Wind Speed Transmitter
Model SLT
DESCRIPTION & FEATURES
The SLT converts the frequency of an anemometer signal
to a 4-20 mA signal. The SLT anemometer is UV stabilized
black polycarbonate. The 4-20 mA transmitter board is track
mounted and powered by the milliamp loop. The wind speed
range is 0-100 MPH over the 4-20 mA output.
Track Mounted Transmitter
ORDERING INFO
PART NUMBER
SLT.............................. Wind Speed Anemometer with 60’ 2 conductor cable,
10-11” long 1/2” conduit post, and 4-20 mA transmitter
ACCESSORIES
SDUM..............................................................................U-Mount Assembly
SA2P...........................................Pole mount 2 wire Surge/Lightning Arrestor
SA2W..........................................Wall mount 2 wire Surge/Lightning Arrestor
SA4P...........................................Pole mount 4 wire Surge/Lightning Arrestor
SA4W..........................................Wall mount 4 wire Surge/Lightning Arrestor
DK191..............................................................Loop Powered Display Series
DK190F...................................................................... Loop Powered Display
DK807/907.......................................................Loop Powered Display Series
Three Cup Anemometer
PW1.0.....................................................................................Power Supply
PW1.5.....................................................................................Power Supply
SPECIFICATIONS
PW2-24...................................................................................Power Supply
Range:
0-100 MPH = 4-20 mA output
Accuracy:
2-10 MPH +/- 1 MPH,
10-100 MPH +/- 5% of reading
Transmitter Dimensions: Track Mount 3”W x 5.25”L x 1.5”H
Anemometer Dimensions: 3.25”H x 7.5”W
Anemometer Cup Diameter: 2”
Shipping Weight:
2 lbs.
Operating Temperature: Anemometer -40 to 60° C
Transmitter 0 to 60° C
Transmitter Connections: Screw terminals for 12AWG or smaller
Transmitter Power:
Powered by the 4-20 mA loop current
Anemometer Mounting: Vertical on a 1/2” conduit or post
Accessories:
Surge/Lightning Arrestors
U-Mount Assembly
C-TON Industries
BDR-924/999............................................4-20 mA Controlled Display Series
CVC................................................................................ 4-20 mA Calibrator
• PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
很抱歉,暂时无法提供与“SLT”相匹配的价格&库存,您可以联系我们找货
