Frequency Transducer
DIN RAIL / PANEL MOUNT
The CR6600 Series, Frequency Transducers and Transmitters
are designed to give a DC output that is proportional to an
input frequency value. These devices are especially suited to
variable frequency systems.
Applications
CR6610
CR6611
CR6612
Outputs isolated from inputs
Ranges available for any application
Sine, square and zero crossover waveforms
35 DIN rail or panel mount
Connection diagram printed on case
CR6620
CR6621
CR6622
Features
40 - 5000 Hz Input Range
Regulatory Agencies
Constructed to meet UL 61010B-1
Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004
Meets requirement of IEC 61010-1 and BS EN 61010-1
E199795
Custom calibrations of unique full scale and zero
scale values including parametric measurements are
available. Contact factory for details.
Add suffix for input range
PART NUMBERS
CR6610
CR6611
CR6612
CR6620
CR6621
CR6622
Sine wave sensing with 0 - 5 VDC Output
Square wave sensing with 0 - 5 VDC Output
100 500 5000 -
0-100 Hz
0-500 Hz
0-5000 Hz
other ranges available
Zero crossover sensing with 0 - 5 VDC Output
Sine wave sensing with 4 - 20 mADC Output
Square wave sensing with 4 - 20 mADC Output
Zero crossover sensing with 4 - 20 mADC Output
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
57
E-mail: sales@crmagnetics.com
C
Transducers
35mm DIN Rail or Panel Mount
Available with 0 - 5 VDC, 0 - 10, or 4 - 20 mADC output
24 VDC powered
Red LED Active Indication
Highest precision available
SPECIFICATIONS
Transducers
C
Basic Accuracy:......................... 0.5%
Linearity:.................................... 10% to 100% FS
Thermal Drift:............................ 500 PPM/°C
Operating Temperature:............ 0°C to +60°C
Installation Category:................. CAT II
Vibration Tested To:................... IEC 60068-2-6,1995
Pollution Degree:........................2
Response Time: ....................... 250 ms max. 0-90% FS
Supply Voltage:......................... 24 VDC
MTBF:.......................................Greater than 100 K hours
Frequency Range:....................0 Hz - 2kHz, sine wave
Insulation Voltage:.................... 2500 VDC
Altitude:................................... 2000 meter max.
Output Load:................ 4-20 mADC -0 to 300 Ω
0-5 VDC - 2K Ω or Greater
Cleaning:.................... Water-dampened cloth
Relative Humidity:......... 5% to 95%, Non-Condensing
Input Voltage:................ 20 to 250 V Peak,
(other voltage ranges available)
Supply Current:
CR6610:.......................
CR6620:.......................
Torque Specs.:.............
Weight:.........................
Typical 30mA
Max 40mA
Typical 50mA
Max 95mA
3.0 inch lbs. (0.4Nm)
0.5 lbs.
Red LED
Indicator
Light
Top View
INPUT 1
[3.3]
.13
Optional
Mounting
1
2
3
4
Din Rail
Mounting
Clip
[73.1]
2.88
[83.3]
3.28
9
8
7
6
5
OUTPUT 1
SUPPLY
CR6610 0 - 5 VDC Output
CR6611 0 - 5 VDC Output
CR6612 0 - 5 VDC Output
[62.1]
2.45
[5.6]
.22
INPUT 1
[88.7]
3.49
1
2
3
4
9
8
7
6
5
OUTPUT
[30.4]
1.2
SUPPLY
CR6610 CR6611 CR6612 CR6620 CR6621 CR6622
[32.4]
1.3
CR6620 4 - 20 mADC Output
CR6621 4 - 20 mADC Output
CR6622 4 - 20 mADC Output
[28.3]
1.12
[36.6]
1.44
End View
OUTLINE DRAWING
CONNECTION DIAGRAM
NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker
shall be marked as the disconnecting device for the equipment.
The Professional
Energy Monitoring
Company
M N TI
58
很抱歉,暂时无法提供与“CR6612-5000”相匹配的价格&库存,您可以联系我们找货
