DLT
DLT
    C-TON
    WIND DIRECTION TRANSMITTER
DLT 数据手册
Wind Direction Transmitter Model DLT DESCRIPTION & FEATURES The DLT converts the output of a precision potentiometric wind vane to a 4-20 mA signal. The DLT wind vane is molded from UV stabilized black Lexan. The 4-20 mA transmitter board is track mounted and powered by the milliamp loop. The wind direction range is 0-360 degrees over the 4-20 mA output with an 5 degree dead band centered on North. Track Mounted Transmitter ORDERING INFO PART NUMBER DLT..................................... Wind Direction Vane with 60’, 3 conductor cable, 4-20 mA Transmitter, and 1/2” Conduit S Mast ACCESSORIES Wind Vane SDUM..............................................................................U-Mount Assembly SA4P...........................................Pole mount 4 wire Surge/Lightning Arrestor SA4W..........................................Wall mount 4 wire Surge/Lightning Arrestor SPECIFICATIONS DK191..............................................................Loop Powered Display Series DK190F...................................................................... Loop Powered Display Range: 0-360 degrees = 4-20 mA output Accuracy: +/-4 degrees Transmitter Dimensions: Track Mount 2.5”W x 5.25”L x 1.5”H Wind Vane Dimensions: 4.5”H x 8”L Wind Vane Sweep Diameter: 10.25” Shipping Weight: 3 lbs. Operating Temperature: Electronics 0 to 60° C Sensor -55 to 60° C Transmitter Connections: Screw terminals for 12AWG or smaller Transmitter Power: Powered by the 4-20 mA loop current Wind Vane Mounting: Vertical on a 1/2” conduit S mast (included) Accessories: Surge/Lightning Arrestors U-Mount Assembly C-TON Industries DK807/907.......................................................Loop Powered Display Series BDR-924/999............................................4-20 mA Controlled Display Series PW1.0.....................................................................................Power Supply PW1.5 ....................................................................................Power Supply PW2-24...................................................................................Power Supply CVC................................................................................ 4-20 mA Calibrator • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
很抱歉,暂时无法提供与“DLT”相匹配的价格&库存,您可以联系我们找货
