CR6620-5000
CR6620-5000
    CR
    TRANSDCR FREQ AC 4-20MA OUT
CR6620-5000 数据手册
Frequency Transducer DIN RAIL / PANEL MOUNT The CR6600 Series, Frequency Transducers and Transmitters are designed to give a DC output that is proportional to an input frequency value. These devices are especially suited to variable frequency systems. Applications CR6610 CR6611 CR6612 Outputs isolated from inputs Ranges available for any application Sine, square and zero crossover waveforms 35 DIN rail or panel mount Connection diagram printed on case CR6620 CR6621 CR6622 Features 40 - 5000 Hz Input Range Regulatory Agencies Constructed to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 E199795 Custom calibrations of unique full scale and zero scale values including parametric measurements are available. Contact factory for details. Add suffix for input range PART NUMBERS CR6610 CR6611 CR6612 CR6620 CR6621 CR6622 - Sine wave sensing with 0 - 5 VDC Output Square wave sensing with 0 - 5 VDC Output 100 500 5000 - 0-100 Hz 0-500 Hz 0-5000 Hz other ranges available Zero crossover sensing with 0 - 5 VDC Output Sine wave sensing with 4 - 20 mADC Output Square wave sensing with 4 - 20 mADC Output Zero crossover sensing with 4 - 20 mADC Output The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 57 E-mail: sales@crmagnetics.com C Transducers 35mm DIN Rail or Panel Mount Available with 0 - 5 VDC, 0 - 10, or 4 - 20 mADC output 24 VDC powered Red LED Active Indication Highest precision available Connection diagram printed on case Frequency Transducer DIN RAIL / PANEL MOUNT SPECIFICATIONS Transducers C Basic Accuracy:......................... 0.5% Linearity:.................................... 10% to 100% FS Thermal Drift:............................ 500 PPM/°C Operating Temperature:............ 0°C to +60°C Installation Category:................. CAT II Vibration Tested To:................... IEC 60068-2-6,1995 Pollution Degree:........................2 Response Time: ....................... 250 ms max. 0-90% FS Supply Voltage:......................... 24 VDC MTBF:.......................................Greater than 100 K hours Frequency Range:....................0 Hz - 2kHz, sine wave Insulation Voltage:.................... 2500 VDC Altitude:................................... 2000 meter max. Output Load:................ 4-20 mADC -0 to 300 Ω 0-5 VDC - 2K Ω or Greater Cleaning:.................... Water-dampened cloth Relative Humidity:......... 5% to 95%, Non-Condensing Input Voltage:................ 20 to 250 V Peak, (other voltage ranges available) Supply Current: CR6610:....................... CR6620:....................... Torque Specs.:............. Weight:......................... Typical 30mA Max 40mA Typical 50mA Max 95mA 3.0 inch lbs. (0.4Nm) 0.5 lbs. Red LED Indicator Light Top View INPUT 1 [3.3] .13 Optional Mounting 1 2 3 4 Din Rail Mounting Clip [73.1] 2.88 [83.3] 3.28 9 8 7 6 5 OUTPUT 1 + SUPPLY CR6610 0 - 5 VDC Output CR6611 0 - 5 VDC Output CR6612 0 - 5 VDC Output [62.1] 2.45 [5.6] .22 INPUT 1 [88.7] 3.49 1 2 3 4 - + 9 8 7 6 5 OUTPUT + [30.4] 1.2 - SUPPLY CR6610 CR6611 CR6612 CR6620 CR6621 CR6622 [32.4] 1.3 - CR6620 4 - 20 mADC Output CR6621 4 - 20 mADC Output CR6622 4 - 20 mADC Output [28.3] 1.12 [36.6] 1.44 End View OUTLINE DRAWING CONNECTION DIAGRAM NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 58 E-mail: sales@crmagnetics.com
CR6620-5000 价格&库存
很抱歉,暂时无法提供与“CR6620-5000”相匹配的价格&库存,您可以联系我们找货
