WBWO-1
WBWO-1
    C-TON
    WATER LEAK DETRECTOR
WBWO-1 数据手册
Specifications Installation and Operating Instructions Water Leak Detector WB Series DESCRIPTION & FEATURES The WB is a small, lightweight device that activates and illuminates when water is sensed. Simply place on a flat surface under your equipment or attach using the included mounting brackets. The WB relies on the electrictal conductivity of water to change the resistance across two contacts at the base of the enclosure. When the contacts are bridged by water, the resistance changes and triggers an alarm. Choose either the WBWO-1 or the WBWA-1 model for applications that require visual alert and/or relay contacts. Both units require an external 24VAC/VDC power supply. The WBWA-1 unit will trigger both visual and audible alarms when water is sensed. SPECIFICATIONS TYPE Switch Type: Electrical Rating: POWER Power Requirements: Power Consumption: Electrical Connections: PHYSICAL Enclosure: Temperatur Limits: Weight: Dimensions: DPDT relay DPDT 1 A @ 24 VAC/DC, 1 A @ 120 VAC 11-27 VAC/DC DC 25 mA typical and 75 mAmax, AC 30 mA typical and 85 mA max attached 22 AWG, PVC insulated cable (4.8 ft long) acrylic, ABS plastic 32 to 122°F (0 to 50°C) 4.3 oz 3" L x 2" W x 1-1/4" H }} }} }} }} }} Visual and audible alarm Small, compact design DPDT relay Compact size Removable mounting bracket Typical Uses: • Dishwashers • Sinks • Toilets • Washing machines • Water heaters • Air conditioners ORDERING INFO PART NUMBER WBWO-1.............................................. Sensor with Relay, 24 VAC/DC power WBWA-1 .................Sensor with Relay, 24 VAC/DC power with audible alarm WIRING C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
WBWO-1 价格&库存
很抱歉,暂时无法提供与“WBWO-1”相匹配的价格&库存,您可以联系我们找货
