total radiant flux (IF = 20 mA, tp = 20 ms) (typ.) e 3.4 mW Temperature coefficient of centroid (IF = 20 mA, -10°C ≤ T ≤ 100°C) (typ.) TCcentroid 0.02 nm / K Temperature coefficient of VF  (IF = 20 mA, -10°C ≤ T ≤ 100°C) (typ.) TCV -4.0 mV / K 2016-04-25 4 Version 1.1 SFH 7051 Characteristics (TA = 25 °C) Parameter Symbol Value Unit Detector Photocurrent (typ.) (Ee = 0.1 mW/cm2, = 535 nm, VR = 5 V) IP,535 Wavelength of max. sensitivity (typ.) S max 920 nm Spectral range of sensitivity (typ.) 10% 400 … 1100 nm Radiation sensitive area (typ.) A Dimensions of radiant sensitive area (typ.) LxW Dark current (VR = 5 V, Ee = 0 mW/cm2) (typ. (max.)) IR Spectral sensitivity of the chip ( = 535nm) (typ.) S535 0.27 A/W Open-circuit voltage  (Ee = 0.1 mW/cm2,  = 535 nm) (typ.) VO,535 240 mV Short-circuit current (Ee = 0.1 mW/cm2,  = 535 nm) (typ.) ISC,535 0.40 µA Rise and fall time  (VR = 3.3 V, RL = 50 ,  = 535nm) (typ.) t r, tf 42 ns Forward voltage (IF = 10 mA, E = 0 mW/cm2) (typ.) VF 0.9 V Capacitance (VR = 5 V, f = 1 MHz, E = 0 mW/cm2) (typ.) C0 5 pF 2016-04-25 5 0.42 1.7 1.3 x 1.3 1 (≤ 5) µA mm2 mm x mm nA Version 1.1 SFH 7051 Diagrams for green emitters Relative spectral emission 1) Irel = f(), TA = 25 °C, IF = 20 mA Forward current 1) Relative radiant flux 1) IF = f(VF), TA= 25°C e /e(20 mA) = f(IF), single pulse, tp = 25µs, TA= 25°C 2016-04-25 6 Version 1.1 SFH 7051 Diagrams for green emitters Max. permissible forward current 1) (single emitter) IF,max = f(TA), RthJA = 800 K/W Permissible pulse handling capability 1) (single emitter) IF = f(tp), TA= 40°C, duty cycle D 2016-04-25 Permissible pulse handling capability 1) (single emitter) IF = f(tp), TA= 85°C, duty cycle D 7 Version 1.1 SFH 7051 Diagrams for green emitters Max. permissible forward current 1) (three emitters) IF,max = f(TA), RthJA = 800 K/W Permissible pulse handling capability 1) (three emitters) IF = f(tp), TA= 40°C, duty cycle D 2016-04-25 Permissible pulse handling capability 1) (three emitters) IF = f(tp), TA= 85°C, duty cycle D 8 Version 1.1 SFH 7051 Diagrams for detector Relative spectral sensitivity 1) Srel = f(), TA = 25 °C Photocurrent 1) Dark current 1) Capacitance 1) IR = f(VR), E = 0 mW/cm2, TA = 25 °C C = f(VR), f = 1 MHz, E = 0 mW/cm2, TA = 25 °C 2016-04-25 IP(VR = 5 V), =530nm, TA = 25 °C 9 Version 1.1 SFH 7051 Directional characteristics of detector 1) Srel = f() 40˚ 30˚ 20˚ 10˚ 0˚ ϕ 50˚ OHL01660 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 1.0 0.8 0.6 0.4 0˚ 20˚ Radiation characteristics of emitter 1) Irel = f() 2016-04-25 10 40˚ 60˚ 80˚ 100˚ 120˚ Version 1.1 SFH 7051 Package Outline Dimensions in mm. Package: chip on board Approximate Weight: 18 mg 2016-04-25 11 Version 1.1 SFH 7051 Recommended solder pad design Dimensions in mm (inch). Reflow Soldering Profile Product complies to MSL Level 4 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t 2016-04-25 12 Version 1.1 SFH 7051 OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Method of Taping Dimensions in mm [inch]. 2016-04-25 °C 13 s Version 1.1 SFH 7051 Tape and Reel 12 mm tape with 3000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Dimensions in mm Tape Dimensions [mm] W 12 +0.3 / -0.1 P0 P1 P2 D0 E F 4 ±0.1 4 ±0.1 2 ±0.05 1.5 ±0.1 1.75 ±0.1 5.5 ±0.05 Reel Dimensions [mm] A 180 2016-04-25 W Nmin W1 W2max 12 60 12.4 +2 18.4 14 Version 1.1 SFH 7051 EX AM PL E Barcode-Product-Label (BPL) OSRAM Opto po BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors tors ors r RoHS Compliant (6P) BATCH NO: NO:: 1234567 1234567890 234 7890 890 ML Temp ST X XXX °C X (1T) LOT NO: 1234567890 (9D) (9D D) D/ D) D/C: D/C: 123 1234 234 34 RXX Pack: RX R XX DEMY XXX X XX X_X123_1234.1234 X_X123_1 12 _123 123 12 234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X XX-XX XX XXX-X-X OHA04563 Dry Packing Process and Materials Moisture-sensitive label or print L VE LE l k, see labe ). code (RH blan If bar . idity RH hum 0% e tive d ˚C/6 kag rela are 30 s _ infr pac < IVE of TOR rs 90% to ak tain SIT < rs ns ed (pe UC or e). rs con Hou SEN rs ND Hou and ject ˚C, cod ditio 72 sing Hou 5 e bag E ˚C sub 48 Hou con ± s UR ICO ces 24 6 dat 40 be time ˚C ory ThiISTSEM pro < time e . or 23 tim at t will l with or fact ent˚C) . MO Flo s TO at or r time at l Flo tica d tha ival ure nth OP Flo 4 if: rea w Floo labe mo ices iden ced 5 equ el g, n e 5a is el belo 24 dev or pro 6 Lev e : ntin el whe e cod , e Lev el ow, see bag Lev l dat mou bak bar ned stur rere Lev refl re> 10% led time for sea re ope e see Moi istu istu is k, or . sea is has k, Mo befo istu d 033 Mo in Flo RH blan Mo or-p blan in bag ing, Car r TDlife (if r t. If r lf J-S thisvapp. d with 10%bak Yea eks rs _ me r < cato 1 Yea tem d, C She ow, at uire not > y 1 WeHou unte DE Afte Indi 1. 4 uire refl is red req 2. bod Mo /JE time 168 req : idity 2b a) time Sto ices or is IPC or time ned b) Hum ing ce Flo or r time e Dev 2a r Flo ope a) 3. b) bak ren Floo dat 1 l Floo If 2 refe time el 2a 4. el sea 3 Lev el and e Lev el Bag e Lev stur rere Lev Dat re Moi istu Mo istu istu Mo Mo U A C N O TI Barcode label S M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. 2016-04-25 15 Version 1.1 SFH 7051 Transportation Packing and Materials Barcode label MY DE 8 T6 PL 76 R1 Q1 P1+ lti LS TO Y ). 44 : 01 rs D/C 99 8 O pt o to 21 uc 00 (9D ) AM nd 21 : co 20 00 Y: (Q) QT SR NO mi H O H1 23 4 Se TC BA 3G ) (6P 5 NO : 12 T 14 2 LO PR OD NO : (1T ) 11 00 see labe N TIO (X) U A GR Mu l k, C (G) L VE LE code (RH blan If y bar . idit RH hum 60% e tive d ˚C/ kag rela are 30 E S s _ < infr pac OR of 90% to ak tainITIV urs CT < e). or ted (pe ons con NS Ho urs g urs SE DU Ho and jec diti cod ˚C, 72 sin Ho urs e 5 bag E ON 48 ˚C sub e Ho con ± ces is UR 24 6 dat MIC 40 be tim e e ˚C h ThISTSE pro < tory tim . or t wit 23 tim e at t will or fac . MO Flo al len ˚C) tim s TO at or at Flo d or ure iva el nth s tha OP ntic Flo 4 if: rea Flo , lab ow mo ice equ ide 5 ced el e 5a is el ingen bel 24 dev, or pro 6 Lev e : el e cod , unt wh Lev el re ow see bag Lev l dat re mo bak e bar ned Lev refl istu 10% re tim sea for ore> re ope e Mo istu see 3 istu is or . sea is has Mo nk, bef , nk, Flo rd -03 Mo istu in RH bla Mo or-p bla in bag ingCa TD life (if ar If with t. lf vapp. 10%baktor J-S this Ye ar eks , _ < ed ica med, C 1 urs Ye She erow tem at uire not > y 1 WeHo unt DE Aft Ind 1. e 4 uire refl red req 2. bod Mo ity is /JE tim e e s 168 req : 2b a) Sto tim or mid is IPC tim e vice or b) ned Flo or Hu tim ing ce or e De 2a Flo a) ope or 3. b) bak ren Flo e 1 l dat Flo If 2 el refe tim 4. 2a el sea 3 Lev el and Lev el re Bag te Lev re Lev istu Da re re Mo istu Mo istu istu Mo Mo OU P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Tem 2a 220 3 240 p ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: Barcode label MY DE Q1 R1 8 lti LS TO Y T6 PL 76 P1+ Mu 99 8 D/C : 01 21 (9D ) 00 21 00 20 Y: QT (Q) ico AM nd O uc pt to o rs NO : 23 4 m H1 Se BA TC H 3G : 12 (X) PR OD NO : (1T ) 11 00 LO T 14 2 NO (6P ) M RA OS 5 O SR 44 (G) GR OU P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Te 2a 220 mp 3 240 ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: led Packing Sealing label OHA02044 Dimensions of transportation box in mm Width 195 ± 5 2016-04-25 Length Height 195 ± 5 42 ± 5 16 Version 1.1 SFH 7051 Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization.?If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. ?By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED and photodiodes, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-04-25 17
SFH7051 价格&库存
很抱歉,暂时无法提供与“SFH7051”相匹配的价格&库存,您可以联系我们找货
